F-218 (Rev 10OCT17)
TMM–110–01–S–D–SM
10 YEAR MFG
WITH 30 µ" GOLD
TMM–112–01–F–S–SM
EXTENDED LIFE
PRODUCT
HIGH MATING
CYCLES
TMM–130–05–L–S–SM
(2.00 mm) .0787"
TMM SERIES
LOW-PROFILE SMT HEADER
SPECIFICATIONS
For complete specifications and
recommended PCB layouts
see www.samtec.com?TMM
Insulator Material:
Black Liquid Crystal Polymer
Terminal Material:
Phosphor Bronze
Plating:
Sn or Au over
50 µ" (1.27 µm) Ni
Current Rating:
3.2 A per pin
(2 pins powered)
Operating Temp Range:
-55 °C to +105 °C with Tin;
-55 °C to +125 °C with Gold
Voltage Rating:
281 VAC mated with SQW;
250 VAC mated with SQT
RoHS Compliant:
Yes
Board Mates:
CLT, SQT, SQW, ESQT,
TLE, SMM, MMS
Cable Mates:
TCSD
(2.00 mm)
.0787" pitch
OTHER SOLUTIONS
Throughhole
Available with optional
• Pick & place pads
• Alignment pins
• Tape & reel packaging
2 mm Shunt
Specify
2SN–BK–G
for 2 mm
shunt with
Gold plating.
PROCESSING
Lead–Free Solderable:
Yes
SMT Lead Coplanarity:
(0.15 mm) .006" max*
*(.004" stencil solution
may be available; contact
IPG@samtec.com)
TMM
1
(2.77 mm)
.109" Low Profile
(4.45)
.175
(1.95)
.077
(2.00 mm)
.0787"
pitch
(3.99)
.157
LEAD
STYLE
NO. PINS
PER ROW
RECOGNITIONS
For complete scope
of recognitions see
www.samtec.com/quality
PLATING
OPTION
Specify
LEAD
STYLE
from
chart
below.
02 thru 40
FILE NO. E111594
• Other platings
Contact Samtec.
01
No. of positions x
(2.00) .0787
SM
–S
–F
= Gold flash on post,
Matte Tin on tail
–L
= 10 µ" (0.25 µm)
Gold on post,
Matte Tin on tail
ALSO AVAILABLE
(MOQ Required)
ROW
OPTION
–A
= Single
Row
= Alignment Pin
(Metal or plastic at
Samtec’s discretion)
(5 positions minimum)
(–D only)
–D
= Double
Row
–“XXX”
–S
= Polarized Position
(Specify position of
omitted pin)
–T
= Pick & Place Pad
(3 positions minimum)
= 30 µ" (0.76 µm)
Gold on post,
Matte Tin on tail
(1.97)
.078
–P
= Matte Tin
–TR
40
02
80
(3.94)
.155
01
79
(0.50) .020 SQ
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
(2.00)
.0787
A
LEAD STYLE
= Tape & Reel Packaging
(3 thru 36 positions only)
MATES WITH
–01
SQT, SQW, ESQT,
(3.20) .126 TLE,
SMM, MMS, TCSD
–04
(1.91) .075
–05
(1.65) .065
–06
(4.27) .168
CLT
CLT-BE
(1.27)
.050 TYP
(1.50)
.059
A
(5.00)
.197
(1.27)
.050
(7.06)
.278
–D
(4.83)
.190
–S
Due to technical progress, all designs, specifications and components are subject to change without notice.
WWW.SAMTEC.COM
OTHER
OPTION
(5.08)
.200
–P
All parts within this catalog are built to Samtec’s specifications.
Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
很抱歉,暂时无法提供与“TMM-119-06-L-D-SM”相匹配的价格&库存,您可以联系我们找货
