LOM-51T-250
LOM-51T-250
    JST
LOM-51T-250 数据手册
TAB-ON TERMINAL 6.35 250 Tab-on type T 3.4 Chamfering L 0.8 E W 8.0 Mating tab Listed E70188 Certified LR20812 Dimensions(mm) Applicable wire Model No. Standard mm2 AWG # Insulation O.D. (mm) 0.3 to 0.75 22 to 18 2.3 to 3.0 Material STO-21-250N Finish W L E 7.7 19.0 7.8 Mating T Material tab approx. thickness thickness Q´ty / reel – STO-21T-250N STO-61-250N – 0.75 to 2.0 STO-61T-250N 18 to 14 2.4 Tin-plated 2.8 to 3.8 Brass 0.4 5,000 Tin-plated 0.8 – STO-81-250N 2.0 to 3.5 STO-81T-250N 14 to 12 3.8 to 5.0 1.6 4,000 0.45 8.0 7.6 UL1015#20 + UL1015#20 UL1015#18 + UL1015#20 UL1015#18 + UL1015#18 *STO-62T-250N 19.6 Tin-plated Tin-plated 5,000 19.0 RoHS compliance Note: Terminal denoted by * is used only for two wires. If using wires in other combinations than the ones shown above, contact JST. 250 Tab-on piggyback type T L E W Listed E70188 Certified LR20812 Dimensions(mm) Applicable wire Model No. SFT-61T-250N Standard mm2 AWG # Insulation O.D. (mm) Material Finish 0.75 to 2.0 18 to 14 2.8 to 3.9 Brass Tin-plated W L E 7.6 19.6 8.3 Mating T Material tab approx. thickness thickness 2.9 0.39 0.8 Q´ty / reel 3,000 RoHS compliance 1 TAB-ON TERMINAL 6.35 250 Tab-on flag type T 3.4 Chamfering E L 0.8 W 8.0 Listed E70188 Mating tab Certified LR20812 Dimensions(mm) Applicable wire Model No. Standard SFO-61-250A mm2 0.75 to 2.0 SFO-61T-250A AWG # 18 to 14 Insulation O.D. (mm) Material 2.8 to 3.8 Brass Finish – W L E 8.0 16.1 7.8 T Material Mating tab approx. thickness thickness 3.0 0.45 0.8 Q´ty / reel 3,000 Tin-plated RoHS compliance 5.2 205 Tab-on type T 3.2 6.35 Mating tab thickness L E W Chamfering Mating tab Listed E70188 Certified LR20812 Dimensions(mm) Applicable wire Model No. Standard mm2 AWG # Insulation O.D. (mm) Material Finish W L E 6.4 15.9 6.4 T Material Mating tab approx. thickness thickness Q´ty / reel – STO-21-205N 0.8 Tin-plated STO-21T-205N 0.3 to 0.75 22 to 18 2.3 to 3.0 STO-21-205N-5 Brass STO-21T-205N-5 0.7 0.4 7,500 – 0.5 Tin-plated RoHS compliance 4.75 187 Tab-on flag type T 3.2 6.35 W E Mating tab thickness L Chamfering Mating tab Listed E70188 Certified LR20812 Dimensions(mm) Applicable wire Model No. Standard mm2 AWG # Insulation O.D. (mm) Material SFO-41-187N-8 SFO-41T-187N-8 RoHS compliance 2 W L E 5.6 12.3 6.4 T Material Mating tab approx. thickness thickness Q´ty / reel – SFO-41-187N SFO-41T-187N Finish 0.5 Tin-plated 0.5 to 1.25 20 to 16 2.6 to 3.5 Brass – Tin-plated 1.0 5,000 0.32 0.8 TAB-ON TERMINAL 4.75 187 Tab-on type T 3.2 6.35 Mating tab thickness L E W Chamfering Mating tab Listed E70188 Certified LR20812 Recognized E70188 (AWG#24) Dimensions(mm) Applicable wire Model No. Standard mm2 AWG # Insulation O.D. (mm) Material Finish W L E 5.6 15.0 6.3 Mating T Material tab approx. thickness thickness Q'ty / reel – STO-01-187N STO-01T-187N 0.5 Tin-plated 0.2 to 0.5 24 to 20 1.5 to 2.6 Brass 1.5 0.32 10,000 – STO-01-187N-8 0.8 Tin-plated STO-01T-187N-8 STO-41-187N – 0.5 STO-41T-187N Tin-plated 0.5 to 1.25 20 to 16 2.6 to 3.5 5.6 Brass 15.0 6.3 1.5 0.32 10,000 – STO-41-187N-8 0.8 Tin-plated STO-41T-187N-8 *STO-62T-187N *STO-82T-187N UL1015#20 + UL1015#20 UL1015#18 + UL1015#20 UL1015#18 + UL1015#18 Brass UL1015#18 + UL1015#18 UL1015#18 + UL1015#16 UL1015#16 + UL1015#16 Brass Tin-plated 5.6 19.6 6.4 1.5 4,000 0.32 0.5 Tin-plated 