733-333
733-333
    WAGO(万可电子)
    插件,P=2.5mm
    接线端子 间距:2.50mm 1x3P 直插
733-333 数据手册
Data sheet from 27.01.2009 Item no.: 733-333 Product description: HEADER; STRAIGHT SOLDER PIN0.8x0.8 MM; 3 POLE; PIN SPACING 2.5 MM / 0.098 IN; 100% PROTECTED AGAINST MISMATING; MATING DIRECTION PERPENDICULAR TO PCB Packing unit 200 pieces Product group 3 (Multi Conn. System) Pin spacing from 2,5 mm Pin spacing from 0,098 in pole count 3 Measured voltage EN 250 V Measured shock voltage 2,5 kV Pollution degree 2 Current intensity EN 4A Weight 0,517 g Color light grey Height 8,9 mm Height 0,35 in Width 10 mm Width 0,394 in Depth 7,8 mm Depth 0,307 in 1 von 2 Data sheet from 27.01.2009 Item number Admission office Approval no. Voltage [V] Current [A] 733-333 ABS 04-HG469925-PDA 250 4 733-333 BV 11915/A0 250 4 733-333 CSA 154112-1465035 150 4 733-333 DNV E-6997 250 4 733-333 GL 17296-00HH 250 4 733-333 KEMA 2077592.01 250 4 733-333 LR 96/20035 250 6 733-333 RMR 11130002 250 4 733-333 UR E45171 250 4 733-333 UR E45172 150 4 Sorting criteria: admission office - approval number © WAGO Kontakttechnik GmbH & Co. KG Specifications are subject to changes and errors may be expected 2 von 2 Cross section [ mm² ] 28-20 28-20
733-333 价格&库存
很抱歉,暂时无法提供与“733-333”相匹配的价格&库存,您可以联系我们找货
    • 500+2.71610
    库存:1289
    733-333
    库存:192
    733-333
    • 1+5.16460
    • 10+4.07680
    库存:18
