TCMD-12-T-20.00-01-N 数据手册
F-215
TCMD–08–D–02.50–01–R
UUUUUUUUUUUUUUUUUUU
TCMD–20–D–02.50–01
(2,00 mm) .0787"
TCMD SERIES
HIGH RELIABILITY IDC HEADER CABLE
Mates with:
SMM*, MMS*, ESQT,
PTF, SQT, SQW, TLE
TYPE
STRIP
END
OPTION
NO. PINS
PER ROW
OVERALL
LENGTH
OTHER
OPTION
TRANSFER
OPTION
01
SPECIFICATIONS
For complete specifications
see www.samtec.com?TCMD
Insulator Material:
Black Glass Filled Polyester
Terminal:
Phosphor Bronze
Plating:
Au or Sn over
50µ" (1,27 µm) Ni
Wire:
28 AWG 7/36 Stranded,
Tinned, Copper with
Gray PVC Insulator
Operating Temp Range:
-40°C to +105°C
RoHS Compliant:
Yes
–“XX.XX”
–04, –05,
–06, –07,
–08, –10, –12,
–13, –15, –17,
–20, –22, –25
= Assembled Length
Leave blank for –S and –D
End Options. For –T End
Option Specify “–N”
(Socket has notch polarization)
Assembled Length
in INCHES (±1/8")
2 inches minimum
(Standard sizes)
• Strain relief option
–SR
–P “XX”
–S = Single End
RECOGNITIONS
–D = Double End
For complete scope
of recognitions see
www.samtec.com/quality
= Position Polarization
01
= Strain Relief
No. of positions x
(2,00) .0787 + (7,874) .3100
02
Not available with –O, –M,
–R, –DXX or –BXX
Specify “XX” as position
number. Requires
Transfer End. Only
Socket is polarized.
1
–T=Transfer End
ALSO AVAILABLE
(MOQ Required)
• Other sizes
Contact Samtec.
–D “XX”
= Daisy Chain
2"
min.
“XX”
± 1/8"
Double
Row
Connectors
–B “XX”
= Breakout
Specify “XX” as number of
conductors to be broken out.
4" minimum
Outer
Most
(End of
assembly)
4
–R
TCMD =Terminal Strip
= Reversed
“XX”
5"max.
2"min.
01
Breakout starts with Number 1
lead indicated by brown wire or
red stripe. Shown on top side.
(4,00)
.158
5
2
–M
= Middle Reverse
–RW
No. of positions x (2,00) .0787
+ (4,00) .158
= Reverse Wiring
(1,00)
.03937
Requires –DXX
*Note: Standard TCMD callout
will not mate with SMM, MMS.
Must use gold plated callouts.
(See drawing on web.)
When mated with a socket,
Wire 1 mates with Pin 2;
Wire 2 mates with Pin 1, etc.
(5,08)
.200
5
–O
= Outside Reverse
01
(3,05)
.120
02
(0,50)
.020
SQ
(2,00)
.0787
(2,00)
.0787
Blue or black wire
opposite position #1.
Note: TCMD Series
assemblies are non-standard,
non-returnable.
Requires –DXX
3
WWW.SAMTEC.COM
Due to technical progress, all designs, specifications and components are subject to change without notice.
5
TCMD-12-T-20.00-01-N 价格&库存
很抱歉,暂时无法提供与“TCMD-12-T-20.00-01-N”相匹配的价格&库存,您可以联系我们找货
