FTM-107-03-L-DV-SA-P-TR
    SAMTEC(申泰)
    1MM MICRO STRIPS
FTM-107-03-L-DV-SA-P-TR 数据手册
SMT MICRO TERMINAL STRIPS (1.00 mm) .0394" PITCH • FTMH/FTM SERIES FTMH Mates: CLM, MLE FTMH -1 FTM PROCESSING Lead-Free Solderable: Yes SMT Lead Coplanarity: -DV: (0.10 mm) .004" max -DH: (0.10 mm) .004" max (05-25) (0.15 mm) .006" max (26-50)* *(.004" stencil solution may be available; contact ipg@samtec.com) –02 –03 –L No. of positions x (1.00) .03937 + B = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail = Dual Vertical (-DV only with 9 pins/row minimum) –DH = End Shroud –ES (1.57) .062 –EC (4.06) .160 –EP (5.49) .216 (1.80) .071 -1 - NO. PINS PER ROW 02 thru 50 MOQ Required –02 = Unshrouded 05 thru 46 = Shrouded (3.18) .125 (5.21) .205 10 YEAR MFG WITH 30 µ" GOLD EXTENDED LIFE PRODUCT PLATING OPTION –03 –L = (1.65 mm) .065" Post (Mates with CLM) –TR OPTION D –FR LEAD STYLE - DV - = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) A –02 (1.91) .075 –03 (1.65) .065 –SA FLEX SHROUD OPTION –S = End Shroud (05 positions minimum). Molded or press-fit shroud at Samtec’s discretion = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail –S (0.97) .038 = Plastic Pick & Place Pad (6 positions min.) (–DV only) = Tape & Reel –F = Gold flash on post, Matte Tin on tail (4.44) .175 –P = End Shroud with Guide Post (Use only when mating with CLM) (2.59) .102 = (1.91 mm) .075" Post (Mates with MLE) No. of positions x (1.00) .03937 + C HIGH MATING CYCLES –K = (2.50 mm) .098" DIA Polyimide Film Pick & Place Pad (–DH only) –DH OPTION - LEAD STYLE –A –EC (5.00) .197 (5.21) .205 OTHER OPTION = Alignment Pin (3 positions min.) Metal or plastic at Samtec discretion (–DV only) –EP B –DV OPTION FTM - –ES = Dual Horizontal A Shrouded option removed for clarity FLEX SHROUD OPTION = End Shroud with Locking Clip (Manual placement required) OPTION (1.49) .059 End shrouds with board locks Molded end shrouds for 05 through 08 positions Other platings F-224 –DV A ALSO AVAILABLE Note: Some lengths, styles and options are non-standard, non-returnable. - ROW OPTION –F = Gold flash on post, Matte Tin on tail = (1.65 mm) .065" Post (Mates with CLM) (3.17) .125 - PLATING OPTION = (1.91 mm) .075" Post (Mates with MLE) No. of positions x (1.00) .03937 SPECIFICATIONS - LEAD STYLE 05 thru 50 Mates: CLM, MLE Insulator Material: Black Liquid Crystal Polymer Terminal Material: Phosphor Bronze Plating: Sn or Au over 50 µ" (1.27 µm) Ni Current Rating (FTMH/CLM): 3.1 A per pin (2 pins powered) Operating Temp Range: -55 °C to +125 °C Voltage Rating: FTMH: 270 VAC - NO. PINS PER ROW –SA = End Shroud with Alignment Pins (05 through 46 positions) C (4.00) .157 (7.00) .276 (1.27) .050 No of positions x (1.00) .03937 LEAD STYLE D –02 (1.91) .075 –03 (1.65) .065 - OTHER OPTION –P = Plastic Pick & Place Pad (7 positions min.) –TR = Tape & Reel –FR = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) Shrouded options removed for clarity samtec.com?FTMH or samtec.com?FTM Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
FTM-107-03-L-DV-SA-P-TR 价格&库存
很抱歉,暂时无法提供与“FTM-107-03-L-DV-SA-P-TR”相匹配的价格&库存,您可以联系我们找货
