WPJT-03V-1-S
WPJT-03V-1-S
    JST
    P=5mm
    塑壳
WPJT-03V-1-S 数据手册
WPJ CONNECTOR 5.0mm pitch/Disconnectable Crimp style Wire-to-wire connectors Specifications ––––––––––––––––––– Compact, Water Resist and Durable. This connector for electrical connection can be used on both waterproof and nonwaterproof conditions, depending on the usage. • Waterproof performance [Grade 7 ingress protection of JIS C 0920 (IPX7 of IEC 60529 )] • Control key system • Contacting part of contact is hardly deformed • Inner-locking system • Compact design • Current rating: 7 A AC, DC (AWG #18) • Voltage rating: 300 V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 10 mΩ max. After environmental tests/ 20 mΩ max. • Insulation resistance: 1,000 MΩ min. • Withstanding voltage: 1,500 VAC/minute • Applicable wire: Conductor size/ AWG #22 to #18 Insulation O.D./ 2.32 to 2.83 mm 1.52 to 2.03 mm • Waterproof grade: Grade 7 ingress protection of JIS C 0920 (IPX7 of IEC 60529 ) * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. * Compliant with RoHS. Standards –––––––––––––––––––––– 0 Recognized E60389 1 Certified LR20812 2 File No.R50073100 Assembly layout 11.2 (41.9) 1 WPJ CONNECTOR (Non-waterproof type) Contact Receptacle contact 2.4 1.4 Tab contact 14.5 20.2 5.6 0.5 5.6 Model No. Tab contact SWPJT-21T-P0.5 Receptacle contact SWPJR-21T-M0.5 SWPJT-21T-P0.5A SWPJR-21T-M0.5A Applicable wire mm2 AWG # 0.33∼0.83 Q’ty/reel Tab contact Receptacle contact Insulation O.D. (mm) 22∼18 2.32∼2.83 6,000 4,500 1.52∼2.03 9,000 4,500 Material and Finish Copper alloy, tin-plated (reflow treatment) RoHS compliance Non-waterproof type Crimping machine Crimp applicator Contact SWPJT-21T-P0.5 AP-K2N SWPJR-21T-M0.5 AP-K2N MKS-L Applicator Dies MK/SWPJR/T-21-05 APLMK SWPJR/T21-05 ― MKS-L ― ― MK/SWPJR/T-21-05 APLMK SWPJR/T21-05 ― Contact Crimp applicator with dies ― ― Applicator Crimping machine Crimp applicator SWPJT-21T-P0.5A AP-K2N SWPJR-21T-M0.5A AP-K2N MKS-L Dies ― MKS-L Crimp applicator with dies MK/SWPJR/T-21-05A APLMK SWPJR/T21-05A ― ― MK/SWPJR/T-21-05A APLMK SWPJR/T21-05A ― ― ― Tab housing (for tab contact) 10.35 Circuits Model No. 2 3 Dimensions (mm) Q’ty/bag A B WPJT-02V-1-S − 14.2 500 WPJT-03V-1-S 10 19.2 500 Material A B 5 38 Glass-filled PBT, UL94V-0, natural (white) RoHS compliance Receptacle housing (for receptacle contact) 2 3 Dimensions (mm) B WPJR-02V-1-S − 12.1 1,000 WPJR-03V-1-S 10 17.1 1,000 14.2 B Q’ty/bag A Material Glass-filled PBT, UL94V-0, natural (white) 0.7 A Model No. 22.8 5 11.2 Circuits RoHS compliance 2 WPJ CONNECTOR (Waterproof type) Contact Receptacle contact 2.4 1.4 Tab contact 14.5 20.2 5.6 0.5 5.6 Model No. Tab contact SWPJT-21T-P0.5 Applicable wire mm2 AWG # Receptacle contact SWPJR-21T-M0.5 0.33∼0.83 Q’ty/reel Tab contact Receptacle contact Insulation O.D. (mm) 22∼18 2.32∼2.83 6,000 4,500 Material and Finish Copper alloy, tin-plated (reflow treatment) RoHS compliance Waterproof type Contact SWPJT-21T-P0.5 Crimping machine Crimp applicator AP-K2N SWPJR-21T-M0.5 AP-K2N MKS-L Applicator Dies ― MKS-L Crimp applicator with dies MK/SWPJR/T-21-05 APLMK SWPJR/T21-05 ― ― MK/SWPJR/T-21-05 APLMK SWPJR/T21-05 ― ― ― Tab housing assembly (for tab contact) Circuits Model No. 2 3 Dimensions (mm) B 02T-WPJV-1-SM − 14.2 675 03T-WPJV-1-SM 10 19.2 495 5 Material A B Q ty/bag A 10.35 38 Tab housing: Glass-filled PBT, UL94V-0, natural (white) Seal rubber plate: Silicon, green RoHS compliance Receptacle housing assembly (for receptacle contact) B 0.7 A 3 Circuits Model No. 2 3 Dimensions (mm) Q ty/bag A B 02R-WPJV-1-SMM − 12.1 720 03R-WPJV-1-SMM 10 17.1 576 14.2 22.8 5 11.2 Material Receptacle housing: Glass-filled PBT, UL94V-0, natural (white) Seal ring: Silicon, green Seal rubber plate: Silicon, green RoHS compliance
WPJT-03V-1-S 价格&库存
很抱歉,暂时无法提供与“WPJT-03V-1-S”相匹配的价格&库存,您可以联系我们找货
WPJT-03V-1-S
    • 1+3.116511+0.40228
    • 10+2.5737510+0.33222
    • 50+2.0309950+0.26216
    • 100+1.66331100+0.21470
    • 500+1.59328500+0.20566
    • 1000+1.540751000+0.19888
    • 2000+1.514492000+0.19549
    库存:209
    WPJT-03V-1-S
      • 500+1.69100
      库存:5000
