F-215 (Rev 17SEP15)
FTSH–110–01–L–DV
FTSH–120–01–F–DV
FTSH–125–01–L–DV–EJ
(1.27 mm) .050"
SMT MICRO HEADER
SPECIFICATIONS
For complete specifications and
recommended PCB layouts
see www.samtec.com?FTSH
Insulator Material:
Black Liquid Crystal Polymer
Terminal Material:
Phosphor Bronze
Plating:
Sn or Au over
50µ" (1.27 µm) Ni
Current Rating (FTSH/CLP):
3.3 A per pin
(1 pin powered per row)
Operating Temp Range:
-55°C to +125°C
RoHS Compliant:
Yes
APPLICATIONS
Mates with:
FFSD, FFTP, CLP, FLE
OTHER SOLUTIONS
CLP FTSH
OPTIONS
–ES OPTION
–P OPTION
HORIZONTAL
(1.27 mm)
.050"
–EC OPTION
–EP OPTION
Ultra-low profile option available.
End Shrouds available.
Call for FTS Series specifications.
Processing:
Lead-Free Solderable:
Yes
SMT Lead Coplanarity:
–MT & –DV Tail Option:
(0.10 mm) .004" max (02-25)
–MT & –DH Tail Option:
(0.15 mm) .006" max (26-50)
RECOGNITIONS
–EJ OPTION
–EL OPTION
LEAD
STYLE
NO. PINS
PER ROW
1
FTSH
–TR OPTION
For complete scope of
recognitions see
www.samtec.com/quality
–01
= (3.05 mm) .120" Post
(Mates with FFSD, CLP–DH)
FILE NO: 090871_0_000
02 thru 50
–02
ALSO AVAILABLE
• Molded Pick & Place pads
• Latches
• Other platings
Contact Samtec.
A
No. of positions x (1.27) .050 + Z
(MOQ Required)
100
02
(4.78)
.188
(1.27)
.050
01
–EX OPTION SHOWN
(0.81)
.032
(0.51)
.020
(2.29)
.090
99
–DH
(Styles –01, –02, –04 only)
(5.64)
.222
OPTION
Z
– ES
(2.57)
.101
(15.77)
.621
(3.33)
.131
(5.87)
.231
(6.53)
.257
–EJ
–EJ OPTION SHOWN
–EC
02
100
–EP
(3.43)
.135
(1.27)
.050 01
= (1.91 mm) .075" Post
(Mates with FLE)
(5.33)
.210
–EL
(0.40)
.016
SQ
99
A
–03
= (1.65 mm) .065" Post
(Mates with CLP–D)
–04
= (3.81 mm) .150" Post
–05
= (4.32 mm) .170" Post
(Mates with CLP–BE)
LEAD
STYLE
– 01
(5.08)
.200
A
Note: Some sizes, styles and
options are non-standard,
non-returnable.
Note: See SFM/TFM for
positive alignment feature.
(1.27) .050
(5.84)
.230
–DV
– 03
– 04
(2.51)
.099
(2.92)
.115
– 02
– 05
(1.27)
(0.81)
(2.29) .050
.032
.090
–MT
(Styles –01, –02 & –04 only)
WWW.SAMTEC.COM
Due to technical progress, all designs, specifications and components are subject to change without notice.
A
(3.05)
.120
(1.91)
.075
(1.65)
.065
(3.81)
.150
(4.32)
.170
FTSH–112–02–L–DH
FTSH–130–02–L–DV–EP
FTSH–116–02–L–DV
FTSH–110–01–F–DV
FTSH–116–03–L–DV–EP–P
FTSH SERIES
Optional
guide
post
(2.92 mm)
.115"
Surface mount
(1.27 mm) .050"
micro pitch
PLATING
OPTION
–F
TAIL
OPTION
OPTION
–DV
Leave Blank
for -DH & -MT
= Gold flash
on post,
Matte Tin
on tail
= Double
Vertical
–L
= Double
Horizontal
(Styles
–01, –02 &
–04 only)
= 10µ"
(0.25 µm)
Gold on post,
Matte Tin
on tail
–MT
–ES
–EL
= End Shroud
= End Shroud with Board Lock
(Boards are positively locked
and cannot be unmated)
–EC
= End Shroud
with Locking Clip
(Manual placement
required)
–EP
= End Shroud
with Guide Post
(1.91)
.075
DIA
(3.05)
.120
–EJ
–C
(0.89)
.035
DIA
–P
–A
(1.17)
.046
(3.05)
.120
(2.16)
.085
(5.08)
.200
(11.18)
.440
(3.20)
.126
(3.30)
.130
x
(5.08)
.200
–EJ
–K
(0.86)
.034
= Pick & Place Pad
(–DV 4 positions min.)
(–DH & –MT not available)
–TR
(4.10)
.160
(2.29)
.090
–EL
–A
= (5.00 mm) .197" DIA
Polyimide film
Pick & Place Pad
(–DH only)
–EP
–ES
= Keying Shroud
(For mating with FFSD
Style –01 only and
05, 08, 10, 13, 17, 20 & 25
pins/row only. 13, 17, 20 & 25
pins/row only with –EJ option)
(–DV only)
= Alignment Pin
(–DV 3 positions min.)
(–DH 5 positions min.)
(Metal or plastic at
Samtec discretion)
= Ejector Shroud
(Style –01 only)
10 pins/row minimum
25 pins/row maximum
(4.83)
.190
(4.83)
.190
–K
(Style –02 & –03 only, –DH & –MT not available)
9 pins/row minimum
(Other positions available. Call Samtec.)
= Polarized
Position
(Specify
position of
omitted pin)
(Not available
with -EX
options)
= Mixed
Technology
(Styles
–01, –02 &
–04 only)
(1.22)
.048
OTHER
OPTIONS
FLEX SHROUD
OPTIONS
–“XXX”
–DH
Optional end
shrouds and
ejector shrouds
–P
– EC
WWW.SAMTEC.COM
= Tape & Reel Packaging
(Flex Shroud options not
available except –ES & –EJ)
很抱歉,暂时无法提供与“FTSH-125-03-L-D”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 18+51.9848718+6.72237
