H75XX-1
150mA Low Power LDO
Features
Low power consumption
High input voltage (up to 15V)
Low voltage drop
Output voltage accuracy: tolerance ±2%
Low temperature coefficient
TO92, SOT89, and SOT23 package
Audio/Video equipment
Applications
Battery-powered equipment
Communication equipment
General Description
technology ensures low voltage drop and low
power high voltage regulators implemented in
quiescent current. Although designed primarily as
CMOS technology. They allow input voltages as
fixed voltage regulators, these devices can be
high as 18V. They are available with several fixed
used with external components to obtain variable
output voltages ranging from 2.1V to 6.0V. CMOS
voltages and currents.
Selection Table
Package
Marking
PR
O
Output Voltage
2.1V
2.5V
2.7V
3.0V
3.3V
3.6V
4.0V
4.4V
4.5V
5.0V
TO92
SOT89
SOT23
75XXA-1(for TO92)
75XX-1(for SOT89)
HTXX(for SOT23)
SI
Part No.
H7521-1
H7525-1
H7527-1
H7530-1
H7533-1
H7536-1
H7540-1
H7544-1
H7545-1
H7550-1
IN
The H75XX-1 series is a set of three-terminal low
Note:”XX” stands for output voltages. Other voltages can be specially customized.
Order Information
H75①②-1③④
Designator
① ②
③
④
Ver1.9
Symbol
Description
Integer
Output Voltage(2.1~5.0V)
T
Package:TO-92
P
Package:SOT89
N
Package:SOT23
R
RoHS / Pb Free
G
Halogen Free
1
Shanghai Siproin Microelectronics Co.
H75XX-1
150mA Low Power LDO
Block Diagram
PR
O
IN
Pin Assignment
SI
Absolute Maximum Ratings
Supply Voltage ................................-0.3V to 18V
Storage Temperature ..................-50℃ to 125℃
Operating Temperature .................-40℃ to 85℃
Note: These are stress ratings only. Stresses exceeding the range specified under “Absolute Maximum
Ratings” may cause substantial damage to the device. Functional operation of this device at other
conditions beyond those listed in the specification is not implied and prolonged exposure to extreme
conditions may affect device reliability.
Thermal Information
Symbol
Parameter
θJA
Thermal Resistance (Junction to
Ambient) (Assume no ambient
airflow, no heat sink)
PD
Power Dissipation
Package
TO92
SOT89
SOT23
TO92
SOT89
SOT23
Max.
200
200
500
0.50
0.50
0.20
Unit
℃/W
℃/W
℃/W
W
W
W
Note: PD is measured at Ta= 25℃
Ver1.9
2
H75XX-1
150mA Low Power LDO
Electrical Characteristics
H7521-1, +2.1V Output Type
Test Conditions
Symbol
Parameter
VIN
Conditions
Min.
Typ.
Max.
Unit
VOUT
Output Voltage
4.1V
IOUT=10mA
2.058
2.100
2.142
V
IOUT
Output Current
4.1V
120
150
mA
ΔVOUT
Load Regulation
4.1V
1mA≤IOUT≤50mA
60
150
mV
VDIF
Voltage Drop(Note)
IOUT=1mA, ΔVOUT=2%
50
mV
ISS
Current Consumption
4.1V
No load
1.5
2
μA
∆VOUT
∆V IN × VOUT
Line Regulation
0.2
%/V
VIN
Input Voltage
15
V
∆VOUT
∆Ta
Temperature
mV/℃
IN
IOUT=1mA
4.1V
IOUT=10mA
0℃
很抱歉,暂时无法提供与“H7550-1”相匹配的价格&库存,您可以联系我们找货
