SN74LS393
Dual 4−Stage Binary
Counter
The SN74LS393 contains a pair of high-speed 4-stage ripple
counters.
Each half of the LS393 operates as a Modulo-16 binary divider, with
the last three stages triggered in a ripple fashion. In the LS393, the
flip-flops are triggered by a HIGH-to-LOW transition of their CP
inputs. Each half of each circuit type has a Master Reset input which
responds to a HIGH signal by forcing all four outputs to the LOW
state.
• Dual Versions
• Individual Asynchronous Clear for Each Counter
• Typical Max Count Frequency of 50 MHz
• Input Clamp Diodes Minimize High Speed Termination Effects
http://onsemi.com
LOW
POWER
SCHOTTKY
14
1
GUARANTEED OPERATING RANGES
Symbol
VCC
Parameter
Supply Voltage
Min
Typ
Max
Unit
4.75
5.0
5.25
V
70
°C
TA
Operating Ambient
Temperature Range
IOH
Output Current − High
−0.4
mA
IOL
Output Current − Low
8.0
mA
PLASTIC
N SUFFIX
CASE 646
14
1
SOIC
D SUFFIX
CASE 751A
14
1
SOEIAJ
M SUFFIX
CASE 965
ORDERING INFORMATION
Device
Package
Shipping
SN74LS393N
14 Pin DIP
2000 Units/Box
SN74LS393D
SOIC−14
55 Units/Rail
SN74LS393DR2
SOIC−14
2500/Tape & Reel
SN74LS393M
SOEIAJ−14
See Note 1
SN74LS393MEL
SOEIAJ−14
See Note 1
1. For ordering information on the EIAJ version of
the SOIC package, please contact your local
ON Semiconductor representative.
© Semiconductor Components Industries, LLC, 2006
July, 2006 − Rev. 2
1
Publication Order Number:
SN74LS393/D
SN74LS393
CONNECTION DIAGRAM DIP (TOP VIEW)
VCC
CP
MR
Q0
Q1
Q2
Q3
14
13
12
11
10
9
8
NOTE:
The Flatpak version
has the same pinouts
(Connection Diagram) as
the Dual In-Line Package.
1
2
3
4
5
6
7
CP
MR
Q0
Q1
Q2
Q3
GND
LOADING (Note a)
PIN NAMES
CP
CP0
CP1
MR
Q0 − Q3
Clock (Active LOW Going Edge)
Input to +16 (LS393)
Input to ÷2 (LS390)
Input to ÷ 5 (LS390)
Master Reset (Active HIGH) Input
Flip−Flop Outputs
NOTES:
a) 1 TTL Unit Load (U.L.) = 40 mA HIGH/1.6 mA LOW.
http://onsemi.com
2
HIGH
LOW
0.5 U.L.
1.0 U.L.
0.5 U.L.
1.0 U.L.
0.5 U.L.
0.5 U.L.
10 U.L.
1.5 U.L.
0.25 U.L.
5 U.L.
SN74LS393
FUNCTIONAL DESCRIPTION
not occur simultaneously. This means that logic signals
derived from combinations of these outputs will be subject
to decoding spikes and, therefore, should not be used as
clocks for other counters, registers or flip-flops. A HIGH
signal on MR forces all outputs to the LOW state and
prevents counting.
Each half of the SN74LS393 operates in the Modulo 16
binary sequence, as indicated in the ÷ 16 Truth Table. The
first flip-flop is triggered by HIGH-to-LOW transitions of
the CP input signal. Each of the other flip-flops is triggered
by a HIGH-to-LOW transition of the Q output of the
preceding flip-flop. Thus state changes of the Q outputs do
SN74LS393 LOGIC DIAGRAM (one half shown)
CP
K CP
CD
K CP
J
Q
J
CD
K CP
CD
Q
J
K CP
Q
CD
J
Q
MR
Q0
Q1
Q2
TRUTH TABLE
COUNT
OUTPUTS
Q3
Q2
Q1
Q0
2
3
L
L
L
L
L
L
L
L
L
L
H
H
L
H
L
H
4
5
6
7
L
L
L
L
H
H
H
H
L
L
H
H
L
H
L
H
8
9
10
11
H
H
H
H
L
L
L
L
L
L
H
H
L
H
L
H
12
13
14
15
H
H
H
H
H
H
H
H
L
L
H
H
L
H
L
H
H = HIGH Voltage Level
L = LOW Voltage Level
http://onsemi.com
3
Q3
SN74LS393
DC CHARACTERISTICS OVER OPERATING TEMPERATURE RANGE (unless otherwise specified)
Limits
Symbol
Min
Parameter
VIH
Input HIGH Voltage
VIL
Input LOW Voltage
VIK
Input Clamp Diode Voltage
VOH
Output HIGH Voltage
VOL
Output LOW Voltage
IIH
Input HIGH Current
IIL
Input LOW Current
Typ
Max
Unit
2.0
0.8
−0.65
2.7
−1.5
3.5
Test Conditions
V
Guaranteed Input HIGH Voltage for
All Inputs
V
Guaranteed Input LOW Voltage for
All Inputs
V
VCC = MIN, IIN = − 18 mA
V
VCC = MIN, IOH = MAX, VIN = VIH
or VIL per Truth Table
0.4
V
IOL = 4.0 mA
0.35
0.5
V
IOL = 8.0 mA
μA
VCC = MAX, VIN = 2.7 V
VCC = MAX, VIN = 7.0 V
0.1
mA
MR
−0.4
mA
CP, CP0
−1.6
mA
CP1
−2.4
mA
−100
mA
VCC = MAX
26
mA
VCC = MAX
IOS
Short Circuit Current (Note 2)
