High Power/Signal Connectors for Industrial Machinery
PQ Series
Variations
Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
PQ50W
Non water-resistant 20 position type
Non water-resistant 48 position type
Water-resistant 50 pos. type
Contact (19A/pin) type
Contact (12.5A/pin) type
PQ50S
■General
PQ50
The PQ series is an interface connector designed to
handle high power/signal connections in industrial
machinery. Available in a water-resistant or non-waterresistant type, they are capable of handling up to 12.5A/
pin (PQ50S and PQ50W) or 19A/pin (PQ50).
■Features
Side locking structure emits a tactile click and produces a secure lock
PQ50 and PQ50S Series [ Non water-resistant type ]
Clear tactile
click!
1. Side locking spring structure delivers a clear tactile
click.
The left and right buttons disengage the mated lock.
(Side locking system). The easy mating operation delivers a clear
tactile click. (Fig.1)
2. Strengthened cable clamps
Cable clamp strength is 98N or more. (* Actual is 400N or more.)
The structure will prevent the mated connecter and clamp from
detaching against excessive forces.
Easy extraction
Fig.1
3. Different cover options
A robust, enhanced, shielded die-cast shell is available on the PQ50
series or a engineered, light weight plated plastic resin shell for the
PQ50S series.
The die cast shell delivers an enhanced EMI shield on the PQ50
series and the plated plastic resin of the PQ50S series’ cover case
and panel shell ensure ESD and EMI performance.
It is possible to insert the terminated housing from the rear
Panel Shell
M3 Screw
Housing
4. Coding key system provides flexibility with multiple options
The coding key system prevents incorrect mating and has multiple
variations available.
Chassis Panel
Female Contact
5. Rear mounted panel shell is available.
After attaching the panel shell to the chassis, it is possible to install
or remove the crimp housing. (Fig.2)
6. Reliable ground connection structure.
Fig.2
Easy and reliable ground connection
The crimp contacts can be mounted directly onto the panel shell
with screws which enhances the grounding connections. (Fig.3)
7. Supports NFPA79 compliant cables (with 600V capability).
(PQ50 Series)
Due to restrictions on the AWM cables by NFPA79 revision, the
requirements of listed cables has increased for wires used in
industrial machines in the U.S.A. This product complies with the
restrictions and requirements of NFPA79.
JIS C2805
(R type, N type)
or equivalent
Fig.3
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
2017.3③
1
PQ Series●High Power/Signal Connectors for Industrial Machinery
[Water-resistant type] PQ50W Series
Special locking structure with lever
1. Water resistant (IP65)
Rated at IP65 when in the mated condition.
2. Special locking structure.
Special lever and cam structure delivers easier operation and assists
with the insertion and extraction of this connector. (Fig.1)
3. Rear mounted unit offers easy operations.
Male and Female plastic crimp case can be installed not only for
panel side metal shell but also plug side one. (Fig.2)
4. Metal plated cover of engineering plastic resin adds
strength and EMI protection.
This robust connector uses a metal plated material of special
engineering plastic for the cover and panel shell to ensure high ESD
Fig.1
Supports mounting from the backside of the panel
5. Independent ground contact structure.
Secure grounding is accomplished by use of the plated plastic cover
and the independent ground contacts. (Fig.3)
Panel Side
Plug Side
6. Coding key system provides flexibility with multiple options
multiple variations available.
Panel Side:Female Cont. Panel Side:Male Cont.
Plug Side: Male Cont.
Plug Side: Female Cont.
[Contact variations]
Fig.2
1. Available contact options
Two styles are available; one with 19A/pin contacts or one with
12.5A/pin contacts.
Independent Ground Contacts
2. Lance protection structure
The side wall of the contact prevents lance deformation and helps to
prevent tangled wires. (Fig.4)
3. Sequential contacts of different length are available
Two types of different contact length are available for the male
contact. (Fig.5)
4. Highly reliable contact structure
The female contact assures a reliable connection by using multiple
contact points and a unique spring structure. (Fig.6)
Lance Protection Structure
[ 19A/pin type ]
Male contact
Different length sequential contacts
[ 19A/pin type ]
Lance
Sequence Contact
(Long)
Female contact
Fig.3
Highly Reliable Contact Structure
[ 19A/pin type ]
3 Point Contact
[ 12.5A/pin type ]
2 Point Contact
Spring Deflection
Spring Deflection
Standard Contact
[ 12.5A/pin type ]
Male contact
Lance protection guard
Lance
Female contact
1.2mm
[ 12.5A/pin type ]
Two types of contacts can be
used depending on application
Sequence Contact
(Long)
Fig.4
2
1.2mm
Multiple contact points and very flexible spring
design.
