YT8522H
YT8522H
    MOTORCOMM(裕太微电子)
    QFN-32-EP(5x5)
    以太网收发器 QFN32_5X5MM_EP
YT8522H 数据手册
Motorcomm YT8522C/YT8522H/YT8522E/ YT8522A Datasheet 10/100 FAST ETHERNET TRANSCEIVER VERSION DRAFT 0.4 DATE 2023-05-15 裕太微电子 | Motorcomm Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet Copyright Statement This document is copyright of Motorcomm Electronic Technology Co., Ltd. ("Motorcomm"). All rights reserved. No company or individual may copy, disseminate, disclose or otherwise distribute any part of this document to any third party without the written consent of Motorcomm. If any company or individual so does, Motorcomm reserves the right to hold it or him liable therefor. Disclaimer This document only provides periodic information, and its contents will/may be updated from time to time according to actual situation of Motorcomm’s products without further notice. Motorcomm will not take any responsibility for any direct or indirect losses caused due to improper use of this document. 1 Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet Revision History Revision Release Date Summary Draft 0.1 2022/12/04 draft version Draft 0.2 2023/03/11 Modify strappin setting and some description errors Draft 0.3 2023/05/05 Add register overview Draft 0.4 2023/05/15 Add block diagram and modify pin map 2 Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet Content 1. General Description .............................................................................................................................................. 1 1.1. Features .......................................................................................................................................................1 1.2. Target Applications .................................................................................................................................... 2 1.3. Block Diagram ............................................................................................................................................ 2 2. Pin Assignment ...................................................................................................................................................... 3 2.1. Pin Map ........................................................................................................................................................3 2.2. Pin Descriptions ......................................................................................................................................... 3 3. Function Description .......................................................................................................................................7 3.1. Application Diagram .................................................................................................................................. 7 3.1.1. 100Base-Tx/100Base-Fx/10Base-Te application .................................................................. 7 3.2. MII Interface ................................................................................................................................................ 7 3.3. RMII Interface ............................................................................................................................................. 7 3.4. Management Interface .............................................................................................................................. 7 3.5. DAC .............................................................................................................................................................. 7 3.6. ADC .............................................................................................................................................................. 8 3.7. Adaptive Equalizer .....................................................................................................................................8 3.8. Auto-Negotiation ....................................................................................................................................... 8 3.9. Polarity Detection and Auto Correction .................................................................................................. 8 3.10. EEE ............................................................................................................................................................ 8 4. Operational Description ................................................................................................................................ 9 4.1. Reset ............................................................................................................................................................ 9 4.2. Strapping pins Setting ............................................................................................................................... 9 4.2.1. POS .................................................................................................................................................. 9 4.2.2. Phy address ...................................................................................................................................11 4.2.3. Mode config ................................................................................................................................... 11 4.2.4. Wake on lan selection ..................................................................................................................11 4.3. XMII Interface ........................................................................................................................................... 12 4.3.1. MII ................................................................................................................................................... 12 4.3.2. RMII ................................................................................................................................................ 12 4.3.3. REMII interface ............................................................................................................................. 13 4.4. Loopback Mode ........................................................................................................................................14 4.4.1. Internal loopback: ......................................................................................................................... 14 4.4.2. External loopback ......................................................................................................................... 14 4.4.3. Remote loopback ..........................................................................................................................14 4.5. Wake on Lan .............................................................................................................................................15 4.5.1. WOL ................................................................................................................................................15 5. Register Overview ......................................................................................................................................... 17 5.1. MII Management Interface Clause 22 Register Programming .........................................................17 5.2. MII Registers .............................................................................................................................................17 5.2.1. Mii register 00H: Basic control register ..................................................................................... 17 5.2.2. Mii register 01H: Basic status register ...................................................................................... 19 5.2.3. Mii register 02H: PHY identification register1 .......................................................................... 20 3 Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet 5.2.4. Mii register 03H: PHY identification register2 .......................................................................... 20 5.2.5. MII register 04H: Auto-Negotiation advertisement .................................................................20 5.2.6. MII register 05H: Auto-Negotiation link partner ability ...........................................................23 5.2.7. MII register 06H: Auto-Negotiation expansion register ......................................................... 25 5.2.8. MII register 07H: Auto-Negotiation Next Page register .........................................................25 5.2.9. MII register 08H: Auto-Negotiation link partner Received Next Page register ..................26 5.2.10. MII register 0AH: MASTER-SLAVE status register ............................................................. 26 5.2.11. MII register 0DH: MMD access control register .................................................................... 27 5.2.12. MII register 0EH: MMD access data register .........................................................................28 5.2.13. Mii register 0FH: Extended status register .............................................................................28 5.2.14. MII register 10H: PHY specific function control register ...................................................... 28 5.2.15. MII register 11H: PHY specific status register .......................................................................29 5.2.16. MII register 12H: Interrupt Mask Register .............................................................................. 30 5.2.17. MII register 13H: Interrupt Status Register ............................................................................ 31 5.2.18. MII register 14H: Speed Auto Downgrade Control Register ............................................... 32 5.2.19. MII register 15H: Rx Error Counter Register ......................................................................... 33 5.2.20. MII register 1AH:Reference Clock Register ...........................................................................33 5.2.21. MII register 1EH: Debug Register’s Address Offset Register ..........................................33 5.2.22. MII register 1FH: Debug Register’s Data Register ............................................................ 33 5.3. Extended register .....................................................................................................................................33 5.3.1. EXT 0000h PHY Broadcast addr ............................................................................................... 33 5.3.2. EXT 0001h Interpolator Filter ..................................................................................................... 34 5.3.3. EXT 0010H: Interpolator Filter Coef.0 .......................................................................................34 5.3.4. EXT 0011H: Interpolator Filter Coef.1 .......................................................................................34 5.3.5. EXT 0012H: Interpolator Filter Coef.2 .......................................................................................34 5.3.6. EXT 0013H: Interpolator Filter Coef.3 .......................................................................................34 5.3.7. EXT 0014H: Interpolator Filter Coef.4 .......................................................................................35 5.3.8. EXT 0015H: Interpolator Filter Coef.5 .......................................................................................35 5.3.9. EXT 0016H: Interpolator Filter Coef.6 .......................................................................................35 5.3.10. EXT 0017H: Interpolator Filter Coef.7 .................................................................................... 35 5.3.11. EXT 0050H: AFE PLL Config ...................................................................................................35 5.3.12. EXT 0061H: AFE Switches .......................................................................................................35 5.3.13. EXT 00A0H: PLL Lock Detect Status ..................................................................................... 36 5.3.14. EXT 200AH: 10BT Debug, LPBKs Register .......................................................................... 36 5.3.15. EXT 2012H: AFE Control Register3 ....................................................................................... 36 5.3.16. EXT 2027H: Sleep Control1 ..................................................................................................... 