TSW-216-16-T-S-RE
TSW-216-16-T-S-RE
    SAMTEC(申泰)
TSW-216-16-T-S-RE 数据手册
F-214 HTSW–116–11–G–S TSW–209–09–F–S–RA HTSW–115–05–L–Q (2,54 mm) .100" THROUGH-HOLE .025" SQ POST HEADER Mates with: SSW, SSQ, SSM, ESW, ESQ, BCS, BSW, CES, SLW, IDSD, IDSS, SMSD, SMSS SPECIFICATIONS For complete specifications see www.samtec.com?TSW or www.samtec.com?TSW Insulator Material: TSW: Black Glass Filled Polyester HTSW: Natural Liquid Crystal Polymer Terminal Material: Phosphor Bronze Plating: Au or Sn over 50µ" (1,27 µm) Ni Operating Temp Range: -55°C to +125°C with Gold -55°C to +105°C with Tin Voltage Rating: 550 VAC mated with SSW; 500 VAC mated with BCS or ESQ; 450 VAC -RA/-RE mated with BCS or SSM 400 VAC mated with CES RoHS Compliant: Yes Lead–Free Solderable: Wave Only TYPE STRIP (2,54) .100 50 02 (2,54) .100 100 (2,54) (5,02) .100 .198 (5,08) (7,56) .200 .298 01 03 (5,08) (7,56) .200 .298 (7,62) .300 01 TSW FILE NO: 090871_0_000 BCS TSW HORIZONTAL 148 (3,09) (1,78) .122 .070 –S 01 100 50 (2,54) .100 (6,10) .240 (1,78) .070 (5,56) .219 (1,78) .070 (8,12) .320 01 99 03 150 (2,54) .100 ALSO AVAILABLE (MOQ Required) –D (8,10) .319 –T (1,78) .070 01 148 03 150 (5,08) .200 (8,12) .320 (8,10) .319 (1,78) .070 01 TSW HTSW 02 thru 25 = .200" (5,08 mm) Center Version (5,08) .200 (1,78) .070 Note: Some lengths, styles and options are non-standard, non-returnable. 01 thru 50 = .100" (2,54 mm) Center Version (2,54) .100 (3,02) .119 (1,78) .070 (1,78) .070 • Other platings Contact Samtec. –Q HTSW 02 APPLICATIONS –T 148 150 (2,54) .100 x No. of Positions Right Angle Versions –D 99 150 (2,54) (7,62) .100 .300 1 POSITION POWERED PER ROW –S 01 01 03 ESW SSW SLW SSQ SSM BCS SNT (2,54) .100 (2,48) .098 (5,08) .200 5.2 A 5.7 A 5.2 A 6.3 A 5.2 A 4.6 A 4.3 A For complete scope of recognitions see www.samtec.com/quality (5,08) .200 (2,54) .100 (2,54) .100 x No. of Positions Straight Pin Versions (5,08 mm) Centers, – 2 = .200" Every Other Position Filled = Hi-Temp Strip CURRENT RATING (PER PIN) TSW mated with RECOGNITIONS (2,54 mm) Centers, –1 = .100" All Positions Filled TSW = Standard Strip HTSW NO. PINS PER ROW PIN CENTERS 148 WWW.SAMTEC.COM –Q TSW–109–10–F–D–RA TSW–114–16–G–S–RE HTSW–120–13–T–D TSW–112–07–G–T TSW, HTSW SERIES PLATING OPTION LEAD STYLE ROW OPTION OTHER OPTIONS –S –F –L –NA = Right Angle (using straight body for coplanar mating with SSW-RA series) = Double Row –G = 10µ" (0,25 µm) Gold on post, Gold flash on balance –T –T = Triple Row = Locking Clip (Styles –08 thru –13 & –22 only) = Right Angle –D = 10µ" (0,25 µm) Gold on post, Matte Tin on tail –LC – RA or –RE = Single Row = Gold flash on post, Matte Tin on tail IDSS or IDSD STRIP ASSEMBLY LOCKING CLIP .025" SQ TERMINAL STRIP (TSW) PC BOARD Requires 4 pin minimum (NA with -T,-Q,-RA or -RE) (1,27) .050 = Matte Tin Straight Pin Versions * * * * A B C STYLE – 05 (3,30) .130 (2,41) .095 (2,54) .100 (5,08) .200 (10,16) .400 (12,70) .500 (15,24) .600 (17,78) .700 (22,86) .900 (8,51) .335 (7,62) .300 (10,92) .430 (13,46) .530 (18,54) .730 (21,08) .830 (23,62) .930 (26,16) 1.030 (31,24) 1.230 (13,46) .530 (2,67) .105 (2,67) .105 –18 – 06 – 07 – 08 – 09 –10 –11 –12 –13 –14 * * * –15 –16 –17 (2,79) .110 (7,87) .310 (2,79) .110 (18,54) .730 (21,08) .830 * * * * * * * * ▲ (5,84) .230 (8,13) .320 (13,21) .520 (8,13) .320 (15,74) .620 –19 – 20 – 21 – 22 – 24 – 25 – 26 – 27 – 28 – 29 – 30 + + * Available with – LL (Locking Lead) Option (0,64) .025 SQ Post (7,62) .300 – 23 – 41 – 42 (2,92) .115 (5,33) .210 (3,20) .126 (25,40) 1.000 (20,32) .800 (23,11) .910 (18,03) .710 (0,89) .035 (1,27) .050 B C (23,62) .930 (26,16) 1.030 (31,24) 1.230 (36,32) 1.430 (16,00) .630 (11,30) .445 (12,15) .480 (16,00) .630 (11,58) .456 (33,78) 1.330 (28,70) 1.130 (33,78) 1.330 (28,70) 1.130 (9,27) .365 (11,94) .470 (18,29) .720 (20,83) .820 (25,91) 1.020 (30,99) 1.220 – 08 – 09 –10 –11 (5,84) .230 (6,73) .265 (8,13) .320 (5,84) .230 (8,13) .320 (5,84) .230 (8,13) .320 SINGLE (– S) –RA LEAD STYLE –12 –13 * * * –16 – 21 – 22 – 25 – 27 – 28 – 29 – 30 A (2,29) .090 (7,37) .290 (9,91) .390 (12,45) .490 (14,99) .590 (20,07) .790 (5,08) .200 (25,15) .990 (4,83) .190 (2,54) .100 (22,61) .890 (17,53) .690 (20,32) .800 (15,24) .600 DOUBLE (– D) TRIPLE (–T & – Q) A A (2,29) .090 (7,37) .290 (9,91) .390 (12,45) .490 (14,99) .590 (20,07) .790 (5,08) .200 (2,29) .090 (7,37) .290 (9,91) .390 (12,45) .490 (14,99) .590 C (5,84) .230 (8,13) .320 (5,84) .230 (8,13) .320 (5,84) .230 (8,13) .320 with HTSW only. B (2,54) .100 A (0,64) .025 SQ Tail ▲ Specify -07 for best mate with IDXX Series IDC Cable LEAD STYLE B – RA (1,52) .060 – RE (4,06) .160 WWW.SAMTEC.COM – 09 (4,83) .190 (7,37) .290 (9,91) .390 (12,45) .490 (17,53) .690 (2,54) .100 (22,61) .890 (2,29) .090 (20,07) .790 (14,99) .590 –10 –11 –12 –13 –16 – 21 N/A N/A – 22 (4,83) .190 (2,54) .100 (4,83) .190 (2,54) .100 – 27 – 28 N/A A C (5,84) .230 (8,13) .320 (5,84) .230 *Available with – LA (Locking Lead) Option (17,53) .690 N/A N/A (15,24) .600 A (0,46) .018 DIA Tail SINGLE (5,08) .200 C ▲Except: Style –26 – RE LEAD STYLE N/A + Style –41 & –42 available C –“XXX” = Polarized Position (Specify “LEAD STYLE” from chart and select –RA or –RE from other options) A (2,79) .110 Two leads per strip crimped in opposite directions on or near centerline. See charts for available styles. N/A with single row 1 or 2 positions. Recommended hole size (1,02 mm ± 0,03 mm) .040" ± .001" Right Angle Versions (Specify “LEAD STYLE” from chart) STYLE = –RA Option with –LL Option = Locking Lead = Double Row (5,08 mm) .200" row space • Elevated Right Angle option • Shunts Contact Samtec –LA –LL –Q OTHER SOLUTIONS (1,78) .070 C A (2,54) .100 B (2,54) .100 (2,54) .100
TSW-216-16-T-S-RE 价格&库存
很抱歉,暂时无法提供与“TSW-216-16-T-S-RE”相匹配的价格&库存,您可以联系我们找货
