LB242-180P-B3R-01
LB242-180P-B3R-01
    LXW(连兴旺)
    P=0.5mm
    板对板连接器 P=0.5mm 180Pin 公
LB242-180P-B3R-01 数据手册
连兴旺电子(深圳)有限公司 规格书 SPECIFICATIONS FOR APPROVAL 客户: Customer: 客户料号: Customer Part No: LB242-xxxP-B3R-01公座 LB232-xxxS-B3R-01 母座 公司料号: Part No: 产品名称: Description: 0.5mm High Speed Plane Ground Plane Socket /Terminal Strips Type Connector . 2019.03.18 发行日期: Issue Date: 客户签核 (Customer Approval): 采购 品保 工程 审核 制作 Hu.bill Chaman 内部签核 (Signature): 核准 连兴旺电子(深圳)有限公司 LXWCONN ELECTRONICS (SHENZHEN) CO.,LTD TEL:+86-0755 2959 1214 FAX:+86-0755 2795 1049 ADD:东莞市虎门镇新联社区高科一路 1 号钧益工业园 F 栋 连兴旺电子(深圳)有限公司 STANDARD SPECIFICATION REV:A 18-Mar- 2019 1. SCOPE 1.1. CONTENTS This specification covers the performance, tests and quality requirements for the 0.8mm (.0315”)High Speed Plane Ground Plane Socket /Terminal Strips Type Connector . 1.2. QUALIFICATION When tests are performed on the subject product line, the procedures specified in LB342-xxxP-B3R-01 LB332-xxxS-B3R-01 inspection plan and product drawings. 2. APPLICABLE DOCUMENT The following LXWCONN documents form a part of this specification to the extent specified herein. Unless otherwise specified, the latest edition of the document applies. In the event of conflict between the requirements of this specification and the product drawings, the product drawing shall take precedence. In the event of conflict between the requirements of this specification and the referenced documents, this specification shall take precedence. 3. REQUIREMENTS 3.1. DESIGN AND CONSTRUCTION Product shall be of the design, construction and physical dimensions specified on the applicable product drawings. 3.2. MATERIALS A. Housing: LCP HIGH-TEMP THERMOPLASTIC, UL94V-0, BEIGE. B. Terminal: Phosphor BRONZE, 1μ"Gold-Flash on contact area and mater tin on pad area over all nickel under plated . 3.3. RATINGS A. Voltage rating: 225VAC B. Current rating: 2 A (One Pin Power Per Row) ;Ground :16A(One Pin Power Per Row) C. Operating Temperature: - 55℃ to +125℃ (Including terminal temperature rise) D. Operating Humidity range: Relative humidity 90%to 95%Max E. Storage temperature range:20±8℃ F. Storage Humidity range: Relative humidity 60%Max 3.4. PERFORMANCE REQUEIREMENT AND TEST DESCRIPTION The product shall be designed to meet the electrical, mechanical and environmental performance Requirements specified in Figure 1. All tests shall be performed at ambient environmental conditions. SPEC.No:LXW-008 2 of 8 连兴旺电子(深圳)有限公司 STANDARD SPECIFICATION 1 REV:A 18-Mar- 2019 测试项目 TEST ITEM 规格 REQUIREMENT 测试方式/条件 PROCEDURE 外观检查 Examination of Product 符合图面外观,无任何形状损坏 Meets requirements of product Drawing. No physical damage. 目视检查 Visual inspection. 电气特性 ELECTRICAL REQUIREMENT 将样品成对连接,开放电压 20mV 以下; 限电流 15mA 的状态下进行测试。 2 接触电阻 Contact Resistance 15mΩ 以下。 15mΩ Max. Subject mated contacts assembled in housing to closed circuit of 15mA max. at open circuit voltage of 20mV max. (EIA-364-23) 3 绝缘阻抗 Insulation Resistance 5000MΩ 以上。 5000MΩ Min. 未连接的样品,提供相邻端子间或端子与地 面间加 AC 675V 进行绝缘阻抗测试。 Impressed Voltage 675V AC Test between adjacent circuits of unmated connectors. (EIA-364-21) 4 耐电压 Dielectric withstanding Voltage 目视外观无任何击穿损坏 No Breakdown 电流泄漏: 1 mA max. Current leakage: 1 mA max. 未连接的样品,提供相邻端子间或端子与地 面间加 AC 675V(有效值)历时 1 分钟下 测定耐电压。 675 V AC for 1minute Test between adjacent circuit of unmated connectors. (EIA-364-20) 机械特性 MECHANICAL REQUIREMENT 5 接触保持力 Contact Retention Force 0.01Kgf/Pin 以上 0.01Kgf/Pin Min. 将样品成对连接,以操作速度每分钟位移 25±3mm 进行接触保持力测试。 