ADV7303AKST
ADV7303AKST
    ROCHESTER(罗切斯特)
    64-LQFP
    SDTV/HDTV VIDEO DECODER
ADV7303AKST 数据手册
a Multiformat SD, Progressive Scan/HDTV Video Encoder with Six 11-Bit DACs ADV7302A/ADV7303A FEATURES High Definition Input Formats YCrCb Compliant to SMPTE293M (525 p), ITU-R.BT1358 (625 p), SMPTE274M (1080 i), SMPTE296M (720 p), and Any Other High Definition Standard Using Async Timing Mode RGB in 3 ⴛ 8-Bit 4:4:4 Format BTA T-1004 EDTV2 525 p Parallel High Definition Output Formats (525 p/625 p/720 p/1080 i) YPrPb Progressive Scan (EIA-770.1, EIA-770.2) YPrPb HDTV (EIA 770.3) RGB + H/V (HDTV 5-Wire Format) CGMS-A (720 p/1080 i) Macrovision Rev 1.0 (525 p/625 p)* CGMS-A (525 p) Standard Definition Input Formats CCIR-656 4:2:2 8-Bit Parallel Input CCIR-601 4:2:2 16-Bit Parallel Input Standard Definition Output Formats Composite NTSC M, N; PAL M, N, B, D, G, H, I, PAL-60 SMPTE170M NTSC Compatible Composite Video ITU-R.BT470 PAL Compatible Composite Video S-Video (Y/C) EuroScart RGB Component YUV (Betacam, MII, SMPTE/EBU N10) Macrovision Rev 7.1* CGMS/WSS Closed Captioning GENERAL FEATURES Simultaneous SD and HD Inputs and Outputs Oversampling (108 MHz/148.5 MHz) On-Board Voltage Reference 6 Precision Video 11-Bit DACs 2-Wire Serial MPU Interface Dual I/O Supply 2.5 V/3.3 V Operation Analog and Digital Supply 2.5 V On-Board PLL 64-LQFP Package Lead-Free Product SIMPLIFIED FUNCTIONAL BLOCK DIAGRAM STANDARD DEFINITION CONTROL BLOCK S7–S0 COLOR CONTROL BRIGHTNESS DNR GAMMA PROGRAMMABLE FILTERS SD TEST PATTERN D E M U X PROGRAMMABLE RGB MATRIX Y7–Y0 C7–C0 S_HSYNC S_VSYNC S_BLANK P_HSYNC P_VSYNC P_BLANK CLKIN_A CLKIN_B D E M U X HIGH DEFINITION CONTROL BLOCK HD TEST PATTERN TIMING GENERATOR COLOR CONTROL ADAPTIVE FILTER CTRL SHARPNESS FILTER PLL ADV7302A/ ADV7303A 11-BIT DAC O V E R S A M P L I N G 11-BIT DAC 11-BIT DAC 11-BIT DAC 11-BIT DAC 11-BIT DAC I2C INTERFACE GENERAL DESCRIPTION The ADV7302A/ADV7303A is a high speed, digital-to-analog encoder on a single monolithic chip. It includes six high speed video D/A converters with TTL compatible inputs. The ADV7302A/ADV7303A has three separate 8-bit wide input ports that accept data in high definition and/or standard definition video format. For all standards, external horizontal, vertical, and blanking signals, or EAV/SAV timing codes, control the insertion of appropriate synchronization signals into the digital data stream and therefore the output signals. APPLICATIONS DVD Players SD/HD Display Devices SD/HD Set-Top Boxes SD/HDTV Studio Equipment *ADV7302A Only REV. A Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. Tel: 781/329-4700 www.analog.com Fax: 781/326-8703 © Analog Devices, Inc., 2002 ADV7302A/ADV7303A DETAILED FEATURES High Definition Programmable Features (720 p/1080 i) 2 Oversampling (148.5 MHz) Internal Test Pattern Generator (Color Hatch, Black Bar, Flat Field/Frame) Fully Programmable YCrCb to RGB Matrix Gamma Correction Programmable Adaptive Filter Control Programmable Sharpness Filter Control CGMS-A (720 p/1080 i) High Definition Programmable Features (525 p/625 p) 4 Oversampling (108 MHz Output) Internal Test Pattern Generator (Color Hatch, Black Bar, Flat Frame) Individual Y and PrPb Output Delay Gamma Correction Programmable Adaptive Filter Control Fully Programmable YCrCb to RGB Matrix Undershoot Limiter HD PIXEL INPUT CLKIN_B Y DEINTER- CR LEAVE CB TEST PATTERN P_HSYNC P_VSYNC P_BLANK TIMING GENERATOR S_HSYNC S_VSYNC S_BLANK TIMING GENERATOR CLKIN_A SD PIXEL INPUT SHARPNESS AND ADAPTIVE FILTER CONTROL Macrovision Rev 1.0 (525 p/625 p)* CGMS-A (525 p) Standard Definition Programmable Features 8 Oversampling (108 MHz) Internal Test Pattern Generator (Color Bars, Black Bar) Controlled Edge Rates for Sync, Active Video Individual Y and UV Output Delay Gamma Correction Digital Noise Reduction Multiple Chroma and Luma Filters Luma-SSAF™ Filter with Programmable Gain/ Attenuation UV SSAF Separate Pedestal Control on Component and Composite/S-Video Outputs VCR FF/RW Sync Mode Macrovision Rev 7.1* CGMS/WSS Closed Captioning DAC Y COLOR CR COLOR CB COLOR PS 4 HDTV 2 4:2:2 TO 4:4:4 DAC DAC CLOCK CONTROL AND PLL UV SSAF CB DEINTER- CR LEAVE Y TEST PATTERN DAC RGB MATRIX SD 8 DAC DNR GAMMA DAC SYNC INSER- U TION V COLOR CONTROL CGMS WSS LUMA AND CHROMA FILTERS 2 OVERSAMPLING FSC MODULATION Figure 1. Functional Block Diagram HDTV SD Standard Definition Video, conforming to ITU-R.BT601/ITU-R.BT656. High Definition Television Video, conforming to SMPTE274M or SMPTE296M. YCrCb SD or HD Component Digital Video HD High Definition Video, i.e., Progressive Scan or HDTV. YPrPb HD Component Analog Video PS Progressive Scan Video, conforming to SMPTE293M or ITU-R.BT1358. YUV SD Component Analog Video TERMS USED IN THIS DATA SHEET SSAF is a trademark of Analog Devices, Inc. *ADV7302A Only –2– REV. A ADV7302A/ADV7303A–SPECIFICATIONS (V = V = 2.375 V–2.625 V, V = 2.375 V–3.600 V, V = 1.235 V, R = 760 , R = 150 , T AA DD DD_IO Parameter REF SET Min MIN to TMAX (0C to 70C), unless otherwise noted.) LOAD Typ Max Unit Test Conditions Bits LSB LSB LSB VAA = 2.5 V VAA = 2.5 V VAA = 2.5 V 1 STATIC PERFORMANCE Resolution Integral Nonlinearity Differential Nonlinearity, +ve2 Differential Nonlinearity, –ve2 DIGITAL OUTPUTS Output Low Voltage, VOL Output High Voltage, VOH Three-State Leakage Current Three-State Output Capacitance DIGITAL AND CONTROL INPUTS Input High Voltage, VIH Input Low Voltage, VIL Input Leakage Current Input Capacitance, CIN ANALOG OUTPUTS Full-Scale Output Current Output Current Range Full-Scale Output Current Output Current Range DAC to DAC Matching Output Compliance Range, VOC Output Capacitance, COUT VOLTAGE REFERENCE Reference Range, VREF POWER REQUIREMENTS Normal Power Mode IDD4 IDD_IO IAA5, 6 Sleep Mode IDD IAA IDD_IO Power Supply Rejection Ratio 11 ± 1.0 0.125 1.0 0.4 [0.4]3 3 2.4 [2.0] ± 1.0 2 2 0.8 1 2 8.2 8.2 4.1 4.1 0 1.15 8.7 8.7 4.35 4.35 2.0 1.0 7 1.235 93 52 84 90 99 108 0.2 70 37 130 10 110 0.01 9.2 9.2 4.6 4.6 1.4 1.3 110 75 45 V V µA pF V V µA pF mA mA mA mA % V pF ISINK = 3.2 mA ISOURCE = 400 µA VIN = 0.4 V, 2.4 V VIN = 2.4 V RSET1, 2 = 1520 Ω RSET1, 2 = 1520 Ω V mA mA mA mA mA mA mA mA mA SD Only [8⫻] PS Only [4⫻] HDTV Only [2⫻] SD and PS SD [8⫻] and HDTV SD and HDTV [2⫻] RSET1, 2 = 1520 Ω µA µA µA %/% NOTES 1 Oversampling disabled. Static DAC performance will be improved with increased oversampling ratios. 2 DNL measures the deviation of the actual DAC o/p voltage step from the ideal. For +ve DNL, the actual step value lies above the ideal step value; for –ve DNL, the actual step values lie below the ideal step value. 3 Value in brackets for V DD_IO = 2.375 V to 2.750 V. 4 IDD or the circuit current is the continuous current required to drive the digital core without the I PLL. 5 IAA is the total current required to supply all DACs including the V REF circuitry and the PLL circuitry. 6 All DACs on. Specifications subject to change without notice. REV. A –3– ADV7302A/ADV7303A DYNAMIC SPECIFICATIONS Parameter (VAA = VDD = 2.375 V–2.625 V, VDD_IO = 2.375 V–3.600 V, VREF = 1.235 V, RSET = 760 , RLOAD = 150 , TMIN to TMAX (0C to 70C), unless otherwise noted.) Min Typ Max Unit Test Conditions PROGRESSIVE SCAN MODE Luma Bandwidth Chroma Bandwidth SNR SNR SNR 12.5 5.8 59 75 70 MHz MHz dB dB dB Luma Ramp Unweighted Flat Field up to 5 MHz Flat Field Full Bandwidth HDTV MODE Luma Bandwidth Chroma Bandwidth SNR SNR SNR 30 13.75 59 75 70 MHz MHz dB dB dB Luma Ramp Unweighted Flat Field up to 5 MHz Flat Field Full Bandwidth STANDARD DEFINITION MODE Hue Accuracy Color Saturation Accuracy Chroma Nonlinear Gain Chroma Nonlinear Phase Chroma/Luma Intermod Chroma/Luma Gain Ineq Chroma/Luma Delay Ineq Luminance Nonlinearity Chroma AM Noise Chroma PM Noise Differential Gain Differential Phase SNR SNR SNR 0.2 0.54 ± 0.4 ± 0.3 ± 0.05 ± 98 0.9 ± 0.4 84 74 0.6 1.4 59 75 70 Degrees % % Degrees % % ns % dB dB % Degrees dB dB dB Referenced to 40 IRE NTSC NTSC Luma Ramp Flat Field up to 5 MHz Flat Field Full Bandwidth Specifications subject to change without notice. –4– REV. A ADV7302A/ADV7303A (VAA = VDD = 2.375 V–2.625 V, VDD_IO = 2.375 V–3.600 V, VREF = 1.235 V, RSET = 760 , RLOAD = 150 , MIN to TMAX (0C to 70C), unless otherwise noted.) TIMING SPECIFICATIONS T Parameter Min Typ Max Unit 400 kHz µs µs µs Test Conditions 1 MPU PORT SCLOCK Frequency SCLOCK High Pulsewidth, t1 SCLOCK Low Pulsewidth, t2 Hold Time (Start Condition), t3 0 0.6 1.3 0.6 Setup Time (Start Condition), t4 0.6 Data Setup Time, t5 SDATA, SCLOCK Rise Time, t6 SDATA, SCLOCK Fall Time, t7 Setup Time (Stop Condition), t8 RESET Low Time 100 300 300 0.6 100 ANALOG OUTPUTS Analog Output Delay2 Output Skew CLOCK CONTROL AND PIXEL PORT3 fCLK fCLK Clock High Time, t9 Clock Low Time, t10 Data Setup Time, t11 Data Hold Time, t121 Output Access Time, t13 Output Hold Time, t14 Pipeline Delay µs 8 1 First Clock Generated After This Period Relevant for Repeated Start Condition ns ns ns µs ns ns ns 27 61 62.5 66.5 33 MHz MHz % 1 clkcycle % 1 clkcycle ns ns ns ns clkcycles clkcycles clkcycles clkcycles 43.5 36 clkcycles clkcycles 81 40 40 2.0 2.0 14 4.0 Progressive Scan Mode HDTV Mode/Async Mode SD [2⫻] SD [8⫻] SD Component Filter [8⫻] PS [1⫻], HD [1⫻], Async Timing Mode PS [4⫻] HD [2⫻] NOTES 1 Guaranteed by characterization. 2 Output delay measured from the 50% point of the rising edge of CLOCK to the 50% point of DAC output full-scale transition. 3 Data: C[7:0]; S[7:0]; Y[7:0] Control: P_HSYNC; P_ VSYNC; P_BLANK; S_HSYNC; S_VSYNC; S_BLANK Specifications subject to change without notice. REV. A –5– ADV7302A/ADV7303A CLKIN_A t9 CONTROL I/PS t12 t10 P_HSYNC, P_VSYNC, P_BLANK Y7–Y0 Y0 Y1 Y2 Y3 Y4 Y5 C7–C0 Cb0 Cr0 Cb2 Cr2 Cb4 Cr4 t11 CONTROL O/PS t13 S_HSYNC, S_VSYNC t14 t9 = CLOCK HIGH TIME, t10 = CLOCK LOW TIME, t11 = DATA SETUP TIME, t12 = DATA HOLD TIME Figure 2. HD 4:2:2 Input Data Format Timing Diagram, Input Mode: PS Input Only, HDTV Input Only (Input Mode at Subaddress 01h = 001 or 010) CLKIN_A t9 CONTROL I/PS Y7–Y0 Y0 Y1 Y2 C7–C0 Cb0 Cb1 Cb2 S7–S0 Cr0 Cr1 Cr2 t11 CONTROL O/PS t10 P_HSYNC, P_VSYNC, P_BLANK Yxxx Yxxx Cb3 Cbxxx Cbxxx Cr3 Crxxx Crxxx t12 t13 S_HSYNC, S_VSYNC t14 t9 = CLOCK HIGH TIME, t10 = CLOCK LOW TIME, t11 = DATA SETUP TIME, t12 = DATA HOLD TIME Figure 3. HD 4:4:4 YCrCb Input Data Format Timing Diagram, Input Mode: PS Input Only, HDTV Input Only (Input Mode at Subaddress 01h = 001 or 010) –6– REV. A ADV7302A/ADV7303A CLKIN_A t9 CONTROL I/PS Y7–Y0 G0 G1 G2 G3 Gxxx Gxxx C7–C0 B0 B1 B2 B3 Bxxx Bxxx S7–S0 R0 R1 R2 Rxxx Rxxx t11 CONTROL O/PS t10 P_HSYNC, P_VSYNC, P_BLANK t12 t13 S_HSYNC, S_VSYNC t14 t9 = CLOCK HIGH TIME, t10 = CLOCK LOW TIME, t11 = DATA SETUP TIME, t12 = DATA HOLD TIME Figure 4. HD 4:4:4 RGB Input Data Format Timing Diagram, HD RGB Input Enabled (Input Mode at Subaddress 01h = 001 or 010) CLKIN_B t9 CONTROL I/PS t10 P_HSYNC, P_VSYNC, P_BLANK Y7–Y0 Cb0 Y0 Cr0 Y1 t12 t11 CONTROL O/PS Crxxx Yxxx t12 t11 t13 S_HSYNC, S_VSYNC t14 t9 = CLOCK HIGH TIME, t10 = CLOCK LOW TIME, t11 = DATA SETUP TIME, t12 = DATA HOLD TIME Figure 5. PS 4:2:2 1 ⫻ 8-Bit Interleaved @ 27 MHz, Input Mode: PS Input Only (Input Mode at Subaddress 01h = 100) REV. A –7– ADV7302A/ADV7303A CLKIN_A t10 t9 CONTROL I/PS P_HSYNC, P_VSYNC, P_BLANK Y7–Y0 Cb0 t11 Y0 Cr0 Y1 Crxxx Yxxx t13 t12 t14 CONTROL O/PS S_HSYNC, S_VSYNC t9 = CLOCK HIGH TIME, t10 = CLOCK LOW TIME, t11 = DATA SETUP TIME, t12 = DATA HOLD TIME Figure 6. PS 4:2:2 1 ⫻ 8-Bit Interleaved @ 54 MHz, Input Mode: PS 54 MHz Input (Input Mode at Subaddress 01h = 111) CLKIN_A t9 CONTROL I/PS t10 t12 S_HSYNC, S_VSYNC, S_BLANK S7–S0 IN SLAVE MODE Cb Y Cr Y t11 CONTROL O/PS Cb Y t13 IN MASTER/SLAVE MODE WITH EAV/SAV S_HSYNC, S_VSYNC t14 Figure 7. 8-Bit SD Pixel Input Timing Diagram, Input Mode: SD Input Only (Input Mode at Subaddress 01h = 000) –8– REV. A ADV7302A/ADV7303A CLKIN_A @ 27MHz t9 CONTROL I/PS t12 t10 S_HSYNC, S_VSYNC, S_BLANK IN SLAVE MODE Y0 S7–S0 Y1 Cb0 Y7–Y0 Y2 Cr0 Cb2 t11 CONTROL O/PS Y3 Cr2 t13 IN MASTER/SLAVE MODE WITH EAV/SAV S_HSYNC, S_VSYNC t14 Figure 8. 16-Bit SD Pixel Input Timing Diagram, Input Mode: SD Input Only (Input Mode at Subaddress 01h = 000) CLKIN_B t9 CONTROL I/PS t12 t10 P_HSYNC, P_VSYNC, P_BLANK Y7–Y0 Y0 Y1 Y2 Y3 Y4 Y5 C7–C0 Cb0 Cr0 Cb2 Cr2 Cb4 Cr4 HD INPUT t11 CLKIN_A CONTROL I/PS S_HSYNC, S_VSYNC, S_BLANK S7–S0 t9 t12 t10 SD INPUT Cb0 Y0 Y1 Cr0 Cb1 Y2 t11 Figure 9. SD and HD Simultaneous Input, Input Mode: SD and PS 16-Bit or SD and HDTV (Input Mode at Subaddress 01h = 011, 101, or 110) REV. A –9– ADV7302A/ADV7303A CLKIN_B t10 t9 CONTROL I/PS P_HSYNC, P_VSYNC, P_BLANK Y7–Y0 PS INPUT Cb0 t11 Y0 Cr0 Crxxx Y1 t12 Yxxx t12 t11 CLKIN_A CONTROL I/PS S_HSYNC, S_VSYNC, S_BLANK S7–S0 t9 t12 t10 SD INPUT Cb0 Y0 Cr0 Cb1 Y1 Y2 t11 Figure 10. SD and HD Simultaneous Input, Input Mode: SD and PS 8-Bit (Input Mode at Subaddress 01h = 100) P_HSYNC P_VSYNC a P_BLANK Y7–Y0 Cb Y Cr Y b a = 32 CLKCYCLES FOR 525p a = 24 CLKCYCLES FOR 625p AS RECOMMENDED BY STANDARD b(MIN) = 244 CLKCYCLES FOR 525p b(MIN) = 264 CLKCYCLES FOR 625p Figure 11. PS 4:2:2 1 ⫻ 8-Bit Interleaved @ 54 MHz Input Timing Diagram –10– REV. A ADV7302A/ADV7303A P_HSYNC P_VSYNC a P_BLANK Y7–Y0 Y0 Y1 Y2 Y3 S7–S0 Cr0 Cr1 Cr2 Cr3 C7–C0 Cb0 Cb1 Cb2 Cb3 Cb Y Cr Y b a = 16 CLKCYCLES FOR 525p a = 12 CLKCYCLES FOR 626p a = 44 CLKCYCLES FOR 1080i a = 70 CLKCYCLES FOR 720p AS RECOMMENDED BY STANDARD b(MIN) = 122 CLKCYCLES FOR 525p b(MIN) = 132 CLKCYCLES FOR 625p b(MIN) = 236 CLKCYCLES FOR 1080i b(MIN) = 300 CLKCYCLES FOR 720p Figure 12. HD Input Timing Diagram HSYNC FIELD PAL = 12  CLOCK/2 NTSC = 16  CLOCK/2 BLANK PIXEL DATA PAL = 132  CLOCK/2 NTSC = 122  CLOCK/2 Figure 13. SD Timing Input for Timing Mode 1 t3 t5 t3 SDA t1 t6 SCLK t2 t4 t7 Figure 14. MPU Port Timing Diagram REV. A –11– t8 ADV7302A/ADV7303A The ADV7302A/ADV7303A is a lead-free environmentally friendly product. It is manufactured using the most up-to-date materials and processes. The coating on the leads of each device is 100% pure tin electroplate. The device is suitable for lead-free applications and is able to withstand surface-mount soldering at up to 255°C (± 5°C). In addition, it is backward compatible with conventional tin-lead soldering processes. This means that the electroplated tin coating can be soldered with tin-lead solder pastes at conventional reflow temperatures of 220°C to 235°C. ABSOLUTE MAXIMUM RATINGS* VAA to AGND . . . . . . . . . . . . . . . . . . . . . . . . +3.0 V to –0.3 V VDD to GND . . . . . . . . . . . . . . . . . . . . . . . . . +3.0 V to –0.3 V VDD_IO to IO_GND . . . . . . . . . . . . . –0.3 V to VDD_IO + 0.3 V Ambient Operating Temperature (TA) . . . . . . . 0°C to +70°C Storage Temperature (TS) . . . . . . . . . . . . . . –65°C to +150°C Infrared Reflow Soldering (20 sec) . . . . . . . . . . . . . . . . 