F-224 WEB
TD–108–G–AA
HTS–115–T–C–2
TS–119–G–A–1
(2.54 mm) .100"
TS, TD, HTS SERIES
PRECISION MACHINED TERMINAL STRIPS
SPECIFICATIONS
For complete specifications
see www.samtec.com?TS,
www.samtec.com?TD or
www.samtec.com?HTS
Insulator Material:
Black G.F. Polyester (TS, TD)
Black Liquid Crystal Polymer
(HTS)
Terminal Material:
Brass, except Style G is
Phosphor Bronze
Plating:
Au over 50 µ" (1.27 µm) Ni or
Sn over 100 µ" (2.54 µm) Cu
or 50 µ" (1.27 µm) Ni
Operating Temp Range:
-55 °C to +125 °C with Gold
-55 °C to +105 °C with Tin
RoHS Compliant:
Yes
Lead-Free Solderable:
HTS: Yes
TS, TD: No, Lead Wave Only
Mates with:
SS, SD, HSS, SL,
SDL, ESS, ESD
TYPE
STRIP
PLATING
OPTION
NO. PINS
PER ROW
TS
= Single
Row Terminal
Strip
HTS
= Single Row
High Temp
Terminal Strip
= 20 µ" (0.51 µm Gold
Except –J & –L are
10 µ" (0.25 µm) Gold
(2.54) .100 x No. of Positions
(2.54)
.100
—T
(2.54)
.100 TYP
= Tin
(2.54)
.100
01 thru 32
=TS Series
(5.08)
.200
TD
= Double Row
Terminal Strip
01 thru 36
(2.54)
.100
= HTS & TD Series
(2.54)
.100 TYP
(2.54)
.100
Note:
Some lengths, styles and options
are non-standard, non-returnable.
FILE NO. E111594
—AA
(0.46)
.018
DIA
(1.78)
.070
DIA
(0.46)
.018
DIA
(4.22)
.166
—A, —A—1, —A–2
(0.64)
.025
DIA
(1.32)
.052
(1.32)
.052
Component No. = T-1R5-
Y
X
(1.78)
.070 DIA
(0.51)
.020
(1.32)
.052 DIA
(0.46)
.018 DIA
(4.75)
.187
(1.83)
.072
DIA
Y
(DIA) (±.015)
—A
—A–1
(0.64)
.025 (5.33)
(0.89) .210
.035
(3.18)
.125
± .010
—C
X
X
Y
(DIA) (±.015)
(0.46) (3.96)
.018 .156
—C—1 (0.64)
.025
(5.33)
.210
—C—2 (0.89)
.035
Y
-C Component No. =T-1R2-C-X Component No. =T-1R9-
—L–1, —L—2, —L–3
(1.07)
.042
DIA
(3.81)
.150
(7.62)
.300
± .015
LEAD
STYLE
(2.54)
.100
—J
(1.83)
.072
DIA
(0.89)
.035
(3.99)
.157
-A Component No. =T-1R0-A-X Component No. =T-1R7
(4.47)
.176
(12.90)
(1.02) .508
.040 ± .015
X
—C, —C—1, —C–2
(0.46) (3.96)
.018 .156
—A–2
—G—1
(0.51)
.020 DIA
LEAD
STYLE
(4.22)
.166
(1.78)
.070
DIA
(3.96)
.156
±.015
LEAD
STYLE
—G
RECOGNITIONS
For complete scope
of recognitions see
www.samtec.com/quality
1
(1.32)
.052 DIA
(0.51)
.020 DIA
Component No. = S-1P1-
(1.07)
.042
(1.83)
.072 DIA
(0.76)
.030
(1.32)
.052
DIA
(0.64)
.025
SQ
Z
Y
LEAD
STYLE
X
Y
(DIA)
(±.015)
—L—1
(12.95)
.510
(17.86)
.703
—L–—2
(9.14)
.360
(14.05)
.553
—L—3
(6.60)
.260
(11.51)
.453
Component No. = S-1W1
WWW.SAMTEC.COM
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
很抱歉,暂时无法提供与“TD-122-G-K”相匹配的价格&库存,您可以联系我们找货
