UB-MC5BR3-RS04-4S-1-TB NMP
    JST
    JST (JAPAN SOLDERLESS TERMINALS) - UB-MC5BR3-RS04-4S-1-TB NMP - USB Connector, Micro USB Type B, Rec...
UB-MC5BR3-RS04-4S-1-TB NMP 数据手册
UB CONNECTOR Micro USB USB (Universal Serial bus) Conforming Connector Standard Reverse Mid mount Specifications ––––––––––––––––––– • Current rating: This connector is an interface connector for cellular phone and other mobile equipments conforming to Micro USB standard. • It is a space saving design of about 50% reduction in mounting area compared with Mini USB. (Standard B type) • 10,000 cycles of mating/unmating is guaranteed. • Variations • SMT configuration Only signal line Signal line (No. 2 to 4-circuit): 1.0A AC, DC/Line : Power supply line Power supply line (No. 1, 5-circuit): 1.8A AC, DC/Line Signal line (No. 2 to 4-circuit): 0.5A AC, DC/Line • Voltage rating: 30V AC, DC • Temperature range: -30˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/30mΩ max. After environmental testing/10mΩ max. (variation from initial value) • Insulation resistance: 1,000MΩ min. • Withstanding voltage: 100V AC/minute * Compliant with RoHS. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. 1 UB CONNECTOR Micro USB Receptacle Standard B type Standard AB type TID No.: 60001357 TID No.: 60001359 6.9 +0.06 −0.02 5 8±0.05 8±0.05 4.8±0.05 4.8±0.05 2.5 3.35±0.05 0.5±0.05 1.45±0.05 PC board edge 4.1±0.05 4.3±0.05 5.2±0.05 6.2±0.05 9.8±0.05 9.8±0.05 Model No. 1.35±0.05 1.4±0.05 2.35±0.05 0.4±0.03 1.9±0.05 0.5±0.05 1.45±0.05 1.9±0.05 3.35±0.05 0.4±0.03 0.65±0.03 1.35±0.05 2.35±0.05 1.4±0.05 0.65±0.03 PC board edge 5 2.6±0.05 2.6±0.05 Q’ty / reel: 3,000 Material and Finish UB-MC5BR3-SD204-4S (0.6) (3) 2.5 (3) 1.85 +0.08 −0.02 (0.6) 1.85 +0.08 −0.02 6.9 +0.06 −0.02 Q’ty / reel: 3,000 Model No. Contact: Copper alloy, nickel-undercoated, gold-plated NMP Housing: Thermoplastic resin, UL94V-0, black Shell: Stainless, nickel-undercoated, tin-plated RoHS compliance Material and Finish Contact: Copper alloy, nickel-undercoated, gold-plated NMP Housing: Thermoplastic resin, UL94V-0, gray Shell: Stainless, nickel-undercoated, tin-plated UB-MC5ABR3-SD204-4S RoHS compliance Reverse AB type Reverse B type TID No.: 60001358 6.9 +0.06 −0.02 8±0.05 4.5±0.05 2.6±0.05 2.6±0.05 0.65±0.03 2.5 1±0.05 3.4±0.05 3.4±0.05 4.75±0.05 PC board edge 6.1±0.05 Model No. 0.5±0.05 1.45±0.05 3.35±0.05 1.5±0.05 3.1±0.05 ±0.05 9.8±0.05 0.4±0.03 1.7±0.05 1.45±0.05 0.5±0.05 1.9±0.05 1.7±0.05 3.1±0.05 3.35±0.05 1.35±0.05 0.4±0.03 5 (3) 1.85 +0.08 −0.02 8±0.05 1 PC board edge (0.6) 4.5±0.05 0.65±0.03 1.5±0.05 2.5 (3) 5 1.9±0.05 (0.6) 1.85 +0.08 −0.02 6.9 +0.06 −0.02 1.35±0.05 TID No.: 60001356 4.75±0.05 