50 Ω SMA TO 6 GHz
SMA
Cable Assemblies
SERIES
RF174, RF178, RF316,
RS316, RF058
END 1
CONNECTOR
RF174
END 2
CONNECTOR
–01SP1
= RG 174 Cable
–“XXXX”
= SMA Straight Plug
RF178
OVERALL
LENGTH
= Overall Length in
millimeters
–01RP1
–0100 (100 mm)
3.94" minimum
= RG 178 Cable
(–01BJ1 & –01BR1 only)
= SMA Right-angle Plug
RF316
= SMA Straight Bulkhead Jack
RS316
= Straight Bulkhead Jack, Sealed
–01BJ1
= RG 316 Cable, Single Braid Shield
–01SB1
= RG 316 Cable, Double Shield
(–01SP1 & –01BJ1 only)
–01SR1
= Straight Bulkhead Jack, Sealed, Reversed Polarity
RF058
–01BR1
= RG 58 Cable
(–01SP1, –01BJ1 & –01SB1 only)
= Straight Bulkhead Jack, Reversed Polarity
–01PN1
= 4-Hole Panel Mount Jack
ALSO AVAILABLE
50 Ω: MCX, MMCX, SMB, BNC, TNC,
N Type = RF174, RF178, RF316
50 Ω: MCX, MMCX, BNC, TNC = RS316
50 Ω: TNC = RF058
SMA
Cable Connectors
SMA-CA
SMA
GENDER
TYPE
–J
PLATING
–C
= Jack
+H[
ORIENTATION
–H
= Cable
–C4
Supplied with pins, washers,
nuts and ferrules. See website
for dimensions.
+H[
–S10, –B10
SMA
GENDER
–P
= Plug
(8.40)
.331
(16.00) .630
See page 154 for
Board Connectors
F-224
(8.00) .315 Hex.
–ST–C10
Leave blank for
individually
bagged.
–BH2
–B10
= Bulk
packaged
(–BH1 only)
= Bulkhead
RG 178 Cable
–BR1
–BR2
TYPE
–C
= Cable
PLATING
= Bulkhead
RG 178 Cable,
Reversed Polarity
–H
= 30 µ" (0.76 µm)
Gold center contact,
3 µ" (0.08 µm)
Gold outer contact
(–CA1, –C10 only)
= 30 µ" (0.76 µm)
3 µ" (0.08 µm)
Gold outer contact
(–CA1S only)
ORIENTATION
–ST
= Straight
–RA
= Right-angle
–B
= Bulkhead
RG 58 Cable
= Bulkhead
–HF
SMA
Board Connectors
–BH1S
PACKAGING
= Bulkhead
RG 316 Cable,
Double Shield
RG 174 / 316,
Reversed Polarity
+H[
= Bulkhead
RG
174 / 316
Cable
–HF
= 30 µ"
(0.76 µm)
Gold center
contact,
3 µ" (0.08 µm)
Gold outer
contact
(–BH1S only)
–BH1
= Straight
Gold center
contact,
3 µ" (0.08 µm)
Gold outer
contact (N/A
with –BH1S)
TERMINATION
–ST
= 30 µ"
(0.76 µm)
+H[
= Cable
4-Mounting
Screws
(–PN1 only)
–PN1
= 4-Hole
Panel Mount
RG 174 /
316 Cable
–S10
= Sealed
Bulkhead
RG 58 Cable
TERMINATION
–CA1
= RG 174 / 316 Cable
–C10
= RG 58 Cable
(–ST only)
–CA1S
PACKAGING
Leave blank for
individually
bagged.
–B
= Bulk
packaged
(–CA1 only)
= RG 316 Double
Shielded Cable
(–ST only)
Supplied with pins, washers, nuts and ferrules.
See website for dimensions.
samtec.com/SMA
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
很抱歉,暂时无法提供与“SMA-J-C-H-ST-BH4”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+60.585711+7.84115
- 国内价格
- 1+119.19960
- 200+47.56320
- 500+45.97560
- 1000+45.18720
