SURFACE MOUNT
.025" SQ POST SOCKET 8
G b p s
(2.54 mm) .100" PITCH • SSW SERIES
SSW
Mates:
TSW, MTSW, HTSW,
HMTSW, MTLW, EW, ZW,
TSS, HTSS, ZSS, TSM,
TSSH, DW, HW
SSW
-1
NO. PINS
PER ROW
22
02 thru 36
SPECIFICATIONS
PLATING
OPTION
–F
= Gold flash
on contact,
Matte Tin on tail
–L
= 10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
Insulator Material:
Black LCP
Contact Material:
Phosphor Bronze
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Current Rating (SSW/TSM):
4.7 A per pin
(2 pins powered)
Operating Temp Range:
-55 °C to +125 °C with Gold
-55 °C to +105 °C with Tin
Insertion Depth:
(3.68 mm) .145" to
(6.35 mm) .250"
Max Cycles:
100 with 10 µ" (0.25 µm) Au
Voltage Rating:
465 VAC / 655 VDC
ROW
OPTION
VS
OTHER
OPTION
–S
–“XX”
= Single
Row
= Polarized
Position
–K
–D
= –S: (3.50 mm)
.138" DIA,
–D: (6.50 mm)
.256" DIA
Polyimide film
Pick & Place Pad
(03 positions min.)
= Double
Row
–G
= 20 µ" (0.51 µm)
Gold on contact,
Gold flash on tail
–P
= Pick & Place Pad
(05 positions min.)
–TR
= Tape & Reel
(–02 thru –28)
–FR
= Full Reel
Tape & Reel
(must order max.
quantity per reel;
contact Samtec
for quantity
breaks)
(–02 thru –28)
PROCESSING
Lead–Free Solderable:
Yes
SMT Lead Coplanarity:
(0.10 mm) .004" max
[1RRI3RVLWLRQV
ALSO AVAILABLE
—P OPTION
MOQ Required
Other platings
Notch option
—S
—D
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
samtec.com?SSW
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
F-224
很抱歉,暂时无法提供与“SSW-136-01-F-D”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 4+60.61220
- 10+59.31846
- 25+58.12145
- 50+56.06598
- 100+41.83487
- 500+36.34556
- 1000+27.60376
- 2000+23.91601
