F-218
FHP–17–01–T–S
FHP–12–02–T–S
(3.96 mm) .156"
FHP SERIES
POWER SOCKETS
Surface Mount
or
Through-hole
Mates with:
FWJ, HFWJ, JW
SPECIFICATIONS
For complete specifications and
recommended PCB layouts see
www.samtec.com?FHP
Insulator Material:
Black LCP
Contact Material:
BeCu
Plating:
Sn over 50 µ" (1.27 µm) Ni
Operating Temp Range:
-55 °C to +105 °C
Voltage Rating:
600 VAC/845 VDC
Insertion Depth:
(3.57 mm) .140" to
(8.76 mm) .345" or
pass-through from top
Wiping Distance:
(0.38 mm) .015"
Standard Creepage:
(1.74 mm) .069" (without -LC)
(0.89 mm) .035" (with -LC)
Standard Clearance:
(1.39 mm) .055" (without -LC)
(0.59 mm) .023" (with -LC)
RoHS Compliant:
Yes
PINS
1
2
3
4
24
(8.89 mm)
.350"
FHP/HFWJ
CURRENT RATING
(PER CONTACT)
13.1 A
11.2 A
10.3 A
9.2 A
6.7 A
(3.96 mm)
.156"
pitch
• Three-finger
Power Eye contact
• Locking clip option
NO. OF PINS
PER ROW
FHP
PROCESSING
Lead–Free Solderable:
Yes
SMT Lead Coplanarity:
(0.10 mm) .004" max
LEAD
STYLE
PLATING
OPTION
–01
RECOGNITIONS
–LC
= Throughhole
02 thru 24
For complete scope of
recognitions see
www.samtec.com/quality
= Locking Clip
(Manual
placement
required)
(–02 lead
style only)
–T
= Matte Tin
(1.19)
.047
–02
= Surface
Mount
FILE NO. E111594
–K
(1.01)
.040
CREEPAGE
AND CLEARANCE
No. of Positions x (3.96) .156
(5.08)
.200
(3.96)
.156
Selectively loading
contacts achieves customer
specific creepage and
clearance requirements.
Contact asp@samtec.com
(0.46)
.018
(MOQ Required)
Note: Some lengths, styles
and options are non-standard,
non-returnable.
(0.94)
.037
(1.42)
.056
(2.46)
.097
(9.35)
.368
(1.14)
.045
(7.11)
.280
–02
–01
Due to technical progress, all designs, specifications and components are subject to change without notice.
WWW.SAMTEC.COM
All parts within this catalog are built to Samtec’s specifications.
Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
= (6.50 mm)
.256" DIA
Polyimide
film Pick &
Place Pad
(2-4 positions
require –TR)
(–02 lead
style only)
–TR
–LC
(8.89)
.350
(2.59)
.102
ALSO AVAILABLE
• Alignment pins
Contact Samtec.
OTHER
OPTION
S
= Tape & Reel
Packaging
(Available on
positions 2-18)
–02 lead
style only
很抱歉,暂时无法提供与“FHP-09-02-T-S-K”相匹配的价格&库存,您可以联系我们找货
