11P-SZN
11P-SZN
    JST
    P=1.5mm
    1X11P 1.5MM
11P-SZN 数据手册
SZN CONNECTOR 1.5 mm pitch/Board-in crimp style connectors SZN CONNECTOR ■ Standards ® ® ® : Recognized E60389 : Certified LR20812 ® ® This low-profile, board-in connector, with a mounting height of only 4.25 mm and a thickness of 2.4 mm, is soldered directly onto printed circuit boards. The solder tail of the contact is resilient for easy assembly. The housing lances facilitate insertion of contacts. • • • • Slim, low-profile design Housing lances Easy mounting onto printed circuit boards Rugged contact construction ■ Specifications • Current rating: 0.7 A AC/DC (AWG #26) • Voltage rating: 50 V AC/DC • Temperature range: -25℃ to +85℃ (including temperature rise in applying electrical current) • • • • Insulation resistance: 500 MΩ min. Withstanding voltage: 500 VAC/minute Applicable wire: AWG #30 to #26 Applicable PC board thickness: 0.6 to 1.2 mm * In using the products,refer to "Handling Precautions for Terminals and Connectors" described on our website (Technical documents of Product information page). * RoHS2 compliance * Dimensional unit: mm * Contact JST for details. PC board layout and Assembly layout 2.4 2.8 2 to 6 circuits:φ0.70 ±0.03 7 to 13 circuits:φ0.75 ±0.03 4.25 1.4 min. 1.5 ±0.03 1.25 min. Note: 1 . The above figure is the figure viewed from soldering side. 2. Tolerances are non-cumulative: ± 0.03 mm for all centers. 3. Hole dimensions differ according to the type of PC board and piercing method. The dimensions above should serve as a guideline. Contact JST for details. 1 SZN CONNECTOR Contact Applicable wire mm2 AWG # Model No. SZN-002T-P0.7K SZN-003T-P0.7K 0.65 0.08 to 0.13 28 to 26 0.8 to 1.1 14,000 0.05 to 0.08 30 to 28 0.7 to 0.9 15,000 0.84 2.2 Insulation O.D.(mm) Q'ty/reel Material and Finish Phosphor bronze, tin-plated (reflow treatment) 1.0 RoHS2 compliance Note: Contact JST for brass products. 1.2 0.5 6.8 1.2 Crimping machine Crimp applicator Contact SZN-002T-P0.7K SZN-003T-P0.7K AP-K2N MKS-L Applicator Dies Crimp applicator with dies MK/SZN-002-07 APLMK SZN002-07 MK/SZN-003-07 APLMK SZN003-07 Note: Contact JST for fully automatic crimping applicator. 2.4 4 5 4.25 3 1.5 JST 1.25 B A 0.25 Housing 2.05 No. of circuits Model No. 2 3 4 5 6 7 8 9 10 11 12 13 2P-SZN 3P-SZN 4P-SZN 5P-SZN 6P-SZN 7P-SZN 8P-SZN 9P-SZN 10P-SZN 11P-SZN 12P-SZN 13P-SZN Dimensions (mm) A B 4.0 1.5 5.5 3.0 7.0 4.5 8.5 6.0 10.0 7.5 11.5 9.0 13.0 10.5 14.5 12.0 16.0 13.5 17.5 15.0 19.0 16.5 20.5 18.0 Q'ty/bag 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 Material and Finish PA 66, UL94V-0, natural (white) RoHS2 compliance Model number allocation Housing Contact 2P - SZN SZN - 002 T - P 0.7 K Series name Applicable wire range: 002・・・AWG #28 to #26 003・・・AWG #30 to #28 Surface finish: T・・・Tin-plated(reflow treatment) Material: P・・・Phosphor bronze 2 Terminal size No. of circuits: 2 to 13 Shape: K・・・Product with connected tip Series name
11P-SZN 价格&库存
很抱歉,暂时无法提供与“11P-SZN”相匹配的价格&库存,您可以联系我们找货
11P-SZN
    • 1000+0.42260
    库存:921
    11P-SZN
      • 1000+0.47030
      库存:3000
      11P-SZN
        库存:20010