ICC
Power Supply Current
VCC = VCC MIN,
VIN = VIL or VIH
per Truth Table
0.25
−20
VCC = MAX, VIN = 0.4 V
2. Not more than one output should be shorted at a time, nor for more than 1 second.
AC CHARACTERISTICS (TA = 25°C, VCC = 5.0 V)
Limits
Symbol
Parameter
Min
Typ
35
fMAX
Maximum Clock Frequency
CP0 to Q0
25
fMAX
CP1 to Q1
tPLH
tPHL
Propagation Delay,
CP to Q0
tPLH
tPHL
tPHL
CP to Q3
MR to Any Output
Max
Unit
Test Conditions
MHz
MHz
12
13
ns
40
40
60
60
ns
24
39
ns
CL = 15 pF
AC SETUP REQUIREMENTS (TA = 25°C, VCC = 5.0 V)
Limits
Symbol
Parameter
Min
Typ
Max
Unit
tW
Clock Pulse Width
ns
tW
MR Pulse Width
ns
trec
Recovery Time
25
ns
http://onsemi.com
4
Test Conditions
VCC = 5.0 V
SN74LS393
AC WAVEFORMS
*CP
1.3 V
1.3 V
tW
tPLH
tPHL
Q
1.3 V
1.3 V
Figure 1.
MR & MS
1.3 V
1.3 V
tW
trec
CP
1.3 V
tPHL
Q
1.3 V
Figure 2.
*The number of Clock Pulses required between tPHL and tPLH measurements can be determined from the appropriate Truth Table.
http://onsemi.com
5
SN74LS393
PACKAGE DIMENSIONS
N SUFFIX
PLASTIC PACKAGE
CASE 646−06
ISSUE M
14
8
B
1
7
A
F
L
N
C
−T−
SEATING
PLANE
H
G
D 14 PL
J
K
0.13 (0.005)
M
M
http://onsemi.com
6
NOTES:
1. DIMENSIONING AND TOLERANCING PER ANSI
Y14.5M, 1982.
2. CONTROLLING DIMENSION: INCH.
3. DIMENSION L TO CENTER OF LEADS WHEN
FORMED PARALLEL.
4. DIMENSION B DOES NOT INCLUDE MOLD FLASH.
5. ROUNDED CORNERS OPTIONAL.
DIM
A
B
C
D
F
G
H
J
K
L
M
N
INCHES
MIN
MAX
0.715
0.770
0.240
0.260
0.145
0.185
0.015
0.021
0.040
0.070
0.100 BSC
0.052
0.095
0.008
0.015
0.115
0.135
0.290
0.310
10_
0.015
0.039
MILLIMETERS
MIN
MAX
18.16
18.80
6.10
6.60
3.69
4.69
0.38
0.53
1.02
1.78
2.54 BSC
1.32
2.41
0.20
0.38
2.92
3.43
7.37
7.87
10_
0.38
1.01
SN74LS393
PACKAGE DIMENSIONS
D SUFFIX
PLASTIC SOIC PACKAGE
CASE 751A−03
ISSUE F
NOTES:
Y14.5M, 1982.
2. CONTROLLING DIMENSION: MILLIMETER.
3. DIMENSIONS A AND B DO NOT INCLUDE
MOLD PROTRUSION.
4. MAXIMUM MOLD PROTRUSION 0.15 (0.006)
PER SIDE.
5. DIMENSION D DOES NOT INCLUDE DAMBAR
PROTRUSION. ALLOWABLE DAMBAR
PROTRUSION SHALL BE 0.127 (0.005) TOTAL
IN EXCESS OF THE D DIMENSION AT
MAXIMUM MATERIAL CONDITION.
