Connecting Links for Surface Mount Terminal Blocks with Push-Buttons
Pin Spacing 4 mm
2060 Series
t$POOFDUJOHMJOLTJNQMJmFT-&%DJSDVJUCPBSEBTTFNCMZ
t&BTZQVTIJOUFSNJOBUJPOBOEEJTDPOOFDUJPOXJUIPVU
push-button actuation
t'PSCPBSEUPCPBSEDPOOFDUJPOTVTJOHTFSJFT
terminal blocks
t&MJNJOBUFTNBOVBMXJSJOHCFUXFFOCPBSETPS-&%NPEVMFT
Technical data:
Pin Spacing
Rating per
Overvoltage category
Pollution degree
Rated voltage
Rated surge voltage
Nominal current
Approvals per
Rated voltage
Nominal current UL
Nominal current CSA
4 mm
0.157 in
IEC/EN 60664-1
III
III
II
3
2
2
63 V 160 V 320 V
2.5 kV 2.5 kV 2.5 kV
9A
9A
9A
U/Y
250 V
9A
6A
Material data:
Material group
Insulating material
Flammability rating per UL 94
Lower/Upper temperature limit
Contact material
Contact plating
I
Polyamide 6.6 (PA 6.6)
V0
-60ºC/+105ºC
Copper alloy
Silver-plated
with Push-Buttons
2060 Series
Pin spacing 4 mm / 0.157 in
160 V/2.5 kV/2 9 A
250 V/9 A U
250 V/6 A Y
L = (pole no. x pin spacing) - 0.6 mm
Pole No.
Item No.
Pack Unit
Connecting link for surface mount terminal blocks
with push-buttons
1
2
3
2060-901
2060-902
2060-903
Inserting the connecting link into terminal block.
Assembly: Place PCB on a flat surface and insert links into terminal blocks on adjoing PCBs.
Disassembly: Pull PCBs apart.
(Maximum 10 connections/disconnections)
The PCBs must be secured (see figure above).
很抱歉,暂时无法提供与“2060-902”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+14.888851+1.93230
- 10+9.9259010+1.28820
- 50+6.4431350+0.83620
- 100+5.65951100+0.73450
- 500+5.57244500+0.72320
- 1000+5.485371000+0.71190
- 2000+5.485372000+0.71190
