TW-05-08-G-D-585-120
    SAMTEC(申泰)
    CONN BRD STACK 2.00 10POS
TW-05-08-G-D-585-120 数据手册
F-218 (Rev 10OCT17) TW–08–09–F–T–165–100 TW–16–06–T–D–500–100 (2.00 mm) .0787" TW SERIES TW–20–03–L–Q–400–085 THROUGH-HOLE BOARD STACKERS SPECIFICATIONS For complete specifications see www.samtec.com?TW-TH Insulator Material: Black Liquid Crystal Polymer Terminal Material: Phosphor Bronze Plating: Sn or Au over 50 µ" (1.27 µm) Ni Current Rating: 5.2 A per pin (2 pins powered) Operating Temp Range: -55 °C to +105 °C with Tin; -55 °C to +125 °C with Gold RoHS Compliant: Yes Lead–Free Solderable: Yes Board Mates: CLT, SQT, SQW, ESQT, TLE, SMM, MMS Cable Mates: TCSD OTHER SOLUTIONS Choice of one through six rows Paste In Hole (PIH) processing. Contact Samtec ASP Group. ALSO AVAILABLE RECOGNITIONS (2.00 mm) .0787 pitch (MOQ Required) For complete scope of recognitions see www.samtec.com/quality FILE NO. E111594 Specify stacker height in (0.13 mm) .005" increments • Other platings Contact Samtec. Notes: For added mechanical stability, Samtec recommends mechanical board spacers be used in applications with gold or selective gold plated connectors. Contact ipg@samtec.com for more information. LEAD STYLE NO. PINS PER ROW TW 02 thru 50 This Series is non-standard, non-returnable. Other Solutions PLATING OPTION –F Specify LEAD STYLE from chart below. = Gold flash on post, Matte Tin on tail –L = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail 2 mm Shunt See 2SN Series. Surface Mount See previous page. (2.00) .0787 TYP Shrouded Double Row See ZLTMM Series. No. of rows x (2.00) .0787 01 –S, –D*, –Q See TMM Series. See TMM Series. = Matte Tin 04 Low Profile Rightangle –T 300 ROW OPTION STACKER HEIGHT –S –“XXX” = Single Row = Double Row –T = Triple Row –“XXX” –Q LEAD STYLE = Four Row –5 = Five Row –6 = Six Row * POST STACKER (1.27) HEIGHT See OAL .050 MIN Chart TAIL (2.00) .0787 (0.00) .000 MIN –S, –D*, –Q –T, –5, –6 * ROW OPTION –S, –D*, & –Q –T, –5, –6 –01 –02 –03 –04 –05 –06 –07 –08 –09 –10 –11 –12 OAL (8.20) .323 (9.60) .377 = Polarized Position (Specify position to be removed) (13.60) .535 (14.10) .555 (15.10) .594 (17.10) .673 (19.10) .751 (21.10) .830 (11.60) .456 (15.60) .614 (10.08) .397 (28.19) 1.110 * Style –08 & –12 = S & D only STACKER HEIGHT (3.05) .120 MIN (4.06) .160 MIN * –D with stacker height greater than (4.06 mm) .160" will not have standoffs. Due to technical progress, all designs, specifications and components are subject to change without notice. WWW.SAMTEC.COM –“XXX” = Tail Length in inches (0.13 mm) .005" increments Example: -150 Example: –250 = (3.81 mm) = (6.35 mm) .150" .250" –D –T, –5, –6 295 (0.51) .020 SQ = Stacker Height in inches (0.13 mm) .005" increments TAIL SPEC All parts within this catalog are built to Samtec’s specifications. Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
TW-05-08-G-D-585-120 价格&库存
很抱歉,暂时无法提供与“TW-05-08-G-D-585-120”相匹配的价格&库存,您可以联系我们找货
  • 1+25.900401+3.29880
  • 50+22.1337050+2.81900
  • 100+20.61770100+2.62590
  • 500+19.18330500+2.44320
  • 1000+17.294201000+2.20260
  • 2000+15.591602000+1.98580
  • 5000+13.807305000+1.75850
库存:11
