09 16 108 3001
09 16 108 3001
    HARTING(浩亭)
    Conn Housing M 108Signal/1Ground POS Crimp ST
09 16 108 3001 数据手册
Han® 108 DD Size  24 B 250  V 10  A Number of contacts 108 + Han D / DD Inserts Identification Crimp terminal rder crimp contacts O separately (see Technical characteristics on page 02.06) Series Part number Male insert (M) Female insert (F) Drawing Dimensions in mm Han DD® 09 16 108 3001 "https://b2b.harting.com/ebusiness/en/ " "https://b2b.harting.com/ebusiness/en/ 09 16 108 3101 " 1) Distance for contact max. 21 mm Contact arrangement view from termination side Panel cut out for inserts for use without hoods/housings Coding pin Coding pin 09 33 000 9915 "https://b2b.harting.com/ebusiness/en/ " Use of the coding pin prevents incorrect mating to other connectors of the same type. The male pin should be omitted from the opposing cavity in the male insert. Stock items in bold type 02 . 17
09 16 108 3001 价格&库存
很抱歉,暂时无法提供与“09 16 108 3001”相匹配的价格&库存,您可以联系我们找货
    • 1+228.50431
    • 100+227.15079
    • 500+224.53959
    库存:10
