2060-402/998-404
2060-402/998-404
    WAGO(万可电子)
    SMD
    带推钮的SMD端子排,采用卷带包装;2极;引脚间距4毫米/0.157英寸
2060-402/998-404 数据手册
Printview: SMD terminal block with push-buttons in tape-and-reel packing; 2-pole; Pin spacing 4 mm / 0.157 in - Item No.: 2060-402/998-404 . SMD terminal block with push-buttons in tape-and-reel packing; 2pole; Pin spacing 4 mm / 0.157 in Item No.: 2060-402/998-404 . SMD terminal block with push-buttons in tape-and-reel packing; 2-pole; Pin spacing 4 mm / 0.157 in . Marking . Business data Supplier WAGO Item no. 2060-402/998-404 GTIN / EAN 4050821377863 Content 1 Order amount 1,000 Customer item number . Notes SMD terminal blocks with Push-in CAGE CLAMP® and push-buttonsHeight of just 4.5 mm minimizes on-board LED shadowingAvailable in tape-and-reel packaging for automated assemblyFor new designs please only use the new white version of 2060 series! CLICK HERE! Technical data Miscellaneous No. of poles 2 Pin Spacing 4 mm (0.157 in %) Total number of connection points 2 Total number of potentials 2 Color white Ratings according to 1 IEC/EN 60664-1 Overvoltage category EN 1 III WAGO Kontakttechnik GmbH & Co. KG 1 Printview: SMD terminal block with push-buttons in tape-and-reel packing; 2-pole; Pin spacing 4 mm / 0.157 in - Item No.: 2060-402/998-404 Technical data Pollution degree (1) 2 Rated voltage EN (1) [V] 160 [V] Rated surge voltage (1) [kV] 2.5 [kV] Nominal current [A] 9 [A] Overvoltage category EN 2 II Degree of pollution (2) 2 Rated voltage EN (2) [V] 320 [V] Rated surge voltage (2) [kV] 2.5 [kV] Nominal current (2) [A] 9 [A] Overvoltage category EN 3 III Degree of pollution (3) 3 Rated voltage EN (3) [V] 63 [V] Rated surge voltage (3) [kV] 2.5 [kV] Nominal current (3) [A] 9 [A] Number of individual connection objects at the product 1 Connection technology (1) Push-in CAGE CLAMP® Solid sizes 1 0.2 … 0.75 mm² / 24 … 18 AWG Fine-stranded wires 1 0.2 … 0.75 mm² / 24 … 18 AWG Fine-stranded wires with insulated ferrule 1 0.25 … 0.34 mm² / … Fine-stranded wires with uninsulated ferrule 1 0.25 … 0.34 mm² / … Strip length 1 6 … 7 mm / 0.24 … 0.28 in Solder pad dimensions [mm] 6 x 2 [mm] Spulendurchmesser der Gurtverpackung [mm] 330 [mm] Gurtbreite [mm] 24 [mm] Material group I Insulating material Polyphtalamid (PPA GF) Flammability rating per UL 94 V0 Limit temperature range -60 C … 105 C Contact material Copper alloy Contact plating tin-plated Weight [g] 0.88 [g] Width 7.9 mm / 0.311 in Height 4.5 mm / 0.177 in Length 13.1 mm / 0.516 in WAGO Kontakttechnik GmbH & Co. KG 2 Printview: SMD terminal block with push-buttons in tape-and-reel packing; 2-pole; Pin spacing 4 mm / 0.157 in - Item No.: 2060-402/998-404 Images & drawings WAGO Kontakttechnik GmbH & Co. KG 3 Printview: SMD terminal block with push-buttons in tape-and-reel packing; 2-pole; Pin spacing 4 mm / 0.157 in - Item No.: 2060-402/998-404 WAGO Kontakttechnik GmbH & Co. KG 4 Printview: SMD terminal block with push-buttons in tape-and-reel packing; 2-pole; Pin spacing 4 mm / 0.157 in - Item No.: 2060-402/998-404 . Address WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Telefon: 0571/887-0 Fax: 0571/887-169 http://www.wago.com © WAGO Kontakttechnik GmbH & Co. KG Technische Änderungen und Irrtümer vorbehalten. WAGO Kontakttechnik GmbH & Co. KG 5
2060-402/998-404 价格&库存
很抱歉,暂时无法提供与“2060-402/998-404”相匹配的价格&库存,您可以联系我们找货