Standard Contact
Fig.5
Fig.6
■Product Specifications
[Non water-resistant type] PQ50 Series
Voltage
Ratings
Current
AC/DC 600V
With UL1015 16 AWG
19A/pin
Items
1. Contact resistance
2. Insulation
resistance
3. Withstand voltage
4. Durability
5. Vibration
resistance
6. Shock resistance
7. Temperature
cycles
8. Moisture resistance
in steady state
9. Salt water spray
* Depending on current capacity
of the cable used.
Specifications
1
10mø max
Operating Temp. Range
−40ç to +105ç
Storage Temp.
Range
−55ç to +85ç
Conditions
Measured at 100mA
Minimum of 5,000Mø
Measured at DC 500V
No flashover or breakdown.
Contact resistance: Increase by 10mø or less
from the initial value.
Apply AC 2,200V for one minute.
qNo electrical discontinuity of 10µs or more.
wNo broken, cracked or loosened parts.
qChange of contact resistance: 20mø or less
wInsulation resistance: minimum of 1,000Mø
eNo broken, cracked or loosened parts.
qChange of contact resistance: 20mø max
(after drying).
eNo breakage, cracks or loosened parts.
No significant corrosion or damage that
impairs functioning.
Perform 500 mating cycles.
Frequency 10 to 55 Hz (5 min/cycle).
With half amplitude 0.75mm, 2 hours each for 3 directions.
Acceleration 490m/s2, duration 11ms, half-sine
wave, 3 times each for 6 axial directions.
Temperature: −55 ➝ +15 to 35 ➝ +105 ➝ +15
to +35ç
Time: 30 ➝ 2 to 3 ➝ 30 ➝ 2 to 3 min.
Subjected to 5 cycles of time and temp as noted.
Left in environment of 60ç ±2° and humidity of
90% to 95% for 96 hours.
5% concentration of salt water spray for 48 hours.
(in mated condition)
1
Excluding conductor resistance of the cable.
*For test methods not described here, JIS C 5402 is applied.
[ Non water-resistant type ] PQ50S Series
Voltage
Rating
Current
AC/DC 300V
12.5A/pin
Items
2. Insulation
resistance
4. Durability
5. Vibration
resistance
With UL1007 18 AWG
of the cable used.
Specifications
1
5mø max
in steady state
9. Salt water spray
−40ç to +105ç
Storage Temp.
Range
−55ç to +85ç
Conditions
Measured at 100mA
Minimum of 5,000Mø
Measured at DC 500V
6. Shock resistance
7. Temperature
cycles
qChange of contact resistance: 10mø or less
wInsulation resistance: Minimum of 1,000Mø
(after drying).
No significant corrosion or damage that impairs
functioning.
directions.
to +35ç
Subjected to 5 cycles of time and temp. as noted.
1
3
[ Water-resistant type ] PQ50W Series
With 12.5A/pin type contacts
Ratings
Voltage
Current
Items
2. Insulation
resistance
4. Durability
5. Vibration
resistance
12.5A/pin
AC/DC 300V
With UL1007 18 AWG
of the cable used.
in steady state
9. Salt water spray
10. Water resistance
−40ç to +105ç
Storage Temp.
Range
−55ç to +85ç
Specifications
Conditions
5mø max
1
Measured at 100mA
Minimum of 5,000Mø
Measured at DC 500V
Contact resistance : Increase by 10mø or less
6. Shock resistance
7. Temperature
cycles
wInsulation resistance : 1,000Mø or more
qChange of contact resistance : 10mø or less
(after drying)
functioning.
IP65
directions.
Temperature : −55 ➝ +15 to 35 ➝ +105 ➝ +15
to +35ç
Time : 30 ➝ 2 to 3 ➝ 30 ➝ 2 to 3 min.