−A−
14
8
−B−
1
0.25 (0.010)
7
G
D 14 PL
0.25 (0.010)
T B
B
M
F
J
M
K
M
M
R X 45 _
C
−T−
SEATING
PLANE
P 7 PL
S
A
S
http://onsemi.com
7
DIM
A
B
C
D
F
G
J
K
M
P
R
MILLIMETERS
MIN
MAX
8.55
8.75
3.80
4.00
1.35
1.75
0.35
0.49
0.40
1.25
1.27 BSC
0.19
0.25
0.10
0.25
0_
7_
5.80
6.20
0.25
0.50
INCHES
MIN
MAX
0.337
0.344
0.150
0.157
0.054
0.068
0.014
0.019
0.016
0.049
0.050 BSC
0.008
0.009
0.004
0.009
0_
7_
0.228
0.244
0.010
0.019
SN74LS393
PACKAGE DIMENSIONS
M SUFFIX
SOEIAJ PACKAGE
CASE 965−01
ISSUE O
14
NOTES:
Y14.5M, 1982.
3. DIMENSIONS D AND E DO NOT INCLUDE MOLD
FLASH OR PROTRUSIONS AND ARE MEASURED
AT THE PARTING LINE. MOLD FLASH OR
PROTRUSIONS SHALL NOT EXCEED 0.15 (0.006)
PER SIDE.
4. TERMINAL NUMBERS ARE SHOWN FOR
REFERENCE ONLY.
5. THE LEAD WIDTH DIMENSION (b) DOES NOT
INCLUDE DAMBAR PROTRUSION. ALLOWABLE
DAMBAR PROTRUSION SHALL BE 0.08 (0.003)
TOTAL IN EXCESS OF THE LEAD WIDTH
DIMENSION AT MAXIMUM MATERIAL CONDITION.
DAMBAR CANNOT BE LOCATED ON THE LOWER
RADIUS OR THE FOOT. MINIMUM SPACE
BETWEEN PROTRUSIONS AND ADJACENT LEAD
TO BE 0.46 ( 0.018).
LE
8
Q1
E HE
M_
L
7
1
DETAIL P
Z
D
VIEW P
A
e
A1
b
0.13 (0.005)
c
M
0.10 (0.004)
DIM
A
A1
b
c
D
E
e
HE
0.50
LE
M
Q1
Z
MILLIMETERS
MIN
MAX
2.05
0.05
0.20
0.35
0.50
0.18
0.27
9.90
10.50
5.10
5.45
1.27 BSC
7.40
8.20
0.50
0.85
1.10
1.50
10 _
0_
0.70
0.90
1.42
INCHES
MIN
MAX
0.081
0.002
0.008
0.014
0.020
0.007
0.011
0.390
0.413
0.201
0.215
0.050 BSC
0.291
0.323
0.020
0.033
0.043
0.059
10 _
0_
0.028
0.035
0.056
ON Semiconductor and
are registered trademarks of Semiconductor Components Industries, LLC (SCILLC). SCILLC reserves the right to make changes without further notice
to any products herein. SCILLC makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does SCILLC assume any liability
arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation special, consequential or incidental damages.
“Typical” parameters which may be provided in SCILLC data sheets and/or specifications can and do vary in different applications and actual performance may vary over time. All
operating parameters, including “Typicals” must be validated for each customer application by customer’s technical experts. SCILLC does not convey any license under its patent rights
nor the rights of others. SCILLC products are not designed, intended, or authorized for use as components in systems intended for surgical implant into the body, or other applications
intended to support or sustain life, or for any other application in which the failure of the SCILLC product could create a situation where personal injury or death may occur. Should
Buyer purchase or use SCILLC products for any such unintended or unauthorized application, Buyer shall indemnify and hold SCILLC and its officers, employees, subsidiaries, affiliates,
and distributors harmless against all claims, costs, damages, and expenses, and reasonable attorney fees arising out of, directly or indirectly, any claim of personal injury or death
associated with such unintended or unauthorized use, even if such claim alleges that SCILLC was negligent regarding the design or manufacture of the part. SCILLC is an Equal
Opportunity/Affirmative Action Employer. This literature is subject to all applicable copyright laws and is not for resale in any manner.
PUBLICATION ORDERING INFORMATION
LITERATURE FULFILLMENT:
Literature Distribution Center for ON Semiconductor
P.O. Box 5163, Denver, Colorado 80217 USA
Phone: 303−675−2175 or 800−344−3860 Toll Free USA/Canada
Fax: 303−675−2176 or 800−344−3867 Toll Free USA/Canada
Email: orderlit@onsemi.com
N. American Technical Support: 800−282−9855 Toll Free
USA/Canada
Europe, Middle East and Africa Technical Support:
Phone: 421 33 790 2910
Japan Customer Focus Center
Phone: 81−3−5773−3850
http://onsemi.com
8
ON Semiconductor Website: www.onsemi.com
Order Literature: http://www.onsemi.com/orderlit
For additional information, please contact your local
Sales Representative
SN74LS393/D
