USB-A-S-S-B-VU
USB-A-S-S-B-VU
    SAMTEC(申泰)
    插件
    USB连接器 Type-A 4P 侧插 端口数:1 额定电压:30VAC 工作温度:-50℃~+85℃
USB-A-S-S-B-VU 数据手册
F-224 SUPPLEMENT STANDARD & RUGGED USB 2.0 USB-B/USBR-B SERIES SPECIFICATIONS Insulator Material: High Temperature Thermoplastic Contact Material: Phosphor Bronze Plating: Gold on Contacts, Nickel on Shell, Tin on Tails Operating Temp Range: -50 °C to +85 °C Voltage Rating: 30 VAC Cycles: 1500 (maximum number of cycles tested) Packaging: Packaged and shipped in Bulk Packaging Trays; Trays suitable for automation are available upon request. Lead–Free Solderable: USB-SM=Yes USB-TH= Yes (Wave Solder only) USBR=Yes (Wave Solder only) TID Number: USB-B-S-X-X-TH (61001155) SERIES - B - S USB - PLATING –F = Standard Connector = Gold Flash on Mating Area, Tin on Tails USBR = Increased Retention Connector (Complies with Class 1, DIV II minimum withdrawal requirement of 15N) –S = 30 µ" (0.76 µm) Gold on Mating Area, Tin on Tails - - COLOR TERMINATION –B - –TH = Black (USB only) = Through-hole –SM –W = Surface Mount (USB only) = White (USB only) –VT –O = Vertical Top Entry = Orange (USBR only) OTHER OPTION –TR = Tape and Reel (–SM only) –FR = Full Reel Tape & Reel (must order maximum quantity per reel; contact Samtec for quantity breaks) (–SM åonly) MATING / UNMATING FORCE (100 CYCLES) SERIES MATING UNMATING USB 5.3 (23.59 N) 6.1 (27.15 N) USBR 11.8 (52.51 N) 11.5 (51.18 N) (16.00) .630 (12.00) .472 (10.90) .429 (12.10) .476 (16.20) .638 —SM (11.10) .437 (14.78) .582 (14.80) .583 (16.20) .638 (12.10) .476 (16.10) .634 (10.80) .425 —VT —TH View complete specifications at: samtec.com?USB-B or samtec.com?USBR-B WWW.SAMTEC.COM Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
USB-A-S-S-B-VU 价格&库存
很抱歉,暂时无法提供与“USB-A-S-S-B-VU”相匹配的价格&库存,您可以联系我们找货
USB-A-S-S-B-VU
  • 1+16.480941+2.13496
  • 50+13.4263250+1.73926
  • 100+11.39871100+1.47660
  • 500+10.85425500+1.40607
库存:258
