F-215
BSW–110–24–T–S
BSW–124–04–T–S–S
BSW–115–04–G–D
(2,54 mm) .100"
BSW SERIES
BOTTOM MOUNT SOCKET STRIPS
Mates with:
TSW, MTSW, HTSW,
MTLW, TSM, EW, ZW,
HW, DW, PHT
NO. PINS
PER ROW
1
BSW
LEAD
STYLE
FEATURES
–04
• Bottom mount socket
strips accept .025" SQ
terminals.
• For low profile
connections and high
temperature soldering.
For complete specifications and
recommended PCB layouts
see www.samtec.com?BSW
Insulator Material:
Black Thermoplastic
Insulation Resistance:
5000 MΩ min
Contact Material:
Phosphor Bronze
Plating:
Au or Sn over
50µ" (1,27 µm) Ni
Operating Temp Range:
-55°C to +125°C with Gold
-55°C to +105°C with Tin
Withstanding Voltage:
1000 VRMS @ 60 Hz
Contact Resistance:
10 mΩ
Insertion Depth:
(3,68 mm) .145" to
(6,35 mm) .250"
Insertion Force:
(Single contact only)
Standard = 8 oz (2,23 N) avg.
Low Insertion Force = 3 oz
(0,83 N) avg.
Withdrawal Force:
(0,83 N) avg.
RoHS Compliant:
Yes
Lead-Free Solderable:
Wave only
= Low
Insertion
Force
–S, –M, –E
(MOQ Required)
(0,79) .031
TYP
Row Option
–S*
–M
–E
–D*
• Other platings
Contact Samtec.
Z
(4,31) .170
*Less
(3,43) .135
(0,38 mm)
.015" with
standoffs
(2,54) .100
FILE NO: 090871_0_000
(0,38)
.015
–T
= Matte Tin
(N/A with Low
Insertion Force)
(–S & –D only)
(4,32) .170
(No. of Pos. X (2,54) .100) + (0,51) .020
01
36
X
Y
72
–S
–M
–E
–S = Single Row
Row
Option
02
–S
(2,54)
.100
(10,16)
.400
(2,54)
.100
(2,54)
.100
71
–M
–D
–E
X
Y
(2,54)
.100
(3,81)
.150
(4,31)
.170
(5,08)
.200
(6,35)
.250
(6,86)
.270
Body design may vary slightly
from drawing shown.
01
Row
–M = Single
More Plug Space
Row
–E = Single
Extended Plug Space
–D = Double Row
APPLICATIONS
BSW
(SINGLE ROW)
BSW
(DOUBLE ROW)
RECOGNITIONS
For complete scope
of recognitions see
www.samtec.com/quality
–G
ALSO
AVAILABLE
–D
–S
= 20µ" (0,51 µm)
Gold contact,
Gold Flash on tail
(8,89)
.350
(2,54)
.100
TYP
OTHER
OPTION
= Standoffs
for single
and double
rows only.
= 10µ" (0,25 µm)
Gold contact,
Matte Tin on tail
–24
(0,41)
.016
TYP
Z
ROW
OPTION
–L
= Standard
Lead
02 thru 36
• Ideal for soldering and
plugging from the same
side of the board.
SPECIFICATIONS
PLATING
OPTION
COMPONENT
SIDE
EW
(SINGLE ROW)
PC
BOARD
SOLDER
SIDE
PC
BOARD
TSW
(SINGLE ROW)
TSW
(DOUBLE ROW)
BSW
(SINGLE ROW)
Note: Some lengths,
styles and options are
non-standard, non-returnable.
WWW.SAMTEC.COM
Due to technical progress, all designs, specifications and components are subject to change without notice.