260°C *Stresses above those listed under Absolute Maximum Ratings may cause permanent damage to the device. This is a stress rating only; functional operation of the device at these or any other conditions above those listed in the operational sections of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. ORDERING GUIDE THERMAL CHARACTERISTICS Model Package Description Package Option θJC = 11°C/W θJA = 47°C/W ADV7302AKST ADV7303AKST Plastic Quad Flatpack Plastic Quad Flatpack ST-64B ST-64B CAUTION ESD (electrostatic discharge) sensitive device. Electrostatic charges as high as 4000 V readily accumulate on the human body and test equipment and can discharge without detection. Although the ADV7302A/ADV7303A features proprietary ESD protection circuitry, permanent damage may occur on devices subjected to high energy electrostatic discharges. Therefore, proper ESD precautions are recommended to avoid performance degradation or loss of functionality. S_VSYNC S_HSYNC GND_IO GND_IO S0 S1 VDD S2 DGND S3 S4 S5 S6 S7 CLKN_B GND_IO PIN CONFIGURATION 64 63 62 61 60 59 58 57 56 55 54 53 52 51 50 49 VDD_IO 1 GND_IO 2 48 S_BLANK PIN 1 IDENTIFIER 47 RSET1 46 VREF GND_IO 3 Y0 4 45 COMP1 Y1 5 44 DAC A 43 DAC B Y2 6 Y3 7 ADV7302A/ADV7303A 42 DAC C Y4 8 TOP VIEW (Not to Scale) 41 VAA 40 AGND Y5 9 VDD 10 DGND 11 39 DAC D Y6 12 37 DAC F Y7 13 36 COMP2 GND_IO 14 35 RSET2 34 EXT_LF 38 DAC E GND_IO 15 33 RESET C0 16 CLKIN_A RTC_SCR_TR C7 C6 C5 C4 C3 P_VSYNC P_BLANK P_HSYNC SCLK SDA I2C ALSB C2 C1 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 PIN FUNCTION DESCRIPTIONS Pin No. Mnemonic Input/Output Function 1 VDD_IO P Power Supply for Digital Inputs and Outputs 4–9, 12, 13 Y0–Y7 I 8-Bit Progressive Scan/HDTV Input Port for Y Data. The LSBs are set up on Pins Y0 and Y1. In default mode, the input on this port is output on DAC D. 16–18, 26–30 C0–C7 I 8-Bit Progressive Scan/HDTV Input Port for CrCb Color Data in 4:2:2 Input Mode. In 4:4:4 Input Mode, this input port is used for the Cb (Blue/U) data. The LSBs are set up on Pins C0 and C1. In default mode, the input on this port is output on DAC E. –12– REV. A ADV7302A/ADV7303A Pin No. Mnemonic 2 Input/Output Function 19 IC I This input pin must be tied high (VDD_IO) for the ADV7302A/ADV7303A to interface over the I2C port. 20 ALSB I/O TTL Address Input. This signal sets up the LSB of the MPU address. When this pin is tied low, the I2C filter is activated, which reduces noise on the I2C interface. 21 SDA I/O MPU Port Serial Data Input/Output 22 SCLK I MPU Port Serial Interface Clock Input 23 P_HSYNC I Video Horizontal Sync Control Signal for HD Sync in Simultaneous SD/HD Mode and HD Only Mode 24 P_VSYNC I Video Vertical Sync Control Signal for HD Sync in Simultaneous SD/HD Mode and HD Only Mode 25 P_BLANK I Video Blanking Control Signal for HD Sync in Simultaneous SD/HD Mode and HD Only Mode 31 RTC_SCR_TR I Multifunctional Input: Realtime Control (RTC) Input, Timing Reset Input, and Subcarrier Reset Input 32 CLKIN_A I Pixel Clock Input for HD Only or SD Only Modes 33 RESET I This input resets the on-chip timing generator and sets the ADV7302A/ ADV7303A into default register setting. Reset is an active low signal. 34 EXT_LF I External Loop Filter for the internal PLL 35, 47 RSET2, 1 I A 760 Ω resistor must be connected from this pin to AGND and is used to control the amplitudes of the DAC outputs. 36, 45 COMP2, 1 O Compensation Pin for DACs. Connect 0.1 µF Capacitor from COMP Pin to VAA. 37 DAC F O In SD Only Mode: Chroma/Red/V Analog Output, in HD Only Mode and Simultaneous HD/SD: Pr/Red (HD) Analog Output 38 DAC E O In SD Only Mode: Luma/Blue/U Analog Output, in HD Only Mode and Simultaneous HD/SD: Pb/Blue (HD) Analog Output 39 DAC D O In SD Only Mode: CVBS/Green/Y Analog Output, in HD Only Mode and Simultaneous HD/SD: Y/Green (HD) Analog Output 40 AGND G Analog Ground 41 VAA P Analog Power Supply 42 DAC C O Chroma/Red/V SD Analog Output 43 DAC B O Luma/Blue/U SD Analog Output 44 DAC A O CVBS/Green/Y SD Analog Output 46 VREF I/O Optional External Voltage Reference Input for DACs or Voltage Reference Output (1.235 V) 48 S_BLANK I/O Video Blanking Control Signal for SD 49 S_VSYNC I/O Video Vertical Control Signal for SD. Option to output SD VSYNC or SD HSYNC in SD Slave Mode 0 and/or any HD Mode. 50 S_HSYNC I/O Video Horizontal Control Signal for SD. Option to output SD HSYNC or HD HSYNC in SD Slave Mode 0 and/or any HD Mode. 53–55, 58–62 S0–S7 I 8-Bit Standard Definition Input Port or Progressive Scan/HDTV Input Port for Cr (Red/V) color data in 4:4:4 Input Mode. The LSBs are set up on Pins S0 and S1. In Default Mode, the input on this port is output on DAC F. 10, 56 VDD P Digital Power Supply 11, 57 DGND G Digital Ground 63 CLKIN_B I Pixel Clock Input. Requires a 27 MHz reference clock for Progressive Scan Mode or a 74.25 MHz (74.1758 MHz) reference clock in HDTV Mode. This clock input pin is only used in Simultaneous SD/HD Mode. 2, 3, 14, 15, 51, 52, 64 GND_IO REV. A Digital Ground –13– ADV7302A/ADV7303A MPU PORT DESCRIPTION The ADV7302A/ADV7303A supports a 2-wire serial (I2C compatible) microprocessor bus driving multiple peripherals. Two inputs, Serial Data (SDA) and Serial Clock (SCL), carry information between any device connected to the bus. Each slave device is recognized by a unique address. The ADV7302A/ ADV7303A has four possible slave addresses for both read and write operations. These are unique addresses for each device and are illustrated in Figures 15 and 16. The LSB sets either a read or write operation. Logic Level “1” corresponds to a read operation, while Logic Level “0” corresponds to a write operation. A1 is set by setting the ALSB Pin of the ADV7302A/ADV7303A to Logic Level “0” or Logic Level “1.” When ALSB is set to “1,” there is greater input bandwidth on the I2C lines, which allows high speed data transfers on this bus. When ALSB is set to “0,” there is reduced input bandwidth on the I2C lines, which means that pulses of less than 50 ns will not pass into the I2C internal controller. This mode is recommended for noisy systems. 1 1 0 1 0 1 A1 X ADDRESS CONTROL SET UP BY ALSB WRITE READ Figure 15. ADV7302A Slave Address = D4h 0 1 0 1 0 1 A1 Stop and start conditions can be detected at any stage during the data transfer. If these conditions are asserted out of sequence with normal read and write operations, it will cause an immediate jump to the idle condition. During a given SCLK high period, the user should issue only one start condition, one stop condition, or a single stop condition followed by a single start condition. If an invalid subaddress is issued by the user, the ADV7302A/ADV7303A will not issue an acknowledge and will return to the idle condition. If in Autoincrement Mode the user exceeds the highest subaddress, the following action will be taken: 2. In Write Mode, the data for the invalid byte will not be loaded into any subaddress register, a no-acknowledge will be issued by the ADV7302A/ADV7303A, and the part will return to the idle condition. X ADDRESS CONTROL Before writing to the subcarrier frequency registers, it is a requirement that the ADV7302A/ADV7303A has been reset at least once since power-up. SET UP BY ALSB READ/WRITE CONTROL 0 1 The ADV7302A/ADV7303A acts as a standard slave device on the bus. The data on the SDA Pin is eight bits long, supporting the 7-bit addresses plus the R/W Bit. It interprets the first byte as the device address and the second byte as the starting subaddress. The subaddress’s autoincrement allows data to be written to or read from the starting subaddress. A data transfer is always terminated by a stop condition. The user can also access any unique subaddress register on a one-by-one basis without having to update all the registers. 1. In Read Mode, the highest subaddress register contents will continue to be output until the master device issues a noacknowledge. This indicates the end of a read. A no-acknowledge condition is where the SDA line is not pulled low on the ninth pulse. READ/WRITE CONTROL 0 1 A Logic “0” on the LSB of the first byte means that the master will write information to the peripheral. A Logic “1” on the LSB of the first byte means that the master will read information from the peripheral. The four Subcarrier Frequency Registers must be updated starting with Subcarrier Frequency Register 0. The subcarrier frequency will not update until the last subcarrier frequency register byte has been received by the ADV7302A/ADV7303A. WRITE READ Figure 16. ADV7303A Slave Address = 54h To control the various devices on the bus, the following protocol must be followed. First, the master initiates a data transfer by establishing a start condition, defined by a high-to-low transition on SDA, while SCLK remains high. This indicates that an address/ data stream will follow. All peripherals respond to the start condition and shift the next eight bits (7-bit address + R/W Bit). The bits are transferred from MSB down to LSB. The peripheral that recognizes the transmitted address responds by pulling the data line low during the ninth clock pulse. This is known as an Acknowledge Bit. All other devices withdraw from the bus at this point and maintain an idle condition. The idle condition is where the device monitors the SDA and SCLK lines waiting for the start condition and the correct transmitted address. The R/W Bit determines the direction of the data. Figure 17 illustrates an example of data transfer for a read sequence and the start and stop conditions. Figure 18 shows bus write and read sequences. SDATA SCLOCK –14– S 1–7 8 9 START ADRR R/W ACK 1–7 8 9 SUBADDRESS ACK 1–7 DATA 8 9 P ACK STOP Figure 17. Bus Data Transfer REV. A ADV7302A/ADV7303A WRITE SEQUENCE S SLAVE ADDR A(S) SUB ADDR A(S) DATA LSB = 0 READ SEQUENCE S SLAVE ADDR A(S) S = START BIT P = STOP BIT A(S) DATA A(S) P LSB = 1 SUB ADDR A(S) S SLAVE ADDR A(S) DATA A(M) DATA A(M) P A(S) = NO-ACKNOWLEDGE BY SLAVE A(M) = NO-ACKNOWLEDGE BY MASTER A(S) = ACKNOWLEDGE BY SLAVE A(M) = ACKNOWLEDGE BY MASTER Figure 18. Read and Write Sequence REGISTER ACCESSES REGISTER PROGRAMMING The MPU can write to or read from all of the registers of the ADV7302A/ADV7303A except the subaddress registers that are write-only registers. The subaddress register determines which register the next read or write operation accesses. All communications with the part through the bus start with an access to the subaddress register. Then a read/write operation is performed from/to the target address which then increments to the next address until a stop command on the bus is performed. The following section describes the functionality of each register. All registers can be read from as well as written to, unless otherwise stated. Subaddress Register (SR7–SR0) The Communications Register is an 8-bit write-only register. After the part has been accessed over the bus and a read/write operation is selected, the subaddress is set up. The Subaddress Register determines to/from which register the operation takes place. Register Select (SR7–SR0) These bits are set up to point to the required starting address. REV. A –15– ADV7302A/ADV7303A Table I. Power Mode Register Subaddress Register Bit Description 00h Power Mode Register Sleep Mode1 Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Register Setting PLL and Oversampling Control2 DAC F: Power On/Off DAC E: Power On/Off DAC D: Power On/Off DAC C: Power On/Off DAC B: Power On/Off DAC A: Power On/Off 0 Sleep Mode Off 1 Sleep Mode On 0 PLL On 1 PLL Off 0 DAC F Off 1 DAC F On 0 DAC E Off 1 DAC E On 0 DAC D Off 1 DAC D On 0 DAC C Off 1 DAC C On 0 DAC B Off 1 DAC B On 0 DAC A Off 1 DAC A On Reset Fch NOTES 1 When enabled, the current consumption is reduced to µA level. All DACs and the internal PLL cct are disabled. I2C registers can be read from and written to. 2 This control allows the internal PLL circuit to be powered down and the oversampling to be switched off. Table II. Input Mode Register Subaddress Register Bit Description 01h BTA T-1004 Compatibility Input Mode Register Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Register Setting Reserved 0 0 Pixel Align 1 Clock Align Disabled 1 Enabled Reset 38h Zero must be written to this bit. Video input data starts with a Y0 bit. Only for PS Interleaved Mode. Video input data starts with a Cb0 bit. 0 1 Input Mode Reserved 0 0 0 0 Must be set if the phase delay between the two input clocks is 27.75 ns. Only if two input clocks are used. SD Input Only 0 0 1 PS Input Only 0 1 0 HDTV Input Only 0 1 1 SD and PS (16-Bit) 1 0 0 SD and PS (8-Bit) SD and HDTV (SD Oversampled) SD and HDTV (HDTV Oversampled) 1 0 1 1 1 0 1 1 1 0 PS 54 MHz Input Zero must be written to this bit. –16– REV. A ADV7302A/ADV7303A Table III. Mode Register Subaddress Register Bit Description 02h Reserved Mode Register 0 Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Register Setting 0 0 0 Test Pattern Black Bar 1 1 0 SYNC on RGB 1 1 0 SD SYNC 1 HD SYNC Output SD SYNCs on S_HSYNC and S_VSYNC 0 No SYNC Output 1 03h F0h 03h RGB Matrix 0 X X Output HD SYNCs on S_HSYNC and S_VSYNC LSB for GY 04h RGB Matrix 1 X X LSB for RV X REV. A 20h SYNC on all RGB Outputs RGB Component Outputs YUV Component Outputs No SYNC Output 0 RGB/YUV Output Reset Enabled. 