X1102WRS-2x08-N0V01
X1102WRS-2x08-N0V01
    XKB(中国星坤)
    SMD,P=1mm,卧贴
    线对线连接器 2x8P 间距:1mm 卧贴
X1102WRS-2x08-N0V01 数据手册
A XKB:1.00[0.039] Specifications: 规格: Voltage rating:50V AC/DC 额定电压:50V AC/DC Current rating:1A AC/DC 额定电流:1A AC/DC Withstanding voltage:500V AC/minute 耐受电压:500V AC/分钟 Temperature range:-25℃-+85℃ 温度范围:-25℃-+85℃ Insulation resistance:≥100MΩ 绝缘电阻:≥100MΩ Contact resistance:≤20mΩ 接触电阻:≤20mΩ After environmental testing:≤30mΩ 环境测试后:≤30兆欧 4.60[0.181] 0.10 6.60[0.260] B X1102 W R S-2xXX X-XXV01-XX ① ②③④ ⑤ ⑥ ⑦ ⑧ ⑨ 1.Series No. 2.Category:W-wafer 3.Welding Board Angle:R-Right Angle 90° 4.Welding Way:S-SMT 5.Row No-Pin No:2xXX-2x03P~2x25P 6.Plug the pin&special No 7.Material:46-PA46 94V-0 N0-PA66-94V-0 8.Planting Category:V01-All Gold Flash 9.Color:Blank-Black N-Natural color Dimensions(mm) 3.90[0.154] 2.00[0.079] 1.00 PITCH 2.50[0.098] A±0.05 7.60[0.299]±0.05 CKT 1 1.50[0.059] 1.25[0.049] Dimensions(mm) Poles C Poles A B 2x03 2.00 5.60 4.20 2x04 3.00 6.60 5.20 2x05 4.00 7.60 6.20 2x06 5.00 8.60 2x07 6.00 2x08 C A B C 2x12 11.00 14.60 13.20 2x13 12.00 15.60 14.20 2x14 13.00 16.60 15.20 7.20 2x15 14.00 17.60 16.20 9.60 8.20 2x16 15.00 18.60 17.20 7.00 10.60 9.20 2x17 16.00 19.60 18.20 2x09 8.00 11.60 10.20 2x18 17.00 20.60 19.20 2x10 9.00 12.60 11.20 2x20 19.00 22.60 21.20 2x11 10.00 13.60 12.20 2x25 24.00 27.60 26.20 1.50[0.059] 0.60[0.024]±0.05 Recommended PCB Layout General Tolerance±0.05 X1102WRS-2xXX-46V01 Nylon 46 UL 94V-0 Tin-Plated Brass X X X MARK DATE DESCRIPTION REVISIONS www.xk-dg.cn www.helloxkb.com REVISED APPROVED units: tolerance: X.X X.XX X.XXX Nylon 66 UL 94V-0 PART NO Material X1102H Gold Flash Material(Pin) Finish(Pin) Suitable XKB Terminal DSND DATE mm DWN DATE SCALE: N/A MODEL TYPE: Wire to board connector VIEW: PART NO.: ±0.2mm ±0.1mm ±0.05mm CHKD DATE UNIT: mm/in APPD DATE UNSPECIFIED TOLERANCES www.helloxkb.cn X1102WRS-2xXX-N0V01 1.00mm Crimp Style Connectors DWG NO.: SIZE: A4 XKB INDUSTRIAL PRECISION CO.,LIMITED WEIGHT 1.0g X1102WRS-2xXX-N0V01 SHEET 1/1 REVISION A0
X1102WRS-2x08-N0V01 价格&库存
很抱歉,暂时无法提供与“X1102WRS-2x08-N0V01”相匹配的价格&库存,您可以联系我们找货
