MPTC-01-24-01-6.30-01-L-V
    SAMTEC(申泰)
    插件
    线对板针座 4x6P 直插
MPTC-01-24-01-6.30-01-L-V 数据手册
F-214 (Rev 14JAN14) MPSC–01–80–01–7.70–01–L–V TM STRIP 30 MPTC–01–80–01–6.30–01–L–V–LC (5,00 mm) .197"(PWR) (2,00 mm) .079"(SIG) MPTC, MPSC SERIES 30 A SIGNAL/POWER COMBO SYSTEM MPTC Mates with: MPSC, MPCC MPSC Mates with: MPTC MPTC PWR PINS SIG PINS LEAD STYLE PWR PINS TAIL LENGTH PLATING OPTION OTHER OPTION V SPECIFICATIONS For complete specifications see www.samtec.com?MPTC or www.samtec.com?MPSC –01, –02 –16 = Power Pins Per End = Signal Pins –24 Insulator Material: = Signal Pins Black LCP Terminal/Contact Material: Signal: Phosphor Bronze MPTC-V/MPSC-V = Signal Pins Power: Copper Alloy CURRENT Plating: POWER RATING Sn or Au over PINS (PER CONTACT) 50µ" (1,27 µm) Ni 04 Operating Temp 1 28.8 A Range: 2 24.7 A -55°C to +105°C (12,45) 3 24.1 A Voltage Rating: .490 4 22.3 A 300 VAC/424 VDC All 18.5 A RoHS Compliant: Yes (6,27) 01 –T PLATING .247 Lead–Free Solderable: Yes Note: Available standard power pin combinations: RECOGNITIONS MPTC-01-XX-01 or MPTC-02-XX-02. For complete scope Contact Samtec for (1,88) of recognitions see other options. .074 www.samtec.com/quality –01, –02 –6.30 = (6,30 mm) 0.248" = Power Pins Per End –01 = Use with (1,60 mm) .062" Thick PCB = Use with (2,36 mm) .093" Thick PCB = Locking Clip (Manual placement required) = 10µ" (0,25 µm) Gold on contact, Matte Tin on tail (Power & Signal) –03 –80 –LC –L –T = Matte Tin on contacts and tail (Power), Gold on contact, Matte Tin on tail (Signal) A A POWER PINS/END 16 SIGNAL 24 SIGNAL 80 SIGNAL (2,00) .0787 –01 –02 (2,00) .0787 (11,38) .448 (0,41) .016 (0,50) .020 SQ PINS (27,44) 1.081 (37,44) 1.474 PINS (31,45) 1.238 (41,45) 1.632 PINS (59,44) 2.340 (69,44) 2.734 (2,72) .107 (2,54) .100 • Locking clip option MATED HEIGHT MPSC PWR PINS SIG PINS LEAD STYLE PWR PINS TAIL LENGTH PLATING OPTION V OTHER OPTION MPSC MPTC 14 mm ALSO AVAILABLE (MOQ Required) • 4, 8, 36 and 48 total signal pins Contact Samtec. –01, –02 –16 = Power Pins Per End = Signal Pins Note: Available standard power pin combinations: MPSC-01-XX-01 or MPSC-02-XX-02. Contact Samtec for other options. –24 = Signal Pins –01, –02 –7.70 = (7,70 mm) .303" = Power Pins Per End –01 = Use with (1,60 mm) .062" Thick PCB –03 –80 = Use with (2,36 mm) .093" Thick PCB = Signal Pins –L –LC = Locking Clip = 10µ" (0,25 µm) Gold on (Manual contact, Matte Tin on tail placement (Power & Signal) required) (Not available = Matte Tin on contacts and with –16 tail (Power), Gold on contact, signal pins) Matte Tin on tail (Signal) –T A OTHER SOLUTIONS (10,16) .400 • Right Angle. See MPTC-RA Series. (2,00) .0787 (2,00) .0787 01 A POWER PINS/END 16 SIGNAL PINS 24 SIGNAL PINS 80 SIGNAL PINS –01 –02 (4,44) .175 (27,44) 1.081 (31,45) 1.238 (59,44) 2.340 (37,44) 1.474 (41,45) 1.632 (69,44) 2.734 (2,72) .107 Note: Some sizes, styles and options are non-standard, non-returnable. (1,88) .074 (0,50) .020 SQ (0,41) .016 WWW.SAMTEC.COM (2,54) .100