1
■Materials / Finish
PQ50 Series
Item
Parts
Crimp case
Panel Shell
Crimp case
Crimp case Shell
Cover case
M4 pan head machine
screw
Clamp metal
Crimp case
In-line plug shell
In-line cover case
M4 pan head machine
screw
Clamp metal
Materials
PBT resin
Zinc die cast
PBT resin
Stainless steel
Zinc die cast
Item
Parts
Crimp case
Receptacle
Panel Shell
Materials
PBT resin
Heat-resistant
Brass
PBT resin
Stainless steel
Heat-resistant
Steel
Brass
Receptacle
Plug
In-line plug
Steel
Steel
PBT resin
Finish
Black
Nickel plating
Black
Remarks
UL94V-0
UL94V-0
Nickel plating
Black
UL94V-0
Nickel plating
Finish
Black
Remarks
UL94V-0
Nickel plating
Black
UL94V-0
Zinc die cast
Steel
Steel
PQ50S Series
M4 insert nut
Crimp case
Crimp case Shell
Plug
Cover case
Clamp metal
M4 insert nut
4
Nickel plating
UL94V-0
PQ50W Series
Item
Crimp case
Parts
Crimp case
Panel Shell
Ground contact
O-ring for mating
Lock lever
Rubber packing
Receptacle
Plug shell
Materials
PBT resin
Heat-resistant
Stainless steel
NBR
PA resin
NBR
Heat-resistant
Stainless steel
Ground contact
M2 tapping screw
Steel
Cover case
Gasket
NBR
Clamp metal (body)
Heat-resistant
Cable clamp
M3 insert nut
Brass
M3 pan head machine screw
Steel
Plug
Finish
Black
Nickel plating
Remarks
UL94V-0
UL94V-0
Black
UL94V-0
Black
UL94V-0
Nickel plating
Trivalent chromate
Nickel plating
Red
Black
UL94V-0
Nickel plating
Finish
Remarks
● Contacts (PQ50, PQ50S, PQ50W)
Part No.
PQ50 -15PCFA
PQ50A -15PCFA
PQ50 -15SCFA
PQ50 -1618PCFA
PQ50A -1618PCFA
PQ50 -1618SCFA
PQ50 -2022PCFA
PQ50A -2022PCFA
PQ50 -2022SCFA
PQ50S -1822PCFA
PQ50SA-1822PCFA
PQ50S -1822SCFA
PQ50S -2428PCFA
PQ50SA-2428PCFA
PQ50S -2428SCFA
Parts
Materials
Male contact
Female contact
Male contact
Female contact
Male contact
Copper alloy
Female contact
Gold plating (contact area)
Tin plating (barrel area)
Male contact
Female contact
Male contact
Female contact
■Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
●Crimp Housing
PQ 50 W S − 25 P − UNIT
❶
❷
❸
❹
❶ Series name
❷ Wiring style
❸ Connector specifications
❹ Contact size
❺ Shell size
❻ Contact type
❼ Shapes
❺
❻
❼
PQ
Crimping
W…Water-resistant type
None…Non water-resistant type
S…Small contact (12.5A/pin) type
None…Standard contact (19A/pin) type
25…25 pos. unit 20…20 pos. unit 48…48 pos. unit
P…Male contact
S…Female contact
UNIT Rear mount multiple unit (PQ50W)
None… (PQ50, PQ50S)
●Crimp contact
PQ 50 S A − 1822 PC F A
❶
❷
❸
❹
❶ Series name
❷ Wiring style
❸ Contact size
❹ Contact usage
❺ Applicable cable type
❻ Contact type
❼ Contact shapes
❽ Contact plating type
❺
❻
❼
❽
PQ
Crimping
A…Sequence contact (long contact)
15…… 14 to 15 AWG (UL1015)
1618…16 to 18 AWG (UL1007, UL1015)
1822…18 to 22 AWG (UL1007) 17 AWG
PC…Male contact
F…End-to-end contacts (on reel)
A…Gold plating (contact area)