0x11h, Bit 2 must also be enabled. Disable Programmable RGB Matrix Enable Programmable RGB Matrix No SYNC 0 RGB Matrix Zero must be written to these bits. Disabled X X X X X LSB for BU LSB for GV LSB for GU 05h RGB Matrix 2 X X X X X X X X Bits 9–2 for GY 4Eh 06h RGB Matrix 3 X X X X X X X X Bits 9–2 for GU 0Eh 07h RGB Matrix 4 X X X X X X X X Bits 9–2 for GV 24h 08h RGB Matrix 5 X X X X X X X X Bits 9–2 for BU 92h X X X X X X X X Bits 9–2 for RV 09h RGB Matrix 6 0Ah Reserved 00h 0Bh Reserved 00h 0Ch Reserved 00h 0Dh Reserved 00h 0Eh Reserved 00h 0Fh Reserved 00h –17– 7Ch ADV7302A/ADV7303A Table IV. HD Mode Register Subaddress Register Bit Description 10h HD Mode Register 1 HD Output Standard Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Register Setting HD Input Control Signals HD 625 p HD 720 p HD BLANK Polarity HD Macrovision for 525 p/625 p 11h HD Mode Register 2 0 0 EIA770.2 Output 0 1 EIA770.1 Output 1 0 1 1 Output Levels for Full Input Range Reserved 0 0 0 1 HSYNC, VSYNC, BLANK EAV/SAV Codes1 1 0 Async Timing Mode 1 1 Reserved 0 525 p 1 625 p 0 1080 i 1 720 p 0 BLANK Active High 1 BLANK Active Low 0 Macrovision Off 1 Macrovision On HD Pixel Data Valid 0 Pixel Data Valid Off 1 Pixel Data Valid On 0 HD Test Pattern Enable HD Test Pattern Hatch/Field HD VBI Open HD Undershoot Limiter HD Sharpness Filter 12h HD Mode Register 3 1 HD Test Pattern Off Hatch 1 Field/Frame 0 Disabled 1 Enabled 0 Disabled 0 1 –11 IRE 1 0 –6 IRE 1 1 –1.5 IRE 0 Disabled 1 Enabled HD CGMS HD CGMS CRC HD Test Pattern Off 0 HD Color Delay wrt Falling Edge of HSYNC 0 0 0 0 Clock Cycle 0 0 1 1 Clock Cycle 0 1 0 2 Clock Cycle 0 1 1 3 Clock Cycle 1 0 0 4 Clock Cycle 0 0 0 0 Clock Cycle 0 0 1 1 Clock Cycle 0 1 0 2 Clock Cycle 0 1 1 3 Clock Cycle 1 0 0 4 Clock Cycle 0 Disabled 1 Enabled 0 Disabled 1 Enabled –18– 00h Reserved 0 0 HDY Delay wrt Falling Edge of HSYNC Reset 00h REV. A ADV7302A/ADV7303A Table IV. HD Mode Register (continued) Subaddress Register Bit Description 13h HD Cr/Cb Sequence 1 HD Mode Register 4 Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Register Setting 0 1 0 Reserved 0 Sync Filter on DAC D, E, F Reserved 0 Disabled 1 Enabled 0 HD Chroma SSAF 1 Reserved 0 Disabled 1 HD Chroma Input HD Double Buffering Enabled 0 4:4:4 1 4:2:2 0 Disabled 1 14h HD Mode Register 5 15h HD Mode Register 6 0 Enabled 0 0 0 0 0 0 Reserved 0 1 HD Sync on PrPb 2 0 HD Gamma Curve A/B HD Gamma Curve Enable HD Adaptive Filter Mode HD Adaptive Filter Enable A Low-High-Low 00h transition resets the internal HD timing counters. Zero must be written 00h to this bit. Disabled Enabled 0 Disabled 1 Enabled 0 DAC E = Pb, DAC F = Pr DAC F = Pb, DAC E = Pr Gamma Curve A 1 Gamma Curve B 1 0 Disabled 1 Enabled 0 Mode A 1 Mode B 0 Disabled 1 Enabled NOTES 1 4:2:2 Input Format Only 2 4:4:4 Input Format Only REV. A X 0 HD RGB Input HD Color DAC Swap Reset Cb after Falling 4Ch Edge of HSYNC Cr after Falling Edge of HSYNC. Reserved –19– ADV7302A/ADV7303A Table V. Register Settings Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Register Setting Reset 16h HD Y Color X X X X X X X X Y Color Value A0h 17h HD Cr Color X X X X X X X X Cr Color Value 80h 18h HD Cb Color X X X X X X X X Cb Color Value 80h 19h Reserved 00h 1Ah Reserved 00h 1Bh Reserved 00h 1Ch Reserved 00h 1Dh Reserved 00h 1Eh Reserved 00h 1Fh Reserved 20h HD Sharpness Filter Gain Subaddress Register Bit Description 00h HD Sharpness Filter Gain Value A HD Sharpness Filter Gain Value B 0 0 0 0 Gain A = 0 0 0 0 1 Gain A = +1 … … … … … 0 1 1 1 Gain A = +7 1 0 0 0 Gain A = –8 … … … … … 1 1 1 1 Gain A = –1 0 0 0 0 Gain B = 0 0 0 0 1 Gain B = +1 … … … … … 0 1 1 1 Gain B = +7 1 0 0 0 Gain B = –8 … … … … … 1 1 1 1 Gain B = –1 00h 21h HD CGMS Data 0 HD CGMS Data Bits 0 0 0 0 C19 C18 C17 C16 CGMS 19–16 00h 22h HD CGMS Data 1 HD CGMS Data Bits C15 C14 C13 C12 C11 C10 C9 C8 CGMS 15–8 00h 23h HD CGMS Data 2 HD CGMS Data Bits C7 24h HD Gamma A 25h HD Gamma A 26h HD Gamma A 27h HD Gamma A 28h HD Gamma A 29h HD Gamma A 2Ah HD Gamma A 2Bh HD Gamma A 2Ch HD Gamma A 2Dh HD Gamma A 2Eh HD Gamma B 2Fh HD Gamma B 30h HD Gamma B 31h HD Gamma B 32h HD Gamma B 33h HD Gamma B 34h HD Gamma B HD Gamma Points HD Gamma Points HD Gamma Points HD Gamma Points HD Gamma Points HD Gamma Points HD Gamma Points HD Gamma Points HD Gamma Points HD Gamma Points HD Gamma Points HD Gamma Points HD Gamma Points HD Gamma Points HD Gamma Points HD Gamma Points HD Gamma Points C6 C5 C4 C3 C2 C1 C0 CGMS 7–0 00h Curve A Data X X X X X X X X A0 00h Curve A Data X X X X X X X X A1 00h Curve A Data X X X X X X X X A2 00h Curve A Data X X X X X X X X A3 00h Curve A Data X X X X X X X X A4 00h Curve A Data X X X X X X X X A5 00h Curve A Data X X X X X X X X A6 00h Curve A Data X X X X X X X X A7 00h Curve A Data X X X X X X X X A8 00h Curve A Data X X X X X X X X A9 00h Curve B Data X X X X X X X X B0 00h Curve B Data X X X X X X X X B1 00h Curve B Data X X X X X X X X B2 00h Curve B Data X X X X X X X X B3 00h Curve B Data X X X X X X X X B4 00h Curve B Data X X X X X X X X B5 00h Curve B Data X X X X X X X X B6 00h –20– REV. A ADV7302A/ADV7303A Table VI. HD Adaptive Filters Subaddress Register 38h HD Adaptive Filter Gain 1 39h 3Ah 3Bh 3Ch 3Dh REV. A HD Adaptive Filter Gain 2 HD Adaptive Filter Gain 3 HD Adaptive Filter Threshold A HD Adaptive Filter Threshold B HD Adaptive Filter Threshold C Bit Description HD Adaptive Filter Gain 1 Value A Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Register Setting 0 0 0 0 Gain A = 0 0 0 0 1 Gain A = +1 0 1 1 1 Gain A = +7 1 0 0 0 Gain A = –8 1 1 1 1 Gain A = –1 HD Adaptive Filter Gain 1 0 Value B 0 0 0 0 Gain B = 0 0 0 1 Gain B = +1 0 1 1 1 Gain B = +7 1 0 0 0 Gain B = –8 1 1 1 1 HD Adaptive Filter Gain 2 Value A Gain B = –1 0 0 0 0 Gain A = 0 0 0 0 1 Gain A = +1 0 1 1 1 Gain A = +7 1 0 0 0 Gain A = –8 1 1 1 1 Gain A = –1 HD Adaptive Filter Gain 2 0 Value B 0 0 0 0 Gain B = 0 0 0 1 Gain B = +1 0 1 1 1 Gain B = +7 1 0 0 0 Gain B = –8 1 1 1 1 Gain B = –1 HD Adaptive Filter Gain 3 Value A 0 0 0 0 Gain A = 0 0 0 0 1 Gain A = +1 0 1 1 1 Gain A = +7 1 0 0 0 Gain A = –8 1 1 1 1 Gain A = –1 HD Adaptive Filter Gain 3 0 Value B 0 0 0 0 Gain B = 0 0 0 1 Gain B = +1 0 1 1 1 Gain B = +7 1 0 0 0 Gain B = –8 1 1 1 1 X X X X HD Adaptive Filter Threshold A Value HD Adaptive Filter Threshold B Value HD Adaptive Filter Threshold C Value Reset 00hex 00hex 00hex Gain B = –1 X X X X Threshold A 00hex X X X X X X X X Threshold B 00hex X X X X X X X X Threshold C 00hex –21– ADV7302A/ADV7303A Table VII. SD Mode Registers Subaddress Register 3Eh Reserved 3Fh Reserved 40h SD Mode Register 0 Bit Description Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Register Setting 00h 00h SD Standard SD Luma Filter SD Chroma Filter 41h Reserved 42h SD Mode Register 1 Reset 0 0 NTSC 0 1 PAL B, D, G, H, I 1 0 PAL M 1 1 PAL N 0 0 0 LPF NTSC 0 0 1 LPF PAL 0 1 0 Notch NTSC 0 1 1 Notch PAL 1 0 0 SSAF Luma 1 0 1 Luma CIF 1 1 0 Luma QCIF 1 1 1 Reserved 0 0 0 1.3 MHz 0 0 1 0.65 MHz 0 1 0 1.0 MHz 0 1 1 2.0 MHz 1 0 0 Reserved 1 0 1 Chroma CIF 1 1 0 Chroma QCIF 1 1 1 3.0 MHz 00h 00h SD UV SSAF SD DAC Output 1* 0 1 SD DAC Output 2 0 0 Disabled 1 Enabled 08h DAC A, B, C: CVBS, L, C; DAC D, E, F: GBR or YUV DAC A, B, C: GBR or YUV; DAC D, E, F: CVBS, L, C Swap DAC A and DAC D Outputs 1 SD Pedestal SD Square Pixel SD VCR FF/RW Sync SD Pixel Data Valid SD Active Video Edge 0 Disabled 1 Enabled 0 Disabled 1 Enabled 0 Disabled 1 Enabled 0 Disabled 1 Enabled 0 Disabled 1 Enabled –22– REV. A ADV7302A/ADV7303A Table VII. SD Mode Registers (continued) Subaddress Register 43h SD Mode Register 2 Bit Description SD Pedestal YUV Output Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Register Setting 0 No Pedestal on YUV 1 SD Output Levels Y SD Output Levels UV SD VBI Open SD CC Field Control 0 7.5 IRE Pedestal on YUV Y = 700 mV/300 mV 1 Y = 714 mV/286 mV 0 0 0 1 700 mV p-p [PAL]; 1000 mV p-p [NTSC] 700 mV p-p 1 0 1000 mV p-p 1 1 648 mV p-p 0 Disabled 1 Enabled 0 0 CC Disabled 0 1 CC on Odd Field Only 1 0 1 1 CC on Even Field Only CC on Both Fields 1 44h SD Mode Register 3 Reserved SD VSYNC-3H SD RTC/TR/SCR SD Chroma SD Burst Reserved 45h Reserved 46h Reserved 47h SD Mode Register 4 Disabled 1 0 0 VSYNC = 2.5 lines [PAL]; VSYNC = 3 lines [NTSC] Genlock Disabled 0 1 Subcarrier Reset 1 0 Timing Reset 1 1 RTC Enabled 720 Pixels 1 0 710 (NTSC); 702(PAL) Chroma Enabled 1 Chroma Disabled 0 Enabled 1 Disabled 0 Disabled 1 Enabled 0 00h Zero must be written to this bit. 00h 00h SD UV Scale SD Y Scale SD Hue Adjust SD Brightness SD Luma SSAF Gain Reserved 0 Reserved Reserved REV. A 0 0 SD Active Video Length SD Color Bars Reset 00h 0 0 –23– 0 Disabled 1 Enabled 0 Disabled 1 Enabled 0 Disabled 1 Enabled 0 Disabled 1 Enabled 0 Disabled 1 Enabled Zero must be written to this bit. Zero must be written to this bit. Zero must be written to this bit. 00h ADV7302A/ADV7303A Table VII. SD Mode Registers (continued) Subaddress Register 48h SD Mode Register 5 Bit Description Reserved Reserved SD Double Buffering Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Register Setting 0 Zero must be written to this bit. 0 Zero must be written to this bit. 0 Disabled 1 SD Input Format Reserved SD Gamma Control SD Gamma Curve 49h SD Mode Register 6 8-Bit Input 1 16-Bit Input 0 Zero must be written to this bit. Disabled 1 Enabled 0 Disabled 1 Enabled 0 Gamma Curve A 1 Gamma Curve B SD Undershoot Limiter SD Black Burst Output on DAC Y SD Black Burst Output on DAC Luma SD Chroma Delay Reserved Reserved 0 0 00h Enabled 0 0 SD Digital Noise Reduction Reset 0 0 Disabled 0 1 –11 IRE 1 0 –6 IRE 1 1 –1.5 IRE 0 Disabled 1 Enabled 0 Disabled 1 Enabled 0 0 Disabled 0 1 4 Clock Cycles 1 0 8 Clock Cycles 1 1 Reserved 00h Zero must be written to this bit. Zero must be written to this bit. *For more detail, see Input and Output Configuration section. –24– REV. A ADV7302A/ADV7303A Table VIII. SD Registers Subaddress Register Bit Description 4Ah SD Timing Register 0 SD Slave/Master Mode Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Register Setting SD Timing Mode SD BLANK Input 0 Slave Mode 1 Master Mode 0 0 Mode 0 0 1 Mode 1 1 0 Mode 2 1 1 Mode 3 1 SD Min. Luma Value Disabled 0 0 No Delay 0 1 2 Clock Cycles 1 0 4 Clock Cycles 1 1 6 Clock Cycles 0 –40 IRE 1 SD Timing Reset 4Bh SD Timing Register 1 X 0 –7.5 IRE 0 0 SD HSYNC to VSYNC Delay HSYNC to Pixel Data Adjust 0 0 0 A low-high-low transistion will reset the internal SD timing counters. 0 0 Ta = 1 Clock Cycle 0 1 Ta = 4 Clock Cycles 1 0 Ta = 16 Clock Cycles 1 1 Ta = 128 Clock Cycles 0 0 Tb = 0 Clock Cycle 0 1 Tb = 4 Clock Cycles 1 0 Tb = 8 Clock Cycles 1 1 Tb = 18 Clock Cycles X 0 Tc = Tb X 1 Tc = Tb + 32 µs 0 0 1 Clock Cycle 0 1 4 Clock Cycles 1 0 16 Clock Cycles 1 1 128 Clock Cycles 0 0 0 Clock Cycle 0 1 1 Clock Cycle 1 0 2 Clock Cycles 00h 1 1 4Ch SD FSC Register 0 X X X X X X X X 4Dh SD FSC Register 1 X X X X X X X X 4Eh SD FSC Register 2 X X X X X X X X 4Fh SD FSC Register 3 X X X X X X X X 50h SD FSC Phase X X X X X X X X 51h X X X X X X X X X X X X X X X X X X X X X X X X Extended Data Bits 15–8 Data Bits 7–0 00h 53h SD Closed Captioning Extended Data on Even Fields SD Closed Captioning Extended Data on Even Fields SD Closed Captioning Data on Odd Fields 54h SD Closed Captioning Data on Odd Fields X X X X X X X X Data Bits 15–8 00h 55h SD Pedestal Register 0 Pedestal on Odd Fields 17 16 15 14 13 12 11 10 56h SD Pedestal Register 1 Pedestal on Odd Fields 25 24 23 22 21 20 19 18 57h SD Pedestal Register 2 Pedestal on Even Fields 17 16 15 14 13 12 11 10 Setting any of these bits 00h to 1 will disable pedestal on the line 00h number indicated by the bit settings. 00h 58h SD Pedestal Register 3 Pedestal on Even Fields 25 24 23 22 21 20 19 18 00h 52h REV. A 0 SD HSYNC Width SD HSYNC to VSYNC Rising Edge Delay (Mode 1 Only); VSYNC Width (Mode 2 Only) 08h Enabled 0 SD Luma Delay Reset –25– 3 Clock Cycles Subcarrier Frequency Bits 7–0 Subcarrier Frequency Bits 15–8 Subcarrier Frequency Bits 23–16 Subcarrier Frequency Bits 31–24 Subcarrier Phase Bits 9–2 Extended Data Bits 7–0 16h 7Ch F0h 21h 00h 00h 00h ADV7302A/ADV7303A Table VIII. SD Registers (continued) Subaddress Register 59h SD CGMS/WSS 0 Bit Description SD CGMS Data SD CGMS CRC Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Register Setting 19 18 17 16 CGMS Data Bits C19–C16 0 Disabled 1 SD CGMS on Odd Fields SD CGMS on Even Fields SD WSS 5Ah SD CGMS/WSS 1 SD CGMS/WSS Data 5Bh SD CGMS/WSS 2 SD CGMS/WSS Data 5Ch SD LSB Register SD LSB for Y Scale Value Enabled 0 Disabled 1 Enabled 0 Disabled 1 Enabled 0 Disabled 1 Enabled 15 14 7 6 13 12 11 10 9 8 5 4 3 2 1 0 X X X X SD LSB for U Scale Value SD LSB for V Scale Value X X Reset 00h CGMS Data Bits 00h C13–C8 or WSS Data Bits C13–C8 CGMS Data Bits C15–C14 CGMS/WSS Data Bits 00h C7–C0 SD Y Scale Bits 1–0 SD U Scale Bits 1–0 SD V Scale Bits 1–0 SD LSB for FSC Phase X X 5Dh SD Y Scale Register SD Y Scale Value X X X X X X X X Subcarrier Phase Bits 1–0 SD Y Scale Bits 7–2 00h 5Eh SD V Scale Register SD V Scale Value X X X X X X X X SD V Scale Bits 7–2 00h 5Fh SD U Scale Register SD U Scale Value X X X X X X X X SD U Scale Bits 7–2 00h 60h SD Hue Register SD Hue Adjust Value X X X X X X X X 61h SD Brightness/WSS SD Brightness Value X X X X X X X SD Hue Adjust Bits 00h 7–0 SD Brightness Bits 6–0 00h SD Blank WSS Data* 0 Disabled 1 62h 63h SD Luma SSAF SD DNR 0 SD Luma SSAF Gain/Attenuation Enabled 0 0 0 0 0 0 0 0 –4 dB 0 0 0 0 0 1 1 0 0 dB 0 0 0 0 1 1 0 0 +4 dB 0 0 0 0 No Gain +1/16 (–1/8 in DNR Mode) +2/16 (–2/8 in DNR Mode) +3/16 (–3/8 in DNR Mode) +4/16 (–4/8 in DNR Mode) +5/16 (–5/8 in DNR Mode) +6/16 (–6/8 in DNR Mode) +7/16 (–7/8 in DNR Mode) +8/16 (–1 in DNR Mode) No Gain Coring Gain Border Coring Gain Data 0 0 0 0 0 0 1 0 0 1 0 0 0 1 1 0 1 0 0 0 1 0 1 0 1 1 0 0 1 1 1 1 0 0 0 –26– 0 0 0 0 1 0 0 1 0 0 0 1 1 0 1 0 0 0 1 0 1 0 1 1 0 0 1 1 1 1 0 0 0 00h 00h +1/16 (–1/8 in DNR Mode) +2/16 (–2/8 in DNR Mode) +3/16 (–3/8 in DNR Mode) +4/16 (–4/8 in DNR Mode) +5/16 (–5/8 in DNR Mode) +6/16 (–6/8 in DNR Mode) +7/16 (–7/8 in DNR Mode) +8/16 (–1 in DNR Mode) REV. A ADV7302A/ADV7303A Table VIII. SD Registers (continued) Subaddress Register 64h SD DNR 1 Bit Description DNR Threshold Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Register Setting 0 0 0 0 0 0 0 Border Area 0 0 0 0 0 1 1 1 1 1 1 1 0 62 1 1 1 1 1 1 0 4 Pixels 0 8 Pixels 1 65h SD DNR 2 16 Pixels DNR Input Select DNR Mode DNR Block Offset 66h SD Gamma A 67h SD Gamma A 68h SD Gamma A 69h SD Gamma A 6Ah SD Gamma A 6Bh SD Gamma A 6Ch SD Gamma A 6Dh SD Gamma A 6Eh SD Gamma A 6Fh SD Gamma A 70h SD Gamma B 71h SD Gamma B 72h SD Gamma B 73h SD Gamma B 74h SD Gamma B 75h SD Gamma B 76h SD Gamma B 77h SD Gamma B 78h SD Gamma B 79h SD Gamma B SD Gamma Curve A Points SD Gamma Curve A Points SD Gamma Curve A Points SD Gamma Curve A Points SD Gamma Curve A Points SD Gamma Curve A Points SD Gamma Curve A Points SD Gamma Curve A Points SD Gamma Curve A Points SD Gamma Curve A Points SD Gamma Curve B Points SD Gamma Curve B Points SD Gamma Curve B Points SD Gamma Curve B Points SD Gamma Curve B Points SD Gamma Curve B Points SD Gamma Curve B Points SD Gamma Curve B Points SD Gamma Curve B Points SD Gamma Curve B Points Detect SD Brightness Value 7Ah SD Brightness 7Bh Field Count Register 0 1 Filter A 0 1 0 Filter B 0 1 1 Filter C 1 0 0 Filter D DNR Mode 1 DNR Sharpness Mode 0 0 0 0 0 Pixel Offset 0 0 0 1 1 Pixel Offset 1 1 1 0 14 Pixel Offset 00h 1 1 1 1 Data X X X X X X X X A0 00h Data X X X X X X X X A1 00h Data X X X X X X X X A2 00h Data X X X X X X X X A3 00h Data X X X X X X X X A4 00h Data X X X X X X X X A5 00h Data X X X X X X X X A6 00h Data X X X X X X X X A7 00h Data X X X X X X X X A8 00h Data X X X X X X X X A9 00h Data X X X X X X X X B0 00h Data X X X X X X X X B1 00h Data X X X X X X X X B2 00h Data X X X X X X X X B3 00h Data X X X X X X X X B4 00h Data X X X X X X X X B5 00h Data X X X X X X X X B6 00h Data X X X X X X X X B7 00h Data X X X X X X X X B8 00h Data X X X X X X X X B9 00h X X X X X Reserved 15 Pixel Offset 0 Reserved 0 Reserved REV. A 0 0 Field Count Reserved Code 63 2 Pixels 1 Block Size Control Reset 00h 0 X X –27– X X X Read-Only X X X Read-Only Zero must be written to this bit. Zero must be written to this bit. Zero must be written to this bit. Read-Only ADV7302A/ADV7303A Table VIII. SD Registers (continued) Subaddress Register Bit Description 7Ch Reset Register Timing Reset Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Register Setting Reserved No reset of Timing 00h Generator in Subcarrier Reset Mode. 44h, Bits 1 and 2 must be set to Subcarrier Reset. 