ZW-21-14-T-S-1250-090 数据手册
ZW–06–13–L–D–787–118
F-218 (Rev 10OCT17)
DW–11–20–T–D–825
HW–14–08–G–S–300–100
(2.54 mm) .100"
DW, EW, ZW, HW-TH SERIES
FLEXIBLE .025" SQ BOARD STACKERS
Mates with:
SSW, SSQ, ESW, ESQ,
CES, SLW, BSW, BCS,
SSM, HLE, PHF
TYPE
STRIP
LEAD
STYLE
NO. PINS
PER ROW
PLATING
OPTION
Cable Mates:
IDSS, IDSD, SMSD, SMSS
DW
SPECIFICATIONS
Specify LEAD STYLE
from chart
= (2.79 mm)
.110" Tail
For complete specifications
see www.samtec.com?DW,
www.samtec.com?EW,
www.samtec.com?ZW or
www.samtec.com?HW-TH
Insulator Material:
DW, EW, ZW: Black Glass
Filled Polyester
HW: Natural Liquid
Crystal Polymer
Terminal Material:
Phosphor Bronze
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Operating Temp Range:
-55 °C to +125 °C with Gold
-55 °C to +105 °C with Tin
RoHS Compliant:
Yes
Lead–Free Solderable:
DW, EW, ZW:
No, Lead Wave Only
HW: Yes
POST
(0.00).000
MIN
(2.79)
.110
OVERALL
LENGTH
EW
(OAL)
STACKER
HEIGHT
= (8.38 mm)
.330" Tail
TAIL
(1.40) .055
MIN
LEAD
STYLE
OAL
– 07
(10.92) .430
– 08
(13.46) .530
– 09
(18.54) .730
–10
(21.08) .830
–11
(23.62) .930
–12
(26.16) 1.030
–13
(31.24) 1.230
–14
(36.32) 1.430
–15
(16.00) .630
–16
(11.30) .445
–17
(12.19) .480
–19
(33.78) 1.330
–20
(28.70) 1.130
ROW
OPTION
STACKER
HEIGHT
OTHER
OPTIONS
–S
–“XXX”
–“XXX”
Example:
–250
= (6.35 mm)
.250"
Example:
–250
= (6.35 mm)
.250"
= Single
Row
–D
= Double
Row
–T
= Triple
Row
–Q
For complete scope of
recognitions see
www.samtec.com/quality
–LL
ZW
= Gold flash on contact,
Matte Tin on tail
= Custom Tail
FILE NO. E111594
50
02
TAIL
LENGTH
Notes:
For added mechanical stability,
Samtec recommends
mechanical board spacers be
used in applications with gold or
selective gold plated connectors.
Contact ipg@samtec.com for
more information.
This Series is non-standard,
non-returnable.
HW
= High Temp
Custom Tail
(2.54) .100 x
No. of Positions
–L
01
(2.54)
.100
–S
(2.54)
.100
–D
100
(5.08)
.200
ALSO AVAILABLE
• Other platings
Contact Samtec.
ZW or
HW TAIL
LENGTH
(1.40)
.055
MIN
–F
01 thru 50
01
99
03
150
(7.52)
.296
(5.08)
.200
01
–T
or –Q*
= 10 µ" (0.25 µm)
Gold on contact area
of longer tail,
Matte Tin on tail
(2.54)
.100
–G
= 10 µ" (0.25 µm)
of longer tail,
Gold flash on balance
–Q*
148
= Same as
-T except
middle
row
of pins
missing.
–T
= Matte Tin
(2.54)
.100
TAIL
LENGTH
(0.64) .025 SQ TYP
Due to technical progress, all designs, specifications and components are subject to change without notice.
WWW.SAMTEC.COM
= ZW or HW
Tail Length
(in inches)
(1.40 mm)
.055"
minimum
STACKER
HEIGHT
(5.08)
.200
MIN
= Double
Row .200"
(5.08 mm)
row space
(8.38)
.330
RECOGNITIONS
(MOQ Required)
= Stacker
Height
(in inches)
(5.08 mm)
.200"
minimum
All parts within this catalog are built to Samtec’s specifications.
Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
= Locking
Lead
(Shortest
dimension
between the
tail and the
post is the
end that will
be crimped.
Available
on tails from
(2.29 mm)
.090" to
(7.87 mm)
.310" only.)
Single row, 01
& 02 positions
& –Q row not
available
–“XXX”
= Polarized
Specify omitted
pin position
ZW-21-14-T-S-1250-090 价格&库存
很抱歉,暂时无法提供与“ZW-21-14-T-S-1250-090”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+22.041171+2.85342