2022…20 to 22 AWG (UL1007, UL1015)
2428…24 to 28 AWG (UL1007) 23 AWG
SC…Female contact
None…Discrete contacts
5
● Clamp metal
PQ W − CM (17.5)
❶
❷
❸
❶ Series name
❷ Connector specifications
❸ Clamp name
❹ Applicable cable diameter
❹
PQ
CM…Clamp metal
(15.0)…For applicable cable diameter Ø15.0
(17.5)…For applicable cable diameter Ø17.5
(22.0)…For applicable cable diameter Ø22.0
PQ50, PQ50S Series
PQ 50 S − 48 P − PC M
❶
❷
❸
❹
❶ Series name
❷ Wiring style
❸ Contact size
❹ Shell size
❺ Contact type
❺
❻
❼
PQ
Crimping
20…20 pos. shell type
P…Male contact
PC…Plug cover case
FL … Panel shell
M…Heat-resistant engineering plastic
resin
❻ Case type
❼ Case material
48…48 pos. shell type
S…Female contact
JC … In-line plug cover case
DS…In-line plug shell
None…Zinc die cast
PQ50W Series
PQ 50 W − 50 − PC
❶
❷
❸
❹
❶ Series name
❷ Wiring style
❹ Shell size
❺ Case type
❺
PQ
Crimping
50…50 pos. shell type
PC…Plug cover case
FL … Panel shell
■Functional Diagram
PQ50, PQ50S Series
qPanel mount receptacle
(Female contact)
wCable plug
eIn-line cable plug
(Male contact)
(Female contact)
PQ50W Series
6
wCable plug
■Panel mount receptacle PQ50 Series
■Crimp case (19A/pin, for female contact)
8.6
18.6
27
28.4
(P=4.6)
27.8
25.6
13
1.7
(P=6.2)
6.2
27.1
18.4
9.2
236-2014-2 00
50 pcs/box
PQ50-20S(01)
236-2014-2 01
1 pcs/box
R2MAX
(39.4)
X
MA
R2
38.6
19.4
31.2
27.2(intersection)
Part No.
HRS No.
Packaging
PQ50-20S-FL
236-2001-0 00
50 pcs/box
PQ50-20S-FL(01)
236-2001-0 01
1 pcs/box
38.4
48
Recommended panel dimensions for attaching
panel shell from panel’s front side.
21
31.2
10.7 3
43.2
13.2(intersection)
10.5
48.6±0.3
51.5±0.1
X
MA
21 (intersection)
■Panel Shell
63
51.5
48
38.6
40.6±0.3
2-M3×0.5
(through hole)
33.2±0.3
PQ50-20S
40.6±0.3
R2MAX
46.6
33.2±0.3
Packaging
16.6±0.1
22.1±0.3
HRS No.
R2
2-M4×0.7(through hole)
2-M3×0.5(through hole)
2-Ø4.3±0.2
R2
28.4±0.3
51.5±0.1
MA
X
AX
M
R2
panel shell from panel’s back side.
■Cable Plug
PQ50 Series
■Crimp case (19A/pin, for male contact)
(P=4.6)
E
D
C
(P=6.2)
6.2
27
18.4
9.2
B
33.3
A
A
12.8
8.8
3
18.6
28.6
2
B
C
D
E
1
1
2
3
4
4
PQ50-20P
(48.8)
Part No.
HRS No.
Packaging
PQ50-20P
236-2011-4 00
50 pcs/box
PQ50-20P(01)
236-2011-4 01
1 pcs/box
27
■Plug Cover case
2
34.2
42.8
(16)
JIS B 1188 M4×0.7×16
M4×0.7
M4×0.7×8.1
Ø4
56.5
64
3
M4×0.7×9
Part No.
HRS No.
Packaging
PQ50-20P-PC
236-2000-8 00
50 pcs/box
PQ50-20P-PC(01)
236-2000-8 01
1 pcs/box
48.8
33.2
28
17.6
11.5
12.5
15.1
Part No.
16.6±0.1
21±0.3
PQ50-20S
R1
2.5
7
■In-Line Cable Plug
PQ50 Series
2
■ In-line Plug Cover case
(16)
38.6
42.8
M4×0.7
M4×0.7×8.1
Ø4
56.5
64
3
M4×0.7×9
17.6
48.8
HRS No.
Packaging
PQ50-20S-JC
236-2002-3 00
50 pcs/box
PQ50-20S-JC(01)
236-2002-3 01
1 pcs/box
33.2
28
11.5
12.5
15.1
Part No.
R1
2.
5
■In-line Plug shell
40.5
38.6
10.2
31.2
33
33.1
27.2
Part No.
HRS No.