1 Reset Timing Generator in Subcarrier Reset Mode 0 Reserved Zero must be written to this bit. Zero must be written to this bit. Zero must be written to this bit. Zero must be written to this bit. Zero must be written to this bit. Zero must be written to this bit. Zero must be written to this bit. 0 Reserved 0 Reserved 0 Reserved 0 Reserved 0 Reserved Reset 0 0 *Line 23 LINE 1 HSYNC LINE 313 LINE 314 tA tC tB VSYNC Figure 19. Timing Register 1 in PAL Mode Table IX. Macrovision Registers* Subaddress Register 7Dh Reserved Bit Description Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Register Setting Reset 7Eh Reserved 7Fh Reserved 80h Macrovision MV Control Bits X X X X X X X X MV 3a [7:0] 00h 81h Macrovision MV Control Bits X X X X X X X X MV 3b [15:8] 00h 82h Macrovision MV Control Bits X X X X X X X X MV 3c [23:16] 00h 83h Macrovision MV Control Bits X X X X X X X X MV 3d [31:24] 00h 84h Macrovision MV Control Bits X X X X X X X X MV 3e [39:32] 00h 85h Macrovision MV Control Bits X X X X X X X X MV 3f [47:40] 00h 86h Macrovision MV Control Bits X X X X X X X X MV 40 [55:48] 00h 87h Macrovision MV Control Bits X X X X X X X X MV 41 [63:56] 00h 88h Macrovision MV Control Bits X X X X X X X X MV 42 [71:64] 00h 89h Macrovision MV Control Bits X X X X X X X X MV 43 [79:72] 00h 8Ah Macrovision MV Control Bits X X X X X X X X MV 44 [87:80] 00h 8Bh Macrovision MV Control Bits X X X X X X X X MV 45 [95:88] 00h 8Ch Macrovision MV Control Bits X X X X X X X X MV 46 [103:96] 00h 8Dh Macrovision MV Control Bits X X X X X X X X MV 47 [111:104] 00h 8Eh Macrovision MV Control Bits X X X X X X X X MV 48 [119:112] 00h 8Fh Macrovision MV Control Bits X X X X X X X X MV 49 [127:120] 00h X X X X X X X X MV 4A [135:128] 00h X MV 4B [136] 00h 90h Macrovision MV Control Bits 91h Macrovision MV Control Bit 0 0 0 0 0 0 0 Zero must be written to these bits. *Macrovision Registers are only available on the ADV7302A. –28– REV. A ADV7302A/ADV7303A INPUT AND OUTPUT CONFIGURATION STANDARD DEFINITION ONLY SMPTE274M (1080 i), SMPTE296M (720 p), or BTA-T1004, the Async Timing Mode must be used. The 8-bit multiplexed input data is input on Pins S7–S0, with S0 being the LSB. ITU-R.BT601/ITU-R.BT656 input standards are supported. In 16-bit Input Mode, the Y pixel data is input on Pins S7–S0 and CrCb data on Pins Y7–Y0. The 27 MHz clock input must be input on Pin CLKIN_A. Input sync signals are optional and are input on the S_VSYNC, S_HSYNC, and S_BLANK pins. The 8-bit standard definition data must be compliant to ITUR.BT601/ITU-R.BT656 in 4:2:2 format. Standard definition data is input on Pins S7–S0, with S0 being the LSB. The clock input for SD must be input on CLKIN_A, and the clock input for HD must be input on CLKIN_B. Synchronization signals are optional. SD syncs are input on Pins S_VSYNC, S_HSYNC, and S_BLANK; the HD syncs on Pins P_VSYNC, P_HSYNC, and P_BLANK. ADV7302A/ ADV7303A 3 MPEG2 DECODER 27MHz YCrCb 8 ADV7302A/ ADV7303A S_VSYNC S_HSYNC S_BLANK MPEG2 DECODER CLKIN_A YCrCb 3 27MHz S7–S0 Y 8 INTERLACED TO PROGRESSIVE 3 PROGRESSIVE SCAN ONLY OR HDTV ONLY YCrCb Progressive Scan, HDTV, or any other HD YCrCb data can be input in 4:2:2 or 4:4:4 format. In 4:2:2 Input Mode, the Y data is input on Pins Y7–Y0 and the CrCb data on Pins C7– C0. In 4:4:4 Input Mode, Y data is input on Pins Y7–Y0, Cb data on Pins C7–C0, and Cr data on Pins S7–S0. If the YCrCb data does not conform to SMPTE293M (525 p), ITU-R.BT1358M (625 p), SMPTE274M (1080 i), SMPTE296M (720 p), or BTA-T1004, the Async Timing Mode must be used. RGB data can only be input in 4:4:4 format in PS Input Mode only, or HDTV Input Mode only, when HD RGB input is enabled. G data is input on Pins Y7–Y0, R data on S7–S0, and B data on Pins C7–C0. The clock signal must be input on Pin CLKIN_A. Synchronization signals are optional and are input on Pins P_VSYNC, P_HSYNC, and P_BLANK. MPEG2 DECODER YCrCb INTERLACED TO PROGRESSIVE 27MHz Cr 8 Cb 8 Y 8 3 S7–S0 C7–C0 Y7–Y0 P_VSYNC P_HSYNC P_BLANK CLKIN_B Figure 22. Simultaneous Progressive Scan and SD Input ADV7302A/ ADV7303A 3 SDTV DECODER 27MHz YCrCb 8 HDTV DECODER CrCb 1080 i Y 720 p ADV7302A/ ADV7303A 27MHz CLKIN_A 8 CrCb 8 Figure 20. Standard Definition Only Input Mode S_VSYNC S_HSYNC S_BLANK 8 8 3 74MHz CLKIN_A S7–S0 S_VSYNC S_HSYNC S_BLANK CLKIN_A S7–S0 C7–C0 Y7–Y0 P_VSYNC P_HSYNC P_BLANK CLKIN_B Figure 23. Simultaneous HDTV and SD Input C7–C0 If in Simultaneous Input Mode the two clock phases differ by less than 9.25 ns or more than 27.75 ns, the Clock Align Bit must be set accordingly. This also applies if the Pixel Align Bit is set. If the application uses the same clock source for both SD and PS, the Clock Align Bit must be set since the phase difference between both inputs is less than 9.25 ns. Y7–Y0 P_VSYNC P_HSYNC P_BLANK Figure 21. Progressive Scan Only Input Mode SIMULTANEOUS STANDARD DEFINITION AND PROGRESSIVE SCAN OR HDTV YCrCb PS, HDTV, or any other HD data must be input in 4:2:2 format. In 4:2:2 Input Mode, the Y data is input on Pins Y7–Y0 and the CrCb data on C7–C0. If PS 4:2:2 data is interleaved onto a single 8-bit bus, Pins Y7–Y0 are used for the input port. The interleaved data is to be input at 27 MHz in setting the Input Mode Register at Address 01h accordingly. If the YCrCb data does not conform to SMPTE293M (525 p), ITU-R.BT1358M (625 p), REV. A –29– tDELAY tDELAY 9.25ns OR 27.75ns Figure 24. Clock Phase with Two Input Clocks ADV7302A/ADV7303A PROGRESSIVE SCAN AT 27 MHz OR 54 MHz CLKIN_A YCrCb progressive scan data can be input at 27 MHz or 54 MHz. The input data is interleaved onto a single 8-bit bus and is input on Pins Y7–Y0. For PS Input Only Mode, the input clock must be input on CLKIN_A. In Simultaneous SD/HD Mode, the input clock is input on CLKIN_B. MPEG2 DECODER YCrCb INTERLACED TO PROGRESSIVE 27MHz OR 54MHz YCrCb 8 3 ADV7302A/ ADV7303A CLKIN_A Y7–Y0 PIXEL INPUT DATA 00 00 XY Y0 Cb0 Y1 Cr0 Figure 26. Input Sequence in PS 8-Bit Interleaved Mode, EAV/SAV Followed by Y0 Data If the input sequence starts with Cb0 data as shown in Figure 27, initially PIXEL ALIGN [Subaddress 01h] must be set to “0.” This ensures that the ADV7302A/ADV7303A locks to the input sequence in decoding the embedded timing information correctly. For correct color decoding, the Pixel Align Bit [Subaddress 01h] must then be set to “l” after a delay of one field. The ADV7302A/ADV7303A is now in free run mode, any changes in the timing information are ignored. P_VSYNC P_HSYNC P_BLANK CLKIN_A Figure 25. 1 ⫻ 8-Bit PS @ 27 MHz or 54 MHz When the input sequence of the PS data, i.e., 8-bit interleaved at 27 MHz, starts with Y0 data as shown in Figure 26, PIXEL ALIGN [Subaddress 01h] must be set to “0.” In this case, the timing information embedded in the data stream is recognized and the video data is transferred to the according Y channel and CrCb channel processing blocks. 3FF PIXEL INPUT DATA 3FF 00 00 XY Cb0 Y0 Cr0 Y1 Figure 27. Input Sequence in PS 8-Bit Interleaved Mode, EAV/SAV Followed by Cb0 Data PS 8-bit interleaved at 54 MHz must be input with separate timing signals. EAV/SAV codes cannot be used in this mode. –30– REV. A ADV7302A/ADV7303A Table X. Overview of All Possible Input Configurations Input Format Total Bits Input Video Input Pins Subaddress ITU-R.BT656 8 4:2:2 YCrCb S7–S0 [MSB = S7] 01h, 48h 00h, 00h 16 4:2:2 Y S7–S0 [MSB = S7] 01h, 48h 00h, 08h CrCb Y7–Y0 [MSB =Y7] 8 (27 MHz Clock) 4:2:2 YCrCb Y7–Y0 [MSB =Y7] 01h, 13h 10h, 40h 8 (54 MHz Clock) 4:2:2 YCrCb Y7–Y0 [MSB =Y7] 01h, 13h 70h, 40h 16 4:2:2 Y Y7–Y0 [MSB =Y7] 01h, 13h 10h, 40h CrCb C7–C0 [MSB = C7] 24 4:4:4 Y Y7–Y0 [MSB =Y7] 01h, 13h 10h, 00h Cb C7–C0 [MSB = C7] PS Only HDTV Only Cr S7–S0 [MSB = S7] 8 4:2:2 YCrCb Y7–Y0 [MSB =Y7] 01h, 13h 20h, 40h 16 4:2:2 Y Y7–Y0 [MSB =Y7] 01h, 13h 20h, 40h CrCb C7–Y0 [MSB = C7] Y Y7–Y0 [MSB =Y7] 01h, 13h 20h, 00h Cb C7–Y0 [MSB = C7] 01h, 13h, 15h 10h or 20h, 00h, 02h 40h 24 HD RGB REV. A Register Setting 24 4:4:4 4:4:4 Cr S7–S0 [MSB = S7] G Y7–Y0 [MSB =Y7] B C7–C0 [MSB = C7] R S7–S0 [MSB = S7] ITU-R.BT656 and PS 8 4:2:2 YCrCb S7–S0 [MSB = S7] 01h 8 4:2:2 YCrCb Y7–Y0 [MSB =Y7] 13h, 48h 40h, 00h ITU-R.BT656 and PS or HDTV 8 4:2:2 YCrCb S7–S0 [MSB = S7] 01h 16 4:2:2 Y Y7–Y0 [MSB =Y7] 13h, 48h 30h, 50h, or 60h 40h, 00h CrCb C7–C0 [MSB = C7] –31– ADV7302A/ADV7303A OUTPUT CONFIGURATION Tables XI–XIII demonstrate what output signals are assigned to the DACs when corresponding control bits are set. Table XI. Output Configuration in SD Only Mode RGB/YUV O/P Addr 02h, Bit 5 SD DAC O/P 1 Addr 42h, Bit 2 SD DAC O/P 2 Addr 42h, Bit 1 DAC A DAC B DAC C DAC D DAC E DAC F 0 0 0 0 1 1 1 1 0 0 1 1 0 0 1 1 0 1 0 1 0 1 0 1 CVBS G G CVBS CVBS Y Y CVBS Luma B Luma B Luma U Luma U Chroma R Chroma R Chroma V Chroma V G CVBS CVBS G Y CVBS CVBS Y B Luma B Luma U Luma U Luma R Chroma R Chroma V Chroma V Chroma Table XII. Output Configuration in HD Only Mode HD I/P Format HD RGB I/P Addr 15h, Bit 1 RGB/YUV O/P Addr 02h, Bit 5 HD Color Swap Addr 15h, Bit 3 DAC A DAC B DAC C DAC D DAC E DAC F YCrCb 4:2:2 YCrCb 4:2:2 YCrCb 4:2:2 YCrCb 4:2:2 YCrCb 4:4:4 YCrCb 4:4:4 YCrCb 4:4:4 YCrCb 4:4:4 RGB 4:4:4 RGB 4:4:4 RGB 4:4:4 RGB 4:4:4 N/A N/A N/A N/A N/A N/A N/A N/A 1 1 1 1 0 0 1 1 0 0 1 1 0 0 1 1 0 1 0 1 0 1 0 1 0 1 0 1 N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A G G Y Y G G Y Y G G G G B R Pb Pr B R Pb Pr B R B R R B Pr Pb R B Pr Pb R B R B Table XIII. Output Configuration in Simultaneous SD/HD Mode Input Formats RGB/YUV O/P Addr 02h, Bit 5 HD Color Swap Addr 15h, Bit 3 DAC A DAC B DAC C DAC D DAC E DAC F SD YCrCb in 4:2:2 and HD YCrCb in 4:2:2 0 0 CVBS Luma Chroma G B R SD YCrCb in 4:2:2 and HD YCrCb in 4:2:2 0 1 CVBS Luma Chroma G R B SD YCrCb in 4:2:2 and HD YCrCb in 4:2:2 1 0 CVBS Luma Chroma Y Pb Pr SD YCrCb in 4:2:2 and HD YCrCb in 4:2:2 1 1 CVBS Luma Chroma Y Pr Pb –32– REV. A ADV7302A/ADV7303A TIMING MODES HD Async Timing Mode [Subaddress 10h, Bits 3–2] For any input data that does not conform to SMPTE293M, SMPTE274M, SMPTE296M, or ITU-R.BT1358 standards, an Asynchronous Timing Mode can be used to interface to the ADV7302A/ADV7303A. Timing control signals for HSYNC, VSYNC, and BLANK have to be programmed by the user. Macrovision is not available in Async Timing Mode. Figure 28 shows an example of how to program the ADV7302A/ ADV7303A to accept a different high definition standard other than SMPTE293M, SMPTE274M, SMPTE296M, or ITU-R.BT1358 standards. Table XIV must be followed when programming the control signals in Async Timing Mode. HD Timing Reset A timing reset is achieved in setting the HD Timing Reset Control Bit at Address 14h from “0” to “1.” In this state, the horizontal and vertical counters will remain reset. On setting this bit back to “0,” the internal counters will again commence counting. The minimum time the pin has to be held high is one clock cycle; otherwise, this reset signal might not be recognized. This timing reset applies to the HD timing counters only. SD Timing Real-time Control, Subcarrier Reset, Timing Reset [Subaddress 44h, Bits 2–1] Together with the RTC_SCR_TR Pin and SD Mode Register 3 [Address 44h, Bits 1–2] the ADV7302A/ADV7303A can be used in Timing Reset Mode, Subcarrier Phase Reset Mode, or RTC Mode. a. A timing reset is achieved in a low-to-high transition on the RTC_SCR_TR Pin (Pin 31). In this state, the horizontal and vertical counters will remain reset. On releasing this pin (set to low), the internal counters will again commence counting. The minimum time the pin has to be held high is one clock cycle; otherwise, this reset signal might not be recognized. This timing reset applies to the SD timing counters only. b. Subcarrier phase reset, a low-to-high transition on the RTC_SCR_TR pin (Pin 31), will reset the subcarrier phase to zero when the SD RTC/TR/SCR control bits at Address 44h are set to “01.” This reset signal will have to be held high for a minimum of one clock cycle. Since the Field Counter is not reset, it is recommended to apply the reset in Field 7 (PAL). The reset of the phase will then occur on the next field by being correctly lined up with the internal counters. The Field Count Register at Address 7Bh can be used to identify the number of the active field. c. In RTC Mode, the ADV7302A/ADV7303A can be used to lock to an external video source. The Real-time Control Mode allows the ADV7302A/ADV7303A to automatically alter the subcarrier frequency to compensate for line length variations. When the part is connected to a device that outputs a digital data stream in the RTC format (such as a ADV7185 video decoder, see Figure 29), the part will automatically change to the compensated subcarrier frequency on a line-by-line basis. This digital data stream is 67 bits wide and the subcarrier is contained in Bits 0 to 21. Each bit is two clock cycles long. 00h should be written into all four Subcarrier Frequency Registers when using this mode. CLK P_HSYNC PROGRAMMABLE INPUT TIMING P_VSYNC P_BLANK* HORIZONTAL SYNC ACTIVE VIDEO ANALOG OUTPUT 81 66 a 66 b 243 1920 c d e *SET ADDRESS 10h, BIT 6 TO “1” Figure 28. Async Timing Mode, Programming Input Control Signals for SMPTE295M Compatibility REV. A –33– ADV7302A/ADV7303A Table XIV. Truth Table P_HSYNC P_VSYNC1 P_BLANK1 1→0 0 0→1 1 1 0 0→1 0 or 1 0 or 1 0 or 1 0 or 1 0 or 1 0 0→1 1→0 Reference2 50% point of falling edge of tri-level horizontal sync signal 25% point of rising edge of tri-level horizontal sync signal 50% point of falling edge of tri-level horizontal sync signal 50% start of active video 50% end of active video a b c d e NOTES For standards that do not require a tri-sync level, P_BLANK must be tied low at all times. 1 When Async Timing Mode is enabled, P_BLANK, Pin 25 becomes an active high input. P_BLANK is set to active low at Address 10h, Bit 6. 