TFML-145-02-S-D-K-TR 数据手册
F-215
TFM–115–02–L–S
TFM–110–02–L–D–LC
SYSTEM
TFM–110–01–L–D–RE1–WT
TFML–115–02–L–D–K
(1,27 mm) .050"
SMT & THROUGH-HOLE HEADER
SPECIFICATIONS
For complete specifications and
recommended PCB layouts
see www.samtec.com?TFM or
www.samtec.com?TFML
Insulator Material:
Black Liquid Crystal Polymer
Terminal Material:
Phosphor Bronze
Plating:
Au or Sn over 50µ" (1,27 µm) Ni
Current Rating (TFM/SFM):
3.2 A per pin
(1 pin powered per row)
Voltage Rating:
250 VAC mated with SFM
Operating Temp Range:
-55°C to +125°C
RoHS Compliant: Yes
Shrouded body
for blind mating
TFM Mates with:
SFM, SFMC, SFSD
(1,27 mm x 1,27 mm)
.050" x .050"
micro pitch
TFML Mates with:
SFML
TFM-DH Mates with:
SFM (-DH), SFMC,
SFSDX (–S, -D, -SR, -DR)
APPLICATIONS
TFM-DH to SFM-DH SHOWN
Processing:
Surface mount or
Through-hole tails
Lead-Free Solderable: Yes
SMT Lead Coplanarity:
(0,10 mm) .004" max (05-25)
(0,15 mm) .006" max (30-50)
TFM to SFM-SH SHOWN
RECOGNITIONS
For complete scope
of recognitions see
www.samtec.com/quality
TYPE
STRIP
NO. PINS
PER ROW
1
MATED HEIGHT
LEAD STYLE
TFM
–02
–12
–22
–32
SFM
–02
(8,13) .320
(9,91) .390
TFML
05, 07, 10, 15, 20,
25, 30, 35, 40, 45, 50
= Locking
(–01 & –02
lead style only)
(1,27) .050 x
No. of Positions + (3,18) .125
MATED
HEIGHT*
(5,97) .235
(5,97) .235
(7,75) .305
–01
(7,75) .305
(9,53) .375
(9,53) .375
(11,43) .450
*Processing conditions will affect
mated height.
OTHER
SOLUTIONS
• Lower cost plating options.
See TFC Series.
LEAD
STYLE
(T/H)
B
C
(5,59) (1,97)
.220 .078
(2,77)
–03* (5,59)
.220 .109
(1,97)
–11* (7,37)
.290 .078
(2,77)
–13* (7,37)
.290 .109
(9,14) (1,97)
–21* .360 .078
(2,77)
–23* (9,14)
.360 .109
(1,97)
–31* (11,05)
.435 .078
* N/A with 07 or -S row
option
(2,79)
.110
(4,45)
.175
LEAD
STYLE
01
(SMT)
(See website for –DS & –WT OAL)
–REX = (1,27) .050 x
No. of Positions + (6,68) .263
–02
–12*
–22*
–32*
SINGLE ROW
–01
(1,27)
.050
02
01
DOUBLE ROW
A
(1,14)
.045
(5,72) .225
(7,49) .295
(9,27) .365
(11,18) .440
* N/A with 07, -DH or
-S row option
(5,72)
.225
(1,27)
.050
DIA –A
(SMT or TH)
(1,27) .050
(0,46) .018 DIA
B
(1,40)
.055
A
C
Note: Some sizes, styles and
options are non-standard,
non-returnable.
= 15µ" (0,38 µm)
Gold on post,
Matte Tin on tail
(Call Samtec for
E.L.P.™ plating option)
(Standard sizes)
(11,81) .465
LEAD STYLE
TFM
SFM
–01
–03
–11
–13
–21
–23
–31
= Standard
MATED
HEIGHT*
(6,35) .250
(TFM –01 & –02 only)
TFM
–L
Specify
LEAD STYLE
from chart
03, 04, 06, 08
FILE NO: 090871_0_000
PLATING
OPTION
LEAD STYLE
(0,36) .014
THROUGH-HOLE
SURFACE MOUNT
(1,42)
.056
–LC
(SMT or TH)
WWW.SAMTEC.COM
Due to technical progress, all designs, specifications and components are subject to change without notice.
(2,35)
(0,64)
.093
.025
–WT
(–01 & –02 ONLY)
TFM–105–01–L–D–RA
TFML–150–01–L–D–LC
TFM–125–01–L–D–WT
TFM–110–02–L–DH
TFM–110–02–L–D–DS
TFM, TFML SERIES
Shrouded body for
blind mating
(1,27 mm)
.050" pitch
• Passes 10 Year MFG
• Locking option
Surface mount or
Through-hole tails
• Locking clip option
• Weld tab option
Screw down
option
ROW
OPTION
Weld tab
option
• Screw Down option
OPTION
–S
Specify only –RA, –RE1 or –RE2
–RA
= Single Row
(TFM only)
= Right Angle
(Lead style –01 only)
–D
Specify only –A, –LC, –DS or –WT
Not available with –RA, –RE1 and –RE2
unless otherwise noted.
–A
SMT lead styles only
Specify only –K or –P
–K
= Polyimide Film Pick & Place Pad
= Alignment Pin
= Double Row
–RE1
–DH*
= Right Angle Elevated for (1,58 mm) .062" PCB
(Requires TFM lead style –01, –D row and –WT)
= Double Horizontal
(TFM lead style –02 only)
(05 thru 50 positions only)
(–TR option only
available)
(0,76)
.030
(2,26)
.089
(1,91)
.075
(0,51)
.020
–RA
(6,48)
.255
(1,99)
.079
–DS
(–D, –01 & –02 ONLY)
–LC
= Locking Clip
(Manual Placement required)
–RE2
= Right Angle Elevated for (2,36 mm) .093" PCB
–DH*
(3,81)
.150
Mates with SFM for
coplanar mating
–RE1 & –RE2
(1,27)
.050
–DS
= Dual Screw Down for
(1,60 mm) .062" PCB
(05, 07, 10, 15, 20, 25, 30,
35, 40 positions only)
(TFM lead styles –01 and –02 only)
(Requires –D row option)
(Mates with SFM–DS option and
SFSD/SFSDT –SS and –DS option only)
(Not available with –A, –LC,
–WT, –K, –P, –TR)
–WT
= Weld Tab
(Required callout for –RE1 & –RE2)
(Mates to SFSS/SFSD –SR and
–DR option only)
(05, 07, 10, 15, 20, 25, 30, 35,
40, 45, 50 positions only)
* Note: Weld tab is standard on –DH option.
No need to specify –WT.
WWW.SAMTEC.COM
–P
= Plastic Pick & Place Pad
(5 positions minimum)
(Not available with
5 position with –WT)
Specify –TR last
–TR
= Tape & Reel
(Not available with –DS)
ALSO AVAILABLE
(MOQ Required)
• Solder nail option
• Other sizes
• Other platings
Contact Samtec.