5.6 19.6 6.4 1.5 4,000 0.32 RoHS compliance Note: Terminal denoted by * is used only for two wires. lf using wires in other combinations than the ones shown above, contact JST. 2.8 110 Tab-on type T 5.7 7.3 Chamfering L E Mating tab thickness W Mating tab Listed E70188 Recognized E70188 (AWG#24) Certified LR20812 Dimensions(mm) Applicable wire Model No. Standard mm2 AWG # Insulation O.D. (mm) Material W L E 3.7 15.4 6.3 Q´ty / T Material Mating reel tab approx. thickness thickness – STO-01-110N STO-01T-110N Finish 0.5 Tin-plated 0.2 to 0.5 24 to 20 2.1 to 2.8 STO-01-110N-8 0.6 – 0.8 STO-01T-110N-8 Brass Tin-plated – STO-41-110N 10,000 0.25 0.5 Tin-plated STO-41T-110N 0.5 to 1.25 STO-41-110N-8 20 to 16 2.6 to 3.5 3.7 15.4 6.3 0.6 – 0.8 STO-41T-110N-8 Tin-plated RoHS compliance 3 TAB-ON TERMINAL Crimping machine, Applicator Contact Crimping machine Crimp applicator MK-L STO-21(T)-250N – MK-L STO-61(T)-250N – MK-L STO-81(T)-250N – Applicator Dies Crimp applicator with dies MK/STO-21-250N APLMK STO21-250N – – MK/STO-61-250N APLMK STO61-250N – – MK/STO-81-250N APLMK STO81-250N – – Contact Crimping machine Crimp applicator MK-L STO-01(T)-187N(-8) – MK-L STO-41(T)-187N(-8) – MK-L-187 STO-62T-187N – Applicator Dies Crimp applicator with dies MK/STO-01-187N APLMK STO01-187N – – MK/STO-41-187N APLMK STO41-187N – – MK/STO-62-187N APLMK STO62-187N – – AP-K2N MK-L STO-62(T)-250N MK/STO-62-250N APLMK STO62-250N – – – MKS-L MK/SFT-61-250N APL SFT61-250N – – – MKF-L-250 MK/SFO-61-250A APL SFO61-250A – – – MK-L MK/STO-21-205N APL STO21-205N STO-82(T)-187N MK-L-187 – MK/STO-82-187N APLMK STO82-187N – – AP-K2N SFT-61(T)-250N SFO-61(T)-250A STO-21(T)-205N(-5) SFO-41(T)-187N(-8) – – – MKF-L-187 MK/SFO-41-187N APL SFO41-187N – – – * Compliant with RoHS. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. 4 STO-01(T)-110N(-8) STO-41(T)-110N(-8) MK-L – MK-L – MK/STO-01-110N APLMK STO01-110N – – MK/STO-41-110N APLMK STO41-110N – – TAB-ON-TAB TERMINAL 250 Tab-on tab type L E W Listed E70188 Dimensions(mm) Applicable wire Model No. Standard mm2 AWG # Insulation O.D. (mm) Material 2.6 to 3.8 Brass Finish W L E Material thickness Tab thickness 6.4 20.8 11.6 0.4 0.8 Q´ty / reel – SOM-51-250 0.5 to 2.0 SOM-51T-250 20 to 14 5,000 Tin-plated RoHS compliance 187 Tab-on tab type L E W Listed E70188 Dimensions(mm) Applicable wire Model No. mm2 AWG # Insulation O.D. (mm) 0.3 to 0.75 22 to 18 2.3 to 3.0 Standard Material Brass Finish W L E Material thickness Tab thickness 4.8 17.2 6.4 0.5 0.5 Q´ty / reel – SOM-21-187 SOM-21T-187 Tin-plated 10,000 RoHS compliance Crimping machine, Applicator Contact SOM-51(T)-250 Crimping machine Crimp applicator MK-L Applicator Dies Crimp applicator with dies MK/SOM-51-250 APLMK SOM51-250 AP-K2N – – – Contact SOM-21(T)-187 Crimping machine Crimp applicator MK-L Applicator Dies Crimp applicator with dies MK/SOM-21-187 APLMK SOM21-187 AP-K2N – – – * Compliant with RoHS. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. 5 TAB-IN/TAB-IN-TAB TERMINAL 250 Tab-in type T E W Dimensions(mm) Applicable wire Model No. mm2 AWG # Insulation O.D. (mm) 0.5 to 2.0 20 to 14 2.6 to 3.8 Standard STI-51-250N L STI-51T-250N Material Brass Finish – W L E 7.5 19.2 7.7 Q´ty / reel T Material Mating approx. thickness tab 0.9 0.32 Tin-plated SIM-51 (T)-250N 5,000 RoHS compliance Note: 1. Combine a plated tab-in terminal with a plated tab and a non-plated tab-in terminal with a non-plated tab. 2. This terminal must be built into the model 250 tab-in housing which has numerous circuits, and it cannot be used independently. Model 250 tab-on terminals, however, can be used independently. 