37 5.3.17. EXT 2056H: 10BT RX Comparator Threshold ...................................................................... 37 5.3.18. EXT 2057H: DAC Ctrl for 10BT and 100BT ...........................................................................37 5.3.19. EXT 2058H: PHY DEBUG CONFIGURE 1 .......................................................................37 5.3.20. EXT 2059H: PHY DEBUG CONFIGURE 2 .......................................................................37 5.3.21. EXT 205AH: PHY DEBUG, MSE1 ...................................................................................... 38 5.3.22. EXT 205BH: PHY DEBUG, MSE2 ...................................................................................... 38 5.3.23. EXT 2068H: PHY Debug, Integrator ....................................................................................... 39 5.3.24. EXT 4000H: extended combo control1 .................................................................................. 39 4 Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet 5.3.25. EXT 4001H: extended pad control .......................................................................................... 39 5.3.26. EXT 4003H: extended combo control2 .................................................................................. 40 5.3.27. EXT 4004H: WOL MAC Address .............................................................................................41 5.3.28. EXT 4005H: WOL MAC Address .............................................................................................41 5.3.29. EXT 4006H: WOL MAC Address .............................................................................................41 5.3.30. EXT 40A0H: pkg_selftest control .............................................................................................42 5.3.31. EXT 40A1H: pkg_selftest control .............................................................................................43 5.3.32. EXT 40A2H: pkg_selftest control .............................................................................................43 5.3.33. EXT 40A3H: pkg_selftest status ..............................................................................................43 5.3.34. EXT 40A4H: pkg_selftest status ..............................................................................................44 5.3.35. EXT 40A5H: pkg_selftest status ..............................................................................................44 5.3.36. EXT 40A6H: pkg_selftest status ..............................................................................................44 5.3.37. EXT 40A7H: pkg_selftest status ..............................................................................................44 5.3.38. EXT 40A8H: pkg_selftest status ..............................................................................................45 5.3.39. EXT 40A9H: pkg_selftest status ..............................................................................................45 5.3.40. EXT 40AaH: pkg_selftest status ..............................................................................................45 5.3.41. EXT 40AbH: pkg_selftest status ..............................................................................................45 5.3.42. EXT 40AcH: pkg_selftest status .............................................................................................. 45 5.3.43. EXT 40AdH: pkg_selftest status ..............................................................................................45 5.3.44. EXT 40AeH: pkg_selftest status ..............................................................................................46 5.3.45. EXT 40AfH: pkg_selftest status ............................................................................................... 46 5.3.46. EXT 40B0H: pkg_selftest status ..............................................................................................46 5.3.47. EXT 40B1H: pkg_selftest status ..............................................................................................46 5.3.48. EXT 40B2H: pkg_selftest status ..............................................................................................47 5.3.49. EXT 40B3H: pkg_selftest status ..............................................................................................47 5.3.50. EXT 40B4H: pkg_selftest status ..............................................................................................47 5.3.51. EXT 40B5H: pkg_selftest status ..............................................................................................47 5.3.52. EXT 40B6H: pkg_selftest status ..............................................................................................47 5.3.53. EXT 40B7H: pkg_selftest control .............................................................................................47 5.3.54. EXT 40B8H: pkg_selftest control .............................................................................................48 5.3.55. EXT 40B9H: pkg_selftest control .............................................................................................48 5.3.56. EXT 40BAH: pkg_selftest control ............................................................................................ 48 5.3.57. EXT 40C0H: LED0 control ........................................................................................................48 5.3.58. EXT 40C1H: LED0/1 control .................................................................................................... 50 5.3.59. EXT 40C2H: LED0/1 control .................................................................................................... 51 5.3.60. EXT 40C3H: LED1 control ........................................................................................................52 5.3.61. EXT 4201H: Txclk_delay .......................................................................................................... 54 5.3.62. EXT 4216H: IO Level .................................................................................................................54 6. Timing and electrical characteristics .....................................................................................................55 6.1. Crystal Requirement ................................................................................................................................55 6.2. Oscillator/External Clock Requirement ................................................................................................ 55 6.3. DC Characteristics ...................................................................................................................................55 6.4. MDC/MDIO Timing .................................................................................................................................. 56 6.5. MII Transmission Cycle Timing ............................................................................................................. 57 5 Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet 6.6. MII Reception Cycle Timing ................................................................................................................... 58 6.7. RMII1 Transmission and Reception Cycle Timing ............................................................................. 59 6.8. RMII2 Transmission and Reception Cycle Timing ............................................................................. 60 6.9. 100Base-FX Characteristics ........................................................................................................ 61 6.9.1. 100Base-FX Differential Transmitter Characteristics ............................................................ 61 6.9.2. 100Base-FX Differential Receiver Characteristics .................................................................62 7. Power Requirements .................................................................................................................................... 63 7.1. Absolute Maximum Ratings ................................................................................................................... 63 7.2. Recommended Operating Condition .................................................................................................... 63 7.3. Power On Sequence ............................................................................................................................... 64 7.4. Power Consumption ...............................................................................................................................65 7.4.1. MII mode ........................................................................................................................................ 65 7.4.2. RMII mode ..................................................................................................................................... 65 7.5. Maximum Power Consumption ............................................................................................................ 65 8. Package information ........................................................................................................................................... 66 8.1. RoHS-Compliant Packaging ................................................................................................................. 66 8.2. Thermal resistance .................................................................................................................................. 66 9. Mechanical Information ...................................................................................................................................... 67 10. Ordering Information .........................................................................................................................................69 6 Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet List of Table Table 1 .Pin Assignment ....................................................................................................................... 4 Table 2 .Power on strapping .................................................................................................................9 Table 3 .Power on strapping-Phy address ........................................................................................ 11 Table 4 .Power on strapping-Mode config .........................................................................................11 Table 5 .Power on strapping-Wake on lan ........................................................................................ 11 Table 6 . Crystal Requirement ............................................................................................................ 55 Table 7 . Oscillator/External Clock Requirement ............................................................................... 55 Table 8 . DC Characteristics ...............................................................................................................55 Table 9 . MDC/MDIO Timing .............................................................................................................. 56 Table 10 . MII Transmission Cycle Timing ......................................................................................... 57 Table 11 . MII Reception Cycle Timing .............................................................................................. 58 Table 12 . RMII1 Transmission and Reception Cycle Timing ............................................................59 Table 13 . RMII2 Transmission and Reception Cycle Timing ............................................................60 Table 14 .100Base-FX Differential Transmitter Characteristics ........................................................61 Table 15 .100Base-FX Differential Transmitter Characteristics ........................................................62 Table 16 . Absolute Maximum Ratings ...............................................................................................63 Table 17 . Recommended Operating Condition .................................................................................63 Table 19 .MII Mode Power Consumption ........................................................................................... 65 Table 20 .RMII Mode Power Consumption ........................................................................................ 65 Table 21 .Maximum Power Consumption .......................................................................................... 