TSDF-50-D-S-L
TSDF-50-D-S-L
    SAMTEC(申泰)
    DISCRETE WIRE HOUSINGS CONTACTS
TSDF-50-D-S-L 数据手册
(1.27 mm) .050" PITCH • DISCRETE WIRE ASSEMBLY/COMPONENTS - SERIES - POSITIONS PER ROW SFSS –03, –04, –05, –07, –10, –15, –20, –25, –40, –50 = Single Row PVC Cable SFSST –28 –28C = Color Coded Cable (SFSS only) SFSS(T) Board Mates: TFM, TFC (–SR & –DR requires –WT option) SPECIFICATIONS Insulator Material: Black LCP Contact Material: BeCu Plating: Au over 50 µ" (1.27 µm) Ni Current Rating: 2.9 A per pin (2 pins powered) Operating Temp Range: -10 °C to +80 °C (PVC) -40 °C to +125 °C (*Teflon™ Fluoropolymer) Voltage Rating: 275 VAC (PVC) 235 VAC (*Teflon™ Fluoropolymer) Wire: 28 or 30 AWG COLOR 1 2 3 4 5 6 7 8 9 10 ETC BROWN RED ORANGE YELLOW GREEN VIOLET GRAY WHITE BLACK BLUE REPEAT - ASSEMBLED LENGTH - –S = Assembled Length in Inches (76.20 mm) 03.00" min. for –S end option (82.60 mm) 03.25" min. for –D end option = 30 AWG = Single Ended –D = Double Ended –SR = Single Ended Retention Latch (TFM-WT option required for mating) No. of Positions x (1.27) .050 + (0.53) .021 –DR End 1 Notch (Always Up) - (5.08) .200 –D–NUS –SR –03, –04, –05, –07, –10, –15, –20, –25, –40, –50 –NUS = Notch up, straight (Pin 1 to Pin N) –NDS = Notch down, straight (Pin 1 to Pin 1) *Teflon™ is a trademark of The Chemours Company FC, LLC used under license by Samtec. End 2 notch location determined by part number - Requires –D or –DR (End 1 Notch Up) (11.18) .440 Assembled Length ± (3.18) .125 POSITIONS PER ROW END 2 OPTION = Double Ended Retention Latch (TFM-WT option required for mating) Notes: Teflon™ Fluoropolymer cable is intended for crimp only. Contact Samtec for solderable cable applications. SFSS OR SFSST For wiring option information refer to drawings on web. View complete specifications at: samtec.com?SFSS & samtec.com?SFSST ISDF - END OPTION –“XX.XX” = 10 µ" (0.25 µm) Gold on contact, Gold Flash on balance –30 –28C CABLE COLOR CODING PIN PLATING OPTION –G = 28 AWG (Standard sizes) = Single Row Blue *Teflon™ Fluoropolymer Cable - WIRE GAUGE - ROW OPTION –S –M = Single Row = Metal Retention Latch (Standard sizes) SERIES OPTION CC03R = Contact, Full Reel (35,000 Parts per Reel) - WIRE GAUGE - 01 - –2830 –GF = 28 to 30 AWG CC03M = Gold flash contact –G = Contact, Mini Reel (1,000 - 5,000 Parts per Reel) No. of Positions x (1.27) .050 + (0.53) .021 PLATING = 10 µ" (0.25 µm) Gold on contact (5.08) .200 (15.37) .605 (11.18) .440 (3.81) .150 (6.32) .249 –S –M TOOLING Hand Tool: CAT-HT-203-2830-12 Mini Applicator: CAT-MC-203-2830-XX-01 Clamp for mounting hand tool: CAT-HT-MNT-01 Extraction Tool: CAT-EX-169-01 Note: Some lengths, styles and options are non-standard, non-returnable. F-224 View complete specifications at: samtec.com?ISDF, samtec.com?CC03R & samtec.com?CC03M samtec.com/127mm-TigerEye Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
TSDF-50-D-S-L 价格&库存
很抱歉,暂时无法提供与“TSDF-50-D-S-L”相匹配的价格&库存,您可以联系我们找货
