RS8051XF
RS8051XF
    RUNIC(润石)
    SC-74A(SOT-753)
    CMOS 放大器 1 电路 满摆幅 SOT-23-5
RS8051XF 数据手册
RS8051, RS8052, RS8054 100kHz, 670nA, Non-Unity Gain, Rail-to-Rail I/O CMOS Operational Amplifier FEATURES DESCRIPTION • GAIN BANDWIDTH:100kHz • RAIL-TO-RAIL INPUT AND OUTPUT 1mV Typical Vos • INPUT VOLTAGE RANGE: -0.1V to +5.6V with Vs = 5.5V • SUPPLY RANGE: +1.4V to +5.5V • STABLE FOR GAINS ≥ 10 • SPECIFIED UP TO +125°C • Micro SIZE The RS8051, RS8052, RS8054, families of products offer low voltage operation and rail-to-rail input and output, as well as excellent speed/power consumption ratio, providing an excellent bandwidth (100kHz) and slew rate of 30V/ms. The op-amps are stable for gains ≥ 10 and feature an ultra-low input bias current. The devices are ideal for sensor interfaces, active filters and portable applications. The RS8051, RS8052, RS8054 families of operational amplifiers are specified at the full temperature range of −40°C to +125°C under single or dual power supplies of 1.4V to 5.5V. PACKAGES: SOT23-5 APPLICATIONS • SENSORS • PHOTODIODE AMPLIFICATION • WEARABLE PRODUCTS • TEMPERATURE MEASUREMENT • BATTERY POWERED SYSTEM PIN CONFIGURATIONS 5 1 V+ + IN 5 1 V+ + V+IN 2 3 + V- - 4 -IN - IN 2 - 3 4 NC 1 -IN 2 +IN OUT V- SOT23-5 3 8 NC 7 V+ + OUT RS8051 RS8051B - RS8051 6 OUT 5 NC 4 SOT23-5 SOIC-8(SOP8),MSOP-8 RS8054 RS8052 OUT A OUT A 1 8 V+ -IN A 2 7 OUTB +IN A 3 6 -IN B V- 4 5 +IN B + A B+ SOIC-8(SOP8),MSOP-8, TDFN2x2-8 A D 14 OUT D -IN A 2 13 -IN D +IN A 3 12 +IN D V+ 4 11 V- +IN B 5 10 +IN C 9 -IN C 8 OUT C -IN B 6 OUT B 7 - + - + B + - + C SOIC-14(SOP14),TSSOP-14 Note: NC indicates no internal connection REV B.3 1 1 www.run-ic.com RS8051, RS8052, RS8054 ABSOLUTE MAXIMUM RATINGS (1) Supply Voltage, V+ to V-...............................................7.0V Input Terminals, Voltage (2) …………... – 0.5 to (V+) + 0.5V Current (2)…………………....….....±10mA Storage Temperature ……….…………… −65°C to +150°C Operating Temperature ……….………… −40°C to +125°C Junction Temperature................................................150°C Package Thermal Resistance @ TA = +25°C SOT23-5, SOT23-6………………….………………200°C/W MSOP-10, SOIC-8 …………………….…………... 150°C/W SOIC-14, TSSOP-14………….……….……………100°C/W Lead Temperature (Soldering, 10s) ……………........260°C ESD Susceptibility HBM …......................................................................5000V MM ……………………….........………………...……….400V ESD SENSITIVITY CAUTION ESD damage can range from subtle performance degradation to complete device failure. Precision integrated circuits may be more susceptible to damage because very small parametric changes could cause the device not to meet its published specifications. (1) Stresses above these ratings may cause permanent damage. Exposure to absolute maximum conditions for extended periods may degrade device reliability. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those specified is not implied. (2) Input terminals are diode-clamped to the power-supply rails. Input signals that can swing more than 0.5V beyond the supply rails should be current-limited to 10mA or less. PACKAGE/ORDERING INFORMATION PRODUCT RS8051 RS8052 RS8054 ORDERING NUMBER TEMPERATURE RANGE PACKAGE LEAD PACKAGE MARKING PACKAGE OPTION RS8051XK -40℃~125℃ SOIC-8(SOP8) RS8051 Tape and Reel,2500 RS8051XF -40℃~125℃ SOT23-5 8051 Tape and Reel,3000 RS8051BXF -40℃~125℃ SOT23-5 8051B Tape and Reel,3000 RS8051XM -40℃~125℃ MSOP-8 RS8051 Tape and Reel,3000 RS8052XK -40℃~125℃ SOIC-8(SOP8) RS8052 Tape and Reel,2500 RS8052XM -40℃~125℃ MSOP-8 RS8052 Tape and Reel,3000 RS8052XTDE8 -40℃~125℃ TDFN2x2-8 RS8052 Tape and Reel,3000 RS8054XP -40℃~125℃ SOIC-14(SOP14) RS8054 Tape and Reel,2500 RS8054XQ -40℃~125℃ TSSOP-14 RS8054 Tape and Reel,3000 2 www.run-ic.com RS8051, RS8052, RS8054 ELECTRICAL CHARACTERISTICS (At TA = +25C, Vs=5.0V, RL = 1MΩ connected to VS/2, and VOUT = VS/2, unless otherwise noted.) PARAMETER CONDITIONS RS8051,RS8052,RS8054 MIN TYP MAX UINTS 5.5 V 670 1500 nA POWER SUPPLY Vs Operating Voltage Range IQ Quiescent Current/Amplifier PSRR 1.4 Power-Supply Rejection Ratio Vs=1.4V to 5.5V, Vcm=(V-)+0.5V Input Offset Voltage Vcm=Vs/2 Input Offset Voltage Drift Vcm=Vs/2, -40°C ≤ TA ≤125°C 60 70 dB INPUT Vos ΔVos/ΔT 1 5 2.3 mV µV/°C IB Input Bias Current 1 10 pA Ios Input Offset Current Common-Mode Voltage Range 1 10 pA 5.6 V Vcm CMRR Common-Mode Rejection Ratio Vs= 5.5V -0.1 Vs= 5.5V, Vcm=-0.1V to 4V 63 75 dB Vs= 5.5V, Vcm=-0.1V to 5.6V 58 70 dB Vs=1.4V,RL=50KΩ,Vo=Vs-0.1V 62 80 dB Vs=5.0V,RL=50kΩ,Vo=Vs-0.1V 65 85 dB 5 mV 30 mA OUTPUT AOL Open-Loop Voltage Gain Output Swing From Rail Iout RL=50KΩ Output Short-Circuit Current FREQUENCY RESPONSE SR GBP PM NOISE enp-p en Slew Rate Gain-Bandwidth Product 30 V/ms 100 kHz Phase Margin 60 ° Input Voltage Noise f = 0.1 Hz to 10 Hz 2.4 μVpp Input Voltage Noise Density f = 1 kHz 160 nV/√Hz 3 www.run-ic.com RS8051, RS8052, RS8054 TYPICAL CHARACTERISTICS At TA = +25C, Vs=5V, RL = 1MΩ connected to VS/2, CL=60pF VCM = VS/2, unless otherwise noted. SMALL−SIGNAL STEP RESPONSE SMALL−SIGNAL STEP RESPONSE CL=60PF 50mV/div 50mV/div CL=60PF 50us/div 50us/div LARGE−SIGNAL STEP RESPONSE LARGE−SIGNAL STEP RESPONSE CL=60PF 1V/div 1V/div CL=60PF 100us/div 100us/div 45 45 40 40 Source Current(mA) Sink Current(mA) SINK CURRENT vs TEMPERATURE 35 30 25 20 SOURCE CURRENT vs TEMPERATURE 35 30 25 20 15 15 -40 -20 0 20 40 60 -40 -20 80 100 120 140 0 20 40 60 80 100 120 140 Temperature(℃) Temperature(℃) 4 www.run-ic.com RS8051, RS8052, RS8054 PACKAGE OUTLINE DIMENSIONS SOT23-5 D 1.90 b 2.59 E1 E 0.99 0.95 0.69 e e1 RECOMMENDED LAND PATTERN (Unit: mm) 0.2 A A2 L A1 Symbol c θ Dimensions In Millimeters