MW-17-03-L-D-160-065
    SAMTEC(申泰)
    CONN HDR 34POS 0.039 STACK SMD
MW-17-03-L-D-160-065 数据手册
SMT MICRO BOARD HEADER (1.00 mm) .0394" PITCH • MW SERIES MW Mates: CLM, MLE MW - - 03 - NO. PINS PER ROW 02 thru 50 SPECIFICATIONS Insulator Material: Top: Black LCP Bottom: Natural LCP Terminal Material: Phosphor Bronze Plating: Au over 50 µ" (1.27 µm) Ni Operating Temp Range: -55 °C to +125 °C PLATING OPTION -D- STACKER HEIGHT –G = 10 µ" (0.25 µm) Gold - –“XXX” –“XXX” (2.41 mm) .095" to (6.22 mm) .245" (1.65 mm) .065" minimum = Stacker Height (in inches) Example: –245 = (6.22 mm) .245" PROCESSING Lead-Free Solderable: Yes SMT Lead Coplanarity: (0.10 mm) .004" max (02-30) (0.15 mm) .006" max (31-50)* *(.004" stencil solution may be available; contact ipg@samtec.com) POST HEIGHT = Post Height (in inches) Example: –065 = (1.65 mm) .065" - OPTION –A = Alignment Pin (5 positions minimum) Metal or plastic at Samtec’s discretion –P = Pick & Place Pad (7 positions minimum) –TR = Tape & Reel –FR = Full Reel Tape & Reel (must order maximum quantity per reel; contact Samtec for quantity breaks) 1RRISRVLWLRQV[       3267 +(,*+7   0,1 ALSO AVAILABLE   0$; 29(5$// /(1*7+ MOQ Required End shrouds End shrouds with guide posts     67$&.(5 +(,*+7    WR    APPLICATION –P OPTION EXAMPLES Notes: For added mechanical stability, Samtec recommends mechanical board spacers be used in applications with gold or selective gold plated connectors. Contact ipg@samtec.com for more information. This Series is non-standard, non-returnable. LEAD STYLE MW –163-065 –233-065 CLM –02 MATED HEIGHT* (6.35 mm) .250" (8.13 mm) .320" *Processing conditions will affect mated height. MATED HEIGHT CLM MW (2.21) .087 samtec.com?MW Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-224
MW-17-03-L-D-160-065 价格&库存
很抱歉,暂时无法提供与“MW-17-03-L-D-160-065”相匹配的价格&库存,您可以联系我们找货