Load shall be applied on each at a speed of 25±3mm/minute as shown below then pin retention force shall be measured. 6 插入力 Insertion Force SPEC.No:LXW-008 0.125KgfxN Max. (N=Pins) 0.125KgfxN Max. (N=Pins) 将成对连接器焊板连接,以操作速度每分钟 位移 25±3mm 进行插入力测试。 Mate The sample connectors shall be soldered on a board and inserted and separated at speed of 25±3mm/min. (EIA-364-13) 3 of 8 连兴旺电子(深圳)有限公司 STANDARD SPECIFICATION 测试项目 TEST ITEM REV:A 18-Mar- 2019 规格 REQUIREMENT 测试方式/条件 PROCEDURE 机械特性 MECHANICAL REQUIREMENT 外观 Appearance 7 8 耐插拔 Durability 耐振动 Vibration 目视外观无任何 损坏异状 No Damage 接触阻抗 Contact Resistance 90mΩ 以下. 90mΩ Max. 接触阻抗 Contact Resistance 90mΩ 以下. 90mΩ Max. 外观 Appearance 目视外观无任何 损坏异状 No Damage 将样品成对连接,以操作速度每分钟位移 25±3mm 进行 500 次插拔测试。 Mate The sample connectors unmated the number of 500cycles specified at the rate of 25±3 mm/min. (EIA-364-09) 通过 DC 电流 1mA,位移相对距离 1.5mm, 振动周期 10~55~10Hz 在 1 分钟内,持续 2 小时,方向在 X,Y,Z 轴做测试 Mate 1 μ sec 以下. 1 μ sec Max. connectors and subject to the following vibration conditions for period of 2 hours in each of 3 mutually perpendicular axes 瞬间断电 Discontinuity should be mounted in the tester and fully mated and passing DC 1mA during test.Amplitude:1.5mm the P-P frequency:10~55~10 Hz in 1 minute (EIA-364-28 Condition I) 9 耐冲击性 Shock (Mechanical) 外观 Appearance 目视外观无任何 损坏异状 No Damage 接触阻抗 Contact Resistance 90mΩ 以下. 90mΩ Max. 瞬间断电 Discontinuity 1 μ sec 以下. 1 μ sec Max.. 将样品成对连接,通过 DC1mA 测试条 件,连续测试 3 次。在 X、Y、Z 3 轴 6 个 垂直方向施予重力加速度 490m/s2{50G}冲 击。 Mate The sample connectors shall and subject to the following shock condition.3 times of shocks shall be applied for each 6 directions along 3 mutually perpendicular axes, passing DC 1mA current during the test.(Total of 18 shocks) Peak value490m/s2{50G} (EIA-364-27, test condition A) 环境特性及其它性能(ENVIRONMENT PERFORMANCE AND OTHERS) 10 温升 Temperature Rising SPEC.No:LXW-008 负载额定电流下温度 30℃ 30℃ Max. Under loaded rating current 量测通过成对连样品接最大容许电流时,样 品接触点这温升。 Mate The sample connectors and measure the temperature rise of contact when the maximum AC rated current is passed. (EIA-364-70 METHOD 2) 4 of 8 连兴旺电子(深圳)有限公司 STANDARD SPECIFICATION 测试项目 TEST ITEM 规格 REQUIREMENT REV:A 18-Mar- 2019 测试方式/条件 PROCEDURE 环境特性及其它性能(ENVIRONMENT PERFORMANCE AND OTHERS) 外观 Appearance 11 12 11 目视外观无任何 损坏异状 No Damage 耐热性 Heat Resistance SPEC.No:LXW-008 completion of the exposure period, the test specimens shall be conditioned at ambient room condition for 1to2 hours, after which the specified measurements shall be performed. 接触阻抗 Contact Resistance 90mΩ 以下. 90mΩ Max. 外观 Appearance 目视外观无任何 损坏异状 No Damage 时间 96 小时。再置放于室温下 1~2 小时。 Mate The sample connectors shall expose to -55±2℃ for 96 hours. Upon completion of 接触阻抗 Contact Resistance 90mΩ 以下. 90mΩ Max. the exposure period, the test specimens shall be conditioned at ambient room condition for 1to2 hours, after which the specified measurements shall be performed. 接触阻抗 Contact Resistance 90mΩ 以下. 90mΩ Max. 耐电压 Dielectric Strength 需能符合电压试 No Breakdown 外观 Appearance 目视外观无任何 损坏异状 No Damage 绝缘阻抗 Insulation Resistance 500MΩ 以上。 500MΩ Min. 耐寒性 Cold Resistance 耐湿性 Humidity 将样品成对连接置于环境温度 85±2℃测试时 间 96 小时。再置放于室温下-55°1~2 小时。 Mate The sample connectors shall expose to 85 ± 2 ℃ for 96 hours. Upon 将样品成对连接置于环境温度-55±2℃测试 将样品成对连接置于环境温度 40±2℃,相对 湿度 90~95%,测试时间 96 小时。再置放于 室温下 1~2 小时。 Mate The sample connectors shall expose to 40±2℃ relative humidity 90~95% for 96 hours. Upon completion of the exposure period, the test specimens shall be conditioned at ambient room condition for 1to2 hours, after which the specified measurements shall be performed. 