Packaging
PQ50-20S-DS
236-2015-5 00
50 pcs/box
PQ50-20S-DS(01)
236-2015-5 01
1 pcs/box
■ Cable Plug
PQ50S Series
■Crimp case (12.5A/pin, for male contact)
(P=3.85)
3.85
11.55
34
26.25
18.75
11.25
F
E
D
C
B
12.8
G
A
19.25
28.6
1
2
3
4
5
6
8.8
H
33.3
3.75
(P=3.75)
A
B
C
D
E
1
2
3
4
5
6
PQ50S-48P
(55.8)
Part No.
HRS No.
Packaging
PQ50S-48P
236-2023-3 00
60 pcs/box
PQ50S-48P(01)
236-2023-3 01
1 pcs/box
■Plug Cover case
(16)
50
M4×0.7×6.5
Ø4
64
79
3
M4×0.7×6.5
Packaging
PQ50S-48P-PCM
236-2003-6 00
60 pcs/box
PQ50S-48P-PCM(01)
236-2003-6 01
1 pcs/box
17.6
56
38.2
28
5
2.
R1
HRS No.
14
17.6
Part No.
8
M4×0.7
F
G
H
PQ50S Series
■Crimp cace (12.5A/pin, for female contact)
1.7
8.6
13.15
19.25
27
28.4
P=3.75
27.95
25.75
P=3.85
11.55
34.1
26.25
18.75
11.25
H
G
F
E
D
C
B
A
1
2
3
4
5
6
PQ50S-48S
236-2024-6 00
60 pcs/box
PQ50S-48S(01)
236-2024-6 01
1 pcs/box
58.5±0.1
47.6±0.3
(46.4)
2-M3×0.7 (through hole)
10.7 7.6 14.8
45.6
21.8
11.3
R2MAX
59.6±0.3
R2 MAX
58.5±0.1
47.6±0.3
Packaging
PQ50S-48S-FLM
236-2004-9 00
60 pcs/box
PQ50S-48S-FLM(01)
236-2004-9 01
1 pcs/box
49.4
35.1 (intersection)
57.6
56 (intersection)
■Clamp metal common for PQ50 and PQ50S Series
33.2±0.3
HRS No.
2-Ø4.3±0.2
Part No.
R2MAX
31.2
69.7
58.5
56
(intersection)
45.6
16.6±0.1
21.8±0.3
■Panel Shell
16.6±0.1
22.8±0.3
Packaging
33.2±0.3
HRS No.
M4×0.7×6.5
R2 MAX
R2 MAX
36.3±0.3
■Clamp metal for Ø15.0mm cable type
37.16
JIS B 1188 M4×0.7×12
M4×0.7
5.5
1.6
(12)
2-4.4
45.4
23.5
(intersection)
HRS No.
Packaging
PQ-CM(15.0)
236-2005-1 00
60 pcs/box
PQ-CM(15.0)(01)
236-2005-1 01
1 pcs/box
15
10
Part No.
■Clamp metal for Ø22.0mm cable type
37.16
(12)
2-4.4
HRS No.
Packaging
PQ-CM(22.0)
236-2013-0 00
50 pcs/box
PQ-CM(22.0)(01)
236-2013-0 01
1 pcs/box
11.9
Part No.
1.5
45.4
27
M4×0.7
22
10
Part No.
R2M
AX
PQ50S-48S
9
■Cable Plug
PQ50W Series
16.85 20.6
No.A1
No.A5
Part No.
HRS No.
Packaging
PQ50WS-25P-UNIT
236-2021-8 00
1 pcs/box
No.E1
23.9
14.8
24.9
7.4
19.5
15
7.5
No.E5
■Crimp case (12.5A/pin, for female contact)
19.5
15
7.5
Part No.
HRS No.
Packaging
PQ50WS-25S-UNIT
236-2022-0 00
1 pcs/box
No.E1
No.A1
No.E5
No.A5
23.9
14.8
24.9
7.4
16.85 20.6
■Panel mount receptacle PQ50W Series
34.9
35.8
■Panel Shell
(36.3)
(5)
(28)
(102)
PQ50W
Part No.
PQ50W-50-FL
HRS No.
Packaging
236-2020-5 00
1 pcs/box
B
44.3
65.8
B
58.8±0.1
50±0.1
23.4±0.1
27.4±0.1
R2.5MAX
4-M3 (through hole)
Panel dimensions for attaching panel
10
■Cable Plug PQ50W Series
■Cover Case
Part No.
HRS No.
