DS-03BLP
DS-03BLP
    XKB(中国星坤)
    插件,P=2.54mm
    间距2.54MM 平拨,凸起式 3位拨码开关
DS-03BLP 数据手册
DIM.A PART N0. 3.9[0.154] 9.9[0.39] A 3.5[0.138] 1.6[0.06] 0.16[0.006] N0.OF DIM.A DIM.B POS DS-01 1 4.06 DS-02 2 6.6 DS-03 3 DS-04 Cover/Red(R) Cover/Blue(BL) Projection(P) Short(S) Projection(P) Short(S) DS-01RP DS-01RS DS-01BLP DS-01BLS 2.54 DS-02RP DS-02RS DS-02BLP DS-02BLS 9.14 5.08 DS-03RP DS-03RS DS-03BLP DS-03BLS 4 11.68 7.62 DS-04RP DS-04RS DS-04BLP DS-04BLS DS-05 5 14.22 10.16 DS-05RP DS-05RS DS-05BLP DS-05BLS DS-06 6 16.76 12.7 DS-06RP DS-06RS DS-06BLP DS-06BLS DS-07 7 19.3 15.24 DS-07RP DS-07RS DS-07BLP DS-07BLS DS-08 8 21.84 17.78 DS-08RP DS-08RS DS-08BLP DS-08BLS DS-09 9 24.38 20.32 DS-09RP DS-09RS DS-09BLP DS-09BLS DS-10 10 26.92 22.86 DS-10RP DS-10RS DS-10BLP DS-10BLS DS-12 12 32 27.94 DS-12RP DS-12RS DS-12BLP DS-12BLS 7.62[0.3] A 5.5 1.4 1,2 Projection(P) 2.54 SPECIFICATION Contact Rating: 25mA,24V DC Contact Resistance: 50mΩ max Insulation Resistance: 100mΩ min.500V DC Dielectric Strength: 500V AC/1minute Operating Force: 1000gf max Travel: 2mm Operating Life: 3000cycles Operating Temp: -20℃~+70℃ Storage Temp: -30℃~+80℃ 0.6 Short(S) DIM.B 2 3 4 5 7.62[0.3] 1 4 6 Ø1[0.039] 7 8 9 10 2.54[0.1] SECTION A-A X X X MARK DATE DESCRIPTION REVISIONS www.xk-dg.cn www.helloxkb.com units: mm tolerance: X.X ±0.2mm X.XX ±0.1mm ±0.05mm REVISED X.XXX APPROVED UNSPECIFIED TOLERANCES www.helloxkb.cn Terminal Copper Alloy T:Tin plated G:Plating Gold≥15MU 3 Base 1 Pa66 Black 2 Keystake 1 Pa66 white 1 Cover 1 Pa66 Black Blue Red ITEM PAPT NAMF QTY MATERIAL FINISHING DSND DATE SCALE: N/A MODEL TYPE: DWN DATE VIEW: CHKD DATE UNIT: mm/in APPD DATE DIP SWITCH PART NO.: DWG NO.: SIZE: A4 XKB INDUSTRIAL PRECISION CO.,LIMITED WEIGHT 1.0g DS-XX-X-X SHEET 1/1 REVISION A0
DS-03BLP 价格&库存
很抱歉,暂时无法提供与“DS-03BLP”相匹配的价格&库存,您可以联系我们找货
DS-03BLP
    • 1+2.72160
    • 10+2.13840
    • 53+1.89000
    • 106+1.57680
    • 477+1.43640
    • 1007+1.35000
    库存:229