65 Table 22 . RoHS-Compliant Packaging .............................................................................................66 Table 23 . Thermal resistance ............................................................................................................ 66 Table 24 . Ordering Information ..........................................................................................................69 7 Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet List of Figures Figure 1 . PIN MAP ............................................................................................................................... 3 Figure 2 . Connection diagram of MII ................................................................................................. 12 Figure 3 . Connection diagram of RMII1(with 25MHz and 50MHz clock) ..........................................13 Figure 4 . Connection diagram of RMII2 ............................................................................................ 13 Figure 5 . Connection diagram of REMII ............................................................................................ 13 Figure 6 . Internal loopback ................................................................................................................ 14 Figure 7 . External loopback ............................................................................................................... 14 Figure 8 . Remote loopback ................................................................................................................15 Figure 9 . MDC/MDIO Timing ............................................................................................................. 56 Figure 10 . MII Transmission Cycle Timing ........................................................................................ 57 Figure 11 . MII Reception Cycle Timing ............................................................................................. 58 Figure 12 . RMII1 Transmission and Reception Cycle Timing ...........................................................59 Figure 13 . RMII2 Transmission and Reception Cycle Timing ...........................................................60 Figure 14 . 100Base-FX Differential Transmitter Eye Diagram ........................................................ 61 Figure 15 . 100Base-FX Differential Receiver Eye Diagram .............................................................62 Figure 16 . Power On Sequence ........................................................................................................ 64 Figure 17 . Mechanical Information .................................................................................................... 67 8 Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet 1. General Description YT8522 is a low power single-port 10/100 Mbps Ethernet PHY. It provides all physical layer functions needed to transmit and receive data over both standard twisted pair cables transceiver or Fiber PECL interface to an external 100Base-FX optical transceiver module. Additionally, YT8522 provides flexibility to connect to a MAC through a standard MII and RMII interface. YT8522 uses mixed-signal processing to perform equalization, data recovery, and error correction to achieve robust operation over CAT5 twisted-pair cable or 100Base-FX optical transceiver module. YT8522 offers integrated built-in self-test and loopback capabilities for ease of use. YT8522 offers innovative and robust approach for reducing power consumption through EEE, WoL and other programmable energy savings modes. 1.1. Features  Supports IEEE 802.3az (Energy Efficient Ethernet)  100Base-TX IEEE 802.3u Compliant  10Base-Te IEEE 802.3 Compliant  Supports MII mode  Supports RMII mode  Supports I/O 1.5V/1.8V/2.5V/3.3V (except for Crystal and LED pins)  Full/Half duplex operation  100BASE-FX support (share with MDI pins)  Twisted pair or fiber mode output  Supports Auto-negotiation  Supports Power down mode  Supports Base Line Wander (BLW) compensation  Supports Auto MDIX  Supports Interrupt function  Supports WOL, Wake on Lan  Automatic Polarity correction  2 sets LED indicator  25MHz crystal or external OSC  50MHz external OSC input  Provide 50Mhz clock source for MAC  Single Power supply, internal LDO  Package QFN 32, 5x5mm 1 Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet 1.2. Target Applications  Ethernet Switch  DTV (Digital TV)  Communication and Network Riser  Routers, PON Equipment  Printer and Office Machine  MAU(Media Access Unit) 1.3. Block Diagram 2 Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet 2. Pin Assignment 2.1. Pin Map Figure 1.PIN MAP 2.2. Pin Descriptions  I = Input  O = Output  I/O = Bidirectional  OD = Open-drain output  PU = Internal pull-up  PD = Internal pull-down  HZ = High Impendence during power on reset  PWR = Power related  XT = Crystal related 3 Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet Table 1.Pin Assignment No. Name Type Description Bias Resistor. 1 RBIAS I An external 2.49 kΩ±1% resistor must be connected between the RBIAS pin and GND Power Output. 2 AVDDL_O PWR/O Be sure to connect a 1uF +0.1uF ceramic capacitor for decoupling purposes. 3 TRXP0 IO 4 TRXN0 IO 5 TRXP1 IO 6 TRXN1 IO 7 AVDD33 PWR Transmit/Receive Pairs for channel 0. Differential data from copper media is transmitted and received on the single TRD± signal pair. There are 50Ω internal terminations on each pin. Since this device incorporates voltage driven DAC, it does not require a center-tap power supply. Transmit/Receive Pairs for channel 1. Differential data from copper media is transmitted and received on the single TRD± signal pair. There are 50Ω internal terminations on each pin. Since this device incorporates voltage driven DAC, it does not require a center-tap power supply. 3.3V Analog Power Input. 3.3V power supply for analog circuit; should be well decoupled. Receive Data Valid. This pin’s signal is asserted high when received data is present on the RXD[3:0] lines. The signal is de-asserted at the end of the packet. The signal is valid on the rising edge of the RXC. This pin should be pulled low when operating in MII 8 RX_DV O/PD mode. Power On Strapping for MII/RMII selection. 0: MII mode 1: RMII mode An internal weakly pulled low resistor sets this to the default of MII mode. It is possible to use an external 4.7KΩ pulled high resistor to enable RMII mode.After power on, the pin operates as the Receive Data Valid pin. 9 RXD[0] O/PD Receive Data [0] Receive Data [1] 10 RXD[1] O/PD An internal weakly pulled low resistor sets RXD[1] to the LED function (default). Use an external 4.7KΩ pulled high resistor to enable the WOL function. 11 RXD[2]/INT_N O/OD/PD Receive Data [2] When in RMII mode, this pin is used for the interrupt function. Receive Data [3] RXD[3]/CLK_CTL pin is the Power On Strapping in RMII Mode. 12 RXD[3]/CLK_CTL O/PD 1: REF_CLK input mode, RMII1 mode 0: REF_CLK output mode, RMII2 mode Note: An internal weakly pulled low resistor sets RXD[3]/CLK_CTL to REF_CLK output mode (default). 4 Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet Receive Clock. 13 RXC O/PD This pin provides a continuous clock reference for RX_DV and RXD [0:3] signals. RXC is 25MHz in 100Mbps mode and 2.5MHz in 10Mbps mode. Supports 3.3V/2.5V/1.8V/1.5V Digital Power Input. 14 DVDDIO PWR 3.3V/2.5V/1.8V/1.5V power supply for digital circuit. Note:IO level register should be connfigured MII Mode Transmit Clock. This pin provides a continuous clock as a timing reference for TXD [3:0] and TXEN signals. 15 TXC IO/PD TXC is 25MHz in 100Mbps mode and 2.5MHz in 10Mbps mode RMII Mode Synchronous 50MHz Clock Reference for Receive, Transmit, and Control Interface. The default direction is reference clock output mode if RXD[3]/CLK_CTL pin floating. 16 TXD[0] I/PD Transmit Data [0] 17 TXD[1] I/PD Transmit Data [1] 18 TXD[2] I/PD Transmit Data [2] 19 TXD[3] I/PD Transmit Data [3] MII/RMII Mode 20 TX_EN I/PD Transmit Enable. The input signal indicates the presence of valid nibble data on TXD [3:0]. An internal weakly pulled low resistor prevents the bus floating. 21 RESET_N I,HZ RESET. Active-low, reset pin for chip. Management Data Clock. This pin provides a clock synchronous to MDIO, 22 MDC I/PU which may be asynchronous to the transmit TXC and receive RXC clocks. The clock rate can be up to 12.5MHz. Use an internal weakly pulled high resistor to prevent the bus floating. Management Data Input/Output. 23 MDIO IO/PU This pin provides the bi-directional signal used to transfer management information 24 25 LED0/PHYAD[0]/ PMEB LED1/PHYAD[1] O/OD/PD O/PD LED 0, Link On/Off. PHY address 0 selection LED 1, Link On/Off,Active blink. PHY address 1 selection MII mode: Carrier Sense. 26 CRS/CRS_DV/ XTAL_SEL This pin’s signal is asserted high if the media is not in Idle state. O/PD RMII mode: Carrier Sense/Receive Data Valid. CRS_DV shall be asserted by the PHY when the receive medium is non-idle. This pin status is latched at power on reset to determine Reference Clock 5 Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet Input Selection . 1:Reference Clock from TXC 0:Reference Clock from XTAL An internal weakly pulled low resistor sets this to select Reference Clock from XTAL.It is possible to use an external 4.7KΩ pulled high resistor to select Reference Clock from TXC.After power on,the pin operates as the CRS/CRS_DV pin. Collision Detect. COL is asserted high when a collision is detected 27 COL/BP_I2C O/PD on the media. It is possible to use an external 4.7KΩ pulled high resistor to bypass I2C load.After power on,the pin operates as the collision detect pin. Receive Error. 100FX/UTP Enable. This pin status is latched at power on reset to determine the media mode to operate in. 28 RXER/FXEN O/PD 1:Fiber mode 0:UTP mode An internal weakly pulled low resistor sets this to the default of UTP mode.It is possible to use an external 4.7KΩ pulled high resistor to enable fiber mode.After power on,the pin operates as the receive error pin. DVDDL Power Output. 29 DVDDL_O PWR/O Be sure to connect a 1uF +0.1uF ceramic capacitor for decoupling purposes. 30 AVDD33 PWR 3.3V Analog Power Input. 3.3V power supply for analog circuit; should be well decoupled. 25 MHz Crystal Input Pin. If use external oscillator or clock from another device. 31 XTAL_IN XT 1. When an external 25Hhz oscillator or clock from another device drivers XTAL_OUT. XTAL_IN must be shorted to GND 2. When an external 25Hhz oscillator or clock from another device drivers XTAL_IN; keep the XTAL_OUT floating. 25 MHz Crystal Output Pin. If use external oscillator or clock from another device. 32 XTAL_OUT XT 1. When an external 25Hhz oscillator or clock from another device drivers XTAL_OUT. XTAL_IN must be shorted to GND 2. When an external 25Hhz oscillator or clock from another device drivers XTAL_IN; keep the XTAL_OUT floating. 33 EPAD GND Exposed ground pad on back of the chip, tie to ground 6 Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet 3. Function Description 3.1. Application Diagram 3.1.1. 100Base-Tx/100Base-Fx/10Base-Te application 100Base-Tx SWITCH/MAC MII/RMII 100Base-Fx YT8522 10Base-Te RXD[3:0] CMC and Capacitive Coupling TXD[3:0] 3.2. MII Interface The Media Independent Interface (MII) is the digital data interface between the MAC and the physical layer that can be enabled when the device is functioning in 10BASE-Te, 100BASE-TX/FX,. The original MII transmit signals include TX_EN, TXC, TXD[3:0], and TX_ER. The receive signals include RX_DV, RXC, RXD[3:0], and RX_ER. The media status signals include CRS and COL. Due to pin-count limitations, the YT8522 supports a subset of MII signals. This subset includes all MII signals except TX_ER. 3.3. RMII Interface Reduced media-independent interface (RMII) is a standard which was developed to reduce the number of signals required to connect a PHY to a MAC. If this interface is active, the number of data signal pins required to and from the MAC is reduced to half by doubling clock frequency. 3.4. Management Interface The Status and Control registers of the device are accessible through the MDIO and MDC serial interface. The functional and electrical properties of this management interface comply with IEEE 802.3, Section 22 and also support MDC clock rates up to 12.5 MHz 3.5. DAC The digital-to-analog converter (DAC) transmits MLT3, and Manchester coded symbols. The transmit DAC performs signal wave shaping that reduces electromagnetic interference (EMI). The transmit DAC uses voltage driven output with internal terminations and hence does not require external components or magnetic supply for operation. 