6.1±0.05 9.8±0.05 Q’ty / reel: 3,000 Material and Finish Model No. Q’ty / reel: 3,000 Material and Finish Contact: Copper alloy, nickel-undercoated, gold-plated UB-MC5BR3-RS04-4S-1 NMP Housing: Thermoplastic resin, UL94V-0, black Shell: Stainless, nickel-undercoated, tin-plated Contact: Copper alloy, nickel-undercoated, gold-plated UB-MC5AB2R3-RS04-4S-1 NMP Housing: Thermoplastic resin, UL94V-0, gray Shell: Stainless, nickel-undercoated, tin-plated RoHS compliance RoHS compliance 2 UB CONNECTOR Micro USB Receptacle Mid mount B type Mid mount B type Mounting height: 0.85mm TID No.: 60001355 Mounting height: 1.2mm TID No.: 62001355 6.9 +0.06 −0.02 6.45 (0.6) 6.45 1.2 1.25 (3) 1.85 +0.08 −0.02 1.6 (3) 1.85 +0.08 −0.02 (0.6) 0.85 6.9 +0.06 −0.02 2.6±0.05 2.6±0.05 R0.5 Max. 4.75±0.05 1.8±0.05 4.7±0.05 7.7±0.05 PC board edge 7.9±0.05 7.9±0.05 11.8±0.05 11.8±0.05 Q’ty / reel: 2,000 Model No. Q’ty / reel: 2,000 Model No. Material and Finish UB-MC5BR3-M04-4S NMP 1.5±0.05 2.2±0.05 2.4±0.05 4.45±0.03 1.5±0.05 2.2±0.05 2.4±0.05 4.45 ±0.03 4.7±0.05 7.7±0.05 PC board edge 0.65±0.03 0.4±0.03 4.75±0.05 1.8±0.05 0.4±0.03 1.2±0.05 1.7±0.05 0.65±0.03 1.7±0.05 R0.5 Max. 1.2±0.05 Contact: Copper alloy, nickel-undercoated, gold-plated Housing: Thermoplastic resin, UL94V-0, black Shell: Stainless, nickel-undercoated, tin-plated RoHS compliance Material and Finish UB-MC5BR3-M404-4S Contact: Copper alloy, nickel-undercoated, gold-plated NMP Housing: Thermoplastic resin, UL94V-0, black Shell: Stainless, nickel-undercoated, tin-plated RoHS compliance Mid mount AB type Mounting height: 0.85mm Mounting height: 1.85mm Mid mount AB type TID No.: 60001365 TID No.: 63001355 6.9 +0.06 −0.02 (0.6) 6.45 1.85 6.45 0.6 (3) 1.85 +0.08 −0.02 1.6 (3) 1.85 +0.08 −0.02 (0.6) 0.85 6.9 +0.06 −0.02 2.6±0.05 7.7 ±0.05 7.9 ±0.05 4.75±0.05 1.8±0.05 PC board edge RoHS compliance 7.7±0.05 7.9±0.05 Q’ty / reel: 2,000 UB-MC5ABR3-M04-4S 4.7±0.05 11.8±0.05 11.8±0.05 Model No. 2.4±0.05 4.45±0.03 2.2±0.05 1.5±0.05 2.4±0.05 2.2±0.05 4.45 ±0.03 PC board edge 4.7±0.05 0.65±0.03 1.2 0.4±0.03 4.75±0.05 1.8±0.05 0.4±0.03 R0.5 Max. 1.5±0.05 0.65±0.03 1.2 1.7±0.05 R0.5 Max. ±0.05 1.7±0.05 2.6±0.05 ±0.05 Material and Finish Contact: Copper alloy, nickel-undercoated, gold-plated NMP Housing: Thermoplastic resin, UL94V-0, gray Shell: Stainless, nickel-undercoated, tin-plated Q’ty / reel: 2,000 Model No. Material and Finish Contact: Copper alloy, nickel-undercoated, gold-plated UB-MC5ABR3-M204-4S NMP Housing: Thermoplastic resin, UL94V-0, gray Shell: Stainless, nickel-undercoated, tin-plated RoHS compliance 3
UB-MC5BR3-RS04-4S-1-TB NMP 价格&库存
很抱歉,暂时无法提供与“UB-MC5BR3-RS04-4S-1-TB NMP”相匹配的价格&库存,您可以联系我们找货
