PCIE-G5-01-01-F-DP-A-WT-TR 数据手册
PCI EXPRESS® EDGE CARD SOCKETS
(1.00 mm) .0394" PITCH
FEATURES & BENEFITS
• 1.00 mm pitch
• Supports 1, 4, 8 and 16 PCI Express® links
• PCIE® 3.0 Solution (PCIE)
11 mm
8 mm
• PCIE® 4.0 Solution with low-profile design for space savings (PCIE-LP)
• PCIE® 4.0 with slim body design (PCIE-G4)
• PCIE® 5.0 Solution with differential pair signaling (PCIE-G5)
• Vertical, right-angle and edge mount
PCIE
• Mates with .062" (1.60 mm) thick cards
PCIE -LP
PCIE® 3.0 & 4.0
Edge Card
connectors
• Alignment pin and weld tab options
PCIE® 4.0 slim body
socket with Edge Rate®
contacts (PCIE-G4)
KEY SPECIFICATIONS
SERIES
TOTAL PINS
(LANES)
INSULATOR
MATERIAL
CONTACT
MATERIAL
OPERATING
TEMP RANGE
CURRENT
RATING
VOLTAGE
RATING
PCIE®
COMPATIBILITY
PCIE
36 (x1), 64 (x4),
98 (x8), 164 (x16)
-TH = Black Nylon
-EMS2 & -TH = LCP
Phosphor Bronze
-55 °C to +125 °C
2.4 A (2 pins)
215 VAC
3.0
PCIE-LP
36 (x1), 64 (x4),
98 (x8), 164 (x16)
LCP
Phosphor Bronze
-55 °C to +125 °C
2.1 A (2 pins)
215 VAC
4.0
PCIE-G4
36 (x1), 64 (x4),
98 (x8), 164 (x16)
LCP
Copper Alloy
-55 °C to +125 °C
2.2 A (2 pins)
300 VAC
4.0
PCIE-G5
36 (x1), 64 (x4),
98 (x8), 164 (x16)
LCP
Copper Alloy
-55 °C to +125 °C
3.2 A (2 pins)
235 VAC
5.0
F-221 (Rev 30MAR22)
samtec.com/EdgeCard
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
4.0 & 5.0 SOLUTIONS
(1.00 mm) .0394" PITCH • PCI EXPRESS ® 4.0 SOCKET
PCIE
G4
NUMBER OF
LANES
01
–01, –04,
–08, –16
PLATING
OPTION
DV
–F
OPTION
1
OPTION
2
–A
= Gold flash
on contact,
Matte Tin
on tail
–K
= Alignment Pin
(Not available
with -WT)
–S
= Weld Tab
(Not available
with -A)
–TR
= Tape & Reel
(“X”R required
with –01, –04,
–08 lanes)
–FR
= Full Reel
Tape & Reel
(must order max.
quantity per reel;
contact Samtec for
quantity breaks)
(“X”R required
with –01, –04,
–08 lanes)
(5.60)
.220
PCIE-G4
Card Mates:
(1.60 mm)
.062" card
PACKAGING
(For -16 lanes
only leave blank for
Tray Packaging)
= (7.00 mm)
.275" DIA
Polyimide
Pick & Place
Pad
–WT
= 30 µ"
(0.76 µm) Gold
on contact,
Matte Tin
on tail
A
(7.98)
.314
NUMBER OF
LANES
A
–01
(24.80) .976
–04
(38.80) 1.528
–08
(55.80) 2.197
–16
(88.80) 3.496
View complete specifications at: samtec.com?PCIE-G4
(1.00 mm) .0394" PITCH • PCI EXPRESS ® 5.0 SOCKET
PCIE
G5
NUMBER OF
LANES
01
–01, –04,
–08, –16
PLATING OPTION
DP
A
–F
OPTION
–WT
= Gold flash on contact,
Matte Tin on tail
= Weld Tab
(For -16 lanes
only leave blank
for Tray Packaging)
= Tape & Reel
(“X”R required
with –01, –04,
–08 lanes)
–FR
(5.60)
.220
Card Mates:
(1.60 mm)
.062" card
PACKAGING
–TR
–S
= 30 µ” (0.76 µm)
Gold on contact,
Matte Tin on tail
PCIE-G5
A
(10.00)
.394
(10.20)
.402
= Full Reel
Tape & Reel
(must order max.
quantity per reel;
contact Samtec for
quantity breaks)
(“X”R required
with –01, –04,
–08 lanes)
PCIE-G5-04-01-X-DP-A SHOWN
NUMBER OF
LANES
PCI-SIG®, PCI Express® and
the PCIe® design marks are
registered trademarks and/or
service marks of PCI-SIG.
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
A
B
(with –WT)
–01
(24.40) .961 (26.70) 1.051
–04
(38.40) 1.512 (40.70) 1.602
–08
(55.40) 2.181 (57.70) 2.272
–16
(88.40) 3.480 (90.70) 3.571
View complete specifications at: samtec.com?PCIE-G5
samtec.com/EdgeCard
B
PCIE-G5-04-01-X-DP-A-WT SHOWN
F-221 (Rev 30MAR22)
PCIE-G5-01-01-F-DP-A-WT-TR 价格&库存
很抱歉,暂时无法提供与“PCIE-G5-01-01-F-DP-A-WT-TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+43.093011+5.57794
