S2M-120-02-S-D-LC-K-TR
    SAMTEC(申泰)
    排母
S2M-120-02-S-D-LC-K-TR 数据手册
RUGGED TIGER EYE™ SYSTEMS (2.00 mm) .0787" PITCH MAX 3.8 A m p s 8 G b p s FEATURES & BENEFITS • Rugged Tiger Eye™ contact system for high reliability • Wide range of stack heights (SMM/TMM Series) • Right-angle mating headers available • Optional metal latching, screw downs, weld tabs and locking clips • Surface mount or through-hole • Discrete wire assemblies available in 24-30 AWG PVC or *Teflon™ Fluoropolymer (See page 240). Contact asp@samtec.com for custom solutions • Severe Environment Testing qualified (S2M/T2M); aligns with MIL-DTL-55302. Visit samtec.com/set Optional strain relief and variety of wiring options *Teflon™ is a trademark of The Chemours Company FC, LLC used under license by Samtec. Components (ISD2/CC81) & tooling available: samtec.com/tooling KEY SPECIFICATIONS (S2M/T2M) STACK INSULATOR HEIGHTS MATERIAL 6 & 7 mm F-224 Black LCP CONTACT MATERIAL PLATING OPERATING TEMP RANGE BeCu (S2M) Au or Sn over -55 °C to +125 °C Phosphor Bronze (T2M) 50 µ" (1.27 µm) Ni CURRENT RATING MAX. CYCLES 3.8 A (T2M) 100 with 10 µ" 2.6 A (S2M) (0.25 µm) Au (2 pins powered) VOLTAGE LEAD-FREE RATING SOLDERABLE 350 VAC Yes samtec.com/2mm-TigerEye Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. (2.00 mm) .0787" PITCH • HIGH-RELIABILITY CABLE INTERCONNECTS SERIES - NO. OF POSITIONS 1 S2M 05, 07, 10, 15, 20, 25, 30 Socket (Per Row) - - LEAD STYLE PLATING OPTION –01 - D - –F = Through-hole –02 Leave blank for tube packaging = (5.50 mm) .217" DIA Polyimide film Pick & Place Pad (–02 only) –L –TR = Tape & Reel (–02 only) –LC = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail –FR = Locking Clip (Manual placement required) (–02 only) = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) (–02 only) –DS = Screw Down (N/A with –LC) (mates with –T2M–DS) S2M Board Mates: T2M Cable Mates: T2SD PACKAGING –K = Gold flash on contact, Matte Tin on tail = Surface Mount - OPTIONS No. of positions x (2.00) .0787 + (0.35) .014 (4.25) .167 (4.52) .178 (4.65) .183 (6.30) .248 –TH –LC –SM View complete specifications at: samtec.com?S2M SERIES - T2M Header NO. OF POSITIONS 1 05, 07, 10, 15, 20, 25, 30 (Per Row) - 01 - PLATING OPTION -D- - No. of positions x (2.00) .0787 + (14.38) .566 (6.00) .236 TAIL OPTION –L –TH = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail = Surface Mount MATED HEIGHT –TR = Tape & Reel (–SM only) –DS = Screw Down (N/A with –RA) (mates with –S2M–DS, S2SD/S2SDT –SS/–DS option) –K –FR = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) (–SM only) No. of positions x (2.00) .0787 + (14.38) .566 (3.98) .157 (7.44) .293 60 70 Leave blank for tube packaging .335 = (7.50 mm) .295" DIA Polyimide film Pick & Place Pad (–SM only) No. of positions x (2.00) .0787 + (5.67) .223 PACKAGING = Weld Tab (S2SD & S2SDT, –SR/–DR required mate) (8.50) –RA –SM Board Mates: S2M Cable Mates: S2SD, S2SDT - –WT = Throughhole = Right-angle T2M OTHER OPTIONS –DS 60  PP  7+  PP  (8.76) .345 Notes: Severe Environment Testing qualified; aligns with MIL-DTL-55302. Visit samtec.com/set Some lengths, styles and options are non-standard, non-returnable. (8.63) .340 –TH–WT –SM–WT –RA–WT View complete specifications at: samtec.com?T2M samtec.com/2mm-TigerEye Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-224
S2M-120-02-S-D-LC-K-TR 价格&库存
很抱歉,暂时无法提供与“S2M-120-02-S-D-LC-K-TR”相匹配的价格&库存,您可以联系我们找货
