MEC6-170-02-L-DV-A-TR
    SAMTEC(申泰)
    SMD,P=0.64mm
    CONN EDGE DUAL FMALE 140P 0.025
MEC6-170-02-L-DV-A-TR 数据手册
F-215 MEC6–140–02–L–DV–A MEC6–130–02–L–DV–A MEC6–160–02–L–DV–A (0,635 mm) .025" MEC6-DV SERIES VERTICAL MICRO EDGE CARD SOCKET SPECIFICATIONS Mates with: (1,60 mm) .062" thick cards For complete specifications and recommended PCB layouts see www.samtec.com?MEC6-DV Insulator Material: Black LCP Contact Material: Phosphor Bronze Plating: Au or Sn over 50µ" (1,27 µm) Ni Operating Temp Range: -55°C to +125°C Insertion Depth: (4,22 mm) .166" to (5,66 mm) .223" Current Rating: 1.7 A per pin (6 adjacent pins powered) Voltage Rating: 210 VAC RoHS Compliant: Yes Processing: Lead–Free Solderable: Yes SMT Lead Coplanarity: (0,10 mm) .004" max (10-50) (0,15 mm) .006" max (60-70) Variety of lead counts Mates with (1,60 mm) .062" thick card MEC6-DV Rated @ 3dB Insertion Loss* 8,65 mm Stack Height Single-Ended Signaling 7.5 GHz / 15 Gbps Differential Pair Signaling 7.0 GHz / 14 Gbps *Performance data includes effects of a non-optimized PCB. Complete test data available at www.samtec.com?MEC6-DV or contact sig@samtec.com MEC6 1 (0,635 mm) .025" pitch POSITIONS PER ROW 02 PLATING OPTION Alignment Pin DV A OPTION RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality –L –K = 10µ" (0,25 µm) Gold on contact, Matte Tin on tail = (5,50 mm) .217" DIA Polyimide Pick & Place Pad 10, 20, 30, 40, 50, 60, 70 No. of Positions x (0,635) .025 + (7,94) .313 B ALSO AVAILABLE A (MOQ Required) –TR = Tape & Reel • Locking Clip (Manual placement required) • Other platings Contact Samtec. POSITIONS PER ROW (3,81) .150 No. of Positions x (0,635) .025 + (4,77) .188 No. of Positions x (0,635) .025 (1,78) + (1,565) .062 .070 02 (4,40) .173 (7,00) .276 (8,80) .346 01 Notes: While optimized for 50Ω applications, this connector with alternative signal/ground patterns may also perform well in certain 75Ω applications. Contact Samtec for further information. Some sizes, styles and options are non-standard, nonreturnable. (8,50) .335 (1,00) .039 (3,60) .142 (0,90) .035 x (1,40) .055 DIA 10, 20, 30 & 40 = No. of Positions x (0,635) .025 + (2,37) .093 50, 60 & 70 = No. of Positions x (0,635) .025 + (3,00) .118 (1,40) .055 DIA (1,50) .059 (1,40) .055 DIA (8,65) .341 (1,40) .055 DIA (1,00) .039 WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. A B 50 (21,06) (36,49) .829 1.437 60 (24,87) (42,84) .979 1.687 70 (28,68) (49,19) 1.129 1.937
MEC6-170-02-L-DV-A-TR 价格&库存
很抱歉,暂时无法提供与“MEC6-170-02-L-DV-A-TR”相匹配的价格&库存,您可以联系我们找货