2 See Figure 28. ADV7302A/ ADV7303A CLKIN_A DAC A DAC B LCC1 COMPOSITE VIDEO1 RTC_SCR_TR GLL ADV7185 DAC C DAC D P19–P12 VIDEO DECODER DAC E S7–S0 DAC F 4 BITS RESERVED H/L TRANSITION 14 BITS COUNT START LOW RESERVED 128 13 0 SEQUENCE BIT3 RESERVED FSC PLL INCREMENT2 21 RESET BIT4 0 RTC TIME SLOT 01 14 6768 19 VALID INVALID SAMPLE SAMPLE NOT USED 8/LINE LOCKED CLOCK 5 BITS RESERVED NOTES 1i.e., VCR OR CABLE 2F SC PLL INCREMENT IS 22 BITS LONG. VALUE LOADED INTO ADV7302A/ADV7303A FSC DDS REGISTER IS FSC PLL INCREMENTS BITS 21:0 PLUS BITS 0:9 OF SUBCARRIER FREQUENCY REGISTERS. ALL ZEROS SHOULD BE WRITTEN TO THE SUBCARRIER FREQUENCY REGISTERS OF THE ADV7302A/ADV7303A. 3PAL: 0 = LINE NORMAL, 1 = LINE INVERTED; NTSC: 0 = NO CHANGE 4RESET ADV7302A/ADV7303A DDS Figure 29. RTC Timing and Connections SD VCR FF/RW Sync [Subaddress 42h, Bit 5] In DVD record applications where the encoder is used with a decoder, the VCR FF/RW Sync Control Bit can be used for nonstandard input video, i.e., in Fast Forward or Rewind Modes. In Fast Forward Mode, the sync information for the start of a new field in the incoming video usually occurs before the total number of lines/fields are reached; in Rewind Mode, this sync signal occurs usually after the total number of lines/fields are reached. Conventionally, this means that the output video will have an erroneous start of new field signals, one generated by the incoming video and one when the internal lines/field counters reach the end of a field. When VCR FF/RW sync control is enabled [Subaddress 42h, Bit 5] the lines/field counters are updated according to the incoming VSYNC signal, and the analog output matches the incoming VSYNC signal. This control is available in all slave timing modes except Slave Mode 0. RESET SEQUENCE A reset is activated with a high-to-low transition on the RESET Pin (Pin 33) according to the timing specifications. The ADV7302A/ADV7303A will revert to the default output configuration. Figure 30 illustrates the RESET sequence timing. RESET DACs DIGITAL TIMING OFF DIGITAL TIMING SIGNALS SUPPRESSED VALID VIDEO TIMING ACTIVE PIXEL DATA VALID Figure 30. RESET Timing Sequence –34– REV. A ADV7302A/ADV7303A VERTICAL BLANKING INTERVAL FILTERS The ADV7302A/ADV7303A accepts input data that contains VBI data [CGMS, WSS, VITS, etc.] in SD and HD Modes. Table XV shows an overview of the programmable filters available on the ADV7302A/ADV7303A. For SMPTE293M (525 p) standards, VBI data can be inserted on Lines 13 to 42 of each frame, or Lines 6 to 43 for ITU-R.BT1358 (625 p) standard. For SD NTSC this data can be present on Lines 10 to 20, in PAL on Lines 7 to 22. If VBI is disabled [Address 11h, Bit 4 for HD; Address 43h, Bit 4 for SD] VBI data is not present at the output and the entire VBI is blanked. These control bits are valid in all master and slave modes. In Slave Mode 0, if VBI is enabled, the Blanking Bit in the EAV/SAV code is overwritten and it is possible to use VBI in this timing mode as well. In Slave Mode 1 or 2, the BLANK Control Bit must be set to enabled [Address 4Ah, Bit 3] to allow VBI data to pass through the ADV7302A/ADV7303A. Otherwise the ADV7302A/ ADV7303A automatically blanks the VBI to standard. If CGMS is enabled and VBI disabled, the CGMS data will nevertheless be available at the output. SUBCARRIER FREQUENCY REGISTER [Subaddress 4Ch–4Fh] Four 8-bit wide registers are used to set up the subcarrier frequency. The value of these registers is calculated in using the equation: Table XV. Selectable Filters Filter Subaddress SD Luma LPF NTSC SD Luma LPF PAL SD Luma Notch NTSC SD Luma Notch PAL SD Luma SSAF SD Luma CIF SD Luma QCIF SD Chroma 0.65 MHz SD Chroma 1.0 MHz SD Chroma 1.3 MHz SD Chroma 2.0 MHz SD Chroma 3.0 MHz SD Chroma CIF SD Chroma QCIF SD UV SSAF HD Chroma Input HD Sync Filter HD Chroma SSAF 40h 40h 40h 40h 40h 40h 40h 40h 40h 40h 40h 40h 40h 40h 42h 13h 13h 13h HD Sync Filter 0.5 0.4 Subcarrier Frequency Register = 0.3 # of Subcarrier Frequency Cycles in One Video Line 32 ×2 # of 27 MHz Clock Cycles in One Video Line GAIN – dB 0.2 Example: NTSC Mode 0.1 0 –0.1 –0.2 Subcarrier Frequency = 227.5 32 ×2 = 569408542 * 1716 –0.3 –0.4 Subcarrier Register Value = 21F07C1Eh –0.5 SD FSC Register 0: 1Eh SD FSC Register 1: 7Ch SD FSC Register 2: F0h SD FSC Register 3: 21h 0 5 10 15 20 FREQUENCY – MHz 25 30 Figure 31. HD Sync Filter Enabled 0.5 Refer to the MPU Port Description section for more detail on how to access the Subcarrier Frequency Registers. 0.4 0.3 SUBCARRIER PHASE REGISTER [Subaddress 50h, 5Ch, Bits 7, 6] GAIN – dB 0.2 Ten bits are used to set up the subcarrier phase. Each bit represents 0.352°. For normal operation, this register is set to 00h. 0.1 0 –0.1 –0.2 –0.3 –0.4 –0.5 5 10 15 20 FREQUENCY – MHz 25 Figure 32. HD Sync Filter Disabled *Rounded to the nearest integer REV. A 0 –35– 30 ADV7302A/ADV7303A HD 4:2:2 to 4:4:4 Interpolation Filters and Chroma SSAF It is recommended to input data in 4:2:2 Input Mode to make use of the HD chroma SSAFs on the ADV7302A/ADV7303A. This filter has a 0 dB pass-band response and prevents signal components from being folded back into the frequency band. In 4:4:4 Input Mode, the video data is already interpolated by the external input device and the chroma SSAFs of the ADV7302A/ ADV7303A are bypassed. The chroma SSAF is controlled with Address 13h, Bit 5. When the HD input format is 4:2:2, the HD Chroma Input Bit [Address 13h, Bit 6] must be set to “1.” 2/4/8 Oversampling Filters The oversampling filters are enabled in setting the PLL ON control [Subaddress 00h, Bit 1] to “1.” If enabled, PS and ITU-R.BT656 data is output at a rate of 108 MHz, HDTV at a rate of 148 MHz. 0 –10 –10 –20 –20 –30 –30 GAIN – dB GAIN – dB 0 –40 –40 –50 –50 –60 –60 –70 –70 –80 –80 0 10 20 30 40 50 60 70 FREQUENCY – MHz 80 90 100 0 110 40 60 80 100 FREQUENCY – MHz 120 160 140 Figure 35. Y – HDTV 2⫻ Oversampling Filter 1.0 1.0 0.5 0.5 0 0 –0.5 –0.5 GAIN – dB GAIN – dB Figure 33. Y – PS 4⫻ Oversampling Filter 20 –1.0 –1.0 –1.5 –1.5 –2.0 –2.0 –2.5 –2.5 –3.0 –3.0 0 2 4 6 8 FREQUENCY – MHz 10 12 0 14 Figure 34. Y – PS 4⫻ Oversampling Filter in the Pass Band 5 10 15 20 FREQUENCY – MHz 25 30 35 Figure 36. Y – HDTV 2⫻ Oversampling Filter in the Pass Band –36– REV. A ADV7302A/ADV7303A 1.0 –10 0.5 –20 0 –30 –0.5 GAIN – dB GAIN – dB 0 –40 –1.0 –50 –1.5 –60 –2.0 –70 –2.5 –80 –3.0 0 10 20 30 40 50 60 70 FREQUENCY – MHz 80 90 100 110 0 Figure 37. UV – HDTV 2⫻ Oversampling Filter 4 6 8 10 12 FREQUENCY – MHz 14 16 18 Figure 39. UV – HDTV 2⫻ Oversampling Filter, Pass Band 0 –10 –10 –20 –20 –30 –30 GAIN – dB GAIN – dB 0 –40 –40 –50 –50 –60 –60 –70 –70 –80 –80 0 10 20 30 40 50 60 70 FREQUENCY – MHz 80 90 100 0 110 Figure 38. UV – PS 4⫻ Oversampling Filter, Linear REV. A 2 10 20 30 40 50 60 70 FREQUENCY – MHz 80 90 100 110 Figure 40. UV – PS 4⫻ Oversampling Filter, SSAF –37– ADV7302A/ADV7303A SD Internal Filter Response [Subaddress 42h, Bit 0] 0 –10 GAIN – dB The Y filter supports several different frequency responses including two low-pass responses, two notch responses, an extended (SSAF) response with or without gain boost/attenuation, a CIF response, and a QCIF response. The UV filter supports several different frequency responses including six low-pass responses, a CIF response, and a QCIF response, as can be seen in Figures 41–59. –20 –30 –40 If SD SSAF gain is enabled, there is the option of 12 responses in the range from –4 dB to +4 dB. The desired response can be chosen by the user by programming the correct value via the I2C. The variation of frequency responses can be seen in Figures 41–59. –50 –60 0 2 1 3 4 5 6 FREQUENCY – MHz In addition to the chroma filters listed above, the ADV7302A/ ADV7303A contains an SSAF filter specifically designed for and applicable to the color difference component outputs U and V. This filter has a cutoff frequency of approximately 2.7 MHz and –40 dB at 3.8 MHz, as shown in Figure 41. This filter can be controlled via Address 42h, Bit 0. If this filter is disabled, the selectable chroma filters shown in Table XVI can be used for the CVBS or chroma signal. Filter Pass-Band Ripple1 (dB) 3 dB Bandwidth2 (MHz) Luma LPF NTSC Luma LPF PAL Luma Notch NTSC Luma Notch PAL Luma SSAF Luma CIF Luma QCIF Chroma 0.65 MHz Chroma 1.0 MHz Chroma 1.3 MHz Chroma 2.0 MHz Chroma 3.0 MHz Chroma CIF Chroma QCIF 0.16 0.1 0.09 0.1 0.04 0.127 Monotonic Monotonic Monotonic 0.09 0.048 Monotonic Monotonic Monotonic 4.24 4.81 2.3/4.9/6.6 3.1/5.6/6.4 6.45 3.02 1.5 0.65 1 1.395 2.2 3.2 0.65 0.5 0 –10 MAGNITUDE – dB Table XVI. Internal Filter Specifications Figure 41. UV SSAF Filter –20 –30 –40 –50 –60 –70 0 2 4 6 8 10 12 FREQUENCY – MHz Figure 42. Luma NTSC Low-Pass Filter 0 MAGNITUDE – dB –10 NOTES 1 Pass-band ripple is the maximum fluctuation from the 0 dB response in the pass band, measured in dB. The pass band is defined to have 0 Hz to fc (Hz) frequency limits for a low-pass filter, 0 Hz to f1 (Hz) and f2 (Hz) to infinity for a notch filter, where fc, f1, and f2 are the –3 dB points. 2 3 dB bandwidth refers to the –3 dB cutoff frequency. –20 –30 –40 –50 –60 –70 0 2 4 6 8 10 12 FREQUENCY – MHz Figure 43. Luma PAL Low-Pass Filter –38– REV. A 0 0 –10 –10 –20 –20 MAGNITUDE – dB MAGNITUDE – dB ADV7302A/ADV7303A –30 –40 –30 –40 –50 –50 –60 –60 –70 –70 0 2 4 6 10 8 12 0 2 4 FREQUENCY – MHz Figure 44. Luma NTSC Notch Filter 10 8 12 Figure 47. Luma SSAF Filter up to 12 MHz 0 4 –10 2 0 MAGNITUDE – dB –20 MAGNITUDE – dB 6 FREQUENCY – MHz –30 –40 –2 –4 –6 –50 –8 –60 –10 –70 –12 0 2 4 6 10 8 12 0 1 2 3 4 5 6 7 FREQUENCY – MHz FREQUENCY – MHz Figure 45. Luma PAL Notch Filter Figure 48. Luma SSAF Filter, Programmable Responses 0 5 –10 4 MAGNITUDE – dB –20 GAIN – dB –30 –40 –50 3 2 1 –60 0 –70 –80 0 10 20 30 40 50 60 70 FREQUENCY – MHz 80 90 100 –1 110 0 2 3 4 5 6 7 FREQUENCY – MHz Figure 46. Luma SSAF Filter up to 108 MHz REV. A 1 Figure 49. Luma SSAF Filter, Programmable Gain –39– ADV7302A/ADV7303A 1 0 –10 MAGNITUDE – dB MAGNITUDE – dB 0 –1 –2 –3 –20 –30 –40 –50 –4 –60 –70 –5 0 1 2 3 5 4 6 0 7 2 6 0 –10 –10 –20 –20 MAGNITUDE – dB 0 –30 –40 10 12 –30 –40 –50 –50 –60 –60 –70 –70 0 2 4 6 8 10 0 12 2 4 6 8 10 12 FREQUENCY – MHz FREQUENCY – MHz Figure 54. Chroma 2.0 MHz LP Filter Figure 51. Luma CIF LP Filter 0 0 –10 –10 –20 –20 MAGNITUDE – dB MAGNITUDE – dB 8 Figure 53. Chroma 3.0 MHz LP Filter Figure 50. Luma SSAF Filter, Programmable Attenuation MAGNITUDE – dB 4 FREQUENCY – MHz FREQUENCY – MHz –30 –40 –30 –40 –50 –50 –60 –60 –70 –70 0 2 4 6 8 10 0 12 2 4 6 8 10 12 FREQUENCY – MHz FREQUENCY – MHz Figure 55. Chroma 1.3 MHz LP Filter Figure 52. Luma QCIF LP Filter –40– REV. A 0 0 –10 –10 –20 –20 MAGNITUDE – dB MAGNITUDE – dB ADV7302A/ADV7303A –30 –40 –30 –40 –50 –50 –60 –60 –70 –70 0 2 4 6 8 10 0 12 2 4 8 10 12 Figure 58. Chroma CIF LP Filter 0 0 –10 –10 –20 –20 MAGNITUDE – dB MAGNITUDE – dB Figure 56. Chroma 1.0 MHz LP Filter –30 –40 –30 –40 –50 –50 –60 –60 –70 –70 0 2 4 6 8 10 0 12 2 4 6 8 10 FREQUENCY – MHz FREQUENCY – MHz Figure 57. Chroma 0.65 MHz LP Filter REV. A 6 FREQUENCY – MHz FREQUENCY – MHz Figure 59. Chroma QCIF LP Filter –41– 12 ADV7302A/ADV7303A COLOR CONTROLS AND RGB MATRIX HD Y Color, HD Cr Color, HD Cb Color [Subaddresses 16h–18h] Three 8-bit wide registers at Addresses 16h, 17h, and 18h are used to program the output color of the internal HD test pattern generator, be it the lines of the cross hatch pattern or the uniform field test pattern. They are not functional as color controls on external pixel data input. For this purpose, the RGB matrix is used. The standard used for the values for Y and the color difference signals to obtain white, black, and the saturated primary and complementary colors conforms to the ITU-R.BT601– ITU-R.BT604 standards. Table XVII shows sample color values to be programmed into the color registers when Output Standard Selection is set to EIA 770.2. Color Y Value Color Cr Value Color Cb Value White Black Red Green Blue Yellow Cyan Magenta 235 (EB) 16 (10) 81 (51) 145 (91) 41 (29) 210 (D2) 170 (AA) 106 (6A) 128 (80) 128 (80) 240 (F0) 34 (22) 110 (6E) 146 (92) 16 (10) 222 (DE) 128 (80) 128 (80) 90 (5A) 54 (36) 240 (F0) 16 (10) 166 (A6) 202 (CA) To make use of the programmable RGB matrix, the YCrCb data should contain the HSYNC signal on the Y channel only. The RGB matrix should be enabled [Address 02h, Bit 3], the output should be set to RGB [Address 02h, Bit 3], Sync on PrPb should be disabled [Address 15h, Bit 2], and Sync on RGB is optional [Address 02h, Bit 4]. GY at Addresses 03h and 05h control the output levels on the green signal, BU at 04h and 08h the blue signal output levels and RV at 04h and 09h the red output levels. To control YPrPb output levels, YUV output should be enabled [Address 02h, Bit 5]. In this case GY [Address 05h; Address 03, Bits 0–1] is used for the Y output, RV [Address 09; Address 04, Bits 0–1] is used for the Pr output, and BU [Address 08h; Address 04h, Bits 2–3] is used for the Pb output. Table XVII. Sample Color Values for EIA 770.2 Output Standard Selection Sample Color standards due to altering the DAC output stages, such as termination resistors. The programmable RGB matrix is used for external HD data and is not functional when the HD test pattern is enabled. If RGB output is selected, the RGB matrix scaler uses the following equations: R = GY × Y + RV × Cr G = GY × Y − GU × Cb − GV × Cr B = GY × Y + BU × Cb If YUV output is selected the following equations are used: R = RV × Cr G = GY × Y B = BU × Cb HD RGB Matrix [Subaddresses 03h–09h] When the programmable RGB matrix is disabled [Address 02h, Bit 3], the internal RGB matrix takes care of all YCrCb to YUV or RGB scaling according to the input standard programmed into the device. On power-up, the RGB matrix is programmed with default values: Address 03h: 03h Address 04h: F0h Address 05h: 4Eh Address 06h: 0Eh Address 07h: 24h Address 08h: 92h Address 09h: 7Ch When the programmable RGB matrix is enabled, the color components are converted according to the SMPTE274M standard (1080 i): Y ' = (0.2126 × R') + (0.7152 × G ') + (0.0722 × B') When the programmable RGB matrix is not functional, the ADV7302A/ADV7303A automatically scales YCrCb inputs to all standards supported. For SMPTE293M, the register values are as follows: 0.5 × (B' −Y ') 1 − 0.0722 0.5 × (R' −Y ') Cr ' = 1 − 0.2126 Cb' = Address 03h: 03h Address 04h: 1Eh Address 05h: 4Eh Address 06h: 1Bh Address 07h: 38h Address 08h: 8Bh Address 09h: 6Eh This is reflected in the preprogrammed values for GY = 13Bh, RV = 1F0h, BU = 248h, GV = 93h, and GU = 3Bh. If another input standard is used the scale values for GY, GU, GV, BU, and RV have to be adjusted according to this input standard. It must be considered by the user that the color component conversion might use different scale values. For example, SMPTE293M uses the following conversion: Y ' = (0.299 × R') + (0.587 × G ') + (0.114 × B') Address 15h, Bit 3 must be set to “1” in this mode. SD Color Control [Subaddresses 5Ch, 5Dh, 5Eh, and 5Fh] SD Y SCALE, SD Cr SCALE, and SD Cb SCALE are three 10-bit wide control registers to scale the Y, U, and V output levels. 0.5 × (B' −Y ') Cb' = 1 − 0.114 0.5 × (R' −Y ') Cr ' = 1 − 0.299 Each of these registers represents the value required to scale the U or V level from 0 to 2.0 and the Y level from 0 to 1.5 of its initial level. The value of these 10 bits is calculated using the equation: The programmable RGB matrix can be used to control the HD output levels in cases where the video output does not conform to –42– Y, U, or V Scalar Value = Scale Factor ⫻ 512 REV. A ADV7302A/ADV7303A Example: Scale Factor = 1.18 onto the scaled Y data. For NTSC with pedestal, the setup can vary from 0 IRE to 22.5 IRE. For NTSC without pedestal and for PAL, the setup can vary from –7.5 IRE to +15 IRE. Y, U, or V Scale Value = 1.18 ⫻ 512 = 665.6 Y, U, or V Scale Value = 665 (rounded to nearest integer) Y, U, or V Scale Value = 1010011001b The Brightness Control Register is an 8-bit wide register. Seven bits are used to control the brightness level. This brightness level can be a positive or negative value. Address 5Ch, SD LSB Register = 15h Address 5Dh, SD Y Scale Register = A6h Address 5Eh, SD V Scale Register = A6h Address 5Fh, SD U Scale Register = A6h Example: Standard: NTSC with pedestal. To add +20 IRE brightness level, write 28h to Address 61h, SD Brightness: SD Brightness Value (hex) = (IRE Value ⫻ 2.015631) SD Hue Adjust Value [Subaddress 60h] 28h = (20 ⫻ 2.015631) = 40.31262 The Hue Adjust Value is used to adjust the hue on the composite and chroma outputs. These eight bits represent the value required to vary the hue of the video data, i.e., the variance in phase of the subcarrier during active video with respect to the phase of the subcarrier during the color burst. The ADV7302A/ADV7303A provides a range of ± 22.5° in increments of 0.17578125°. For normal operation (zero adjustment), this register is set to 80h. FFh and 00h represent the attainable upper and lower limit (respectively) of adjustment. For a positive hue adjust value: Standard: PAL. To add –7 IRE brightness level, write 72h to Address 61h, SD Brightness: SD Brightness Value (hex) = (IRE Value ⫻ 2.015631) 0001110b = (7 ⫻ 2.015631) = 14.109417 0001110 in twos complement equals 1110010, or 72h. SD Brightness Detect [Subaddress 7Ah] The ADV7302A/ADV7303A allows monitoring of the brightness level of the incoming video data. The Brightness Detect Register is a read-only register. 