SMM-104-02-S-D-01-K-TR
    SAMTEC(申泰)
    2MM SOCKET STRIPS
SMM-104-02-S-D-01-K-TR 数据手册
8 G b p s (2.00 mm) .0787" PITCH • TIGER EYE™ SOCKET SMM - NO. PINS PER ROW 1 02 thru 40 - 02 - PLATING OPTION - –F - ROW OPTION –S = Gold flash on contact, Matte Tin on tail = Single Row –D = Double Row –L = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail –S –K = (5.50 mm) .217" DIA Polyimide Film Pick & Place Pad (2 positions minimum, –02 thru –05 requires –TR) = Plastic Pick & Place Pad (–02 thru –05 requires –TR) –TR Board Mates: TMM, TMMH, MTMM, MMT, LTMM, TW, PTT, ZLTMM Cable Mates: TCMD = Tape & Reel Packaging (27 positions maximum) –FR = Full Reel Tape & Reel (must order maximum quantity per reel; contact Samtec for quantity breaks) (27 positions maximum) SPECIFICATIONS Insulator Material: Black Liquid Crystal Polymer Contact Material: BeCu Plating: Sn or Au over 50 µ" (1.27 µm) Ni Current Rating (TMM/SMM): 3.2 A per pin (2 pins powered) Voltage Rating: 350 VAC Operating Temp Range: -55 °C to +125 °C Insertion Depth: (3.05 mm) .120" to (3.25 mm) .128" Max Cycles: 100 with 10 µ" (0.25 µm) Au –“XX” = Polarized Position –P = 30 µ" (0.76 µm) Gold on contact, Matte Tin on tail SMM OTHER OPTIONS No. of positions x (2.00) .0787 PROCESSING Lead–Free Solderable: Yes SMT Lead Coplanarity: (0.10 mm) .004" max –S Row (2.00) .0787 (3.81) .150 x (7.62) .300 –D Row (5.71) .225 x (10.01) .394 (4.00) .158 ALSO AVAILABLE MOQ Required –P Locking Clip (Manual placement required) Other platings (3.56) .140 (4.32) .170 Note: Some lengths, styles and options are non-standard, non-returnable. F-224 (6.30) .248 View complete specifications at: samtec.com?SMM samtec.com/2mm-TigerEye Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
SMM-104-02-S-D-01-K-TR 价格&库存
很抱歉,暂时无法提供与“SMM-104-02-S-D-01-K-TR”相匹配的价格&库存,您可以联系我们找货
