NSHDR-28V-Z
NSHDR-28V-Z
    JST
    P=1mm
    2X14P 1MM
NSHDR-28V-Z 数据手册
NSHD CONNECTOR Emboss Tape 1.0 mm pitch/Disconnectable Crimp style connectors NSHD CONNECTOR Specifications In 1.0 mm pitch and dual-row secure lock type connector, this NSHD connector realizes a top grade of a space saving in the industry and supports a high densification of equipment. ● Excellent mounting and dismounting workability of socket ● Adopting large lock in consideration of unlocking and withstanding external force ● Various lineups of circuits ● An existing crimping applicator is available. • Current rating: 1.0 A AC/DC (AWG #28) • Voltage rating: 50 V AC/DC • Temperature range: -25℃ to +85℃ (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 20 mΩ max. After environmental tests/ 40 mΩ max. • Insulation resistance: 100 MΩ min. • Withstanding voltage: 500 VAC/minute • Applicable wire: Conductor size/ AWG #32 to #28 Insulation O.D./ 0.4 to 0.8 mm * In using the products,refer to "Handling Precautions for Terminals and Connectors" described on our website (Technical documents of Product information page). * RoHS2 compliance * Dimensional unit: mm * Contact JST for details. PC board layout and Assembly layout Side entry type A±0.05 1±0.05 0.85 ±0.1 C ±0.1 0.85±0.1 0.9 ±0.05 (Lock side) 1.6 ±0.05 Circuit No.2 0.85 ±0.1 C ±0.1 0.85±0.1 〈40 circuits〉 〈16, 20, 24, 28, 32 circuits〉 (7.3) (6.8) (8.9) (7.6) (7.1) (8.1) (7.7) (6.9) Circuit No.N (Mating side faces to this side) 〈40 circuits〉 〈16, 20, 24, 28, 32 circuits〉 7.3 ±0.05 7.2 ±0.05 Circuit No.1 Circuit No.N-1 Circuit No.N-1 Connector outline 1.6 ±0.05 ±0.05 0.5 1.8 ±0.1 Connector outline 1±0.05 Circuit No.1 1.8 ±0.1 Circuit No.2 Circuit No.N A ±0.05 0.6 ±0.05 1.6 ±0.05 0.6 ±0.05 1.6 ±0.05 Top entry type Note: 1 . The above figure is the figure viewed from the connector mounting side. 2. Tolerances are non-cumulative: ± 0.05 mm for all centers. The dimensions above should serve as a guideline. Contact JST for details. 1 NSHD CONNECTOR Contact Applicable wire Model No. SNSHD-003T-P0.2 AWG # Insulation O.D. (mm) Q'ty/ reel 0.032~0.08 32~28 0.4~0.8 23,000 NSHD CONNECTOR Material and Finish 3.9 2 0.5 mm2 0.8 Copper alloy, tin-plated (reflow treatment) 0.8 1.3 RoHS2 compliance Contact Crimping machine Crimp applicator SNSHD-003T-P0.2 AP-K2N MKS-L-10-3 Applicator Dies Crimp applicator with dies MK/SSH/L-003-02 APLMK SSH/L003-02 Note: 1 .C  ontact JST for applicable wires in case that it is not usable due to wire size. 2. Contact JST for fully automatic crimping applicator. Housing No. of circuits B 6.8 Model No. NSHDR-16V-Z NSHDR-20V-Z NSHDR-24V-Z NSHDR-28V-Z NSHDR-32V-1-Z NSHDR-40V-2-Z 16 Circuit No.1 mark 20 24 28 5.6 32 40 A Dimensions (mm) A B Q'ty/ bag 7.0 9.2 2,500 9.0 11.2 2,000 11.0 13.2 1,500 13.0 15.2 1,000 15.0 17.2 1,000 19.0 21.2 900 Material and Finish 1 PBT, UL94V-0, ivory RoHS2 compliance B 6.8 Circuit No.1 mark As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. NSHDR-16V-Z- 5.6 Z...ivory TR...tomato red E...blue MG...moss green DPK...dark pink 1 A B 6.8 5.6 Circuit No.1 mark 1 A B 7.3 6.8 Circuit No.1 mark 1 A 2 NSHD CONNECTOR Shrouded header Top entry type Side entry type 0.1 5.8 B 0.5 6 4.25 (4.35) Circuit No.1 mark 1 B 0.1 5.8 B 0.5 6 (4.35) 4.25 1 5.8 B 0.5 6 (4.35) 4.25 1 A 5.8 B 0.5 6 (4.35) 4.25 1 A 0.7 Side entry type Model No. BM16B-NSHDZS-TFT BM20B-NSHDZS-TFT BM24B-NSHDZS-TFT BM28B-NSHDZS-TFT BM32B-NSHDZS-1-TFT BM40B-NSHDZS-1-TFT Dimensions (mm) A B C Q'ty/ reel No. of circuits 7.0 10.2 8.8 1,600 16 9.0 12.2 10.8 1,600 20 11.0 14.2 12.8 1,600 24 13.0 16.2 14.8 1,600 28 15.0 18.2 16.8 1,600 32 19.0 22.2 20.8 1,600 40 Model No. SM16B-NSHDZS-TF SM20B-NSHDZS-TF SM24B-NSHDZS-TF SM28B-NSHDZS-TF SM32B-NSHDZS-1-TF SM40B-NSHDZS-1-TF Material and Finish Contact: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Header: Polyamide resin, UL94V-0, ivory Reinforcing tab: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Dimensions (mm) A B C Q'ty/ reel 7.0 10.2 8.8 1,000 9.0 12.2 10.8 1,000 11.0 14.2 12.8 1,000 13.0 16.2 14.8 1,000 15.0 18.2 16.8 1,000 19.0 22.2 20.8 1,000 Material and Finish Contact: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Header: Polyamide resin, UL94V-0, ivory Reinforcing tab: Copper alloy, copper-undercoated, tin-plated (reflow treatment) RoHS2 compliance Note: These products listed above are supplied on embossed-tape. RoHS2 compliance Note: These products listed above are supplied on embossed-tape. As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. 3 0.7 1 A Top entry type 5.1 Circuit No.1 (6.1) 0.1 Circuit No.1 mark 40 0.7 B 32 5.1 1 A 28 0.7 Circuit No.1 (6.1) 0.1 Circuit No.1 mark 24 0.7 B 20 5.1 1 A 16 0.7 Circuit No.1 Circuit No.1 mark No. of circuits 0.7 1 A A 5.1 (6.1) A 0.7 Circuit No.1 (6.1) B BM16B-NSHDZS-TFTZ...ivory TR...tomato red E...blue MG...moss green DPK...dark pink ex. SM16B-NSHDZS-TFZ...ivory TR...tomato red E...blue MG...moss green DPK...dark pink
NSHDR-28V-Z 价格&库存
很抱歉,暂时无法提供与“NSHDR-28V-Z”相匹配的价格&库存,您可以联系我们找货
NSHDR-28V-Z
    • 1+4.202041+0.54240
    • 10+3.0990110+0.40002
    • 50+2.5474950+0.32883
    • 100+2.17981100+0.28137
    • 500+2.10978500+0.27233
    • 1000+2.057251000+0.26555
    • 2000+2.030992000+0.26216
    库存:840
    NSHDR-28V-Z