7 Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet 3.6. ADC Receive channel has its own analog-to-digital converter (ADC) that samples the incoming data on the receive channel and feeds the output to the digital data path. 3.7. Adaptive Equalizer The digital adaptive equalizer removes inter-symbol interference (ISI) created by the channel. The equalizer accepts sampled data from the analog-to-digital converter (ADC) on channel and produces equalized data. The coefficients of the equalizer are adaptive to accommodate varying conditions of cable quality and cable length. 3.8. Auto-Negotiation The YT8522 negotiates its operation mode using the auto negotiation mechanism according to IEEE 802.3 clause 28 over the copper media. Auto negotiation supports choosing the mode of operation automatically by comparing its own abilities and received abilities from link partner. The advertised abilities include: a) Speed: 10/100Mbps b) Duplex mode: full duplex and/or half duplex c) Pause Auto negotiation is initialized when the following scenarios happen: a) Power-up/Hardware/Software reset b) Auto negotiation restart c) Transition from power-down to power up d) Link down Auto negotiation is enabled for YT8522 by default, and can be disable by software control. 3.9. Polarity Detection and Auto Correction YT8522 can detect and correct two types of cable errors: swapping of pairs within the UTP cable and swapping of wires within a pair. For 10BASE-Te/100BASE-TX, YT8522 can handle both cable errors at the same time. 3.10. EEE EEE is IEEE 802.3az, an extension of the IEEE 802.3 standard. EEE defines support for the PHY to operate in Low Power Idle (LPI) mode which, when enabled, supports QUIET times during low link utilization allowing both link partners to disable portions of each PHY's circuitry and save power. 8 Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet 4. Operational Description 4.1. Reset YT8522 have a hardware reset pin(RESET_N) which is low active. RESET_N should be active for at least 10ms to make sure all internal logic is reset to a known state. Hardware reset should be applied after power up. RESET_N is also used as enable for power on strapping. After RESET_N is released , YT8522 latches input value on POS related pins are used as configuration information which provides flexibility in application without mdio access. YT8522 also provides a software reset control registers which are used to reset all internal logic except some mdio configuration registers. For detailed information about what register will be reset by software reset, please refer to register table. 4.2. Strapping pins Setting 4.2.1. POS Table 2.Power on strapping No. Name Internal POS Pull/Down Description The PHY address is 00~11 config by 24 LED0/PHYAD[0] phy_address[0] Pull Down phy_address[1:0].Wol_led_sel=1, this PAD works as PMEB, it shall be external pull-up, then phy_address[0] always =1. 25 LED1/PHYAD[1] phy_address[1] Pull Down The PHY address is 00~11 config by phy_address[1:0] The power on strapping value of PAD RXD1, 10 RXD[1] Wake on selection LAN Wol_led_sel, determines the PAD LED0 Pull Down working as LED0 or PMEB. 1, LED0 works as PMEB (WOL interrupt) 0, LED0 works as LED0. 12 RXD[3]/ CLK_CTL Clock control Pull Down 9 The power-on strapping value of {RX_DV, RXD3} determines the xMII mode: Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet {RX_DV, RXD3}=2’b00 means MII mode; {RX_DV, RXD3}=2 ’ b01 8 RX_DV MII/RMII mode selection means ReMII mode; Pull Down {RX_DV, RXD3}=2’b10 means RMII2 mode, TXC 50Mhz reference clock is output. {RX_DV, RXD3}=2’b11 means RMII1 mode, TXC 50Mhz reference clock is input. This pin status is latched at power on reset to determine Reference Clock Input Selection . 1:Reference Clock from TXC 0:Reference Clock from XTAL 26 CRS/CRS_DV/ Reference XTAL_SEL selection Clock Pull Down An internal weakly pulled low resistor sets this to select Reference Clock from XTAL.It is possible to use an external 4.7KΩ pulled high resistor to select Reference Clock from TXC.After power on,the pin operates as the CRS/CRS_DV pin. It is possible to use an external 4.7K Ω 27 COL/BP_I2C Bypass I2C load Pull Down pulled high resistor to bypass I2C load.After power on,the pin operates as the collision detect pin. This pin status is latched at power on reset to determine the media mode to operate in. 1:Fiber mode 0:UTP mode 28 RX_ER/FXEN FX_EN Pull Down An internal weakly pulled low resistor sets this to the default of UTP mode.It is possible to use an external 4.7K Ω pulled high resistor to enable fiber mode.After power on,the pin operates as the receive error pin. 10 Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet 4.2.2. Phy address Table 3.Power on strapping-Phy address Pin 25 Pin 24 LED1/ PHYAD[1] (PD) LED0/ PHYAD[0] (PD) 0 0 00 0 1 01 1 0 10 1 1 11 PHY address 4.2.3. Mode config Table 4.Power on strapping-Mode config Pin 8 Pin 12 RX_DV (PD) RXD3 (PD) 0 0 0 1 1 0 1 1 Mode MII ReMII, Reverse MII Mode RMII2, TXC 50Mhz reference clock is output by default RMII1, TXC 50Mhz reference clock is input 4.2.4. Wake on lan selection Table 5.Power on strapping-Wake on lan Pin 10 RXD1 (PD) Function 0 LED Mode 1 WOL Mode 11 Mote Pin 24 is LED0 Pin 24 is PMEB, Must external pull up Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet 4.3. XMII Interface YT8522 support 4 kinds of MII related interfaces: MII, RMII1, RMII2 and REMII. 4.3.1. MII The Media Independent Interface (MII) is the digital data interface between the MAC and the physical layer that can be enabled when the device is functioning in 10BASE-Te, 100BASE-TX, The original MII transmit signals include TX_EN, TXC, TXD[3:0], and TX_ER. The receive signals include RX_DV, RXC, RXD[3:0], and RX_ER. The media status signals include CRS and COL. Due to pin-count limitations, the YT8522 supports a subset of MII signals. This subset includes all MII signals except TX_ER. For 100M application, TXC and RXC are 25MHz; for 10M application, TXC and RXC are 2.5MHz. TXC and RXC are output in this case. Figure 2. Connection diagram of MII 4.3.2. RMII Reduced media-independent interface (RMII) is a standard which was developed to reduce the number of signals required to connect a PHY to a MAC. If this interface is active, the number of data signal pins required to and from the MAC is reduced to half by doubling clock speed compared to MII. It has 7 signals: REF_CLK, TX_EN, TXD[1:0], RX_DV and RXD[1:0]. YT8522 uses TXC or Cystal as REF_CLK. For 100M application, REF_CLK is 50MHz; for 10M application, REF_CLK is still 50MHz, data will be duplicated for 10 times in 20ns cycles. YT8522 supports two types of connection method; 1. RMII1 mode: This is fully conforming to RMII standard.For RMII1, YT8522 supports Cystal 25M/50M ,TXC 50M without Cystal. 2. RMII2 mode: TXC will be 50MHz output to MAC. 12 Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet Figure 3. Connection diagram of RMII1(with 25MHz and 50MHz clock) Figure 4. Connection diagram of RMII2 4.3.3. REMII interface Reverse media independent interface is the opposite of MII interface. The only difference is the direction of tx clock and rx clock. For MII, tx clock and rx clock are output; for REMII, tx clock and rx clock are input. REMII interface are used for back to back connection of two phys. Figure 5. Connection diagram of REMII 13 Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet 4.4. Loopback Mode There are three loopback modes in YT8522. 4.4.1. Internal loopback: In Internal loopback mode, YT8522 feed transmit data to receive path in chip. Configure bit 14 of mii register(address 0h0) to enable internal loopback mode. For 10Base-Te and 100Base-Tx, YT8522 feeds digital DAC data to ADC directly. Figure 6. Internal loopback 4.4.2. External loopback In external loopback mode, YT8522 feed transmit data to receive path out of chip. For 10Base-Te and 100Base-Tx, just connect TRX_P0/N0 to TRX_P1/N1. Figure 7. External loopback 4.4.3. Remote loopback In remote loopback mode, YT8522 feed MII receive data to transmit path in chip. Configure bit 11 of extended register(address 0h4000) and for TRX interface, just connect to link partner normally. 14 Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet Figure 8. Remote loopback 4.5. Wake on Lan 4.5.1. WOL Wake-on-LAN (WOL) is a mechanism to manage and regulate the total network power consumption.YT8522 supports automatic detection of a specific frame and notification via dedicated hardware interrupt pin or general PHY interrupt pin. The specific frame contains a specific data sequence located anywhere inside the packet. The data sequence consists of 6 bytes of consecutive 1 (0xFFFFFFFFFFFF), followed by 16 repetitions of the MAC address of the computer to be waked up. The 48-bit MAC address is written in EXT 0x4004, 0x4005, 0x4006 registers. For example, to write a specific MAC address (0xAAAABBBBCCCC) to PHY, write EXT 0x4004 = 0xAAAA, 0x4005 = 0xBBBB, and 0x4006 = 0xCCCC. The PHY internal MAC address can be set to any value. NOTE: The MAC address is not a real MAC address and is only a symbol to indicate the content of the frame.The WOL mechanism is enabled via EXT 0x4000 bit2. POS RXD[1] can ’ t control enable or disable the WOL mechanism but only control pad LED0 working as WOL interrupt. 15 Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet 4.5.2. WOL Interrupt YT8522 support dedicated WOL interrupt pin. When the pad RXD[1] is externally PULL UP, pad LED0 will work as WOL interrupt. If EXT 0x4003 bit7 is 0, the dedicated WOL interrupt is programmed to a level, otherwise, it’s programed to a pulse; either is active low. When it’s programmed to a pulse, the pulse width can be programmed via EXT 0x4003 bit9:8. WOL interrupt is also wire-and to general PHY interrupt RXD[2]_INTN when the bit6 INT_WOL in Interrupt enable register (MII Register 0x12) is set to 1. If the general PHY interrupt is triggered by WOL, it can be cleared by reading MII register 0x13 bit6. NOTE: When general PHY interrupt is used to monitor WOL interrupt, EXT 0x4003 bit7 should be 1, otherwise, the general PHY interrupt can’t be read cleared. Because PHY requires to receive packets from the line side, PHY cannot be powered down. If the link partner supports Energy Efficient Ethernet function, both ends can use EEE mode to save more power. MII register 0x0 bit10 ISOLATE: When this bit is set to 1, the xMII output pins are HighZ. The xMII inputs are ignored. 16 Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet 5. Register Overview 5.1. MII Management Interface Clause 22 Register Programming The YT8522 transceiver is designed to be fully compliant with the MII clause of the IEEE 802.3u Ethernet specification. The MII management interface registers are written and read serially, using the MDIO and MDC pins. A clock of up to 12.5 MHz must drive the MDC pin of the YT8512. Data transferred to and from the MDIO pin is synchronized with the MDC clock. The following sections describe what each MII read or write instruction contains. Notation Description RW Read and write SC Self-clear RO Read only LH Latch high LL Latch Low RC Read clear SWC Software reset clear 5.2. MII Registers 5.2.1. Bit Mii register 00H: Basic control register Symbol Access Default Description PHY Software Reset. Writing 1 to this bit causes immediate PHY reset. Once the operation is done, this 15 Reset RW SC 1’b0 bit is cleared automatically. 0: Normal operation 1: PHY reset 14 Loopback RW SWC Internal loopback control 1’b0 1’b0: disable loopback 1’b1: enable loopback 17 Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet LSB of speed_selection[1:0]. Link speed can be selected via either the Auto-Negotiation process, or manual speed selection speed_selection[1:0]. Speed_selection[1:0] is valid when Auto-Negotiation is disabled by clearing bit 0.12 to zero. 13 Speed Selection(LSB) RW 1’b0 Bit 6 Bit 13 1 1 Reserved 1 0 1000Mb/s 0 1 100Mb/s 0 0 10Mb/s 1: to enable auto-negotiation; 12 Autoneg_En RW 1’b1 0: auto-negotiation is disabled. =1: Power down =0: Normal operation When the port is switched from power down to 11 Power_down RW SWC 1’b0 normal operation, software reset and AutoNegotiation are performed even bit[15] RESET and bit[9] RESTART_AUTO_NEGOTIATION are not set by the user. Isolate phy from MII/RMII: PHY will not respond to xMII TXD/TX_EN, 10 Isolate RW SWC 1’b0 and present high impedance on RXD/RX_DV. 1’b0: Normal mode 1’b1: Isolate mode Auto-Negotiation automatically restarts after hardware RW 9 Re_Autoneg SWS 1’b0 SC or software reset regardelss of bit[9] RESTART. =1: Restart Auto-Negotiation Process =0: Normal operation The duplex mode can be selected via either the Auto-Negotiation process or manual duplex selection. Manual 8 Duplex_Mode RW 1’b1 duplex Auto-Negotiation selection is disabled AUTO_NEGOTIATION to 0. =1: Full Duplex =0: Half Duplex 18 is by allowed when setting bit[12] Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet Setting this bit to 1 makes the COL signal asserted 7 Collision_Test RW SWC whenever the TX_EN signal is asserted. 