TLE-134-01-G-DV-A-K-TR 数据手册
F-215
TLE–107–01–G–DV
TLE–115–01–G–DV
TLE–135–01–G–DV
(2,00 mm) .0787"
TLE SERIES
COST-EFFECTIVE RELIABLE SOCKET
SPECIFICATIONS
For complete specifications and
recommended PCB layouts
see www.samtec.com?TLE
Insulator Material:
Black Liquid Crystal
Polymer
Contact Material:
Phosphor Bronze
Plating:
Au over 50µ" (1,27 µm) Ni
Current Rating (TLE/TMMH):
3.2 A per pin
(1 pin powered per row)
Operating Temp Range:
-55°C to +125°C
Insertion Depth:
(2,08 mm) .082" to
(4,37 mm) .172" with
(0,38 mm) .015" wipe,
pass-through, or
(3,35 mm) .132" min
for bottom entry
Insertion Force:
(Single contact only)
2.75 oz (0,76 N) avg.
Withdrawal Force:
0.80 oz (0,22 N) avg.
RoHS Compliant:
Yes
Tiger BeamTM
contacts
Mates with:
TMMH, TMM,
MTMM, MMT,
TW, LTMM,
ZLTMM, TCMD,
TSH
Ideal for
pass-through
applications
Available
with optional
Pick & Place Pads
OPTIONS
–P OPTION
Surface
Mount
–A OPTION
TLE
1
(2,00 mm) .0787"
micro pitch
–TR OPTION
NO. PINS
PER ROW
PLATING
OPTION
01
DV
OPTION
Processing:
Lead–Free Solderable:
Yes
SMT Lead Coplanarity:
(0,10 mm) .004" max (02-26)
(0,15 mm) .006" max (27-50)
–G
= 10µ" (0,25 µm)
Gold
02 thru 50
–A
= Alignment Pin
(3 positions minimum)
Metal or plastic at Samtec's discretion.
RECOGNITIONS
For complete scope of
recognitions see
www.samtec.com/quality
–K
= (5,00 mm) .197" DIA
Polyimide Film Pick & Place Pad
(2,00)
.0787 01
No. of positions x
(2,00) .0787
(2,00)
.0787
(4,00)
.157
02
–P
(5,08)
.200
x
(5,71)
.225
= Metal Pick & Place Pad
(4 positions minimum)
–TR
(4,70)
.185
(0,56)
.022
= Tape & Reel Packaging
(2-37 positions only)
–P Option
BILITY
EL AVAILA
TAPE & RE
(4,32)
.170
(0,76)
.030
(4,50)
.177
(5,51)
.217
(0,64)
.025
DIA
–A Option
Note: Some lengths,
styles and options are
non-standard, non-returnable.
WWW.SAMTEC.COM
Due to technical progress, all designs, specifications and components are subject to change without notice.
arges.
No tooling chthe lesser of
is
r
de
or
um
pieces.
Minim
antity or 125
a full reel quantity above minimum.
Order any qudesign, manufacture.
In-house turn-around.
Quick
s
ion
for specificat
Call Samtecring information.
and orde
TLE-134-01-G-DV-A-K-TR 价格&库存
很抱歉,暂时无法提供与“TLE-134-01-G-DV-A-K-TR”相匹配的价格&库存,您可以联系我们找货