Packaging
PQ50W-50-PC
236-2018-3 00
1 pcs/box
(2.45)
55.5
31
35.9
■Metal Cable Clamp for PQ50W Series
■Cable clamp for Ø17.5mm cable type
34
35.5
27
28
(3)
65.5
80.5
31.5
Part No.
HRS No.
Packaging
PQW-CM(17.5)
236-2019-6 00
1 pcs/box
11
Crimp Contacts
■Male contact (19A/pin type)
PQ50A-**PC*A
2.2
3
Part No.
24.35
23.15
PQ50-**PC*A
0.9
3.8
HRS No.
2.2
0.9
3
3.8
Packaging
Applicable Cables
PQ50 -15PCFA(Note) 236-2016-8 00 3,500 pcs/reel 14 to 15 AWG (UL1015) insulator outer diameter max. Ø3.3mm
PQ50A-15PCFA
236-2073-1 00 3,500 pcs/reel 14 to 15 AWG (UL1015) insulator outer diameter max. Ø3.3mm
PQ50 -1618PCFA
236-2006-4 00 3,500 pcs/reel 16 to 18 AWG (UL1007, UL1015), insulator outer diameter max. Ø3.3mm
PQ50A-1618PCFA
236-2007-7 00 3,500 pcs/reel 16 to 18 AWG (UL1007, UL1015), insulator outer diameter max. Ø3.3mm
PQ50 -2022PCFA
236-2031-1 00 3,500 pcs/reel 20 to 22 AWG (UL1007, UL1015), insulator outer diameter max. Ø2.7mm
PQ50A-2022PCFA
236-2032-4 00 3,500 pcs/reel 20 to 22 AWG (UL1007, UL1015), insulator outer diameter max. Ø2.7mm
PQ50 -15PCA
236-2037-8 00 100 pcs/pack 14 to 15 AWG insulator outer diameter max. Ø3.3mm
PQ50A-15PCA
236-2073-1 00 100 pcs/pack 14 to 15 AWG insulator outer diameter max. Ø3.3mm
PQ50 -1618PCA
236-2038-0 00 100 pcs/pack 16 to 18 AWG (UL1007, UL1015), insulator outer diameter max. Ø3.3mm
PQ50A-1618PCA
236-2040-2 00 100 pcs/pack 16 to 18 AWG (UL1007, UL1015), insulator outer diameter max. Ø3.3mm
PQ50 -2022PCA
236-2039-3 00 100 pcs/pack 20 to 22 AWG (UL1007, UL1015), insulator outer diameter max. Ø2.7mm
PQ50A-2022PCA
236-2041-5 00 100 pcs/pack 20 to 22 AWG (UL1007, UL1015), insulator outer diameter max. Ø2.7mm
Note : Please see ATAI-E2926 for the details of UL1015 14 AWG cable crimping.
18.9
■Female contact (19A/pin) type
2.9
3
Part No.
HRS No.
3.9
Packaging
Applicable Cables
PQ50-15SCFA(Note) 236-2017-0 00 3,500 pcs/reel 14 to 15 AWG (UL1015) insulator outer diameter max. Ø3.3mm
PQ50-1618SCFA
236-2008-0 00 3,500 pcs/reel 14 to 15 AWG (UL1007, UL1015), insulator outer diameter max. Ø3.3mm
PQ50-2022SCFA
236-2010-1 00 3,500 pcs/reel 20 to 22 AWG (UL1007, UL1015), insulator outer diameter max. Ø2.7mm
PQ50-15SCA
236-2043-0 00 100 pcs/pack 14 to 15 AWG (UL1007, UL1015), insulator outer diameter max. Ø3.3mm
PQ50-1618SCA
236-2044-3 00 100 pcs/pack 16 to 18 AWG (UL1007, UL1015), insulator outer diameter max. Ø3.3mm
PQ50-2022SCA
236-2045-6 00 100 pcs/pack 20 to 22 AWG (UL1007, UL1015), insulator outer diameter max. Ø2.7mm
Note : Please see ATAI-E3038 for the details of UL1015 14 AWG cable crimping.
12
Crimp Contacts
■Male contact (12.5A/pin type)
PQ50S-****PC*A
PQ50SA-****PC*A
Wire gauge
marking
23.2
0.7
2.15
2.25
Part No.
1.35
2.15
HRS No.
