859-354
859-354
    WAGO(万可电子)
859-354 数据手册
Rail-Mounted Terminal Blocks with Miniature Switching Relay Relay with 1 changeover contact (1u) for normal switching power Nominal input voltage VN 12 V, 24 V, 48 V, 115 V, 230 V AC/DC Relay with 1 changeover contact (1u) for normal switching power Nominal input voltage VN 5 V … 220 V DC DC load limit curve 14 A2 11 Note: Inductive loads have to be attenuated by an appropriate protective circuit in order to protect relay coils and contacts. A1 12 Description VN IN Item No. Pack. Unit Rail-mounted terminal block with miniature switching relay, for DIN 35 rail 5 V DC 12 V DC 24 V DC 48 V DC 60 V DC 120 V DC 220 V DC 31 mA 17 mA 10 mA 6.5 mA 5.2 mA 3.5 mA 3.2 mA 859-302 859-303 859-304 859-305 859-306 859-307 859-308 1 1 1 1 1 1 1 Technical Data Coil: Input voltage range Contacts: Contact material Max. continuous current Max. make current Max. switching voltage Max. switching power (resistive) Recommended minimum load Pull-in/drop-out/bounce time typ. Mechanical life General specifications: Nominal voltage to EN 60664-1 Dielectric strength, contact-coil (AC, 1 min) Dielectric strength open contact (AC, 1 min) Dielectric strength contact-contact (AC, 1 min) Ambient operating temperature at VN Storage temperature Dimensions (mm) W x H x L Wire connection Cross sections Strip length Standards/specifications WAGO Kontakttechnik GmbH & Co. KG Subject to design changes 14.01.2015 VN IN Item No. Pack. Unit 12 V AC/DC 24 V AC/DC 48 V AC/DC 60 VAC/DC 115 V AC/DC 230 V AC/DC 15 mA 8 mA 5.3 mA 4.1 mA 3.5 mA 3.5 mA 859-353 859-354 859-355 859-356 859-357 859-358 1 1 1 1 1 1 Accessories see page 72 Accessories see page 72 VN -15 % ... +20 % VN -15 % ... +20 % AgNi 5A 4s (AC), 10A 250 V AC 1250 VA AC ; DC see load limit curve 10 VDC / 10 mA, 24 VDC / 1 mA 5ms / 6ms / 5 ms 5 x 106 switching operations AgNi 5A 4s (AC) 10A 250 V AC 1250 VA AC ; DC see load limit curve 10 VDC / 10 mA, 24 VDC / 1 mA 5ms / 6ms / 5 ms 5 x 106 switching operations 250 V / 4 kV / 2 4 kVrms 1 kVrms -25 °C ... +50 °C -40 °C ... +70 °C 6 x 56 x 91 Height from upper-edge of DIN 35 rail CAGE CLAMP® 0.08 mm² … 2.5 mm² / AWG 28 … 14 5 … 6 mm / 0.2 … 0.24 in EN 60664-1; EN 61810-5; UL 508; EEx nC II T4; g 250 V / 4 kV / 2 4 kVrms 1 kVrms -25 °C ... +50 °C -40 °C ... +70 °C 6 x 56 x 91 Height from upper-edge of DIN 35 rail CAGE CLAMP® 0.08 mm² … 2.5 mm² / AWG 28 … 14 5 … 6 mm / 0.2 … 0.24 in EN 60664-1; EN 61810-5; UL 508; EEx nC II T4; g – – Postfach 2880 - D-32385 Minden Hansastr. 27 - D-32423 Minden Tel.: +49(0)571/887-0 E-Mail: info@wago.com Fax: +49(0)571/887-169 www.wago.com
859-354 价格&库存
很抱歉,暂时无法提供与“859-354”相匹配的价格&库存,您可以联系我们找货
  • 1+149.846191+19.44730
  • 10+144.0125510+18.69020
      • 1+369.10804
      库存:52
      859-354
      • 1+448.964701+58.26743
      • 10+399.8182010+51.88911
      • 25+381.7735225+49.54724
      • 50+368.6524550+47.84436
      • 100+355.97577100+46.19916
      • 250+339.87281250+44.10929