0.17578125° ⫻ (HCR – 128) Example: To adjust the hue by +4°, write 97h to the Hue Adjust Value Register: Double Buffering [Subaddress 13h, Bit 7; Subaddress 48h, Bit 2] Double buffered registers are updated once per field on the falling edge of the VSYNC signal. Double buffering improves the overall performance since modifications to register settings will not be made during active video but take effect on the start of the active video. +4 + 128 = 151 = 97 h 0.17578125 where 151 is rounded to the nearest integer. To adjust the hue by –4°, write 69h to the Hue Adjust Value Register: Double buffering can be activated on the following HD registers: HD Gamma A and Gamma B curves and HD CGMS Registers. Double buffering can be activated on the following SD Registers: SD Gamma A and Gamma B Curves, SD Y Scale, SD U Scale, SD V Scale, SD Brightness, SD Closed Captioning, and SD Macrovision Bits 5–0. –4 + 128 = 105 = 69h 0.17578125 where 105 is rounded to the nearest integer. SD Brightness Control [Subaddress 61h] The brightness is controlled by adding a programmable setup level onto the scaled Y data. This brightness level may be added Table XVIII. Brightness Control Values Setup Level— NTSC w/Pedestal (IRE) Setup Level— NTSC w/o Pedestal (IRE) Setup Level— PAL (IRE) SD Brightness Value 22.5 15 7.5 0 +15 +7.5 0 –7.5 +15 +7.5 0 –7.5 1Eh 0Fh 00h 71h Values in the range from 3Fh to 44h might result in an invalid output signal. NTSC WITHOUT PEDESTAL +7.5 IRE 100 IRE 0 IRE –7.5 IRE NO SETUP VALUE ADDED POSITIVE SETUP VALUE ADDED NEGATIVE SETUP VALUE ADDED Figure 60. Examples for Brightness Control Values REV. A –43– ADV7302A/ADV7303A Example: Gamma Correction [Subaddresses 21h–37h for HD; Subaddresses 66h–79h for SD]   8  0.5  y24 =   × 224 + 16 = 58 *    224     Gamma correction is available for SD and HD video. For each standard there are 20 8-bit wide registers. They are used to program the gamma correction curves A and B. HD Gamma Curve A is programmed at Addresses 24h–2Dh, HD Gamma Curve B at 2Eh–37h. SD Gamma Curve A is programmed at Addresses 66h–6Fh, and SD Gamma Curve B at Addresses 70h–79h. y32   32  0.5  y 48 =   × 224 + 16 = 101 *    224     Generally, gamma correction is applied to compensate for the nonlinear relationship between signal input and brightness level output (as perceived on the CRT). It can also be applied wherever nonlinear processing is used.   48  y64 =     224   Gamma correction uses the function: SignalOUT = (SignalIN ) where ␥ equals the gamma power factor. y96 Gamma correction is performed on the luma data only. The user has the choice to use two different curves, Curve A or Curve B. At any one time only one of these curves can be used. The response of the curve is programmed at 10 predefined locations. In changing the values at these locations, the gamma curve can be modified. Between these points, linear interpolation is used to generate intermediate values. Considering the curve to have a total length of 256 points, the 10 locations are at: 24, 32, 48, 64, 80, 96, 128, 160, 192, and 224. Locations 0, 16, 240, and 255 are fixed and cannot be changed.  × 224 + 16 = 120 *     80  0.5  =  × 224 + 16 = 150 *    224       112  0.5  y128 =   × 224 + 16 = 174 *    224       144  0.5  y160 =   × 224 + 16 = 195 *    224       176  0.5  y192 =   × 224 + 16 = 214 *    224     For the length of 16 to 240, the gamma correction curve must be calculated as:   208  0.5  y224 =   × 224 + 16 = 232 *    224     y = xγ To program the Gamma Correction Registers, the values for y must be calculated using the formula: 0.5   64  0.5  y80 =   × 224 + 16 = 136 *    224     γ where y = gamma corrected output, x = linear input signal, and ␥ = the gamma power factor.   16  0.5  =  × 224 + 16 = 76 *    224     The gamma curves shown in Figures 61 and 62 are examples. Any user defined curve is acceptable in the range of 16–240. 300 γ GAMMA CORRECTED AMPLITUDE  x(n−16)  yn =   × (240 − 16) + 16  240 − 16  where x(n–16) = the value for x along the x-axis at points n = 24, 32, 48, 64, 80, 96, 128, 160, 192, or 224; yn = the value for y along the y-axis, which has to be written into the Gamma Correction Register. 250 0.5 200 SIGNAL OUTPUT 150 100 SIGNAL INPUT 50 0 0 50 100 150 LOCATION 200 250 Figure 61. Signal Input (Ramp) and Signal Output for Gamma 0.5 *Rounded to the nearest integer –44– REV. A ADV7302A/ADV7303A To select one of the 256 individual responses, the corresponding gain values for each filter, which range from –8 to +7, must be programmed into the HD Sharpness Filter Gain Register at Address 20h. GAMMA CORRECTED AMPLITUDE 300 250 SIGNAL INPUT 0.3 HD Adaptive Filter Mode 200 The HD Adaptive Filter Threshold A, B, C Registers, the HD Adaptive Filter Gain 1, 2, and 3 Registers, and the HD Sharpness Filter Gain Register are used in Adaptive Filter Mode. To activate the adaptive filter control, HD Sharpness Filter and HD Adaptive Filter Enable must be enabled. 0.5 150 1.5 100 1.8 The derivative of the incoming signal is compared to the three programmable threshold values: HD Adaptive Filter Threshold A, B, C. The recommended threshold range is from 16–235, although any value in the range of 0–255 can be used. 50 0 0 50 100 150 LOCATION 200 250 The edges can then be attenuated with the settings in HD Adaptive Filter Gain 1, 2, 3 Registers and HD Sharpness Filter Gain Register. Figure 62. Signal Input (Ramp) and Selectable Gamma Output According to the settings of the HD Adaptive Filter Mode control, there are two adaptive filter modes available: HD SHARPNESS FILTER CONTROL AND ADAPTIVE FILTER CONTROL [Subaddresses 20h and 38h-3Dh] There are three filter modes available on the ADV7302A/ ADV7303A: Sharpness Filter Mode and two adaptive filter modes. HD Sharpness Filter Mode 1.5 1.4 1.4 1.3 1.3 1.2 1.2 1.1 1.0 0.9 1.6 1.1 1.0 0.9 0.8 0.8 0.7 0.7 0.6 0.6 0.5 2. Mode B is used when Adaptive Filter Mode is set to “1.” In this mode, a cascade of Filter A and Filter B is used. Both settings for Gain A and Gain B in the HD Sharpness Filter Gain, HD Adaptive Filter Gain 1, 2, 3 become active when needed. MAGNITUDE – Linear Scale 1.5 MAGNITUDE INPUT SIGNAL: STEP MAGNITUDE To enhance or attenuate the Y signal in the frequency ranges shown in Figure 63, the following register settings must be used: HD Sharpness Filter must be enabled and HD Adaptive Filter Enable must be set to disabled. 1. Mode A is used when Adaptive Filter Mode is set to “0.” In this case, Filter B (LPF) will be used in the adaptive filter block. Also, only the programmed values for Gain B in the HD Sharpness Filter Gain, HD Adaptive Filter Gain 1, 2, 3 are applied when needed. The Gain A values are fixed and cannot be changed. 1.5 1.4 1.3 1.2 1.1 0.5 1.0 FREQUENCY – MHz FREQUENCY – MHz FILTER A RESPONSE – Gain Ka FILTER B RESPONSE – Gain Kb 0 2 4 6 8 10 FREQUENCY – MHz 12 FREQUENCY RESPONSE IN SHARPNESS FILTER MODE WITH Ka = 3 AND Kb = 7 Figure 63. Sharpness and Adaptive Filter Control Block REV. A –45– ADV7302A/ADV7303A a d b e c f Figure 64. HD Sharpness Filter Control with Different Gain Settings for HD Sharpness Filter Gain Value HD Sharpness Filter and Adaptive Filter Application Examples HD Sharpness Filter Application The HD sharpness filter can be used to enhance or attenuate the Y video output signal. Adaptive Filter Control Application Figure 65 shows a typical signal to be processed by the adaptive filter control block. : 692mV @: 446mV : 332ns @: 12.8ms The register settings in Tables XIX and XX are used to achieve the results shown in Figure 64. Input data was generated by an external signal source. Table XIX. Sharpness Filter on Frequency Sweep Address Register Setting Reference* 00h 01h 02h 10h 11h 20h 20h 20h 20h 20h 20h FCh 10h 20h 00h 81h 00h 08h 04h 40h 80h 22h a b c d e f Figure 65. Input Signal to Adaptive Filter Control : 690mV @: 446mV : 332ns @: 12.8ms *See Figure 64. The effect of the sharpness filter can also be seen when using the internally generated cross hatch pattern. Table XX. Sharpness Filter on Internal Test Pattern Address Register Setting 00h 01h 02h 10h 11h 20h FCh 10h 20h 00h 85h 99h In toggling the Sharpness Filter Enable Bit [Address 11h, Bit 8], it can be seen that the line contours of the crosshatch pattern change their sharpness. Figure 66. Output Signal After Adaptive Filter Control The register settings in Table XXI are used to obtain the results shown in Figure 66, i.e., to remove the ringing on the Y signal. Input data was generated by an external signal source. –46– REV. A ADV7302A/ADV7303A Table XXI. Adaptive Filter Control on Step Input Signal Address Register Setting 00h 01h 02h 10h 11h 15h 20h 38h 39h 3Ah 3Bh 3Ch 3Dh FCh 38h 20h 00h 81h 80h 00h ACh 9Ah 88h 28h 3Fh 64h SD DIGITAL NOISE REDUCTION [Subaddresses 63h, 64h, and 65h] DNR is applied to the Y data only. A filter block selects the high frequency, low amplitude components of the incoming signal (DNR input select). The absolute value of the filter output is compared to a programmable threshold value (DNR threshold control). There are two DNR modes available: DNR Mode and DNR Sharpness Mode. In DNR Mode, if the absolute value of the filter output is smaller than the threshold, it is assumed to be noise. A programmable amount (coring gain border, coring gain data) of this noise signal will be subtracted from the original signal. All other register settings are 00h. When changing the Adaptive Filter Mode to Mode B [Address 15h, Bit 6], the output in Figure 67 can be obtained. : 674mV @: 446mV : 332ns @: 12.8ms In DNR Sharpness Mode, if the absolute value of the filter output is less than the programmed threshold, it is assumed to be noise, as before. Otherwise, if the level exceeds the threshold, now being identified as a valid signal, a fraction of the signal (coring gain border, coring gain data) will be added to the original signal in order to boost high frequency components and to sharpen the video image. In MPEG systems it is common to process the video information in blocks of 8 ⫻ 8 pixels for MPEG2 systems, or 16 ⫻ 16 pixels for MPEG1 systems (block size control). DNR can be applied to the resulting block transition areas that are known to contain noise. Generally, the block transition area contains two pixels. It is possible to define this area to contain four pixels (border area.) It is also possible to compensate for variable block positioning or differences in YCrCb pixel timing with the use of the DNR block offset. DNR MODE DNR CONTROL BLOCK SIZE CONTROL BORDER AREA BLOCK OFFSET GAIN Figure 67. Output Signal from Adaptive Filter Control NOISE SIGNAL PATH The adaptive filter control can also be demonstrated using the internally generated crosshatch test pattern and toggling the Adaptive Filter Control Bit [Address 15h, Bit 7], shown in Table XXII. INPUT FILTER BLOCK Table XXII. Adaptive Filter Control on Internal Test Pattern Address Register Setting 00h 01h 02h 10h 11h 15h 20h 38h 39h 3Ah 3Bh 3Ch 3Dh FCh 38h 20h 00h 85h 80h 00h ACh 9Ah 88h 28h 3Fh 64h CORING GAIN DATA CORING GAIN BORDER FILTER OUTPUT < THRESHOLD ? Y DATA INPUT SUBTRACT SIGNAL IN THRESHOLD RANGE FROM ORIGINAL SIGNAL FILTER OUTPUT > THRESHOLD DNR OUT MAIN SIGNAL PATH DNR SHARPNESS MODE DNR CONTROL BLOCK SIZE CONTROL BORDER AREA BLOCK OFFSET GAIN NOISE SIGNAL PATH CORING GAIN DATA CORING GAIN BORDER INPUT FILTER BLOCK Y DATA INPUT FILTER OUTPUT > THRESHOLD ? ADD SIGNAL ABOVE THRESHOLD RANGE FROM ORIGINAL SIGNAL FILTER OUTPUT < THRESHOLD DNR OUT MAIN SIGNAL PATH Figure 68. DNR Block Diagram REV. A –47– ADV7302A/ADV7303A The Digital Noise Reduction Registers are three 8-bit wide registers. They are used to control the DNR processing. Block Size Control [Address 64h, Bit 7] Coring Gain Border [Address 63h, Bits 3–0] This bit is used to select the size of the data blocks to be processed. Setting the block size control function to a Logic “1” defines a 16 ⫻ 16 pixel data block, a Logic “0” defines an 8 ⫻ 8 pixel data block, where 1 pixel refers to 2 clock cycles at 27 MHz. These four bits are assigned to the gain factor applied to border areas. In DNR Mode, the range of gain values is 0–1, in increments of 0.125. This factor is applied to the DNR filter output that lies below the set threshold range. The result is then subtracted from the original signal. DNR Input Select Control [Address 65h, Bits 2–0] In DNR Sharpness Mode, the range of gain values is 0 to 0.5, in increments of 0.0625. This factor is applied to the DNR filter output that lies above the threshold range. The result is added to the original signal. Three bits are assigned to select the filter that is applied to the incoming Y data. The signal that lies in the pass band of the selected filter is the signal that will be DNR processed. The figure below shows the filter responses selectable with this control. Coring Gain Data [Address 63h, Bits 7–4] 1.0 FILTER D These four bits are assigned to the gain factor applied to the luma data inside the MPEG pixel block. 0.8 FILTER C In DNR Mode, the range of gain values is 0–1, in increments of 0.125. This factor is applied to the DNR filter output that lies below the set threshold range. The result is then subtracted from the original signal. 