USB-AM-S-S-B-SM1
USB-AM-S-S-B-SM1
    SAMTEC(申泰)
    SMD
    USB连接器 Type-A 4P 卧贴
USB-AM-S-S-B-SM1 数据手册
F213 (Rev 13SEP13) USBR–A–S–F–O–TH USB–AM–S–F–W–TH USB–A–D–S–B–TH USB–A–S–F–B–VU USB-A, USBR-A, USB-AM SERIES STANDARD & RUGGED USB 2.0 SPECIFICATIONS For complete specifications and recommended PCB layouts see www.samtec.com?USB-A, www.samtec.com?USBR-A or www.samtec.com?USB-AM Insulator Material: High Temperature Thermoplastic Contact Material: Phosphor Bronze Shell Material: Copper Alloy Plating: Gold on Contacts, Nickel on Shell, Tin on Tails Operating Temp Range: -50°C to +85°C Voltage Rating: 30 VAC Contact Resistance: 30 mΩ Cycles: 1500 (max tested) Packaging: Packaged and shipped in Bulk Packaging Trays; Trays suitable for automation available RoHS Compliant: Yes Lead–Free Solderable (USB-A/USBR-A): –SM1=Yes –TH, –VU & –VT=Yes (Wave Solder only) Lead–Free Solderable (USB-AM): –SM1=Yes –TH=Yes (Wave Solder only) TID Numbers (USB-A): USB-A-D-X-X-TH (61001199) USB-A-S-X-X-TH (61001180) USB-A-S-X-X-SM2 (61001152) USB-A-S-X-X-VT (61001153) TID Number (USB-AM): USB-AM-S-X-X-SM (61001154) SHELL TYPE A TYPE USB –S –F = Single –B = Gold Flash on Mating Area, Tin on Tails = Black = Standard Connector –D USBR = Double (–TH option only) = Increased Retention Connector (Complies with Class 1, DIV II minimum withdrawal requirement of 15N.) –O = Surface Mount (USB only) (6,90) .272 –VU = Upright, Through-Hole 01 –SM2 (2,50) .098 (2,00) .079 (1,20) .047 DIA 01 (2,84) .112 (10,40) .409 (12,50) .492 04 (5,12) .202 (13,62) .536 (14,50) .571 (13,21) .520 –VT = Vertical, Through-Hole –TH (5,81) .229 (14,22) .560 (15,49) .610 (5,12) .202 (0,10) .004 (7,10) .280 (3,07) .121 (11,58) .456 –VU –SM1 SHELL TYPE TYPE RECOGNITIONS –AM = A Type (Plug) 04 01 (2,90) .114 For complete scope of recognitions see www.samtec.com/quality –SM2 = Orange (USBR only) (5,72) .225 (5,12) .202 01 USB –SM1 = Offset Surface Mount (12,50) .492 (19,20) .756 (11,26) .443 –TH = Through-hole = White = 30µ" (0,76 µm) Gold on Mating Area, Tin on Tails (6,90) .272 (5,00) .197 TERMINATION –W –S (16,40) .646 01 COLOR PLATING (2,00) .079 (7,00) .276 (2,00) .079 (14,60) .575 (17,60) .693 (10,72) .422 –D (Requires –TH) COLOR PLATING TERMINATION –S –F = Single = Gold Flash on Mating Area, Tin on Tails –B –TH = Black = Through-hole –W –SM1 (2,62) (2,87) .103 .113 –S = White = Surface Mount (18,70) .736 (4,50) .177 (3,00) .118 (3,72) .146 (2,50) .098 (2,00) .079 = 30µ" (0,76 µm) Gold on Mating Area, Tin on Tails (18,80) .740 (2,62) .103 (4,52) .178 (3,10) .122 (14,70) .579 (17,70) .697 (1,00) .039 DIA 01 01 (12,00) .472 (4,55) (7,00) .179 .276 (12,00) .472 (2,00) .079 (4,60) .181 (1,00) .039 DIA (12,50) .492 (12,00) .472 (7,00) .276 (2,00) .079 (2,00) .079 –SM1 (2,00) .079 (1,00) .039 –TH WWW.SAMTEC.COM (1,45) .057
USB-AM-S-S-B-SM1 价格&库存
很抱歉,暂时无法提供与“USB-AM-S-S-B-SM1”相匹配的价格&库存,您可以联系我们找货
USB-AM-S-S-B-SM1
  • 1+31.353051+4.04480
  • 50+25.5495450+3.29610
  • 100+21.68313100+2.79731
  • 500+20.65271500+2.66437
库存:10
