ZSS-120-01-T-D-515
ZSS-120-01-T-D-515
    SAMTEC(申泰)
    CONN HDR .100" 40POS
ZSS-120-01-T-D-515 数据手册
ZSS–113–03–L–D–0735 F-218 (Rev 10OCT17) HTSS–125–01–L–DV (2.54 mm) .100" TSS, HTSS, ZSS SERIES SHROUDED .025" SQ POST HEADERS Mates with: SSW, SSQ, ESW, ESQ, SSM, BCS 1 TYPE STRIP NO. PINS PER ROW LEAD STYLE PLATING OPTION 03 Specify LEAD STYLE from chart. = Gold flash on post, Matte Tin on tail (Not available on -DV) SPECIFICATIONS For complete specifications see www.samtec.com?TSS, www.samtec.com?HTSS or www.samtec.com?ZSS TSS (TSS only) = Connector Strip Insulator Material: TSS, ZSS: Black Glass Filled Polyester HTSS: Natural PCT Insulation Resistance: 5000 MΩ min Terminal Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Operating Temp Range: -55 °C to +125 °C with Gold -55 °C to +105 °C with Tin Flammability Rating: UL 94V-O Withstanding Voltage: 1000 VRMS RoHS Compliant: Yes 05, 07, 08, 10, 12, 13, 15, 17, 20, 25, 32, 36 HTSS = High Temp Connector Strip LEAD STYLE –01 –02 –03 (2.92) .115 (4.19) .165 (14.35) .565 PROCESSING A –D RECOGNITIONS ZSS For complete scope of recognitions see www.samtec.com/quality (0.38) .015 –DV (HTSS ONLY) NO. PINS PER ROW (2.54) .100 x No. of Positions + (3.81) .150 (2.54) .100 x No. of Positions + (1.27) .050 02 • Other sizes • Other platings • Alignment Pins • Single Row • Locking Leads • Polarized Contact Samtec. Note: Some lengths, styles and options are non-standard, non-returnable. ZSS is non-standard, non-returnable. LEAD STYLE PLATING OPTION Specify LEAD STYLE from chart. = Gold flash on post, Matte Tin on tail (2.54) .100 –T (2.54) .100 (6.35) .250 (8.89) .350 (2.29) .090 MIN (0.64) .025 SQ TYP (2.54) .100 –D–RA –“XXXX” = Body Height BODY HEIGHT C (OAL) LEAD STYLE –01 –02 –03 –04 –05 –06 –07 –08 –09 C (OAL) MAX BODY HEIGHT (16.00) .630 (13.72) .540 (18.54) .730 (16.26) .640 (21.08) .830 (18.80) .740 (23.62) .930 (21.34) .840 (26.16) 1.030 (23.88) .940 (28.70) 1.130 (26.42) 1.040 (31.24) 1.230 (28.96) 1.140 (33.78) 1.330 (31.50) 1.240 (36.32) 1.430 (34.04) 1.340 Note: For added mechanical stability, Samtec recommends mechanical board spacers be used in applications with gold or selective gold plated connectors. Contact ipg@ samtec.com for more information. Due to technical progress, all designs, specifications and components are subject to change without notice. WWW.SAMTEC.COM BODY HEIGHT D –L = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail = Matte Tin (0.38) .015 (5.08) .020 –F (9.27) .365 01 = Double Row Right-angle (lead style –04 & –05 only) (11.18) .440 (Standard sizes) ALSO AVAILABLE B (6.35) .250 (10.16) .400 (0.64) .025 SQ TYP 1 –D–RA LEAD RIGHT STYLE ANGLE (B) –04 (3.30) .130 –05 (5.84) .230 (2.54) .100 03, 05, 07, 08, 10, 12, 13, 15, 17, 20, 25, 32, 36 • Shrouded IDC headers and stackers to mate with IDSD, SMSD Series.See TST, HTST and ZST Series. (MOQ Required) –T (9.27) .365 01 –DV = Double Row Surface Mount (lead style –01 only) (HTSS only) = Matte Tin (2.54) .100 FILE NO. E111594 OTHER SOLUTIONS –L (2.54) .100 x No. of Positions + (3.81) .150 (2.54) .100 x No. of Positions + (1.27) .050 02 –D = Double Row Through-hole (lead style –01, –02 & –03 only) = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail (8.89) .350 Lead–Free Solderable: HTSS: Yes TSS, ZSS: Wave Only SMT Lead Coplanarity: (0.15 mm) .006" max* *(.004" stencil solution may be available; contact IPG@samtec.com) –F (Standard sizes) T/H (A) ROW OPTION All parts within this catalog are built to Samtec’s specifications. Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
ZSS-120-01-T-D-515 价格&库存
很抱歉,暂时无法提供与“ZSS-120-01-T-D-515”相匹配的价格&库存,您可以联系我们找货
ZSS-120-01-T-D-515
    • 1+41.074411+5.11715
