SHROUDED IDC
HEADER & STACKER
(2.00 mm) .0787" PITCH • STMM/ZSTMM SERIES
STMM/ZSTMM
Mates:
TCSD (except –SR)
STMM
-1
04, 05, 06,
07, 08, 10,
12, 13, 14, 15,
17, 20, 22, 25
SPECIFICATIONS
Insulator Material:
Black Liquid Crystal Polymer
Terminal Material:
Phosphor Bronze
Plating:
Sn or Au over
50 µ" (1.27 µm) Ni
Operating Temp Range:
-55 °C to +105 °C with Tin;
-55 °C to +125 °C with Gold
- 02 -
NO. PINS
PER ROW
-D-
PLATING
OPTION
–F
= Gold flash
on post,
Matte Tin on tail
–L
(Standard sizes)
TAIL
OPTION
–RA
= Locking Clip
(-SM only)
(Manual placement
required)
–SM
= Surface
Mount
–K
= (7.50 mm) .295" DIA
Film Pick & Place Pad
(-SM only)
= Matte Tin
–TR
= Tape & Reel
(–SM only)
–FR
T/H
ZSTMM
—SM
-1
—RA
04, 05, 06,
07, 08, 10,
12, 13, 14, 15,
17, 20, 22, 25
(Standard sizes)
LEAD
STYLE
Specify
LEAD
STYLE
from
chart
PLATING
OPTION
–F
BODY
HEIGHT
–“XXX”
= Body
Height
OTHER
OPTION
–“XX”
= Polarized
Position
–L
–T
= Matte Tin
(6.00)
.237
(4.80)
.190
-D-
= Gold flash
on post,
Matte Tin
on tail
= 10 µ" (0.25 µm)
Gold on post,
Matte Tin on tail
(2.00) .0787 x
No. of positions + (6.17) .243
= Full Reel Tape & Reel
(must order max.
quantity per reel;
contact Samtec for
quantity breaks)
(–SM only)
—RA
—SM
NO. PINS
PER ROW
Notes:
For added mechanical
stability, Samtec recommends
mechanical board spacers
be used in applications
with gold or selective gold
plated connectors. Contact
ipg@samtec.com for more
information.
–LC
= Right-angle
Other sizes
Other platings
= Polarized Position
–T
PROCESSING
MOQ Required
–“XX”
Leave blank for
Through-hole
= 10 µ" (0.25 µm)
Gold on post,
Matte Tin on tail
1RRISRVLWLRQV
Lead–Free Solderable:
Yes
SMT Lead Coplanarity:
(0.10 mm) .004" max
ALSO AVAILABLE
OTHER
OPTION
BODY
HEIGHT
(6.35)
A
.250
(OAL) MIN
(2.29)
.090
MIN
LEAD
STYLE
A
(OAL)
MAX BODY
HEIGHT
–75
(9.58) 0.377
(7.42) 0.292
–62
(10.08) 0.397
(7.92) 0.312
–65
(10.49) 0.413
(8.33) 0.328
–73
(12.09) 0.476
(9.93) 0.391
–63
(14.10) 0.555
(11.94) 0.470
–66
(15.09) 0.594
(12.93) 0.509
–69
(15.60) 0.614
(13.44) 0.529
–74
(17.09) 0.673
(14.94) 0.588
–70
(17.60) 0.693
(15.44) 0.608
–71
(21.08) 0.830
(18.92) 0.745
–72
(21.62) 0.851
(19.46) 0.766
This Series is non-standard,
non-returnable.
samtec.com?STMM or samtec.com?ZSTMM
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
F-224
很抱歉,暂时无法提供与“STMM-111-01-L-D-RA”相匹配的价格&库存,您可以联系我们找货
