TCSD-08-S-16.00-01-N-B12 数据手册
TIGER
IDC
EYE
TIGER EYE™ IDC
SOCKET CABLE
(2.00 mm) .0787" PITCH • TCSD SERIES
TCSD
Mates:
TMM, TMMH, STMM,
MMT, TW, MTMM, EHT,
ETMM (-SR), ZSTMM
SPECIFICATIONS
Insulator Material:
Black Glass Filled Polyester
Contact:
BeCu
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Wire:
28 AWG 7/36 Stranded,
Tinned, Copper with
Gray PVC Insulator
Current Rating
(TCSD/STMM):
2.8 A per pin
(2 pins powered)
Operating Temp Range:
-40 °C to +105 °C
Lead Size Accepted:
(0.48 mm) .019" to
(0.53 mm) .021"
Insertion Depth:
(2.87 mm) .113" to
(3.17 mm) .125"
ALSO AVAILABLE
SERIES
TCSD
= Socket
Strip
NO. PINS
PER ROW
–04, –05,
–07, –08,
–10, –12,
–13, –15,
–17, –20,
–22, –25
END
OPTION
–S
= Single
End
OVERALL
LENGTH
- 01 -
–“XX.XX”
PLATING
OPTION
Leave blank
for standard
plating
30 µ"
(0.76 µm)
Gold on
contact area
= Assembled
Length
–D
= Double
End
–N
= Notch
Polarization
–F
(Standard
sizes)
OTHER
OPTION
–P “XX”
= Position
Polarization
(Specify “XX” as
position number.
Same position
will be polarized
on both ends)
–B “XX”
= Gold flash
on contact
= Breakout
(Specify “XX”
as number of
conductors to
be broken out)
–RW
= Reverse Wiring
(Blue or black
wire opposite
position #1)
01
–D “XX”
(4.00)
.158
= Daisy Chain
–SR
No. of positions x (2.00) .0787 + (4.00) .157
= Strain Relief
(Not available
with –O, –M, –R,
–DXX or –BXX)
(5.08)
.200
–R
MOQ Required
= Reversed
Other sizes
Other platings
–M
= Middle
Reversed
(Requires –DXX)
Assembled Length
in INCHES (±1/8")
1 inch minimum
–O
POLARIZING KEY
Specify PK-01-07 for polarizing key
(Available in wheels of six each).
Also polarizes SMM Series
socket strips.
N
= Outside
Reversed
(Requires –DXX)
Single End (—S)
Double End (—D)
Assembled Length (—“XX.XX”)
2"
min.
01
5"max.
2"min.
Breakout starts with Number 1
lead indicated by brown wire or
red stripe. Shown on top side.
Breakout (—B “XX”)
1/8"
Double
Row
Connectors
“XX”
02
Position Polarization (—P “XX”)
“XX”
01
02
Reverse Wiring (—RW)
4" minimum
Outer
Most
(End of
assembly)
Daisy Chain (—D “XX”)
No. of positions x
(2.00) .0787 + (7.874) .3100
Note:
TCSD Series assemblies are
non-standard, non-returnable.
F-224
Strain Relief (—SR)
Reversed —R)
Middle Reversed (—M)
Outside Reversed (—O)
samtec.com?TCSD
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
TCSD-08-S-16.00-01-N-B12 价格&库存
很抱歉,暂时无法提供与“TCSD-08-S-16.00-01-N-B12”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+85.642811+11.03373