Packaging
0.7
2.25
Applicable Cables
PQ50S -1822PCFA
236-2025-9 00
6,000 pcs/reel 17 to 22 AWG (UL1007), insulator outer diameter max. Ø2.25mm
PQ50SA-1822PCFA
236-2029-0 00
PQ50S -2428PCFA
236-2027-4 00
6,000 pcs/reel 23 to 28 AWG (UL1007), insulator outer diameter max. Ø1.8mm
PQ50SA-2428PCFA
236-2030-9 00
PQ50S -1822PCA
236-2046-9 00
100 pcs/pack
PQ50SA-1822PCA
236-2048-4 00
100 pcs/pack
PQ50S -2428PCA
236-2047-1 00
100 pcs/pack
PQ50SA-2428PCA
236-2049-7 00
100 pcs/pack
■Female contact (12.5A/pin type)
2.15
1822S
Wire gauge
marking
17.8
1822P
1822P
1.35
24.4
Wire gauge
marking
2.15
2.25
Part No.
PQ50S-1822SCFA
HRS No.
Packaging
Applicable Cables
236-2026-1 00
PQ50S-2428SCFA
236-2028-7 00
PQ50S-1822SCA
236-2050-6 00
100 pcs/pack
PQ50S-2428SCA
236-2051-9 00
100 pcs/pack
13
Coding Key System
■For 19A/pin type crimp case
3
2.9
5.95
27.7
24.8
Part No.
PQ50-SC-KY
HRS No.
Packaging
236-2009-2 00
100 pcs/pack
■For 12.5A/pin type crimp case
27.8
3.05
1.8
2.23
23.7
Part No.
PQ50S-SC-KY
HRS No.
Packaging
236-2033-7 00
100 pcs/pack
Contact Extraction Tools
■For 19A/pin type crimp housing
Ø7
80
PQ50/RE-MD
Part No.
PQ50/RE-MD
HRS No.
Packaging
902-2201-0 00
1 pcs/box
■For 12.5A/pin type crimp housing
PQ 50 S/RE-MD
Part No.
PQ50S/RE-MD
14
Ø10
75
HRS No.
Packaging
902-2202-2 00
1 pcs/box
Hand Crimp Tool
The complete hand tool with crimper frame (1) is available for each terminal and wire gauge. Parts (2) to (8) can
be ordered to accommodate repairs and to be able to switch to other wire gauges without having to purchase
another complete tool.
①Crimper Frame
Part No.
HT702
qCrimper Frame
HRS No.
250-1001-1 00
* Unit Name
Upper row: Part No.
Lower row: HRS No.
PQ50-1618(1007)
【250-1002-4】
PQ50-1618(1015)
【250-1003-7】
PQ50A-1618(1007)
【250-1004-0】
PQ50A-1618(1015)
【250-1005-2】
PQ50-2022(1007)
【250-1006-5】
PQ50-2022(1015)
【250-1007-8】
HT702
【250-1001-1】
Switch wire crimper and insulation crimper die according to
the wire size being used.
PQ50A-2022(1007)
【250-1008-0】
PQ50A-2022(1015)
【250-1009-3】
Applicable Cables
Applicable Contacts
PQ50-1618PCA
PQ50-1618SCA
PQ50 -1618PCA
PQ50A-1618PCA
PQ50-2022PCA
PQ50-2022SCA
PQ50 -2022PCA
PQ50A-2022PCA
UL
UL1007
UL1015
UL1007
UL1015
UL1007
UL1015
UL1007
UL1015
AWG
16
18
16
18
16
18
16
18
wIC
(Insulation Crimper)
286191
【250-1002-4(61)】
285990
【250-1003-7(61)】
286191
【250-1004-0(61)】
285990
【250-1005-2(61)】
286197
【250-1006-5(61)】
286193
【250-1007-8(61)】
286197
【250-1008-0(61)】
286193
【250-1009-3(61)】
PQ50-14(1015)
【250-1019-7】
PQ50-15PCA
PQ50-15SCA
UL1015
14
286629
【250-1019-7(61)】
PQ50A-14(1015)
【250-1021-9】
PQ50 -15PCA
PQ50A-15PCA
UL1015
14
286629
【250-1021-9(61)】
PQ50S-1820(1007)
【250-1010-2】
PQ50S-2022(1007)
【250-1011-5】
PQ50SA-1820(1007)
【250-1012-8】
PQ50SA-2022(1007)
【250-1013-0】
18
PQ50S-1822PCA
PQ50S-1822SCA
UL1007
18
PQ50SA-1822PCA
UL1007
286219
【250-1010-2(61)】
286220
【250-1011-5(61)】
286219
【250-1012-8(61)】
286220
【250-1013-0(61)】
Ex.: When unit PQ50-1618 (1007) is purchased as a whole, all of parts (2) through (8) are included.
