ESQT-111-03-M-D-355
ESQT-111-03-M-D-355
    SAMTEC(申泰)
    插件,P=2mm
    排母 间距:2mm 2x11P 直插
ESQT-111-03-M-D-355 数据手册
ESQT–125–02–L–Q–465 F-218 (Rev 10OCT17) ESQT–115–02–GF–D–600 ESQT–125–03–M–Q–310 (2.00 mm) .0787" ESQT SERIES FLEXIBLE ELEVATED SOCKET STRIPS SPECIFICATIONS For complete specifications see www.samtec.com?ESQT Insulator Material: Black Liquid Crystal Polymer Contact Material: Phosphor Bronze Plating: Sn or Au over 50 µ" (1.27 µm) Ni Current Rating (ESQT/TMMH): 4.5 A per pin (2 pins powered) Operating Temp Range: -55 °C to +125 °C Insertion Depth: (2.62 mm) .103" to (5.03 mm) .198" with (0.38 mm) .015" wipe Max Cycles: 100 with 10 µ" (0.25 µm) Au RoHS Compliant: Yes Lead–Free Solderable: Yes, for -S, -D & -Q (Wave only for -T, -5 & -6) RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality High-retention contacts Board Mates: TMMH, TMM, MTMM, MMT, TW, LTMM, ZLTMM, ESQT, PTT, TSH, TMMS Cable Mates: TCMD APPLICATION SPECIFIC OPTION: NOTEBOOK 2.5" DISK DRIVE INTERFACE (2.00 mm) .0787" pitch Call for part number. ESQT 1 NO. PINS PER ROW LEAD STYLE Specify LEAD STYLE from chart FILE NO. E111594 02 thru 50 Note: This Series is non-standard, non-returnable. Surface Mount 300 No. of positions x (2.00) .0787 + (0.30) .012 OTHER OPTION –F = Single Row –S –“XXX” –“XXX” –L = Double Row = Gold flash on contact, Matte Tin on tail (2.00) No. of .0787 rows TYP x (2.00) .0787 295 –D –T = Triple Row –Q = 20 µ" (0.51 µm) Gold on contact, Matte Tin on tail 06 See CLT Series. 01 See SMM Series. = Quad Row –GF See SQW Series. (1.52) .060 PC/104-PlusTM Sockets (0.50) .020 SQ A BODY HEIGHT = Body Height (in inches) (7.87 mm) .310" minimum for –S, –D, –Q (9.53 mm) .375" minimum for –T, –5, –6 = Five Row –6 = Six Row TAIL (1.27) .050 MIN (2.00) .0787 Paste In Hole (PIH) processing. Contact Samtec ASP Group. (Not recommended for stack through applications) MAX MAX BODY TAIL HEIGHT (13.72) (20.32) – 02 (21.59) .850 .540 .800 (11.63) (3.76) (10.36) –03 .458 .148 .408 LEAD STYLE A Due to technical progress, all designs, specifications and components are subject to change without notice. WWW.SAMTEC.COM = Polarized Position (Indicate position number) OTHER SOLUTIONS –5 = 15 µ" (0.38 µm) Gold on contact, Gold flash on tail (Recommended for self-nesting) (–02 lead style only) (6.35) .250 RightAngle See ESQT-368 and PTHF Series. BODY HEIGHT –M Low Profile High Reliability ROW OPTION = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail Other Solutions See SQW and TLE Series. PLATING OPTION All parts within this catalog are built to Samtec’s specifications. Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
ESQT-111-03-M-D-355 价格&库存
很抱歉,暂时无法提供与“ESQT-111-03-M-D-355”相匹配的价格&库存,您可以联系我们找货