1’b0 =1: Enable COL signal test =0: Disable COL signal test 6 Speed_ Selection(MSB) See bit13. RW 1’b1 RO 5’b0 Reserved. Write as 0, ignore on read 5:0 Reserved 5.2.2. Mii register 01H: Basic status register Bit Symbol Access Default Description 15 100Base-T4 RO 1’b0 PHY doesn’t support 100BASE-T4 14 100Base-X_Fd RO 1’b1 PHY supports 100BASE-X_FD 13 100Base-X_Hd RO 1’b1 PHY supports 100BASE-X_HD 12 10Mbps_Fd RO 1’b1 PHY supports 10Mbps_Fd 11 10Mbps_Hd RO 1’b1 PHY supports 10Mbps_Hd 10 100Base-T2_Fd RO 1’b0 PHY doesn’t support 100Base-T2_Fd 9 100Base-T2_Hd RO 1’b0 PHY doesn’t support 100Base-T2_Hd Whether support extended status register in 0Fh 8 Extended_Status RO 1’b1 0: Not supported 1: Supported 1’b0: PHY able to transmit from MII only when the PHY has determined that a valid link has been 7 Unidirect_Ability RO established 1’b0 1’b1: PHY able to transmit from MII regardless of whether the PHY has determined that a valid link has been established 1’b0: PHY will not accept management frames 6 Mf_Preamble_Suppression RO with preamble suppressed 1’b1 1’b1: PHY will accept management frames with preamble suppressed 5 Autoneg_Complete RO SWC 1’b0: Auto-negotiation process not completed 1’b0 1’b1: Auto-negotiation process completed 1’b0: no remote fault condition detected RO RC 4 Remote_Fault SWC 1’b0 1’b1: remote fault condition detected LH 3 Autoneg_Ability RO 1’b0: PHY not able to perform Auto-negotiation 1’b1 1’b1: PHY able to perform Auto-negotiation 19 Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet Link status RO 2 Link_Status LL 1’b0: Link is down 1’b0 SWC 1’b1: Link is up 10BaseTe jabber detected RO RC 1 Jabber_Detect LH 1’b0: no jabber condition detected 1’b0 SWC 1’b1: Jabber condition detected To indicate whether support EXTs, to access from 0 Extended_Capability RO address register 1Eh and data register 1Fh 1’b1 1’b0: Not supported 1’b1: Supported 5.2.3. Mii register 02H: PHY identification register1 Bit Symbol Access Default 15:0 Phy_Id RO 16’b0 5.2.4. Description Bits 3 to 18 of the Organizationally Unique Identifier Mii register 03H: PHY identification register2 Bit Symbol Access Default Description 15:10 Phy_Id RO 6’b0 Bits 19 to 24 of the Organizationally Unique Identifier 9:4 Type_No RO 6’h12 3:0 Revision_No RO 4’h8 5.2.5. Bit 4 bits manufacturer’s revision number MII register 04H: Auto-Negotiation advertisement Symbol Access Default Description This bit is updated immediately after the writing operation; however the configuration does not take effect until any of the following occurs:  Software reset is asserted by writing register 0x0 bit[15] 15 Next_Page RW 1’b0  Restart Auto-Negotiation is triggered by writing register 0x0 bit[9]  The port is switched from power down to normal operation by writing register 0x0 bit[11]  Link goes down If 1000BASE-T is advertised, the required next pages are automatically transmitted. 20 Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet This bit must be set to 0 if no additional next page is needed. =1: Advertise =0: Not advertised 14 Reserved RO 1’b0 Reserved =1: Set Remote Fault bit 13 Remote_Fault RW 1’b0 =0: Do not set Remote Fault bit Extended next page enable control bit =1: Local device supports transmission of 12 Extended_Next_Page RW 1’b1 extended next pages =0: Local device does not support transmission of extended next pages. This bit is updated immediately after the writing operation; however the configuration does not take effect until any of the following occurs:  Software reset is asserted by writing register 0x0 bit[15] 11 Asymmetric_Pause RW 1’b1  Restart Auto-Negotiation is triggered by writing register 0x0 bit[9]  The port is switched from power down to normal operation by writing register 0x0 bit[11]  Link goes down =1: Asymmetric Pause =0: No asymmetric Pause This bit is updated immediately after the writing operation; however the configuration does not take effect until any of the following occurs:  10 Pause RW 1’b1 Software reset is asserted by writing register 0x0 bit[15]  Restart Auto-Negotiation is triggered by writing register 0x0 bit[9]  The port is switched from power down to normal operation by writing register 0x0 bit[11]  21 Link goes down Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet =1: MAC PAUSE implemented =0: MAC PAUSE not implemented =1: Able to perform 100BASE-T4 9 100BASE-T4 RO 1’b0 =0: Not able to perform 100BASE-T4 Always 0 This bit is updated immediately after the writing operation; however the configuration does not take effect until any of the following occurs:  Software reset is asserted by writing register 0x0 bit[15] 8 100BASE-TX_Full_Duplex RW 1’b1  Restart Auto-Negotiation is triggered by writing register 0x0 bit[9]  The port is switched from power down to normal operation by writing register 0x0 bit[11]  Link goes down =1: Advertise =0: Not advertised This bit is updated immediately after the writing operation; however the configuration does not take effect until any of the following occurs:  Software reset is asserted by writing register 0x0 bit[15] 7 100BASE-TX_Half_Duplex RW 1’b1  Restart Auto-Negotiation is triggered by writing register 0x0 bit[9]  The port is switched from power down to normal operation by writing register 0x0 bit[11]  Link goes down =1: Advertise =0: Not advertised This bit is updated immediately after the writing operation; however the configuration does not take effect until any of the following 6 10BASE-Te_Full_Duplex RW 1’b1 occurs:  Software reset is asserted by writing register 0x0 bit[15]  22 Restart Auto-Negotiation is triggered by Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet writing register 0x0 bit[9]  The port is switched from power down to normal operation by writing register 0x0 bit[11]  Link goes down =1: Advertise =0: Not advertised This bit is updated immediately after the writing operation; however the configuration does not take effect until any of the following occurs:  Software reset is asserted by writing register 0x0 bit[15] 5 10BASE-Te_Half_Duplex RW 1’b1  Restart Auto-Negotiation is triggered by writing register 0x0 bit[9]  The port is switched from power down to normal operation by writing register 0x0 bit[11]  Link goes down =1: Advertise =0: Not advertised Selector Field mode. 4:0 5.2.6. Bit 15 Selector_Field RW 5’b00001 00001 = IEEE 802.3 MII register 05H: Auto-Negotiation link partner ability Symbol 1000Base-X_Fd Access RO SWC Default 1’b0 Description Received Code Word Bit 15 =1: Link partner is capable of next page =0: Link partner is not capable of next page Acknowledge. Received Code Word Bit 14 14 ACK RO SWC =1: Link partner has received link code 1’b0 word =0: Link partner has not received link code word Remote Fault. Received Code Word Bit 13 13 REMOTE_FAULT RO SWC 1’b0 =1: Link partner has detected remote fault =0: Link partner has not detected remote fault 12 RESERVED RO SWC 1’b0 23 Technology Ability Field. Received Code Word Bit 12 Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet Technology Ability Field. Received Code Word Bit 11 11 ASYMMETRIC_PAUSE RO SWC 1’b0 =1: Link partner requests asymmetric pause =0: Link partner does not request asymmetric pause Technology Ability Field. Received Code 10 PAUSE RO SWC Word Bit 10 1’b0 =1: Link partner supports pause operation =0: Link partner does not support pause operation Technology Ability Field. Received Code 9 100BASE-T4 RO SWC Word Bit 9 1’b0 =1: Link partner supports 100BASE-T4 =0: Link partner does not support100BASE-T4 Technology Ability Field. Received Code Word Bit 8 8 100BASE-TX_FULL_DUPLEX RO SWC 1’b0 =1: Link partner supports 100BASE-TX full-duplex =0: Link partner does not support 100BASE-TX full-duplex Technology Ability Field. Received Code Word Bit 7 7 100BASE-TX_HALF_DUPLEX RO SWC =1: Link partner supports 100BASE-TX 1’b0 half-duplex =0: Link partner does not support 100BASE-TX half-duplex Technology Ability Field. Received Code Word Bit 6 6 10BASE-Te_FULL_DUPLEX RO SWC 1’b0 =1: Link partner supports 10BASE-Te full-duplex =0: Link partner does not support 10BASE-Te full-duplex Technology Ability Field. Received Code Word Bit 5 5 10BASE-Te_HALF_DUPLEX RO SWC 1’b0 =1: Link partner supports 10BASE-Te half-duplex =0: Link partner does not support 10BASE-Te half-duplex 4:0 SELECTOR_FIELD RO SWC 5’h0 24 Selector Field Received Code Word Bit 4:0 Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet 5.2.7. MII register 06H: Auto-Negotiation expansion register Bit Symbol Access Default 15:5 Reserved RO 11’h0 Always 0 4 Parallel_Detection_fault RO RC LH 1’b0 =1: Fault is detected SWC 3 Link_partner_next_page able RO LH SWC Description =0: No fault is detected 1’b0 =1: Link partner supports Next page =0: Link partner does not support next page 2 Local_Next_Page_able RO 1’b1 =1: Local Device supports Next Page =0: Local Device does not Next Page 1 Page_received RO RC LH 1’b0 =1: A new page is received =0: No new page is received 0 Link_Partner_Auto_negotiation_able RO 1’b0 =1: Link partner supports auto-negotiation =0: Link partner does not support auto-negotiation 5.2.8. Bit MII register 07H: Auto-Negotiation Next Page register Symbol Access Default Description Transmit Code Word Bit 15 15 Next_Page RW 1’b0 =1: The page is not the last page =0: The page is the last page 14 Reserved RO 1’b0 Transmit Code Word Bit 14 Transmit Code Word Bit 13 13 Message_page_mode RW 1’b1 =1: Message Page =0: Unformatted Page Transmit Code Word Bit 12 12 Ack2 RW 1’b0 =1: Comply with message =0: Cannot comply with message Transmit Code Word Bit 11 =1: This bit in the previously exchanged 11 Toggle RO 1’b0 Code Word is logic 0 =0: The Toggle bit in the exchanged Code Word is logic 1 10:0 Message_Unformatte RW 11’h1 25 Transmit Code Word Bits [10:0]. previously Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet D_Field These bits are encoded as Message Code Field when bit[13] is set to 1, or as Unformatted Code Field when bit[13] is set to 0. 5.2.9. Bit MII register 08H: Auto-Negotiation link partner Received Next Page register Symbol Access Default Description Received Code Word Bit 15 15 Next_Page RO 1’b0 =1: This page is not the last page =0: This page is the last page 14 Reserved RO 1’b0 Received Code Word Bit 14 Received Code Word Bit 13 13 Message_page_mode RO 1’b0 =1: Message Page =0: Unformatted Page Received Code Word Bit 12 12 Ack2 RO 1’b0 =1: Comply with message =0: Cannot comply with message Received Code Word Bit 11 =1: This bit in the previously exchanged 11 Toggle RO 1’b0 Code Word is logic 0 =0: The Toggle bit in the previously exchanged Code Word is logic 1 Received Code Word Bit 10:0 10:0 Message_Unformatte D_Field These bits are encoded as Message Code RO 11’b0 Field when bit[13] is set to 1, or as Unformatted Code Field when bit[13] is set to 0. 5.2.10. Bit MII register 0AH: MASTER-SLAVE status register Symbol Access Default Description This register bit will clear on read, rising of MII 0.12 and RO RC 15 Master_Slave_Configuration_Fault SWC 1’b0 LH rising of AN complete. =1: Master/Slave configuration fault detected =0: No fault detected 14 Master_Slave_Configuration_Resolution 26 RO 1’b0 This bit is not valid Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet unless register 0x1 bit5 is 1. =1: Local PHY configuration resolved to Master =0: Local PHY configuration resolved to Slave =1: Local Receiver OK 13 Local_Receiver_Status RO 1’b0 =0: Local Receiver not OK Always 0. =1: Remote Receiver OK 12 Remote_Receiver_Status RO 1’b0 =0: Remote Receiver not OK Always 0. This bit is not valid unless register 0x1 bit5 is 1. Link Partner_ 11 RO 1000Base-T_Full_Duplex_Capability 1’b0 =1: Link Partner supports 1000BASE-T half duplex =0: Link Partner does not support 1000BASE-T half duplex This bit is not valid unless register 0x1 bit5 is 1. 10 Link_Partner_1000Base-T_Half_Duplex_Capability RO 1’b0 =1: Link Partner supports 1000Base-T full duplex =0: Link Partner does not support 1000Base-T full duplex 9:8 Reserved RO 2’b0 Always 0 7:0 Idle_Error_Count RO SC 8’b0 Counter for Idle errors 5.2.11. Bit MII register 0DH: MMD access control register Symbol Access Default Description 00 = Address 15:14 Function RW 01 = Data, no post increment 2’b0 10 = Data, post increment on reads and writes 11 = Data, post increment on writes only 27 Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet 13:5 Reserved RO 9’b0 Always 0 MMD register device address. 