If the insulation crimper (IC) only is needed for PQ50-1618(1007), then 250-1002-4 61 should be ordered.
15
Powered by TCPDF (www.tcpdf.org)
Upper row: Part No. / Lower row: HRS No.
uContact Holder
eWC
rIA
tWA
iCrimper Spacer
yContact Holder A
B/C
(Wire Crimper)
(Insulation Anvil)
(Wire Anvil)
285991
285992
285993
285994
285995
285996
【250-1002-4(62)】 【250-1002-4(63)】 【250-1002-4(64)】 【250-1002-4(65)】 【250-1002-4(66)】 【250-1002-4(67)】
285991
285992
285993
285994
285995
285996
【250-1003-7(62)】 【250-1003-7(63)】 【250-1003-7(64)】 【250-1003-7(65)】 【250-1003-7(66)】 【250-1003-7(67)】
285991
285992
285993
285994
286192
285996
【250-1004-0(62)】 【250-1004-0(63)】 【250-1004-0(64)】 【250-1004-0(65)】 【250-1004-0(66)】 【250-1004-0(67)】
285991
285992
285993
285994
286192
285996
【250-1005-2(62)】 【250-1005-2(63)】 【250-1005-2(64)】 【250-1005-2(65)】 【250-1005-2(66)】 【250-1005-2(67)】
286194
285992
286196
285994
285995
285996
【250-1006-5(62)】 【250-1006-5(63)】 【250-1006-5(64)】 【250-1006-5(65)】 【250-1006-5(66)】 【250-1006-5(67)】
286194
285992
286196
285994
285995
285996
【250-1007-8(62)】 【250-1007-8(63)】 【250-1007-8(64)】 【250-1007-8(65)】 【250-1007-8(66)】 【250-1007-8(67)】
286194
285992
286196
285994
286192
285996
【250-1008-0(62)】 【250-1008-0(63)】 【250-1008-0(64)】 【250-1008-0(65)】 【250-1008-0(66)】 【250-1008-0(67)】
286194
285992
286196
285994
286192
285996
【250-1009-3(62)】 【250-1009-3(63)】 【250-1009-3(64)】 【250-1009-3(65)】 【250-1009-3(66)】 【250-1009-3(67)】
286630
286631
286632
285994
285995
285996
【250-1019-7(62)】 【250-1019-7(63)】 【250-1019-7(64)】 【250-1019-7(65)】 【250-1019-7(66)】 【250-1019-7(67)】
286630
286631
286632
285994
286192
285996
【250-1021-9(62)】 【250-1021-9(63)】 【250-1021-9(64)】 【250-1021-9(65)】 【250-1021-9(66)】 【250-1021-9(67)】
286223
286225
286226
286233
286234
285996
【250-1010-2(62)】 【250-1010-2(63)】 【250-1010-2(64)】 【250-1010-2(65)】 【250-1010-2(66)】 【250-1010-2(67)】
286224
286225
286226
286233
286234
285996
【250-1011-5(62)】 【250-1011-5(63)】 【250-1011-5(64)】 【250-1011-5(65)】 【250-1011-5(66)】 【250-1011-5(67)】
286223
286225
286226
286233
286235
285996
【250-1012-8(62)】 【250-1012-8(63)】 【250-1012-8(64)】 【250-1012-8(65)】 【250-1012-8(66)】 【250-1012-8(67)】
286224
286225
286226
286233
286235
285996
【250-1013-0(62)】 【250-1013-0(63)】 【250-1013-0(64)】 【250-1013-0(65)】 【250-1013-0(66)】 【250-1013-0(67)】
16
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
TEL: +81-45-620-3526 Fax: +81-45-591-3726
http://www.hirose.com
http://www.hirose-connectors.com
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 03/2017. Contents are subject to change without notice for the purpose of improvements.