0.6 0.4 In DNR Sharpness Mode, the range of gain values is 0–0.5, in increments of 0.0625. This factor is applied to the DNR filter output that lies above the threshold range. The result is added to the original signal. APPLY DATA CORING GAIN 0.2 FILTER A 0 APPLY BORDER CORING GAIN DNR27 – DNR24 = 01HEX OFFSET CAUSED BY VARIATIONS IN INPUT TIMING 2 3 4 FREQUENCY – Hz 5 6 This bit controls the DNR mode selected. A Logic “0” selects DNR mode, a Logic “1” selects DNR Sharpness Mode. DNR works on the principle of defining low amplitude, high frequency signals as probable noise and subtracting this noise from the original signal. OXXXX XXO OXXXX XXO In DNR Mode, it is possible to subtract a fraction of the signal that lies below the set threshold, assumed to be noise, from the original signal. The threshold is set in DNR Register 1. DNR Threshold [Address 64h, Bits 5–0] These six bits are used to define the threshold value in the range of 0 to 63. The range is an absolute value. Border Area [Address 64h, Bit 6] In setting this bit to a Logic “1,” the block transition area can be defined to consist of four pixels. If this bit is set to a Logic “0,” the border transition area consists of two pixels, where one pixel refers to two clock cycles at 27 MHz. 2 PIXEL BORDER DATA 8ⴛ8 PIXEL BLOCK 1 DNR Mode Control [Address 65h, Bit 3] Figure 69. DNR Block Offset Control 720ⴛ485 PIXELS (NTSC) 0 Figure 71. DNR Input Select OXXXX XXO OXXXX XXO OXXXX XXO OXXXX XXO FILTER B When DNR Sharpness Mode is enabled, it is possible to add a fraction of the signal that lies above the set threshold to the original signal, since this data is assumed to be valid data and not noise. The overall effect is that the signal will be boosted (similar to using extended SSAF filter). Block Offset Control [Address 65h, Bits 7–4] Four bits are assigned to this control, which allows a shift of the data block of 15 pixels maximum. Consider the coring gain positions fixed. The block offset shifts the data in steps of one pixel such that the border coring gain factors can be applied at the same position regardless of variations in input timing of the data. 8ⴛ8 PIXEL BLOCK Figure 70. DNR Border Area –48– REV. A ADV7302A/ADV7303A SD ACTIVE VIDEO EDGE [Subaddress 42h, Bit 7] When the active video edge is enabled, the first three pixels and the last three pixels of the active video on the Luma Channel are scaled in such a way that maximum transitions on these pixels are not possible. The scaling factors are 1/8⫻, 1/2⫻, and 7/8⫻. All other active video passes through unprocessed. LUMA CHANNEL WITH ACTIVE VIDEO EDGE DISABLED LUMA CHANNEL WITH ACTIVE VIDEO EDGE ENABLED 100 IRE 100 IRE 87.5 IRE 50 IRE 12.5 IRE 0 IRE 0 IRE Figure 72. Active Video Edge Functionality Example 6.8␮H BOARD DESIGN AND LAYOUT CONSIDERATIONS DAC Termination and Layout Considerations The ADV7302A/ADV7303A contain an on-board voltage reference. The VREF Pin is normally terminated to VAA through a 0.1 µF capacitor when the internal VREF is used. Alternatively, the ADV7302A/ADV7303A can be used with an external VREF (e.g., AD1580). The RSET resistors are connected between the RSET Pins and AGND and are used to control the full-scale output current and, therefore, the DAC voltage output levels. For full-scale output, RSET must have a value of 760 Ω. The RSET values should not be changed. RLOAD has a value of 150 Ω for full-scale output. Output buffering on all six DACs is necessary in order to drive output devices, such as SD or HD monitors. Analog Devices produces a range of suitable op amps for this application, for example the AD8061. More information on line driver buffering circuits is given in the relevant op amp data sheets. An optional analog reconstruction LPF might be required as an antialias filter if the ADV7302A/ADV7303A is connected to a device that requires this filtering. The filter specifications vary with the application, see Table XXIII. Table XXIII. External Filter Requirements 300R SD SD PS PS HDTV HDTV 2⫻ 8⫻ 1⫻ 4⫻ 1⫻ 2⫻ REV. A >6.5 MHz >6.5 MHz >12.5 MHz >12.5 MHz >30 MHz >30 MHz 75R 300R BNC O/P 600R Figure 73. Example for Output Filter for SD, 8⫻ Oversampling 36n480 0 –10 30n360 MAGNITUDE (dB) GROUP DELAY (sec) –20 24n240 –30 18n120 –40 12n0 6n–120 –50 PHASE (Deg) –60 1 External Filter Cutoff Oversampling Frequency Attenuation 47pF 600R THIRD ORDER LOW-PASS BUTTERWORTH Video Output Buffer and Optional Output Filter Input Mode 6.8␮H DAC O/P 10 CIRCUIT FREQUENCY RESPONSE – MHz 0n–240 100 Figure 74. Filter Plot for Output Filter for SD, 8⫻ Oversampling –50 dB @ 20.5 MHz –50 dB @ 101.5 MHz –50 dB @ 14.5 MHz –50 dB @ 95.5 MHz –50 dB @ 44.25 MHz –50 dB @ 118.5 MHz –49– ADV7302A/ADV7303A 6.8H 2.2H 6.8pF 18pF DAC O/P Table XXIII. Possible Output Rates 300R 300R 75R BNC O/P Input Mode Addr 01h, Bits 6–4 PLL Addr 00h, Bit 1 Output Rate SD Off On 27 MHz (2⫻) 108 MHz (8⫻) PS Off On 27 MHz (1⫻) 108 MHz (4⫻) HDTV Off On 74.25 MHz (1⫻) 148.5 MHz (2⫻) SD and Off On Off On 27 MHz (2⫻) 108 MHz (8⫻) 27 MHz (1⫻) 108 MHz (4⫻) Off On Off On 27 MHz (2⫻) 108 MHz (8⫻) 74.25 MHz (1⫻) 74.25 MHz (1⫻) Off On Off On 27 MHz (2⫻) 27 MHz (2⫻) 74.25 MHz (1⫻) 148.5 MHz (2⫻) 600R 600R Figure 75. Example of Output for Output Filter for PS, 4⫻ Oversampling 30n480 FOURTH ORDER LOW-PASS BUTTERWORTH 0 MAGNITUDE (dB) 25n360 –10 –20 20n240 –30 15n120 –40 10n0 SD* and HDTV SD and PHASE (Deg) –50 5n–120 –60 0n–240 HDTV* 10M 100M CIRCUIT FREQUENCY RESPONSE – Hz *Oversampled Figure 76. Filter Plot for Output Filter for PS, 4⫻ Oversampling 470nH 220nH 33pF 82pF BNC O/P 75R 75R 500R DAC O/P 500R 300R Figure 77. Example for Output Filter HDTV, 2⫻ Oversampling 14n498 0 FOURTH ORDER LOW-PASS BUTTERWORTH PS GROUP DELAY (sec) PCB Board Layout Considerations The ADV7302A/ADV7303A is optimally designed for lowest noise performance, both radiated and conducted noise. To complement the excellent noise performance of the ADV7302A/ADV7303A, it is imperative that great care be given to the PC board layout and the ADV7302A/ADV7303A power and ground lines. This can be achieved by shielding the digital inputs and providing good decoupling. The lead length between groups of VAA and AGND, VDD and DGND, and VDD_IO and GND_IO Pins should be kept as short as possible to minimize inductive ringing. It is recommended that a four-layer printed circuit board be used with power and ground planes separating the layer of the signal carrying traces of the components and solder side layer. Placement of components should take into account noisy circuits such as crystal clocks, high speed logic circuitry, and analog circuitry. MAGNITUDE (dB) 12n398 –8.6 GROUP DELAY (sec) –17.1 10n298 –25.7 8n198 –34.3 6n97.6 –42.9 4n0 PHASE (Deg) –51.4 2n–102 0n–203 –60.0 1 10 100 CIRCUIT FREQUENCY RESPONSE – MHz Figure 78. Filter Plot for Output Filter for HDTV, 2⫻ Oversampling There should be a separate analog ground plane and a separate digital ground plane. Power planes should encompass a digital and an analog power plane. The analog power plane should contain the DACs and all associated circuitry, VREF circuitry. The digital power plane should contain all logic circuitry. The analog and digital power planes should be individually connected to the common power plane at one single point through a suitable filtering device, such as a ferrite bead. DAC output traces on a PCB should be treated as transmission lines. It is recommended that the DACs be placed as close as possible to the output connector, with the analog output traces being as short as possible (less than three inches). The DAC termination resistors should be placed as close as possible to the DAC outputs and should overlay the PCB’s ground plane. As well as minimizing reflections, short analog output traces will reduce noise pickup due to neighboring digital circuitry. –50– REV. A ADV7302A/ADV7303A To avoid crosstalk between the DAC outputs, it is recommended to leave as much space as possible between the tracks of the individual DAC output pins. the high clock rates used, long clock lines to the ADV7302A/ ADV7303A should be avoided to minimize noise pickup. Any active pull-up termination resistors for the digital inputs should be connected to the digital power plane and not the analog power plane. Supply Decoupling Noise on the analog power plane can be further reduced by the use of decoupling capacitors. Optimum performance is achieved by the use of 0.1 µF ceramic capacitors. Each of the group of VAA, VDD, or VDD_IO Pins should be individually decoupled to ground. This should be done by placing the capacitors as close as possible to the device with the capacitor leads as short as possible, thus minimizing lead inductance. Analog Signal Interconnect The ADV7302A/ADV7303A should be located as close as possible to the output connectors, thus minimizing noise pickup and reflections due to impedance mismatch. For optimum performance, the analog outputs should each be source and load terminated, as shown in Figure 79. The termination resistors should be as close as possible to the ADV7302A/ADV7303A to minimize reflections. Digital Signal Interconnect The digital signal lines should be isolated as much as possible from the analog outputs and other analog circuitry. Digital signal lines should not overlay the analog power plane. Due to Any unused inputs should be tied to ground. POWER SUPPLY DECOUPLING FOR EACH POWER SUPPLY GROUP VAA 0.1F 10nF VAA 0.1F VDD VAA 0.1F 10nF 10, 56 0.1F 10nF VDD_IO 0.1F COMP1 COMP2 VAA VDD VDD_IO VREF S0–S7 SD CVBS/GREEN/Y DAC A 150 S_HSYNC DAC B S_VSYNC SD LUMA/BLUE/U 150 S BLANK SD CHROMA/RED/V DAC C 150 C0–C7 HD Y/GREEN DAC D Y0–Y7 ADV7302A/ ADV7303A 150 DAC E P_HSYNC HD Pb/BLUE 150 VDD_IO P_VSYNC DAC F VAA HD Pr/RED 150 P_BLANK 5k 47k SCLK RESET 4.7F 6.3V SDA CLKIN_B VDD_IO I2C VAA CLKIN_A VDD_IO ALSB 820pF GND_IO AGND DGND 3.9nF 2, 3, 14, 15, 51, 52, 64 5k RSET1 EXT_LF 680R 760 RSET2 760 11, 57 UNUSED INPUTS SHOULD BE GROUNDED Figure 79. Circuit Layout REV. A VDD_IO –51– 5k 5k I2C BUS ADV7302A/ADV7303A Appendix A COPY GENERATION MANAGEMENT SYSTEM HD CGMS DATA Registers 2–0 [Subaddress 12h] March 1998” and IEC61880, 1998, video systems (525/60)— video and accompanied data using the vertical blanking interval—analog interface. HD CGMS is available in 525 p Mode only, conforming to “CGMS-A EIA-J CPR1204-1, Transfer Method of Video ID information using vertical blanking interval (525 p System), When HD CGMS is enabled, CGMS data is inserted on Line 41. The HD CGMS Data Registers are to be found at Addresses 21h, 22h, and 23h. CRC SEQUENCE +700mV BIT 1 REF BIT 20 70% 10% C0 C1 C2 C3 C4 C5 C6 C7 C8 C9 C10 C11 C12 C13 C14 C15 C16 C17 C18 C19 0mV –300mV 21.2s 0.22s 22T 5.8s 0.15s 6T T = 1/(fH  33) = 963ns fH = HORIZONTAL SCAN FREQUENCY T 30ns Figure 80. CGMS Waveform output directly from the CGMS registers (no CRC calculated; must be calculated by the user). SD CGMS Data Registers 2–0 [Subaddresses 59h, 5Ah, and 5Bh] The ADV7302A/ADV7303A supports Copy Generation Management System (CGMS) conforming to the standard. CGMS data is transmitted on Line 20 of the odd fields and Line 283 of even fields. Bits C/W05 and C/W06 control whether or not CGMS data is output on odd and even fields. CGMS data can only be transmitted when the ADV7302A/ADV7303A is configured in NTSC mode. The CGMS data is 20 bits long, the function of each of these bits is as shown below. The CGMS data is preceded by a reference pulse of the same amplitude and duration as a CGMS bit, see Figure 81. If SD CGMS CRC [Address 59h, Bit 4] is set to a Logic “1,” the last six bits, C19–C14, that comprise the 6-bit CRC check sequence are calculated automatically on the ADV7302A/ ADV7303A based on the lower 14 bits (C0–C13) of the data in the data registers and output with the remaining 14 bits to form the complete 20 bits of the CGMS data. The calculation of the CRC sequence is based on the polynomial: Table XXIV. Function of CGMS Bits Word Bit Function 0 B1 Aspect Ratio B2 Display Format B3 B4–B6 Undefined Identification Information about Video and Other Signals (i.e., Audio) 1 B7–B10 Identification Signal. Incidental to Word 0. 2 B11–B14 Identification Signal and Information. Incidental to Word 0. 0 = 4:3 1 = 16:9 0 = Normal 1 = Letterbox x6 + x + 1 with a preset value of 111111. If SD CGMS CRC [Address 59h, Bit 4] is set to a Logic “0,” then all 20 bits (C0–C19) are +100 IRE CRC SEQUENCE REF +70 IRE C0 C1 C2 C3 C4 C5 C6 C7 C8 C9 C10 C11 C12 C13 C14 C15 C16 C17 C18 C19 0 IRE –40 IRE 49.1s 0.5s 11.2s 2.235s 20ns Figure 81. CGMS Waveform –52– REV. A ADV7302A/ADV7303A Appendix B SD WIDE SCREEN SIGNALING [Subaddresses 59h, 5Ah, and 5Bh] Table XXVI. Function of WSS Bits 0–3 The ADV7302A/ADV7303A supports Wide Screen Signaling (WSS) conforming to the standard. WSS data is transmitted on Line 23. WSS data can only be transmitted when the ADV7302A/ ADV7303A is configured in PAL Mode. The WSS data is 14 bits long. The function of each of these bits is as shown in Table XXV. The WSS data is preceded by a run-in sequence and a start code (see Figure 82). If SD WSS [Address 59h, Bit 7] is set to a Logic “1,” it enables the WSS data to be transmitted on Line 23. The latter portion of Line 23 (42.5 µs from the falling edge of HSYNC) is available for the insertion of video. B0 B1 B2 B3 Aspect Ratio Format Position 0 1 0 1 0 1 0 1 4:3 14:9 14:9 16:9 16:9 >16:9 14:9 16:9 Full Format Letterbox Letterbox Letterbox Letterbox Letterbox Full Format N/A N/A Center Top Center Top Center Center N/A 0 0 1 1 0 0 1 1 0 0 0 0 1 1 1 1 1 0 0 1 0 1 1 0 It is possible to blank the WSS portion of Line 23 with Subaddress 61h, Bit 7. Table XXV. Function of WSS Bits Bit Function 0 Aspect Ratio 1 Format 2 Position 3 Odd Parity Check of Bits 0–2 4 0 = Camera Mode 1 = Film Mode 5 0 = Standard Coding 1 = Motion Adaptive Color Plus 6 0 = No Helper 1 = Modulated Helper 7 Reserved 8 Reserved 9–10 00 = No Open Subtitles 10 = Subtitles Inside Active Image Area 01 = Subtitles Outside Active Image Area 11 = Reserved 11 0 = No Surround Sound Information 1 = Surround Sound Mode 12–13 Reserved 500mV RUN-IN SEQUENCE START CODE W0 W1 W2 W3 W4 W5 W6 W7 W8 W9 W10 W11 W12 W13 11.0␮s 38.4␮s 42.5␮s Figure 82. WSS Waveform REV. A –53– ACTIVE VIDEO ADV7302A/ADV7303A Appendix C SD CLOSED CAPTIONING [Subaddresses 51h–54h] ADV7303A. All pixels inputs are ignored during Lines 21 and 284 if closed captioning is enabled. The ADV7302A/ADV7303A supports closed captioning conforming to the standard television synchronizing waveform for color transmission. Closed captioning is transmitted during the blanked active line time of Line 21 of the odd fields and Line 284 of the even fields. FCC Code of Federal Regulations (CFR) 47, Section 15.119 and EIA608 describe the closed captioning information for Lines 21 and 284. Closed captioning consists of a 7-cycle sinusoidal burst that is frequency and phase-locked to the caption data. After the clock run-in signal, the blanking level is held for two data bits and is followed by a Logic Level “1” start bit. Sixteen bits of data follow the start bit. These consist of two 8-bit bytes, seven data bits, and one odd parity bit. The data for these bytes is stored in the SD Closed Captioning Registers [Addresses 53h–54h]. The ADV7302A/ADV7303A also supports the extended closed captioning operation that is active during even fields and is encoded on Line 284. The data for this operation is stored in the SD Closed Captioning Registers [Addresses 51h–52h]. All clock run-in signals and timing to support closed captioning on Lines 21 and 284 are generated automatically by the ADV7302A/ 10.5  0.25s The ADV7302A/ADV7303A uses a single buffering method. This means that the closed captioning buffer is only one byte deep, therefore there will be no frame delay in outputting the closed captioning data unlike other 2-byte deep buffering systems. The data must be loaded one line before (Line 20 or Line 283) it is output on Line 21 and Line 284. A typical implementation of this method is to use VSYNC to interrupt a microprocessor, that in turn will load the new data (two bytes) every field. If no new data is required for transmission, “0” must be inserted in both data registers; this is called nulling. It is also important to load “control codes,” all of which are double bytes on Line 21, or a TV will not recognize them. If there is a message like “Hello World” that has an odd number of characters, it is important to pad it out to even to get the “end of caption” 2-byte control code to land in the same field. 