5 of 8 连兴旺电子(深圳)有限公司 STANDARD SPECIFICATION 测试项目 TEST ITEM 规格 REQUIREMENT REV:A 18-Mar- 2019 测试方式/条件 PROCEDURE 环境特性及其它性能(ENVIRONMENT PERFORMANCE AND OTHERS) 12 接触阻抗 Contact Resistance 90mΩ 以下. 90mΩ Max. 外观 Appearance 目视外观无任何 损坏异状 No Damage 温度循环 Temperature Cycling 将样品成对连接, 承受 5 cycles 冷热冲击后, 置放于室温下 1~2 小时。1cycle time 如下 a)-55±3℃,30 分钟 b) +85±3℃,30 分钟 A connector shall and subject to the following condition for 5 cycles .Upon completion of the exposure period, the test specimens shall be conditioned at ambient room condition for 1to2 hours, after which the specified measurements shall be performed. 1cycle a)-55±3℃,30 minutes b) +85±3℃,30 minutes (Transit time shall be with in 3 minutes ) (EIA-364-31, Test condition A) 13 盐水喷雾 Salt Spray 外观 Appearance 目视外观无任何 损坏异状 No Damage 将样品成对连接,使用 5±1%浓度盐水,测试 温度 35±2℃,测试时间 24 小时后,于室温 下使用清水冲洗后再干燥。 Mate The sample connectors shall expose to the following salt mist conditions. Upon completion of the exposure period, salt deposits shall be removed by a gentle wash or dip in running water, after which the specified NaCl solution Concentration:5±1% Spray time:24hours Ambient temperature:35±2℃ (EIA-364-26,Test condition B) 14 焊锡性 Solder ability SPEC.No:LXW-008 润湿性 Solder Wetting 润湿面积 95%以 上,并不得有漏 焊针孔现象。 95% of immersed area must show no voids, pin holes. 锡温 250±5℃,将导电端子浸入锡炉液面至 Housing 距离锡面 0.1mm 位置,焊锡时间 3 ±0.5 秒。 Tip of solder tails and fitting mails into the molten solder (held at 250±5℃) up to 0.1mm from the Housing for 3±0.5sec onds. (EIA-364-52) 6 of 8 连兴旺电子(深圳)有限公司 STANDARD SPECIFICATION 测试项目 TEST ITEM 规格 REQUIREMENT REV:A 18-Mar- 2019 测试方式/条件 PROCEDURE 环境特性及其它性能(ENVIRONMENT PERFORMANCE AND OTHERS) 15 焊锡耐热性 Resistance to Reflow Soldering Heat 外观 Appearance 目视外观无任何 损坏异状 No Damage 使用红外线回流焊时请参考第 4 点 When reflowing….Refer to paragraph 4. 使用烙铁手焊时须符合下述焊锡条件 Soldering iron method 0.2 mm from terminal tip and fitting nail tip. Soldering time:5 seconds Max. Soldering temperature:370~400℃ Figure 1 NOTE: Shall meet visual requirements, show no physical damage, and meet requirement of additional tests as specified in the test sequence in Figures 2 4. INFRARED REFLOW CONDITION (Lead Free) 300 Temperature (℃) 250℃ Max.(Peak Temp)5sec.or less 250 230 200 150 100 25 Start 50 100 150 220 250 T1 Temperature Ramp Up Rate 2 ~5 /Sec T2 Preheat:150 ~200 60~90Sec T3 Time Over 230 30~50Sec T4 Preheat:200 ~250 30Sec T5 Ramp Down Rate During Cooling 4 ~7 /Sec Peak Temperature 300 Time (sec) 250 Max NOTE: Please check the reflow soldering condition by your own devices beforehand. Because the condition changes by the soldering devices, P.C.Boarde and so on. SPEC.No:LXW-008 7 of 8 连兴旺电子(深圳)有限公司 STANDARD SPECIFICATION REV:A 18-Mar- 2019 5.0. PRODUCT QUALIFICATION AND RELIABILITY TEST SEQUENCE Test or Examination Appearance (外观) A B C D Test Group E F G H 1;7 1;3 1;6 1;6 1;6 2;5 2;5 2;5 Contact Resistance (接触电阻) Dielectric Withstanding Voltage (耐电压) 3;6 Insulation Resistance (绝缘阻抗) 2;5 Insertion Force (插入力) 1;3 J K L 1;3 1;3 1;6 1;6 1;5 1;5 2;5 2;5 2;4 2;4 2 Contact Retention Force(接触保持力) 3,4 Vibration(耐振动) 3,4 Shock Mechanical (耐冲击性) 3,4 2 Temperature Rising (温升) 3,4 Heat Resistance(抗热性) 3,4 Cold Resistance(耐寒性) Humidity(耐湿性) I 4 3 Temperature Cycling (温度循环) 3 Salt Spray(盐水喷雾) 2 Solder ability (可焊性) 2 Resistance to Soldering Heat (焊锡耐热性) Figure 2 NOTE: (a) Numbers indicate sequence in which tests are performed. (b) Discontinuities shall not take place in this test group, during test SPEC.No:LXW-008 8 of 8
LB242-180P-B3R-01 价格&库存
很抱歉,暂时无法提供与“LB242-180P-B3R-01”相匹配的价格&库存,您可以联系我们找货
