F-218 (Rev 10OCT17)
SSM–120–S–DV
10 YEAR MFG
WITH 30 µ" GOLD
SSM–116–S–SV
EXTENDED LIFE
PRODUCT
HIGH MATING
CYCLES
SSM–115–L–SH
(2.54 mm) .100"
SSM SERIES
TIGER CLAW SURFACE MOUNT SOCKET
Mates with:
TSW, MTSW, TST,
TSS, ZST, ZSS, DW,
EW, ZW, TSM, HMTSW,
HTSW, TSSH, BST,
HTSS, TLW, MTLW
SSM
1
NO. PINS
PER ROW
PLATING
OPTION
–BE
02 thru 36
SPECIFICATIONS
(–SV, – SH, –DH)
For complete specifications and
recommended PCB layouts
see www.samtec.com?SSM
= Locking Clip
(–DV & –SV only)
Contact Samtec for
–DH & –SH
–L
= 10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
–K
–S
–TR
= Tape & Reel Packaging
(29 positions max.)
HORIZONTAL
–SV
PROCESSING
–“XXX”
TSM
SSM TSSH
• Alignment pin
Contact Samtec.
(2.54) .100 x No. of Positions
–DV
72
(2.54)
.100
71
(7.04)
.277
01
(7.37)
.290
(7.37)
.290
(2.54) .100
For complete scope
of recognitions see
www.samtec.com/quality
(0.51) .020
(2.54) .100
(0.13) .005
(0.51) .020
01
(0.89) .035 SQ TYP
(1.42) .056
= Double Row Horizontal Pin
(11.00)
.433
36
(1.27) .050
–DH
–SH
= Single Row Horizontal Pin
(1.78)
.070
02
(5.08)
.200
(4.42)
.174
01
FILE NO. E111594
(1.27)
.050
36
(2.54)
.100
RECOGNITIONS
(4.95)
.195
x
(10.03)
.395
= Double Row Vertical Pin
= Single Row Vertical Pin
Lead–Free Solderable:
Yes
–DH Coplanarity:
Less than 28 positions
(0.15 mm) .006" max*
More than 27 positions
(0.20 mm) .008" max*
–SH, –SV, –DV Coplanarity:
*(.004" stencil solution
may be available; contact
IPG@samtec.com)
–P
= Plastic Pick
& Place Pad
(–DV & –SV only)
(6 pos. minimum.
Contact Samtec
for availability on
smaller positions)
= Polarized Position
(–BE not available)
APPLICATIONS
(MOQ Required)
(5.94) .234
x
(5.72) .225
= (6.50 mm) .256" DIA
Polyimide film
Pick & Place Pad
(2 positions min.)
–DV & –SV only
= 30 µ" (0.76 µm)
Gold on contact,
Matte Tin on tail
ALSO AVAILABLE
= Metal Pick &
Place Pad
(5 positions min.)
–DV only
–LC
= Gold flash
on contact,
Matte Tin on tail
(–DV)
–M
= Bottom Entry
(–DV & –SV only)
–F
02 thru 40
Insulator Material:
Black Liquid Crystal Polymer
Contact Material:
Phosphor Bronze
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Current Rating (SSM/TSW):
5.2 A per pin
(2 pins powered)
Voltage Rating:
405 VAC / 572 VDC
Operating Temp Range:
-55 °C to +125 °C with Gold
-55 °C to +105 °C with Tin
Insertion Depth:
SV/DV is (4.34 mm) .171" to
(7.24 mm) .285" or pass-through
from top; (5.56 mm) .219" plus
board thickness minimum from
bottom; SH/DH is (4.34 mm)
.171" to (6.35 mm) .250"
Normal Force:
125 grams (1.21 N) average
RoHS Compliant:
Yes
(3.18)
.125
(0.25)
.010
(8.13)
.320
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
OTHER
OPTION
ROW
OPTION
72
(1.78)
.070
01
71
(8.13)
.320
(0.51) .020
(2.54).100
(0.51) .020
Due to technical progress, all designs, specifications and components are subject to change without notice.
WWW.SAMTEC.COM
02
(5.72) (2.54)
.225 .100
All parts within this catalog are built to Samtec’s specifications.
Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
(11.18)
.440
很抱歉,暂时无法提供与“SSM-132-L-DV-M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 7+76.484647+9.93938
