8
G b p s
(2.00 mm) .0787" PITCH • TIGER EYE™ SOCKET
SMM
NO. PINS
PER ROW
1
02 thru 40
02
PLATING
OPTION
–F
ROW
OPTION
–S
= Gold flash
on contact,
Matte Tin on tail
= Single Row
–D
= Double Row
–L
= 10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
–S
–K
= (5.50 mm) .217" DIA
Polyimide Film
Pick & Place Pad
(2 positions minimum,
–02 thru –05 requires –TR)
= Plastic Pick & Place Pad
(–02 thru –05 requires –TR)
–TR
Board Mates:
TMM, TMMH, MTMM, MMT,
LTMM, TW, PTT, ZLTMM
Cable Mates:
TCMD
= Tape & Reel Packaging
(27 positions maximum)
–FR
= Full Reel Tape & Reel
(must order maximum
quantity per reel;
contact Samtec
for quantity breaks)
SPECIFICATIONS
Insulator Material:
Black Liquid Crystal Polymer
Contact Material:
BeCu
Plating: Sn or Au over
50 µ" (1.27 µm) Ni
Current Rating (TMM/SMM):
3.2 A per pin
(2 pins powered)
Voltage Rating:
350 VAC
Operating Temp Range:
-55 °C to +125 °C
Insertion Depth:
(3.05 mm) .120" to
(3.25 mm) .128"
Max Cycles:
100 with 10 µ" (0.25 µm) Au
–“XX”
= Polarized Position
–P
= 30 µ" (0.76 µm)
Gold on contact,
Matte Tin on tail
SMM
OTHER
OPTIONS
No. of positions x (2.00) .0787
PROCESSING
Lead–Free Solderable:
Yes
SMT Lead Coplanarity:
(0.10 mm) .004" max
–S Row
(2.00)
.0787
(3.81) .150
x (7.62) .300
–D Row
(5.71) .225
x (10.01) .394
(4.00)
.158
ALSO AVAILABLE
MOQ Required
–P
Locking Clip
(Manual placement required)
Other platings
(3.56)
.140
(4.32)
.170
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
F-224
(6.30)
.248
View complete specifications at: samtec.com?SMM
samtec.com/2mm-TigerEye
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
SMM-140-02-F-D-LC-P 价格&库存
很抱歉,暂时无法提供与“SMM-140-02-F-D-LC-P”相匹配的价格&库存,您可以联系我们找货