3. The above case does not apply when we confirm the condition of application and judge that there is no problem. 110 Tab-in type T L E W Dimensions(mm) Applicable wire Model No. AWG # Insulation O.D. (mm) 0.3 to 0.5 22 to 20 2.1 to 2.8 0.5 to 1.25 20 to 16 2.6 to 3.5 Standard STI-01-110N mm2 Material Finish W L E – STI-01T-110N Brass STI-41-110N Tin-plated SIM-01 (T)-110A 3.7 15.3 6.3 0.7 0.25 – STI-41T-110N Q´ty / reel T Material Mating approx. thickness tab 10,000 SIM-41 (T)-110B Tin-plated RoHS compliance Note: 1. Combine a plated tab-in terminal with a plated tab and a non-plated tab-in terminal with a non-plated tab. 2. This terminal must be built into the model 110 tab-in housing which has numerous circuits, and it cannot be used independently. Model 110 tab-on terminals, however, can be used independently. Crimping machine, Applicator Contact Crimping machine Crimp applicator MK-L STI-51(T)-250N – Applicator Dies Crimp applicator with dies MK/STI-51-250N APLMK STI51-250N – – AP-K2N STI-01(T)-110N 6 MK-L – MK/STI-01-110N APLMK STI01-110N – – Contact STI-41(T)-110N Crimping machine Crimp applicator MK-L Applicator Dies Crimp applicator with dies MK/STI-41-110N APLMK STI41-110N AP-K2N – – – TAB-IN/TAB-IN-TAB TERMINAL 250 Tab-in tab type L E W Dimensions(mm) Applicable wire Model No. mm2 AWG # Insulation O.D. (mm) 0.3 to 0.75 22 to 18 2.2 to 3.2 Standard SIM-21-250 SIM-21T-250 Material 20 to 14 0.5 to 2.0 SIM-51T-250N Q´ty / reel Tab Material thickness thickness W L E 6.0 28.0 15.8 – Brass SIM-51-250N Finish Tin-plated 5,000 0.4 0.84 – 2.6 to 3.8 Tin-plated 6.0 24.5 4,000 0.4 13.0 RoHS compliance Note: SIM-21 differs from SIM-51 in terminal size. 110 Tab-in tab type E L W Listed E70188 Dimensions(mm) Applicable wire Model No. Standard SIM-01-110A SIM-01T-110A mm2 AWG # 0.3 to 0.5 22 to 20 0.5 to 1.25 20 to 16 Insulation O.D. (mm) Material SIM-41T-110B Tab Material thickness thickness W L E 2.8 20.6 12.0 Q´ty / reel – 2.1 to 2.8 Brass SIM-41-110B Finish 2.6 to 3.5 Tin-plated 0.5 0.5 7,500 – Tin-plated RoHS compliance Crimping machine, Applicator Contact Crimping machine Crimp applicator MK-L SIM-21(T)-250 – Applicator Dies MK/SIM-21-250 Crimp applicator with dies APLMK SIM21-250 – – Contact MK-L SIM-01(T)-110A AP-K2N SIM-51(T)-250N Crimping machine Crimp applicator – Applicator Dies Crimp applicator with dies MK/SIM-01-110A APLMK SIM01-110A – – AP-K2N MK-L – MK/SIM-51-250N APLMK SIM51-250N – – SIM-41(T)-110B MK-L – MK/SIM-41-110B APLMK SIM41-110B – – * Compliant with RoHS. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. 7
LOM-51T-250 价格&库存
很抱歉,暂时无法提供与“LOM-51T-250”相匹配的价格&库存,您可以联系我们找货
LOM-51T-250
    • 1+374.95021
    • 2+365.57775
    • 4+359.94387
    库存:6200
    LOM-51T-250
      • 100+0.35824
      • 300+0.34991
      • 500+0.34262
      库存:1800
      LOM-51T-250
        • 1+0.630311+0.08136
        • 10+0.4814910+0.06215
        • 50+0.4027050+0.05198
        • 100+0.35017100+0.04520
        • 500+0.32391500+0.04181
        • 1000+0.315161000+0.04068
        • 2000+0.306402000+0.03955
        库存:282
