RUGGED TIGER EYE™ SYSTEMS
(1.27 mm) .050" PITCH
MAX
8
3.7
A
m
p
G b p s
s
FEATURES & BENEFITS
• S
crew down, locking clip, friction latching and
weld tab ruggedizing options
• Shrouded, polarized and keyed
• Surface mount or through-hole tails
• High-density, four row design (FOLC/MOLC Series)
• Discrete wire assemblies available in single or double row,
28 and 30 AWG PVC or *Teflon™ Fluoropolymer (See pages 238-239).
Contact asp@samtec.com for custom solutions.
• Cable components (ISDF/CC03) and tooling available: samtec.com/tooling
• Severe Environment Testing qualified (SFM/TFM); aligns with MIL-DTL-55302.
Visit samtec.com/set
*Teflon™ is a trademark of The Chemours Company FC, LLC
used under license by Samtec.
KEY SPECIFICATIONS
SERIES
STACK
INSULATOR
HEIGHTS MATERIAL
CONTACT
MATERIAL
BeCu (SFM)
SFM/TFM 6 to 12 mm
Black LCP
SFC/TFC
Black LCP
6 to 12 mm
F-224 (Rev 04APR24)
Phosphor
Bronze (TFM)
Phosphor
Bronze
IDC cable
assemblies with
rugged strain relief
(FFSD/FFMD, FFTP/FMTP)
Locking for
increased
unmating force
(SFML/TFML)
PLATING
OPERATING
TEMP RANGE
CURRENT
RATING
VOLTAGE
RATING
MAX.
CYCLES
LEAD-FREE
SOLDERABLE
Au or Sn
over 50 µ"
(1.27 µm) Ni
-55 °C to +125 °C
3.7A per pin
(2 pins powered)
275 VAC
10,000
with 30 µ"
(0.76 µm) Au
Yes
Au or Sn
over 50 µ"
(1.27 µm) Ni
-55 °C to +125 °C
3.1 A per pin
(2 pins powered)
350 VAC
(Call Samtec for
E.L.P.™ plating
option)
Yes
samtec.com/127mm-TigerEye
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
8
MAX
3.1
A
(1.27 mm) .050" PITCH • COST-EFFECTIVE HEADER/SOCKET
SFC
NO. PINS
PER ROW
1
LEAD STYLE
04, 05, 10, 15,
20, 25, 30, 35,
40, 45, 50
–T1
D
p
OPTIONS
–A
= Gold flash on contact,
Matte Tin on tail
–T2
= Alignment Pin
–K
–L
= Surface Mount
Tiger Eye™ LITE
G b p s
s
–F
= Through-hole
Tiger Eye™ LITE
(Standard sizes)
PLATING OPTION
m
= (4.00 mm) .157" DIA Polyimide film
Pick & Place Pad
= 10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
–TR
= Tape & Reel
(–T2 only)
–FR
= Full Reel Tape & Reel
(must order max. quantity per reel;
contact Samtec for quantity breaks)
(-T2 only)
SFC
Board Mates:
TFC
Cable Mates:
TFSD, TFSDT
[1RRI3RVLWLRQV
H[FHSWIRUDOLJQPHQWSLQRSWLRQ
[1RRI3RVLWLRQV
NO. PINS
PER ROW
1
03, 04, 06, 08
LEAD
STYLE
–X1
(Lead Style –01 & –02 only)
= Through-hole
05, 07, 10, 15, 20, 25,
30, 35, 40, 45, 50
= Surface Mount
–X2
(Standard sizes)
PLATING
OPTION
D
–F
–T2
OPTIONS
–RA
= Gold flash on
post, Matte Tin
on tail
= Right-angle
(–01 only)
–L
= Alignment Pin
–A
= 15 µ" (0.38 µm)
Gold on post,
Matte Tin on tail
–LC
= Locking Clip
(Manual Placement required)
(not available with –RA)
(1.27) .050 x No. of Positions + (3.18) .125
–K
= (6.75 mm) .266" DIA
Polyimide film Pick & Place Pad
(5.72)
.225
TFC
Board Mates:
SFC
Cable Mates:
SFSD, SFSDT
–P
B
A
SMT
LEAD
STYLE
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
–T1
View complete specifications at: samtec.com?SFC
TFC
–A OPTION
A
B
TH
LEAD
STYLE
= Plastic Pick & Place Pad
(5 positions min.)
A
–TR
= Tape & Reel
(–X2 only)
A
B
–02
(5.72) .225 (3.38) .133
–01
(5.59) .220 (3.38) .133
–12
(7.49) .295
–11
(7.37) .290
–22
(9.27) .365 (3.30) .130
–21
(9.14) .360 (3.30) .130
–32
(11.18) .440
–31
(11.05) .435
–FR
(-X2 only)
View complete specifications at: samtec.com?TFC
F-224 (Rev 04APR24)
很抱歉,暂时无法提供与“TFC-140-22-F-D-A-K”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 10+57.2428310+7.44139