4:0 DEVAD RW 00001 = MMD1 5’b0 00011 = MMD3 00111 = MMD7 5.2.12. Bit MII register 0EH: MMD access data register Symbol Access Default Description If register 0xD bits [15:14] are 00, this register is 15:0 Address_data RW 16’b0 used as MMD DEVAD address register. Otherwise, this register is used as MMD DEVAD data register as indicated by its address register. 5.2.13. Mii register 0FH: Extended status register Bit Symbol Access Default 15 1000Base-X_Fd RO 1’b0 PHY not able to support 1000Base-X_Fd 14 1000Base-X_Hd RO 1’b0 PHY not able to support 1000Base-X_Hd 13 1000Base-T_Fd RO 1’b0 PHY not able to support 1000Base-T_Fd 12 1000Base-T_Hd RO 1’b0 PHY not able to support 1000Base-T_Hd 11:8 Reserved RO 1’b0 Reserved 7 100Base-T1 RO 1’b1 Reserved 6 1000Base-T1 RO 1’b0 Reserved 5:0 Reserved RO 6’b0 Reserved 5.2.14. Description MII register 10H: PHY specific function control register Bit Symbol Access Default 15:7 Reserved RO 9’b0 Description Always 0. Changes made to these bits disrupt normal operation, thus a software reset is mandatory after the change. And the configuration does not take effect until software reset. 6:5 Cross_md RW 2’b11 00 = Manual MDI configuration 01 = Manual MDIX configuration 10 = Reserved 11 = Enable automatic crossover for all modes 4 Int_polar_sel RW 1’b0 28 No use. Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet This bit is effective in 10BASE-Te half-duplex mode and 100BASE-TX mode: 3 Crs_on_tx RW 1’b0 =1: Assert CRS on transmitting or receiving =0: Never assert CRS on transmitting, only assert it on receiving. =1: SQE test enabled =0: SQE test disabled 2 En_sqe_test RW 1’b0 Note: SQE Test is automatically disabled in full-duplex mode regardless the setting in this bit. If polarity reversal is disabled, the polarity is 1 En_pol_inv RW 1’b1 forced to be normal in 10BASE-Te. =1: Polarity Reversal Enabled =0: Polarity Reversal Disabled Jabber takes effect only in 10BASE-Te 0 Dis_jab RW 1’b0 =1: Disable jabber function =0: Enable jabber function 5.2.15. Bit MII register 11H: PHY specific status register Symbol Access Default Description This status bit is valid only when bit11 is 1. Bit11 is set when Auto-Negotiation is completed 15:14 Speed_mode RO 2’b00 or Auto-Negotiation is disabled. 11 = Reserved 10 = 1000 Mbps 01 = 100 Mbps 00 = 10 Mbps This status bit is valid only when bit11 is 1. Bit11 is set when Auto-Negotiation is 13 Duplex RO 1’b0 completed or Auto-Negotiation is disabled. =1: Full-duplex =0: Half-duplex 12 Page_Received_real-time RO 1’b0 =1: Page received =0: Page not received This bit is set when Auto-Negotiation is 11 Speed_and_Duplex_Resolved RO 1’b0 completed or disabled =1: Resolved =0: Not resolved 10 Link_status_real-time RO 1’b0 29 Auto-Negotiation =1: Link up is Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet =0: Link down 9:7 Reserved RO 3’b111 Always 3’b111. This status bit is valid only when bit11 is 1. Bit11 is set when Auto-Negotiation is completed or Auto-Negotiation is disabled. The bit value depends on register 0x10 6 MDI_Crossover_Status RO “ PHY 1’b0 specific register ” function control bits6~bit5 configurations. Register 0x10 configurations take effect after software reset. =1: MDIX =0: MDI 5 Wirespeed_downgrade RO 1’b0 4:2 Reserved RO 3’b0 1 Polarity_Real_Time RO 1’b0 0 Jabber_Real_Time RO 1’b0 5.2.16. =1: Downgrade =0: No Downgrade Always 0. =1: Reverted polarity =0: Normal polarity =1: Jabber is asserted. =0: No jabber MII register 12H: Interrupt Mask Register Bit Symbol Access Default 15 Auto-Negotiation_Error_int _mask RW 1’b0 14 Speed_Changed_int_mask RW 1’b0 13 Duplex_changed_int_mask RW 1’b0 12 Page_Received_int_mask RW 1’b0 11 Link_Failed_int_mask RW 1’b0 10 Link_Succeed_int_mask RW 1’b0 9 Reserved RW 1’b0 Reserved 8 Reserved RW 1’b0 Reserved 7 Reserved RW 1’b0 Reserved 6 WOL_int_mask RW 1’b0 30 Description =1: Interrupt enable =0: Interrupt disable =1: Interrupt enable =0: Interrupt disable =1: Interrupt enable =0: Interrupt disable =1: Interrupt enable =0: Interrupt disable =1: Interrupt enable =0: Interrupt disable =1: Interrupt enable =0: Interrupt disable =1: Interrupt enable =0: Interrupt disable Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet 5 Wirespeed_downgraded_int_mask RW 1’b0 4:2 Reserved RW 3’b0 1 Polarity_changed_int_mask RW 1’b0 0 Jabber_Happened_int_mask RW 1’b0 5.2.17. Bit =1: Interrupt enable =0: Interrupt disable No used. =1: Interrupt enable =0: Interrupt disable =1: Interrupt enable =0: Interrupt disable MII register 13H: Interrupt Status Register Symbol Access Default Description Error can take place when any of the following happens:  MASTER/SLAVE does not resolve correctly 15 Auto-Negotiation_Error_INT RO RC  Parallel detect fault  No common HCD  Link does not come up after 1’b0 negotiation is complete  Selector Field is not equal  flp_receive_idle=true while Autoneg Arbitration FSM is in NEXT PAGE WAIT state =1: Auto-Negotiation Error takes place =0: No Auto-Negotiation Error takes place =1: Speed changed 14 Speed_Changed_INT RO RC 1’b0 13 Duplex_changed_INT RO RC 1’b0 12 Page_Received_INT RO RC 1’b0 11 Link_Failed_INT RO RC 1’b0 10 Link_Succeed_INT RO RC 1’b0 9 Reserved RO 1’b0 Always 0. 8 Reserved RO 1’b0 Always 0. 7 Reserved RO 1’b0 Always 0. 31 =0: Speed not changed =1: duplex changed =0: duplex not changed =1: Page received =0: Page not received =1: Link down takes place =0: No link down takes place =1: Link up takes place =0: No link up takes place Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet =1: PHY received WOL magic 6 WOL_INT RO RC 1’b0 5 Wirespeed_downgraded_INT RO RC 1’b0 4:2 Reserved RO 3’b0 frame. =0: PHY didn ’ t receive WOL magic frame. =1: speed downgraded. =0: Speed didn’t downgrade. Always 0. =1: PHY revered MDI polarity 1 Polarity_changed_INT RO RC 1’b0 =0: PHY didn ’ t revert MDI polarity =1:10BaseTe 0 Jabber_Happened_INT 5.2.18. RO RC 1’b0 TX jabber happened =0: 10BaseTe TX jabber didn’t happen MII register 14H: Speed Auto Downgrade Control Register Bit Symbol Access Default 15:12 Reserved RO 4’b0 Description Always 0. =1: To latch MII/MMD register’s read 11 En_mdio_latch RW 1’b1 out value during MDIO read =0: Do not latch MII/MMD register ’ s read out value during MDIO read 10:6 Reserved RW SC 5’b0 Reserved When this bit is set to 1, the PHY 5 En_speed_downgrade RW 1’b1 enables smart-speed function. Writing this bit requires a software reset to update. If these bits are set to 3, the PHY 4:2 Autoneg retry limit pre-downgrade attempts five times (set value 3 + RW 3’b011 additional 2) before downgrading. The number of attempts can be changed by these bits. =1: the wirespeed downgrade FSM will bypass the timer used for link stability check; 1 Bp_autospd_timer RW 1’b0 =0: not bypass the timer, then links that established but hold for less than 2.5s would still be taken as failure, autoneg retry counter will increase by 1. 0 Reserved RO 1’b0 32 Always 0. Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet 5.2.19. Bit MII register 15H: Rx Error Counter Register Symbol Access Default Description This counter increase by 1 at the 1st rising of RX_ER when RX_DV is 1. The counter will hold at maximum 16’hFFFF and not 15:0 Rx_err_counter RO 16’b0 roll over. If speed mode is 2 ’ b01, it counts for fe_100 RX_ER; Else, it’s 0. 5.2.20. MII register 1AH:Reference Clock Register Bit Symbol Access Default 15:2 Reserved RW 14’b0 1 Txc_xtal_sel RW 1’b0 0 Xtal_freq_sel RW 1’b0 5.2.21. Bit 15:0 Reserved =1: Use Txc as ext reference clock =0: Use Xtal as ext reference clock =1: Xtal = 50Mhz =0: Xtal = 25Mhz MII register 1EH: Debug Register’ s Address Offset Register Symbol Extended_Register_Address 5.2.22. Description _Offset Access Default RW 16’b0 Description It’s the address offset of the EXT that will be Write or Read MII register 1FH: Debug Register’ s Data Register Bit Symbol Access Default Description It’s the data to be written to the EXT 15:0 Extended_Register_Datas RW 16’b0 indicated by the address offset in register 0x1E, or the data read out from that debug register. 5.3. Extended register 5.3.1. EXT 0000h PHY Broadcast addr Bit Symbol Access default 15:7 reserved RO 0 6 En_phyaddr0 RW 1’b1 Description reserved 33 Enable mdio phy address 0 access Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet 5 En_bdcst_addr RW 1’b1 4:0 Bdcst_addr RW 5’b11111 5.3.2. Enable mdio broadcast address access EXT 0001h Interpolator Filter Bit Symbol Access default 15:10 Reserved RO 6’b100 9 Step_sw_en RW 1’b0 8:0 Reserved RO 9’b1000000 5.3.3. Description reserved Use manual step for interp filter reserved EXT 0010H: Interpolator Filter Coef.0 Bit Symbol Access default 15:0 Reserved RO 16’b0 5.3.4. MDIO Broadcast address Description Reserved EXT 0011H: Interpolator Filter Coef.1 Bit Symbol Access default 15:11 Reserved RO 8’b0 Reserved 10:8 Step_sw_1[10:8] RO 3’b0 Interp filter coefficient 1 7:1 Step_sw_1[7:1] RW 7’b1001_101 Interp filter coefficient 1 0 Step_sw_1[0] RO 1’b0 Interp filter coefficient 1 5.3.5. Description EXT 0012H: Interpolator Filter Coef.2 Bit Symbol Access default 15:11 Reserved RO 5’b0 Reserved 10:9 Step_sw_2[10:9] RO 2’b0 Interp filter coefficient 2 8:1 Step_sw_2[8:1] RW 8’b1_0001_101 Interp filter coefficient 2 0 Step_sw_2[0] RO 1’b0 Interp filter coefficient 2 5.3.6. Description EXT 0013H: Interpolator Filter Coef.3 Bit Symbol Access default 15:11 Reserved RO 5’b0 10:8 Step_sw_3[10:8] RO 3’b001 Interp filter coefficient 3 7:1 Step_sw_3[7:1] RW 7’b1000_000 Interp filter coefficient 3 0 Step_sw_3[0] RO 1’b0 Interp filter coefficient 3 34 Description Reserved Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet 5.3.7. EXT 0014H: Interpolator Filter Coef.4 Bit Symbol Access default 15:11 Reserved RO 5’b0 10:8 Step_sw_4[10:8] RO 3’b001 Interp filter coefficient 4 7:1 Step_sw_4[7:1] RW 7’b1100_110 Interp filter coefficient 4 0 Step_sw_4[0] RO 1’b0 Interp filter coefficient 4 5.3.8. Description Reserved EXT 0015H: Interpolator Filter Coef.5 Bit Symbol Access default 15:11 Reserved RO 5’b0 Reserved 10:8 Step_sw_5[10:8] RO 3’b001 Interp filter coefficient 5 7:1 Step_sw_5[7:1] RW 7’b1110_011 Interp filter coefficient 5 0 Step_sw_5[0] RO 1’b0 Interp filter coefficient 5 5.3.9. EXT 0016H: Interpolator Filter Coef.6 Bit Symbol Access default 15:11 Reserved RO 5’b0 10:0 Step_sw_6 RO 11’d512 5.3.10. Description Reserved Interp filter coefficient 6 EXT 0017H: Interpolator Filter Coef.7 Bit Symbol Access default 15:11 Reserved RO 5’b0 10:0 Step_sw_7 RO 11’d512 5.3.11. Description Description Reserved Interp filter coefficient 7 EXT 0050H: AFE PLL Config Bit Symbol Access default 15:7 Reserved RO 9’b0 Reserved 6 Pll_refclk_sel RW 1’b0 Sel clk source in rmii2 mode 5 Reserved RW 6’b111111 5.3.12. Description Reserved EXT 0061H: AFE Switches Bit Symbol Access default 15:7 Reserved RO 9’b110 35 Description Reserved Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet enable or disable VCO_fast or VCO_slow 6 en_vco_check RW 1’b1 5:0 reserved RO 6’b11110 5.3.13. check circuit reserved EXT 00A0H: PLL Lock Detect Status Bit Symbol Access default 15:2 Reserved RO 13’b0 reserved 1 Pll_vco_h RO 1’b0 Analog Pll vco fast flag 0 Pll_vco_l RO 1’b0 Analog pll vco slow flag 5.3.14. Bit Description EXT 200AH: 10BT Debug, LPBKs Register Symbol Access Default Description =1: Control to gate the baset10 module’s clock 15 En_gate_bt10 RW when link up at 100Mbps. 1’b1 =0: disable the clock gating. 14:11 reserved RO 4'b1001 reserved =1: In 10BT mode , if there’s no data or NLP to transmit, shut off DAC; otherwise turn on the 10 En_10bt_idl RW 1’b1 DAC; =0: In 10BT, DAC will not be turn off. 9:0 Reserved 5.3.15. RO 10'h208 reserved EXT 2012H: AFE Control Register3 Bit Symbol Access Default 15 Reserved RW 1’b0 Description reserved when speed mode is 100Mb/s or 10Mb/s, 14 En_clkadc_aon RW 1’b0 =1: keep channel 0 and 1 clkadc both on; =0: open one channel ’ s clkadc based on mdi status. 