HEN35UVB308-20-H1
HEN35UVB308-20-H1
    HENLAI(恒磊光)
    SMD,3.5x3.5mm
    LED灯珠 3535 UVB 6V SMD,3.5x3.5mm
HEN35UVB308-20-H1 数据手册
REV:REV.2.1 Date:2020.3.06 SPECIFICATION FOR APPROVAL 承认书 Product Name: 3535 UVB LED PKG @ If=100mA Customer Parts No.: Parts No.: Date: Company: Division: Approved by: HENUVB35P14W01 Features - Lighting Color (Peak Wavelength):303~315nm - Surface Mount Type:3.5×3.5×1.6(L×W×H)[Unit:mm] - Viewing Angle(Directivity):Typical 120° - Soldering Methods:Reflow Soldering Outline Dimensions 3.50 1.30 3.20 1.20 0.45 0.46 0.45 1.59 1.00 3.30 3.20 1.40 NOTES: 1. All dimensions are in millimeters (inches). 2. Tolerance is ±0.10mm (0.004”) unless otherwise specified. 3. Specifications are subject to change without notice. 0.50 Applications - Disinfection, Phototherapy, Fluorescent Spectroscopy, Sensor Light,Bio-Analysis / Detection, Counterfeit Detectors, etc. Absolute Maximum Ratings Items Symbols Ratings Unit Forward Current If 150 mA Power Dissipation Pd 1000 mW Reverse Voltage VR 5 V Operating Temperature Topr -10~+60 ℃ StorageTemperature Tstg -40 ~ +100 ℃ Soldering Temperature JEDEC-J-STD-020D Operating the LED beyond the listed maximum ratings may affect device reliability and cause permanent damage. These or any other conditions beyond those indicated under recommended operating conditions are not implied. The exposure to the absolute maximum rated conditions may affect device reliability. The LEDs are not designed to be driven in reverse bias. Electro-Optical Characteristics Items Symbols Condition Min. Typ. Max unit Forward Voltage Vf If = 100mA 5.0 6.0 6.5 V Radiant Flux Φe If = 100mA Peak Wavelength λp If = 100mA Spectrum Half Width △λ If = 100mA 13 nm Viewing Angle 2Θ1/2 If = 100mA 120 deg Reverse Current Ir If = 100mA mW 20 303 308 315 10 nm μA These values are measured by the Photonwave optical spectrum analyzer within the following tolerances. - Forward Voltage(Vf) : ±0.1V - Peak Wavelength(λp) : ±3.0nm - Radiant Flux(Φe) : ±10% Although all LEDs are tested by Photonwave equipment, some values may vary slightly depending on the conditions of the test equipment. Typical Characteristic Curves Relative Radiant Flux vs. Forward Current 300% 200 180 160 140 120 100 80 60 40 20 0 250% Relative po.[a.u.] Forward Current(mA) Forward Current vs. Forward Voltage 200% 150% 100% 50% 0 2 4 6 0% 8 50 Forward Voltage (V) 100 125 150 175 200 Forward Current(mA) Spectrum Peak Wavelength vs. Forward Current 315 314 313 312 311 310 309 308 307 306 305 304 303 302 301 300 1.2 Relative Radiant Flux[a.u.] Peak Wavelength[nm] 75 1 0.8 0.6 0.4 0.2 0 60 80 100 120 140 160 180 200 Forward Current[mA Radiation Characteristics(Angle of Beam Spread,Directivity) 260 268 276 284 292 300 308 316 324 332 340 Peal Wavelength[nm] Soldering : 1. Manual Soldering The temperature of the iron tip should not be higher than 350℃and Soldering time to be within 3 seconds per solder-pad. 2. Reflow Soldering Preheating : 140℃~160℃±5℃,within 2 minutes. Operation heating : 260℃(Max.) within 10 seconds.(Max) Gradual Cooling (Avoid quenching). Storage: In order to avoid the absorption of moisture, it is recommended to solder PTW LEDs as soon as possible after unpacking the sealed envelope. If the envelope is still packed, to store it in the environment as following: 1.Temperature : 5℃-30℃ Humidity : RH 60%Max. 2.After this bag is opened, devices that will be applied to infrared reflow,vapor-phase reflow, or equivalent soldering process must be: a. Completed within 168 hours. b. Stored at less than 30% RH. 3.Devices require baking before mounting, if: (2) a or (2) b is not met. 4.If baking is required, devices must be baked under below conditions:48 hours at 60℃±3℃. Tapping and packaging specifications(Units:mm) Package Method(unit:mm) 10 bag/box 1000 pcs/reel 225 Bar Code Label 270 280 215 Aluminum Foil Bag 130
HEN35UVB308-20-H1 价格&库存
很抱歉,暂时无法提供与“HEN35UVB308-20-H1”相匹配的价格&库存,您可以联系我们找货