Dimensions In Inches Min Max Min Max A 1.050 1.250 0.041 0.049 A1 0.000 0.100 0.000 0.004 A2 1.050 1.150 0.041 0.045 b 0.300 0.500 0.012 0.020 c 0.100 0.200 0.004 0.008 D 2.820 3.020 0.111 0.119 E 1.500 1.700 0.059 0.067 E1 2.650 2.950 0.104 0.116 e 0.950(BSC) 0.037(BSC) e1 1.800 2.000 0.071 0.079 L 0.300 0.600 0.012 0.024 θ 0° 8° 0° 8° 5 www.run-ic.com RS8051, RS8052, RS8054 MSOP-8 b e E E1 4.8 1.02 D 0.65 0.41 RECOMMENDED LAND PATTERN (Unit: mm) A2 c A A1 L Symbol Dimensions In Millimeters θ Dimensions In Inches Min Max Min Max A 0.820 1.100 0.032 0.043 A1 0.020 0.150 0.001 0.006 A2 0.750 0.950 0.030 0.037 b 0.250 0.380 0.010 0.015 c 0.090 0.230 0.004 0.009 D 2.900 3.100 0.114 0.122 e 0.650(BSC) 0.026(BSC) E 2.900 3.100 0.114 0.122 E1 4.750 5.050 0.187 0.199 L 0.400 0.800 0.016 0.031 θ 0° 6° 0° 6° 6 www.run-ic.com RS8051, RS8052, RS8054 TSSOP-14 e b 5.6 E1 E 1.78 D 0.65 0.42 RECOMMENDED LAND PATTERN (Unit: mm) A2 A1 Symbol H C A θ L Dimensions In Millimeters Min Max A Dimensions In Inches Min Max 1.200 0.047 A1 0.050 0.150 0.002 0.006 A2 0.800 1.050 0.031 0.041 b 0.190 0.300 0.007 0.012 c 0.090 0.200 0.004 0.008 D 4.860 5.100 0.191 0.201 E 4.300 4.500 0.169 0.177 E1 6.250 6.550 0.246 0.258 e L 0.650(BSC) 0.500 H θ 0.026(BSC) 0.700 0.020 0.25(TYP) 1° 0.028 0.01(TYP) 7° 7 1° 7° www.run-ic.com RS8051, RS8052, RS8054 SOIC-8(SOP8) b e 5.2 E E1 2.2 D 1.27 0.6 RECOMMENDED LAND PATTERN (Unit: mm) A2 c A A1 L Symbol Dimensions In Millimeters θ Dimensions In Inches Min Max Min Max A 1.350 1.750 0.053 0.069 A1 0.100 0.250 0.004 0.010 A2 1.350 1.550 0.053 0.061 b 0.330 0.510 0.013 0.020 c 0.170 0.250 0.007 0.010 D 4.800 5.000 0.189 0.197 e 1.270(BSC) 0.050(BSC) E 5.800 6.200 0.228 0.244 E1 3.800 4.000 0.150 0.157 L 0.400 1.270 0.016 0.050 θ 0° 8° 0° 8° 8 www.run-ic.com RS8051, RS8052, RS8054 SOIC-14(SOP14) e b 5.2 1.27 E E1 0.6 D 1.27 RECOMMENDED LAND PATTERN (Unit: mm) A2 A1 c A θ L Symbol Dimensions In Millimeters Dimensions In Inches Min Max Min Max A 1.350 1.750 0.053 0.069 A1 0.100 0.250 0.004 0.010 A2 1.350 1.550 0.053 0.061 b 0.310 0.510 0.012 0.020 c 0.100 0.250 0.004 0.010 D 8.450 8.850 0.333 0.348 e 1.270(BSC) 0.050(BSC) E 5.800 6.200 0.228 0.244 E1 3.800 4.000 0.150 0.157 L 0.400 1.270 0.016 0.050 θ 0° 8° 0° 8° 9 www.run-ic.com RS8051, RS8052, RS8054 TDFN2x2-8 E e D E1 L b D1 TOP VIEW BOTTOM VIEW 0.50 0.70 A1 1.95 A2 A 0.65 0.24 1.20 SIDE VIEW RECOMMENDED LAND PATTERN (Unit: mm) Symbol Dimensions In Millimeters Dimensions In Inches Min Max Min Max A 0.700 0.800 0.028 0.031 A1 0.000 0.050 0.000 0.002 A2 0.203(TYP) 0.008(TYP) b 0.180 0.300 0.007 0.012 D 1.900 2.100 0.075 0.083 D1 1.100 1.300 0.043 0.051 E 1.900 2.100 0.075 0.083 E1 0.600 0.800 0.024 0.031 e L 0.500(TYP) 0.250 0.020(TYP) 0.450 10 0.010 0.018 www.run-ic.com
RS8051XF 价格&库存
很抱歉,暂时无法提供与“RS8051XF”相匹配的价格&库存,您可以联系我们找货