13:0 Reserved RO 12'h2f0 reserved 36 Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet 5.3.16. Bit EXT 2027H: Sleep Control1 Symbol Access default Description =1: enable sleep mode: PHY will enter sleep 15 En_sleep_sw RW 1’b1 mode and close AFE after unplug cable for a timer; 14:0 reserved RO 15’h200 reserved 5.3.17. EXT 2056H: 10BT RX Comparator Threshold Bit Symbol Access default 15:14 Tenbt_vth_cfg_10M RW 2’b00 13:0 Reserved RO 14’b0 5.3.18. Description 10BT RX comparator threshold. It ’ s valid only when speed mode is 10Mbps. Always 0. EXT 2057H: DAC Ctrl for 10BT and 100BT Bit Symbol Access default 15 Reserved RO 1’b0 14:12 DAC_amp_100M RW 3’b010 11:8 DAC_amp_cfg_100M RW 4’b0110 7 Reserved RO 1’b0 6:4 DAC_amp_10M RW 3’b010 3:0 DAC_amp_cfg_10M RW 4’b0110 5.3.19. Description Always 0. Always 0. EXT 2058H: PHY DEBUG CONFIGURE1 Bit Symbol Access default 15 reserved RO 1’b0 14 En_snap_shot RW 1’b0 13:0 reserved RO 14'hc00 5.3.20. EXT 2059H:PHY DEBUG CONFIGURE2 Bit Symbol Access default 15 Prob_auto RW 1’b0 Description reserved 1 = enable to snap shot 1000BT and 100BT PMA FSM and related intermediate status. reserved Description 1 = probe the PMA status immediately, not at certain condition. 37 Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet 1 = monitor big slicer error after 1000BT training done; 14 Cnt_err_auto RW 1’b0 0 = monitor big slicer error after 1000BT training done and during RX_DV; 1 = monitor big ADC output after 1000BT training done; 13 Cnt_clp_auto RW 1’b0 0 = monitor big ADC output after 1000BT training done and during RX_DV; 12:8 Target_eee_st RW 5’b0 7:0 Err_big_th RW 8’d64 5.3.21. Bit The target PMA EEE state to be snap shot. The amplitude threshold determining the errors after slicer are big. EXT 205AH:PHY DEBUG, MSE1 Symbol Access default Description Valid when EXT 2058h bit14 en_snap_shot is set. 15 Hold_snap_shot RO 1’b0 1 = the snap shot condition is met and triggerd Valid when EXT 2058h bit14 en_snap_shot is set, or 14:0 Mse0 RO EXT 2059h bit15 prob_auto is set. Corresponding to these two setting, it is the: 15’b0 MSE0 at the time snap shot condition is met, or MSE0 at the time this EXT register is being read. 5.3.22. Bit EXT 205BH:PHY DEBUG, MSE2 Symbol Access default Description Valid when EXT 2058h bit15 en_snap_shot_az is set. 15 Hold_snap_shot_az RO 1’b0 1 = the EEE snap shot condition is met and triggerd 14:0 Reserved RO 15’b0 38 Always 0. Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet 5.3.23. Bit EXT 2068H: PHY Debug, Integrator Symbol Access default Description Channel 0’s integrator. Frquence different between lp and dut. PPM = 0.95 * integrator; integrator is 2's complement value 15:0 Integrator RO Valid when EXT 2058h bit14 en_snap_shot is set, 16’h0 or EXT 2059h bit15 prob_auto is set. Corresponding to these two setting, it is the: Integrator at the time snap shot condition is met, or Integrator at the time this EXT register is being read. 5.3.24. EXT 4000H: extended combo control1 Bit Symbol Access default Description 15 Led0_wk_mode RW 1’b0 0 = LED,1 = WOL 14 Led0_polarity RW 1’b0 0 = active high 1 = active low 13 Led1_polarity RW 1’b0 0 = active high,1 = active low 12 External_Loopback RW 1’b0 0 = disable 1 = enable 11:7 Reserved RW 5’b0 Reserved 6 Rmii1_clk_sel RW 1’b0 1 = rmii tx clk use xtal 0 = txc 1 = Enable Jumbo frame, reception up to 5 Jumbo_Enable RW 1’b0 18KB frame; 0 = disabled, only up to 4.5KB frame supported Drive PAD CRS_DV of RMII by (0= 4 Rmii_rxdv_sel RW 1’b0 3 Fx_en RW 1’b0 1 = enable fx100 mode, 0 = disable 2 Wol_en RW 1’b0 1 = enable WOL mechanism. 1 Rmii_en RW 1’b0 0 Clk_sel RW 1’b0 5.3.25. CRS_DV, 1 = RX_DV). 1 = enable RMII mode; Symbol Access default 15:6 reserved RO 10'h203 1 = input TXC/RXC 0 = output TXC/RXC(default by power on strapping) Description reserved 39 0 = disable RMII mode(default by power on strapping) EXT 4001H: extended pad control Bit 0 = disable. Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet 5:4 Xmii_Dr RW 2’b10 3:0 reserved RO 4'b1111 5.3.26. Xmii interface driver strength control in non-scan mode. reserved EXT 4003H: extended combo control2 Bit Symbol Access default 15 Reserved RW 1’b0 Description Reserved Mux clk_dac to rxc in slave jitter test mode 14 Slave_jitter_test RW 1’b0 1: enable 0: disable 13:10 Reserved RW 4’b0 Reserved Wol_lth_sel[0] control WOL INTn to be a level or a pulse. 1’b1: a pulse; 1’b0: a level. Wol_lth_sel[2:1] control WOL INTn pulse width when Wol_lth_sel[0] is 1. 9:7 Wol_lth_sel RW 3’b100 2’b00: 10us; 2’b01: 100us; 2’b10: 1ms; 2’b11: 10ms. 40 Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet When isolate (mii.0.10) is 1, control to make TXC input or not. 6 En_isolate_txc RW 1’b1 1’b1: input; 1’b0: keep TXC previous direction. When isolate (mii.0.10) is 1, control to make RXC input or not. 5 En_isolate_rxc RW 1’b1 1’b1: input; 1’b0: keep RXC previous direction. 4:0 Reserved 5.3.27. RW 5’b01111 EXT 4004H: WOL MAC Address Bit Symbol Access default 15:0 Mac_addr_loc[47:32] RW 16’b0 5.3.28. Description mac address for WOL EXT 4005H: WOL MAC Address Bit Symbol Access default 15:0 Mac_addr_loc[31:16] RW 16’b0 5.3.29. Reserved Description mac address for WOL EXT 4006H: WOL MAC Address Bit Symbol Access default 15:0 Mac_addr_loc[15:0] RW 16’b0 41 Description mac address for WOL Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet 5.3.30. Bit EXT 40A0H: pkg_selftest control Symbol Access default Description 1: to enable RX/TX package checker. RX 15 Pkg_chk_en RW 1’b0 checker checks the MII data at transceiver’ s PCS RX; TX checker checks the MII data at mii_bridge’s TX. 1: to enable gate all the clocks to package self-test module when bit15 pkg_chk_en is 14 Pkg_en_gate RW 1’b1 0, bit13 bp_pkg_gen is 1 and bit12 pkg_gen_en is 0; 0: not gate the clocks. 1: normal mode, to send xMII TX data from PAD; 13 Bp_pkg_gen RW 1’b1 0: test mode, to send out the MII data generated by pkg_gen module. 1: to enable pkg_gen generating MII packages. But, the data will only be sent to transceiver when Bit13 bp_pkg_gen is 1’b0. If pkg_burst_size is 0, continuous packages 12 Pkg_gen_en RW SC 1’b0 will be generated and will be stopped only when pkg_gen_en is set to 0; Otherwise, after the expected packages are generated, pkg_gen will stop, pkg_gen_en will be self-cleared. The preamble length of the generated packages, in Byte unit. Pkg_gen function 11:8 Pkg_prm_lth RW 4’d8 only support >=2 Byte preamble length. Values smaller than 2 will be ignored by the pkg_gen module. 42 Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet The IPG of the generated packages, in Byte 7:4 Pkg_ipg_lth RW 4’d12 unit. Pkg_gen function only support >=2 Byte preamble length. Values smaller than 2 will be ignored by the pkg_gen module. 1: To enable pkg_gen to send out the 3 Xmit_mac_force_gen RW 1’b0 generated data even when the link is not established. 1: to make pkg_gen to send out CRC error 2 Pkg_corrupt_crc RW 1’b0 packages. 0: pkg_gen sends out CRC good packages. Control the payload of the generated packages. 00: increased Byte payload; 1:0 Pkg_payload RW 2’b0 01: random payload; 10: fix pattern 0x5AA55AA5… 11: reserved. 5.3.31. EXT 40A1H: pkg_selftest control Bit Symbol Access default 15:0 Pkg_length RW 16’d64 5.3.32. Bit Description To set the length of the generated packages. EXT 40A2H: pkg_selftest control Symbol Access default Description To set the number of packages in a burst of 15:0 Pkg_burst_size RW package generation. 16’b0 0: continuous packages will be generated. 5.3.33. Bit EXT 40A3H: pkg_selftest status Symbol Access default 43 Description Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet Pkg_ib_valid[31:16], pkg_ib_valid is the number 15:0 Pkg_ib_valid_high RO 16’b0 of RX packages from wire whose CRC are good and length are >=64Byte and =64Byte and 1518Byte. 5.3.36. Bit EXT 40A6H: pkg_selftest status Symbol Access default Description Pkg_ib_os_good[15:0], pkg_ib_os_good is 15:0 Pkg_ib_os_good_low RO 16’b0 the number of RX packages from wire whose CRC are good and length are >1518Byte. 5.3.37. Bit EXT 40A7H: pkg_selftest status Symbol Access default Description Pkg_ib_us_good[31:16], pkg_ib_us_good 15:0 Pkg_ib_us_good_high RO 16’b0 is the number of RX packages from wire whose CRC are good and length are 1518Byte. 5.3.39. Bit EXT 40A9H: pkg_selftest status Symbol Access default Description pkg_ib_err is the number of RX packages from wire 15:0 Pkg_ib_err RO 16’b0 whose CRC are wrong and length are >=64Byte, =1518Byte. 5.3.41. EXT 40AbH: pkg_selftest status Bit Symbol Access default 15:0 Pkg_ib_frag RO 16’b0 5.3.42. Symbol Access default 15:0 Pkg_ib_nosfd RO 16’b0 Bit pkg_ib_frag is the number of RX packages from wire whose length are =64Byte and =64Byte and 1518Byte. 5.3.46. Bit EXT 40B0H: pkg_selftest status Symbol Access default Description Pkg_ob_os_good[15:0], pkg_ob_os_good 15:0 Pkg_ob_os_good_low RO 16’b0 is the number of TX packages from MII whose CRC are good and length are >1518Byte. 5.3.47. Bit EXT 40B1H: pkg_selftest status Symbol Access default Description Pkg_ob_us_good[31:0], pkg_ob_us_good 15:0 Pkg_ob_us_good_high RO 16’b0 is the number of TX packages from MII whose CRC are good and length are 1518Byte. 5.3.49. Bit EXT 40B3H: pkg_selftest status Symbol Access default Description pkg_ob_err is the number of TX packages from MII 15:0 Pkg_ob_err RO 16’b0 whose CRC are wrong and length are >=64Byte, =1518Byte. 5.3.51. EXT 40B5H: pkg_selftest status Bit Symbol Access default 15:0 Pkg_ob_frag RO 16’b0 5.3.52. pkg_ob_frag is the number of TX packages from MII whose length are Led_act_level_th*42ms, then the traffic is heavy; otherwise, traffic is not heavy. 5.3.59. Bit EXT 40C2H: LED0/1 control Symbol Access default Description Control the LED blink frequency in Blink mode 0. ON/OFF duty cycle could be reverted by 40C1h bit9 invert_led_duty. Below description is the default ON/OFF cycle, that is invert_led_duty=0. 4’d0=LED blink once every 10s, 6% OFF; 4’d1=LED blink once every 9.4s, 7% OFF; 4’d2=LED blink once every 8s, 8% OFF; 4’d3=LED blink once every 7.4s, 9% OFF; 15:12 Freq_sel_c0 RW 4’d4=LED blink once every 6s, 11% OFF; 4’d14 4’d5=LED blink once every 5s, 6% OFF; 4’d6=LED blink once every 4s, 8% OFF; 4’d7=LED blink once every 3s, 11% OFF; 4’d8=LED blink once every 2s, 16% OFF; 4’d9=LED blink once every 1s, 16% OFF; 4’d10=LED blink at 2Hz, 50% OFF; 4’d11=LED blink at 3Hz, 50% OFF; 4’d12=LED blink at 4Hz, 50% OFF; 4’d13=LED blink at 6Hz, 50% OFF; 4’d14=LED blink at 8Hz, 50% OFF; 4’d15=LED blink at 10Hz, 50% OFF; Control the LED blink frequency in Blink mode 1. 11:8 Freq_sel_c1 RW 4’d12 See description in bit15~12 Freq_sel_c0 for detail. 51 Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet Control the LED blink frequency in Blink mode 2. 7:4 Freq_sel_c2 RW 4’d7 See description in bit15~12 Freq_sel_c0 for detail. 3:0 5.3.60. Freq_sel_c3 RW Control the LED blink frequency in Blink mode 3. 4’d5 See description in bit15~12 Freq_sel_c0 for detail. EXT 40C3H: LED1 control Bit Symbol Access default 15 Led_force_en RW 1’b0 Description To enable LED force mode. Valid when bit15 led_force_en is set. 00 = force LED OFF; 01 = force LED ON; 14:13 Led_force_mode RW 2’b0 10 = force LED to blink at Blink Mode1; 11 = force LED to blink at Blink Mode0. There are 4 Blink Mode, which are different at blink frequency. Refer to EXT 40C2 for detail of Blink Mode0~3. When traffic is present, make LED BLINK no matter the previous LED status is ON or OFF, or make LED blink only when the previous LED is ON. when any *_blk_en in bit9~8 and bit3~1 is set and chip do work at corresponding status, 12 Led_act_blk_ind RW 1’b0 =1: LED will blink, no matter bit11~10 (duplex control) and bit5~4 (speed control) are 1 or 0; =0: LED will not blink, unless one (more) of bit11~10 (duplex control) and bit5~4 (speed control) is (are) 1 and related status is (are) matched (ON at certain speed or duplex mode is/are activated);. If BLINK status is not activated, when PHY link 11 Led_fdx_on_en RW 1’b0 up and duplex mode is full duplex, =1: make LED ON; =0: don’t make LED ON; If BLINK status is not activated, when PHY link 10 Led_hdx_on_en RW 1’b0 up and duplex mode is half duplex, =1: make LED ON; =0: don’t make LED ON; 52 Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet If bit12 Led_act_blk_ind is 1, or it is 0 and LED ON at certain speed or duplex more is/are 9 Led_txact_blk_en RW 1’b1 activated, when PHY link up and TX is active, =1: make LED BLINK at Blink mode 0 or 1 based on traffic weight; =0: don’t make LED BLINK. If bit12 Led_act_blk_ind is 1, or it is 0 and LED ON at certain speed or duplex more is/are activated, when PHY link up and RX is active, 8 Led_rxact_blk_en RW 1’b1 =1: make LED BLINK at Blink mode 0 or 1 based on traffic weight; =0: don’t make LED BLINK. =1: if BLINK status is not activated, when PHY 7 Led_txact_on_en RW 1’b0 link up and TX is active, make LED ON at least 10ms; =1: if BLINK status is not activated, when PHY 6 Led_rxact_on_en RW 1’b0 link up and RX is active, make LED ON at least 10ms; =1: if BLINK status is not activated, when PHY 5 Led_ht_on_en RW 1’b1 link up and speed mode is 100Mbps, make LED ON; =1: if BLINK status is not activated, when PHY 4 Led_bt_on_en RW 1’b0 link up and speed mode is 10Mbps, make LED ON; =1: if PHY link up at FE and collision happen, 3 Led_col_blk_en RW 1’b0 make LED BLINK at Blink mode 0 or 1 based on 40C1h bit6 col_blk_sel; 2 Led_ht_blk_en RW 1’b0 1 Led_bt_blk_en RW 1’b0 0 Reserved RO 1’b0 53 =1: if PHY link up and speed mode is 100Mbps, make LED BLINK at Blink mode 2; =1: if PHY link up and speed mode is 10Mbps, make LED BLINK at Blink mode 3; Always 0. Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet 5.3.61. EXT 4201H: Txclk_delay Bit Symbol Access default 15:3 Reserved RW 5’b0 Description No use. 1: use 8ns delayed tx mii clock 2: use 16ns delayed tx mii clock 2:0 txclk_delay_sel_100bt RW 3’d4 3: use 24ns delayed tx mii clock 4: use 32ns delayed tx mii clock others: use no delayed tx mii clock 5.3.62. EXT 4216H: IO Level Bit Symbol Access default 15:4 Reserved RW 12’b0 3 en_led_ren_ctrl RW 1’b1 2 en_ren_ctrl RW 1’b1 Description No use. 0: LED PAD ren will be 0 after strap done 1: LED PAD ren will be 1 after strap done 0: output PAD ren will be 0 after strap done 1: output PAD ren will be 1 after strap done 0: 1.5V IO level 1:0 io_level_ctrl RW 1’d3 1: 1.8V IO level 2: 2.5V IO level 3: 3.3V IO level 54 Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet 6. Timing and electrical characteristics 6.1. Crystal Requirement Table 6. Crystal Requirement Symbol Description Min Typ Max Unit Fref Crystal Reference Frequency - 25 - MHz Fref Tolerance Crystal Reference Frequency tolerance -50 - 50 ppm Duty Cycle Reference clock input duty cycle 40 - 60 % ESR Equivalent Series Resistance - 50 ohm DL Drive Level - - 0.5 mW Vih Crystal output high level 1.4 - - V Vil Crystal output low level - - 0.4 V 6.2. Oscillator/External Clock Requirement Table 7. Oscillator/External Clock Requirement Parameter Condition Min Frequency Typ Max Unit 25/50 Frequency tolerance Ta= -40~85 C MHz -50 Duty Cycle 40 50 PPM 60 % 200 ps AVDD33+0.3 V 0.4 V - Peak to Peak Jitter Vih 1.4 Vil Rise Time 10%~90% 10 ns Fall Time 10%~90% 10 ns Temperature Range YT8522C 0 70 °C Temperature Range YT8522H -40 85 °C Temperature Range YT8522E -40 125 °C Temperature Range YT8522A -40 125 °C 6.3. DC Characteristics Table 8. DC Characteristics Symbol Description Min Typ Max Unit Voh (3.3V) Minimum High Level Output Voltage 2.4 - 3.63 V Vol (3.3V) Maximum Low Level Output Voltage -0.3 - 0.4 V Voh (2.5V) Minimum High Level Output Voltage 2 - 2.8 V Vol (2.5V) Maximum Low Level Output Voltage -0.3 - 0.4 V 55 Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet Voh (1.8V) Minimum High Level Output Voltage 1.62 - 2.1 V Vol (1.8V) Maximum Low Level Output Voltage -0.3 - 0.4 V Voh (1.5V) Minimum High Level Output Voltage 1.4 - 1.8 V Vol (1.5V) Maximum Low Level Output Voltage -0.3 - 0.4 V Vih (3.3V) Minimum High Level Input Voltage 2 - - V Vil (3.3V) Maximum Low Level Input Voltage - - 0.8 V Vih (2.5V) Minimum High Level Input Voltage 1.7 - - V Vil (2.5V) Maximum Low Level Input Voltage - - 0.7 V Vih (1.8V) Minimum High Level Input Voltage 1.3 - - V Vil (1.8V) Maximum Low Level Input Voltage - - 0.5 V Vih (1.5V) Minimum High Level Input Voltage 1.1 - - V Vil (1.5V) Maximum Low Level Input Voltage - - 0.4 V Min Typ Max Unit 20 ns 6.4. MDC/MDIO Timing Figure 9. MDC/MDIO Timing Table 9. MDC/MDIO Timing Symbol Description T DLY_MDIO MDC to MDIO Output Delay Time T SU_MDIO MDIO Input to MDC Setup Time 10 ns T HD_MDIO MDIO Input to MDC Hold Time 10 ns T P_MDC MDC Period 80 ns T H_MDC MDC High 30 ns T L_MDC MDC Low 30 ns Maximum Frequency = 12.5M Hz 56 Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet 6.5. MII Transmission Cycle Timing Figure 10. MII Transmission Cycle Timing Table 10. MII Transmission Cycle Timing Symbol Description Minimum Typical Maximum Unit 100Mbps 14 20 26 ns 10Mbps 140 200 260 ns 100Mbps 14 20 26 ns 10Mbps 140 200 260 ns 100Mbps - 40 - ns 10Mbps - 400 - ns TXEN, TXD[0:3] 100Mbps 10 - - ns Setup to TXCLK Rising Edge 10Mbps 5 - - ns TXEN, TXD[0:3] 100Mbps 0 - - ns Hold After TXCLK Rising Edge 10Mbps 0 - - ns 100Mbps - - 40 ns 10Mbps - - 400 ns 100Mbps - - 160 ns 10Mbps - - 2000 ns t1 TXCLK Low Pulse Width t2 TXCLK High Pulse Width t3 TXCLK Period t4 t5 t6 TXEN Sampled to CRS High t7 TXEN Sampled to CRS Low 57 Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet 6.6. MII Reception Cycle Timing Figure 11. MII Reception Cycle Timing Table 11. MII Reception Cycle Timing Symbol Description Minimum Typical Maximum Unit 100Mbps 14 20 26 ns 10Mbps 140 200 260 ns 100Mbps 14 20 26 ns 10Mbps 140 200 260 ns 100Mbps - 40 - ns 10Mbps - 400 - ns 100Mbps 10 - - ns 10Mbps 10 - - ns 100Mbps 10 - - ns 10Mbps 10 - - ns 100Mbps - - 130 ns 10Mbps - - 2000 ns t1 RXCLK Low Pulse Width t2 RXCLK High Pulse Width t3 RXCLK Period t4 RXER, RX_DV,RXD[0:3] Setup to RXCLK Rising Edge t5 RXER, RX_DV, RXD[0:3] Hold After RXCLK Rising Edge t6 Receive Frame to CRS High t7 End of Receive Frame to CRS Low 100Mbps - - 240 ns 10Mbps - - 1000 ns t8 Receive Frame to Sampled Edge of RX_DV 100Mbps - - 150 ns 10Mbps - - 3200 ns t9 End of Receive Frame to Sampled Edge of RX_DV 100Mbps - - 120 ns 10Mbps - - 1000 ns 58 Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet 6.7. RMII1 Transmission and Reception Cycle Timing Figure 12. RMII1 Transmission and Reception Cycle Timing Table 12. RMII1 Transmission and Reception Cycle Timing Symbol Description Minimum Typical REFCLK Frequency Frequency of Reference Clock - 50 - MHz REFCLK Duty Cycle Duty Cycle of Reference Clock 35 - 65 % T_ipsu_tx_rmii TXD[1:0]/TXEN Setup Time to REFCLK 4 - - ns T_iphd_tx_rmii TXD[1:0]/TXEN Hold Time from REFCLK 2 - - ns T_ophd_rx_rmii RXD[1:0]/CRS_DV/RXER Output Delay Time from REFCLK 6 - 12 ns 59 Maximum Unit Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet 6.8. RMII2 Transmission and Reception Cycle Timing Figure 13. RMII2 Transmission and Reception Cycle Timing Table 13. RMII2 Transmission and Reception Cycle Timing Symbol Description Minimum REFCLK Frequency Frequency of Reference Clock - 50 - MHz REFCLK Duty Cycle Duty Cycle of Reference Clock 35 - 65 % T_ipsu_tx_rmii TXD[1:0]/TXEN Setup Time to REFCLK 4 - - ns T_iphd_tx_rmii TXD[1:0]/TXEN Hold Time from REFCLK 2 - - ns T_ophd_rx_rmii RXD[1:0]/CRS_DV/RXER Output Delay Time from REFCLK 0 - 3 ns 60 Typical Maximum Unit Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet 6.9. 100Base-FX Characteristics 6.9.1. 100Base-FX Differential Transmitter Characteristics Table 14.100Base-FX Differential Transmitter Characteristics Symbol Parameter Min Typ Max Units Notes UI Unit Interval 7.9976 8 8.0024 ns 8ns ± 300ppm T_X1 Eye Mask - - 0.15 UI - T_X2 Eye Mask - - 0.4 UI - T_Y1 Eye Mask 250 - - mV - T_Y2 Eye Mask - - 600 mV - VTX-DIFFp-p Output Differential Voltage 500 700 1200 mV - TTX-EYE Minimum TX Eye Width 0.7 - - UI - TTX-JITTER Output Jitter - - 0.3 UI RTX Differential Resistance 80 100 120 ohm - CTX AC Coupling Capacitor 80 100 200 nF - LTX Transmit Length in PCB - - 10 Inch - Figure 14. 100Base-FX Differential Transmitter Eye Diagram 61 TTX-JITTER-MAX = 1 - TTX-EYE-MIN = 0.35UI Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet 6.9.2. 100Base-FX Differential Receiver Characteristics Table 15.100Base-FX Differential Transmitter Characteristics Symbol Parameter Min Typ Max Units Notes UI Unit Interval 7.9976 8 8.0024 ns 8ns ± 300ppm R_X1 Eye Mask - - 0.3 UI - R_Y1 Eye Mask 100 - - mV - R_Y2 Eye Mask - - 1000 mV - 200 - 2000 mV - VRX-DIFFp-p Input Differential Voltage TRX-EYE Minimum RX Eye Width 0.4 - - UI TRX-JITTER Input Jitter Tolerance - - 0.6 UI RRX Differential Resistance 80 100 120 ohm Figure 15.100Base-FX Differential Receiver Eye Diagram 62 TRX-JITTER-MAX = 1 - TRX-EYE-MIN = 0.6UI - Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet 7. Power Requirements 7.1. Absolute Maximum Ratings Table 16. Absolute Maximum Ratings Symbol Description Min Max Unit AVDD33 3.3 V power supply -0.3 3.70 V AVDDL 1.2 V power supply -0.2 1.50 V DVDDL 1.2 V power supply -0.2 1.50 V DVDDIO 3.3V 3.3V power supply -0.3 3.70 V DVDDIO 2.5V 2.5V power supply -0.3 2.8 V DVDDIO 1.8V 1.8V power supply -0.3 2.3 V DVDDIO 1.5V 1.5V power supply -0.3 1.7 V 7.2. Recommended Operating Condition Table 17. Recommended Operating Condition Description Pins Min Typ Max Unit AVDD33 2.97 3.30 3.63 V AVDDL 1.08 1.20* 1.32 V DVDDL 1.08 1.20* 1.32 V DVDDIO 3.3V 2.97 3.30 3.63 V DVDDIO 2.5V 2.25 2.50 2.75 V DVDDIO 1.8V 1.71 1.8 1.89 V DVDDIO 1.5V 1.43 1.5 1.57 V YT8522C Ambient Operation Temperature Ta 0 - 70 °C YT8522H Ambient Operation Temperature Ta -40 - 85 °C YT8522E Ambient Operation Temperature Ta -40 - 125 °C YT8522A Ambient Operation Temperature Ta -40 - 125 °C 135 °C Power Supply Maximum Junction Temperature Note:AVDDL/DVDDL is from internal LDO.Actual voltage is about 1.15V. 63 Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet 7.3. Power On Sequence Figure 16.Power On Sequence When using crystal, the clock generated internally.1.2V power from internal LDO, the sequence between clock and 3.3V, or 1.2V and 3.3V is determined by YT8522 inside and can be ignored. When using external clock CLK 25/50MHz or TXC, CLK 25/50MHz or TXC should be a stable clk after AVDDH/AVDDL reaches 3.3V/1.2V.For a reliable power on reset, suggest to keep asserting the reset low long enough (10ms) to ensure the clock is stable and clock-to-reset 10ms requirement is satisfied. 64 Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet 7.4. Power Consumption 7.4.1. MII mode Table 19.MII Mode Power Consumption Condition DVDDIO=3.3V(mA) AVDD33(mA) 3.3V total(mA) Power Consumption(mW) Reset 1.4 5.8 7.2 23.8 Power down 1.6 6.0 7.6 25.1 Sleep 1.9 6.6 8.5 28.1 Active 1.8 44.2 46.0 151.8 Traffic 100FX 7.0 47.7 54.7 180.5 10M 3.1 29.1 32.2 106.3 100M 4.6 56.7 61.3 202.3 10M 7.9 39.6 47.5 156.8 100M 10.8 57.1 67.9 224.1 Link Traffic 7.4.2. RMII mode Table 20.RMII Mode Power Consumption Condition DVDDIO=3.3V(mA) AVDD33(mA) 3.3V total(mA) Power Consumption(mW) Reset 1.4 5.8 7.2 23.8 Power down 0.9 6.1 7.0 23.1 Sleep 1.0 6.6 7.6 25.1 Active 3.1 46.9 50.0 165.0 Traffic 100FX 5.7 48.1 53.8 177.5 10M 3.8 31.4 35.2 116.2 100M 3.8 57.4 61.2 202.0 10M 5.2 40.5 45.7 150.8 100M 5.7 57.7 63.4 209.2 Link Traffic Note: The power consumption is measured under room temperature with typical process DUT.When dvddio=2.5/1.8/1.5V,power consumption is close to 3.3v. 7.5. Maximum Power Consumption Table 21.Maximum Power Consumption Condition Traffic 100M DVDDIO=3.3V(mA) AVDD33(mA) 3.3V total(mA) Power Consumption(mW) 15.0 65.0 80.0 264.0 Note: Test by FF corner IC in MII mode with DVDDIO= 3.3V at 125℃ ambient temperature. 65 Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet 8. Package information 8.1. RoHS-Compliant Packaging Motor-comm offers a RoHS package that is compliant with RoHS Table 22. RoHS-Compliant Packaging Part Number Status Package Op temp (℃) YT8522C Active QFN 32 5x5mm 0 to 70 YT8522H Active QFN 32 5x5mm -40 to 85 YT8522E Active QFN 32 5x5mm -40 to 125 YT8522A Active QFN 32 5x5mm -40 to 125 Note 8.2. Thermal resistance Symbol θJA Table 23. Thermal resistance Pa r a m e t e r C o n di t on Thermal resistance - junction to ambient θJA = (TJ - TA)/ P P = Total power dissipation Typ Units JEDEC 3 in. x 4.5 in. 4-layer PCB with no air flow TA=25°C 37.8 °C/W JEDEC 3 in. x 4.5 in. 4-layer PCB with no air flow TA=125°C 33.3 °C/W JEDEC with no air flow 35 °C/W JEDEC with no air flow 16.3 °C/W Thermal resistance - junction to case θJC θJC = (TJ - TC)/ Ptop Ptop = Power dissipation from the top of the package Thermal resistance - junction to board θJB θJB = (TJ - TB)/ Pbottom Pbottom = Power dissipation from the bottom of the package to the PCB surface. 66 Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet 9. Mechanical Information Figure 17. Mechanical Information 67 Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet 68 Motorcomm YT8522(C)/(H)/(E)/(A) Datasheet 10. Ordering Information Table 24. Ordering Information Part Number Grade YT8522C Consumer YT8522H Industrial YT8522E Extreme YT8522A Package QFN 32 5x5mm QFN 32 5x5mm QFN 32 5x5mm Automotive application QFN 32 AECQ-100 Grade 2 5x5mm Packaging Tape Reel 3000ea Tape Reel 3000ea Status Mass production Mass production Operation temp(℃) 0 to 70 ℃ -40 to 85 ℃ Tape Reel 3000ea Sampling -40 to 125 ℃ Tape Reel 3000ea Sampling -40 to 125 ℃ 69
YT8522H 价格&库存
很抱歉,暂时无法提供与“YT8522H”相匹配的价格&库存,您可以联系我们找货
YT8522H
  • 1+7.10500
  • 10+5.88000
  • 30+5.26260
  • 100+4.65500
库存:497
YT8522H
    • 1+7.83000
    • 10+6.48000
    • 30+5.79960
    • 100+5.13000
    • 500+4.24440
    • 1000+4.03920
    库存:5884
    YT8522H
    • 1+4.90600
    • 100+4.09200
    • 750+3.78400
    • 1500+3.60800
    • 3000+3.46500
    库存:848