12.91s 7 CYCLES OF 0.5035MHz CLOCK RUN-IN TWO 7-BIT + PARITY ASCII CHARACTERS (DATA) S T A R T 50 IRE P A R I T Y D0–D6 D0–D6 BYTE 0 P A R I T Y BYTE 1 40 IRE REFERENCE COLOR BURST (9 CYCLES) FREQUENCY = FSC = 3.579545MHz AMPLITUDE = 40 IRE 10.003s 27.382s 33.764s Figure 83. Closed Captioning Waveform, NTSC –54– REV. A ADV7302A/ADV7303A Appendix D TEST PATTERNS The ADV7302A/ADV7303A can generate SD and HD test patterns. Figure 84. NTSC Color Bars Figure 87. PAL Color Bars Figure 88. PAL Black Bar (–21 mV, 0 mV, +3.5 mV, +7 mV, +10.5 mV, +14 mV, +18 mV, +23 mV) Figure 85. NTSC Black Bar (–21 mV, 0 mV, +3.5 mV, +7 mV, +10.5 mV, +14 mV, +18 mV, +23 mV) Figure 86. 525 p Hatch Pattern REV. A Figure 89. 625 p Hatch Pattern –55– ADV7302A/ADV7303A Figure 90. 525 p Field Pattern Figure 92. 625 p Field Pattern Figure 93. 625 p Black Bar (–35 mV, 0 mV, +7 mV, +14 mV, +21 mV, +28 mV, +35 mV) Figure 91. 525 p Black Bar (–35 mV, 0 mV, +7 mV, +14 mV, +21 mV, +28 mV, +35 mV) –56– REV. A ADV7302A/ADV7303A Table XXVII. NTSC CVBS Output on DAC A Table XXXI. 525 p Hatch Pattern on DAC D Subaddress Register Setting Subaddress Register Setting 00h 11h 40h 42h 44h 4Ah 4Ch 4Dh 4Eh 4Fh 82h 01h 10h 40h 40h 08h 16h 7Ch F0h 21h 00h 01h 02h 10h 11h 16h 17h 18h 12h 10h 20h 40h 05h A0h 80h 80h All other registers are set to 00h. For PAL CVBS output on DAC A, the same settings in Table XXVII are used except those listed in Table XXVIII. All other registers are set to 00h. For a 625 p Hatch Pattern on DAC D, the same settings in Table XXXI are used except for Subaddress 10h, which has a register setting of 50h. Table XXXII. 525 p Field Pattern* Table XXVIII. PAL CVBS Output on DAC A Subaddress Register Setting 40h 4Ch 4Dh 4Eh 4Fh 11h CBh 8Ah 09h 2Ah Table XXIX. NTSC Black Bar Pattern Output on DAC A Subaddress Register Setting 00h 02h 11h 40h 42h 44h 4Ah 4Ch 4Dh 4Eh 4Fh 82h 04h 01h 10h 40h 40h 08h 16h 7Ch F0h 21h Subaddress Register Setting 00h 01h 02h 10h 11h 16h 17h 18h 12h 10h 20h 40h 0Dh A0h 80h 80h NOTES All other registers are set to 00h. *See Figure 90. For a 625 p Field Pattern on DAC D, the same settings in Table XXXII are used except for Subaddress 10 h, which has a register setting of 50h. For a 525 p Black Bar Pattern Output on DAC D, the same settings in Table XXXII are used except for Subaddresses 02h, which has a register setting of 24h. For a 625 p Black Bar Pattern Output on DAC D, the same settings in Table XXXII are used except for Subaddresses 02h, and 10h, which have register settings of 24h and 50h, respectively. All other registers are set to 00h. The subcarrier frequency registers 4Ch–4Fh will be needed to generate the correct color burst signal. For PAL black bar pattern output on DAC A, the same settings in Table XXIX are used except those listed in Table XXX. Table XXX. PAL Black Bar Pattern Output on DAC A Subaddress Register Setting 40h 4Ch 4Dh 4Eh 4Fh 11h CBh 8Ah 09h 2Ah REV. A –57– ADV7302A/ADV7303A Appendix E timing information is transmitted using a 4-byte synchronization pattern. A synchronization pattern is sent immediately before and after each line during active picture and retrace. S_VSYNC, S_HSYNC, and S_BLANK (if not used) pins should be tied high during this mode. Blank output is available. SD TIMING MODES [Subaddress 4Ah] Mode 0 (CCIR-656): Slave Option (Timing Register 0 TR0 = X X X X X 0 0 0) The ADV7302A/ADV7303A is controlled by the start active video (SAV) and end active video (EAV) time codes in the pixel data. All ANALOG VIDEO EAV CODE SAV CODE C F 0 0 X 8 1 8 1 Y Y r F 0 0 Y 0 0 0 0 INPUT PIXELS C C 8 1 8 1 F 0 0 X C Y C Y C Y r Y b b 0 0 0 0 F 0 0 Y b r 0 F F A A A 0 F F B B B ANCILLARY DATA (HANC) 4 CLOCK 4 CLOCK 268 CLOCK NTSC/PAL M SYSTEM (525 LINES/60Hz) 1440 CLOCK 4 CLOCK 4 CLOCK 280 CLOCK PAL SYSTEM (625 LINES/50Hz) 1440 CLOCK START OF ACTIVE VIDEO LINE END OF ACTIVE VIDEO LINE Figure 94. SD Slave Mode 0 Mode 0 (CCIR-656): Master Option (Timing Register 0 TR0 = X X X X X 0 0 1) The ADV7302A/ADV7303A generates H, V, and F signals required for the SAV and EAV time codes in the CCIR-656 standard. The H Bit is output on the S_HSYNC pin, the V Bit is output on the S_BLANK pin, and the F Bit is output on the S_VSYNC pin. DISPLAY DISPLAY VERTICAL BLANK 522 523 524 525 1 2 3 4 5 6 7 8 9 10 11 20 21 22 H V EVEN FIELD F ODD FIELD DISPLAY DISPLAY VERTICAL BLANK 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 283 284 285 H V F ODD FIELD EVEN FIELD Figure 95. SD Master Mode 0, NTSC –58– REV. A ADV7302A/ADV7303A DISPLAY DISPLAY VERTICAL BLANK 622 623 624 625 1 2 3 4 5 6 7 21 22 23 H V EVEN FIELD F ODD FIELD DISPLAY DISPLAY VERTICAL BLANK 309 310 311 312 313 314 315 316 317 318 319 320 H V F ODD FIELD EVEN FIELD Figure 96. SD Master Mode 0, PAL ANALOG VIDEO H F V Figure 97. SD Master Mode 0 Data Transitions REV. A –59– 334 335 336 ADV7302A/ADV7303A retrace. The BLANK signal is optional. When the BLANK input is disabled, the ADV7302A/ADV7303A automatically blanks all normally blank lines as per CCIR-624. HSYNC is input on the S_HSYNC Pin, BLANK on the S_BLANK Pin, and FIELD on the S_VSYNC Pin. Mode 1: Slave Option HSYNC, BLANK, FIELD (Timing Register 0 TR0 = X X X X X 0 1 0) In this mode the ADV7302A/ADV7303A accepts horizontal SYNC and odd/even FIELD signals. A transition of the FIELD input when HSYNC is low indicates a new frame, i.e., vertical DISPLAY DISPLAY 522 523 VERTICAL BLANK 524 525 1 2 3 4 6 5 7 8 9 10 20 11 21 22 HSYNC BLANK FIELD EVEN FIELD ODD FIELD DISPLAY DISPLAY 260 261 VERTICAL BLANK 262 263 264 265 266 267 268 269 270 271 272 273 283 274 284 285 HSYNC BLANK FIELD ODD FIELD EVEN FIELD Figure 98. SD Slave Mode 1, NTSC DISPLAY DISPLAY 622 623 VERTICAL BLANK 624 625 1 2 3 4 5 6 7 21 22 23 HSYNC BLANK FIELD EVEN FIELD ODD FIELD DISPLAY DISPLAY VERTICAL BLANK 309 310 311 312 313 314 315 316 317 318 319 320 334 335 336 HSYNC BLANK FIELD ODD FIELD EVEN FIELD Figure 99. SD Slave Mode 1, PAL –60– REV. A ADV7302A/ADV7303A Mode 1: Master Option HSYNC, BLANK, FIELD (Timing Register 0 TR0 = X X X X X 0 1 1) In this mode the ADV7302A/ADV7303A can generate horizontal SYNC and odd/even FIELD signals. A transition of the FIELD input when HSYNC is low indicates a new frame, i.e., vertical retrace. The blank signal is optional. When the BLANK input is disabled, the ADV7302A/ADV7303A automatically blanks all normally blank lines as per CCIR-624. Pixel data is latched on the rising clock edge following the timing signal transitions. HSYNC is output on the S_HSYNC Pin, BLANK on the S_BLANK Pin, and FIELD on the S_VSYNC Pin. HSYNC FIELD PAL = 12  CLOCK/2 NTSC = 16  CLOCK/2 BLANK PIXEL DATA Cb Y PAL = 132  CLOCK/2 NTSC = 122  CLOCK/2 Figure 100. SD Timing Mode 1 Odd/Even Field Transitions, Master/Slave REV. A –61– Cr Y ADV7302A/ADV7303A A VSYNC low transition when HSYNC is high indicates the start of an even field. The BLANK signal is optional. When the BLANK input is disabled, the ADV7302A/ADV7303A automatically blanks all normally blank lines as per CCIR-624. HSYNC is input on the S_HSYNC Pin, BLANK on the S_BLANK Pin, and FIELD on the S_VSYNC Pin. Mode 2: Slave Option HSYNC, VSYNC, BLANK (Timing Register 0 TR0 = X X X X X 1 0 0) In this mode the ADV7302A/ADV7303A accepts horizontal and vertical SYNC signals. A coincident low transition of both HSYNC and VSYNC inputs indicates the start of an odd field. DISPLAY 522 DISPLAY VERTICAL BLANK 523 524 525 1 2 3 4 6 5 7 8 10 9 20 11 21 22 HSYNC BLANK VSYNC ODD FIELD EVEN FIELD DISPLAY DISPLAY VERTICAL BLANK 260 261 262 263 264 265 266 267 268 269 270 271 272 273 283 274 284 285 HSYNC BLANK VSYNC EVEN FIELD ODD FIELD Figure 101. SD Slave Mode 2, NTSC DISPLAY 622 623 DISPLAY VERTICAL BLANK 624 625 1 2 3 4 5 6 7 21 22 23 HSYNC BLANK VSYNC EVEN FIELD ODD FIELD DISPLAY DISPLAY 309 310 VERTICAL BLANK 311 312 313 314 315 316 317 318 319 320 334 335 336 HSYNC BLANK VSYNC ODD FIELD EVEN FIELD Figure 102. SD Slave Mode 2, PAL –62– REV. A ADV7302A/ADV7303A Mode 2: Master Option HSYNC, VSYNC, BLANK (Timing Register 0 TR0 = X X X X X 1 0 1) In this mode the ADV7302A/ADV7303A can generate horizontal and vertical SYNC signals. A coincident low transition of both HSYNC and VSYNC inputs indicates the start of an odd field. A VSYNC low transition when HSYNC is high indicates the start of an even field. The BLANK signal is optional. When the BLANK input is disabled, the ADV7302A/ADV7303A automatically blanks all normally blank lines as per CCIR-624. HSYNC is output on the S_HSYNC Pin, BLANK on the S_BLANK Pin, and FIELD on the S_VSYNC Pin. HSYNC VSYNC BLANK PAL = 12  CLOCK/2 NTSC = 16  CLOCK/2 PIXEL DATA Cb Y PAL = 132  CLOCK/2 NTSC = 122  CLOCK/2 Figure 103. SD Timing Mode 2 Even to Odd Field Transition, Master/Slave HSYNC VSYNC PAL = 12  CLOCK/2 NTSC = 16  CLOCK/2 PAL = 864  CLOCK/2 NTSC = 858  CLOCK/2 BLANK PIXEL DATA Cb Y Cr Y Cb PAL = 132  CLOCK/2 NTSC = 122  CLOCK/2 Figure 104. SD Timing Mode 2 Odd to Even Field Transition, Master/Slave REV. A –63– Cr Y ADV7302A/ADV7303A i.e., vertical retrace. The BLANK signal is optional. When the BLANK input is disabled, the ADV7302A/ADV7303A automatically blanks all normally blank lines as per CCIR-624. HSYNC is interfaced on the S_HSYNC Pin, BLANK on the S_BLANK Pin, and FIELD on the S_VSYNC Pin. Mode 3: Master/Slave Option HSYNC, BLANK, FIELD (Timing Register 0 TR0 = X X X X X 1 1 0 or X X X X X 1 1 1) In this mode the ADV7302A/ADV7303A accepts or generates horizontal SYNC and odd/even FIELD signals. A transition of the FIELD input when HSYNC is high indicates a new frame, DISPLAY DISPLAY VERTICAL BLANK 522 523 524 525 1 2 3 4 6 5 7 8 9 10 20 11 21 22 HSYNC BLANK FIELD EVEN FIELD ODD FIELD DISPLAY 260 DISPLAY VERTICAL BLANK 261 262 263 264 265 266 267 268 269 270 271 272 273 283 274 284 285 HSYNC BLANK FIELD ODD FIELD EVEN FIELD Figure 105. SD Timing Mode 3, NTSC DISPLAY DISPLAY VERTICAL BLANK 622 623 624 625 1 2 3 4 5 6 7 21 22 23 HSYNC BLANK FIELD EVEN FIELD ODD FIELD DISPLAY DISPLAY VERTICAL BLANK 309 310 311 312 313 314 315 316 317 318 319 320 334 335 336 HSYNC BLANK FIELD EVEN FIELD ODD FIELD Figure 106. SD Timing Mode 3, PAL –64– REV. A ADV7302A/ADV7303A Appendix F VIDEO OUTPUT LEVELS INPUT CODE EIA-770.2, STANDARD FOR Y INPUT CODE EIA-770.3, STANDARD FOR Y +700mV 940 OUTPUT VOLTAGE VIDEO ACTIVE +700mV 940 OUTPUT VOLTAGE +300mV VIDEO ACTIVE 0mV 64 64 –300mV 0mV EIA-770.3, STANDARD FOR Pr/Pb OUTPUT VOLTAGE –300mV +350mV 960 EIA-770.2, STANDARD FOR Pr/Pb +300mV OUTPUT VOLTAGE VIDEO ACTIVE 960 +350mV 0mV 512 VIDEO ACTIVE –300mV 0mV 512 Figure 109. EIA 770.3 Standard Output Signals (1080 i, 720 p) –300mV –350mV 64 Figure 107. EIA 770.2 Standard Output Signals (525 p) INPUT CODE INPUT CODE EIA-770.1, STANDARD FOR Y Y–OUTPUT LEVELS FOR FULL I/P SELECTION OUTPUT VOLTAGE 1023 OUTPUT VOLTAGE +782mV +714mV 940 –350mV 64 +700mV VIDEO ACTIVE VIDEO ACTIVE 64 64 –300mV 0mV –286mV EIA-770.1, STANDARD FOR Pr/Pb 960 0mV INPUT CODE 1023 OUTPUT VOLTAGE Pr/Pb–OUTPUT LEVELS FOR FULL I/P SELECTION OUTPUT VOLTAGE +700mV +350mV VIDEO ACTIVE VIDEO ACTIVE 512 0mV 64 –300mV –300mV 64 –350mV Figure 110. Output Levels for Full Input Selection Figure 108. EIA 770.1 Standard Output Signals (525 p) REV. A 0mV –65– ADV7302A/ADV7303A Appendix G VIDEO STANDARDS 0HDATUM SMPTE274M ANALOG WAVEFORM DIGITAL HORIZONTAL BLANKING 4T 272T 4T 1920T EAV CODE ANCILLARY DATA (OPTIONAL) OR BLANKING CODE SAV CODE DIGITAL ACTIVE LINE F F INPUT PIXELS 0 0 0 F 0 V H* F F 4 CLOCK SAMPLE NUMBER 2112 C 0 F C 0 V b Y r H* 0 0 C Y r 4 CLOCK 2116 2156 0 2199 44 188 192 2111 FVH* = FVH AND PARITY BITS SAV/EAV: LINE 1–562: F = 0 SAV/EAV: LINE 563–1125: F = 1 SAV/EAV: LINE1–20; 561–583; 1124–1125: V = 1 SAV/EAV: LINE 21–560; 584–1123: V = 0 Figure 111. EAV/SAV Input Data Timing Diagram, SMPTE274M SMPTE293M ANALOG WAVEFORM ANCILLARY DATA (OPTIONAL) EAV CODE F F INPUT PIXELS 0 0 F 0 V 0 H* F F 4 CLOCK SAMPLE NUMBER 719 DIGITAL ACTIVE LINE SAV CODE 0 0 F 0 V 0 H* C C b Y r C Y r Y 4 CLOCK 723 736 0HDATUM 799 853 857 0 719 DIGITAL HORIZONTAL BLANKING FVH* = FVH AND PARITY BITS SAV: LINE 43–525 = 200H SAV: LINE 1–42 = 2AC EAV: LINE43–525 = 274H EAV: LINE 1–42 = 2D8 Figure 112. EAV/SAV Input Data Timing Diagram, SMPTE293M –66– REV. A ADV7302A/ADV7303A ACTIVE VIDEO 522 523 ACTIVE VIDEO VERTICAL BLANK 524 525 1 2 5 6 7 8 9 12 13 14 15 16 42 43 44 Figure 113. SMPTE293M ACTIVE VIDEO 622 623 624 ACTIVE VIDEO VERTICAL BLANK 625 1 2 4 5 6 7 8 9 10 11 12 13 43 44 45 Figure 114. ITU-R.BT1358 (625 p) DISPLAY VERTICAL BLANKING INTERVAL 747 748 749 750 1 2 3 4 5 6 7 8 26 25 27 744 745 Figure 115. SMPTE296M (720 p) DISPLAY VERTICAL BLANKING INTERVAL FIELD 1 1124 1125 1 2 3 4 5 6 7 8 20 21 22 560 DISPLAY VERTICAL BLANKING INTERVAL FIELD 2 561 562 563 564 565 566 567 568 569 570 Figure 116. SMPTE274M (1080 i) REV. A –67– 583 584 585 1123 ADV7302A/ADV7303A OUTLINE DIMENSIONS 64-Lead Thin Plastic Quad Flatpack [LQFP] (ST-64B) 0.75 0.60 0.45 C02863–0–11/02(A) Dimensions shown in millimeters 12.00 BSC 1.60 MAX 64 49 1 48 SEATING PLANE TOP VIEW 10.00 BSC (PINS DOWN) 1.45 1.40 1.35 0.15 0.05 0.20 0.09 SEATING PLANE 7ⴗ 3.5ⴗ 0ⴗ 0.08 MAX COPLANARITY VIEW A 16 33 32 17 0.50 BSC VIEW A ROTATED 90ⴗ CCW 0.27 0.22 0.17 COMPLIANT TO JEDEC STANDARDS MS-026BCD Revision History Location Page 11/02—Data Sheet changed from REV. 0 to REV. A. Changes to Figure 1 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Changes to SPECIFICATIONS . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Changes to TIMING SPECIFICATIONS . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5 Added Thermal Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Changes to Table IV . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18 Changes to Table XII . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 32 Changes to Table XIII . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 32 Changes to the Realtime Control, Subcarrier Reset, Timing Reset section . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 33 Changes to SD SUBCARRIER FREQUENCY REGISTERS [Subaddress 4Ch–4Fh] . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 35 Changes to Figure 73 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 49 Changes to Figure 75 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 50 Changes to Figure 76 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 50 Changes to Figure 79 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 51 Updated OUTLINE DIMENSIONS . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 68 –68– REV. A PRINTED IN U.S.A. Changes to PIN FUNCTION DESCRIPTIONS . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12
ADV7303AKST 价格&库存
很抱歉,暂时无法提供与“ADV7303AKST”相匹配的价格&库存,您可以联系我们找货
